oldjet
Reged: 01/29/11
How do I mount Takahashi Clamshell on Vixen GPDX? new
      #6149081 - 10/20/13 09:00 PM
Hi Friends,
I have a Takahashi TSA102 that came with a clamshell tube holder.
Would you please advise how do I mount it to a Vixen-style saddle (my mount is GPDX).
I believe I'll need a matching dovetail plate, but I need advise regarding:
- The right plate length for that scope.
- Where to get the properly sized screws to fit into the Tak clamshell holes.
- Well.. the actual part number would be very nice
Thanks in advance for sharing your experience..
-oldjet
Mr Greybush
Reged: 05/16/13
Loc: Virginia
Re: How do I mount Takahashi Clamshell on Vixen GPDX? new [Re: oldjet]
      #6149086 - 10/20/13 09:03 PM
Read this it should help http://www.cloudynights.com/item.php?item_id=845
GolfSierra
Reged: 12/27/08
Loc: Michigan
Re: How do I mount Takahashi Clamshell on Vixen GPDX? new [Re: Mr Greybush]
      #6151290 - 10/22/13 09:25 AM Attachment (3 downloads)
I used an ADM VDUP7 Vixen plate bolted directly to the clamshell. Balance the OTA fore and aft in the clamshell, a 6MM or 1/4x 20 bolt will work with a locknut.
http://www.admaccessories.com/V_Series_Universal.htm?
oldjet
Reged: 01/29/11
Re: How do I mount Takahashi Clamshell on Vixen GPDX? new [Re: GolfSierra]
      #6152341 - 10/22/13 07:45 PM
THANK YOU for that!
Kunama
Reged: 10/22/12
Re: How do I mount Takahashi Clamshell on Vixen GPDX? [Re: oldjet]
      #6152738 - 10/22/13 11:49 PM Attachment (5 downloads)
I would recommend that you don't rely on just one 1/4" bolt to hold such a beautiful bit of kit.
The clamshell has 8.5mm holes drilled 35mm apart in line with the 1/4" hole,
I recommend you drill the dovetail plate and tap some M8 threads into these holes to secure the OTA to the dove plate. Then use 2 stainless steel M8 cap screws for a nice secure fit.
Just my 2 cents but I would hate to see a Tak Teaser hit the floor.
I actually changed to a Robin Casady saddle and dovetail which are designed just for this situation:
8 registered and 34 anonymous users are browsing this forum.
