james andraza
newbie
Reged: 05/24/09
Ioptron ZEQ25 mount new
      #6150596 - 10/21/13 09:04 PM
To anyone using the new Ioptron ZEQ25 mount. Do you find that the polar scope led units burn out prematurely? I had two burn out.
ramasule
Reged: 04/12/12
Re: Ioptron ZEQ25 mount new [Re: james andraza]
      #6150754 - 10/21/13 10:30 PM
Mines still fine, make sure your not overvolting the mount as I suspect the led is not fed from conditioned power, as in connected straight from the switch.
Seanem44
Reged: 09/22/11
Loc: Woodbridge, VA
Re: Ioptron ZEQ25 mount new [Re: ramasule]
      #6151174 - 10/22/13 07:28 AM
I never had an issue. Though I will say the connection to the scope is a little loose.
I will add that it is the best polar scope I have ever used.
rkayakr
Reged: 10/27/10
Loc: Northeast Ohio
Re: Ioptron ZEQ25 mount [Re: Seanem44]
      #6151307 - 10/22/13 09:37 AM
No LED problems here.
I have seen even a slightly higher voltage that is still well within spec cause drive error reports.
19 registered and 41 anonymous users are browsing this forum.
