anat
Reged: 06/03/04
Re: AstroTortilla vs UniMap for plate solving new [Re: orlyandico]
      #6149243 - 10/21/13 02:25 AM
I use the Astrometry.net engine in Linux for solving images with plate sizes of about 1 deg or slightly less. It takes less than 5 sec on PC. And it takes about 15 sec or less on Arm Linux devices.
I always use downsample = 2 or 3. And I put the minimal number of index files having the largest sky diameter down to the sky diameter of about a half of the camera coverage (30 arcsec). If you put all index files in the index folder, the computation will be slow even though scale-low is specified. The engine still tries to use some of index files with small sky diameters.
Edited by anat (10/21/13 02:28 AM)
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AstroTortilla vs UniMap for plate solving new [Re: anat]
      #6149263 - 10/21/13 04:11 AM
hi Anat,
yup i have also pruned my indexes. What i noticed was even with downsampling the solve time was still high. i think downsampling itself consumes CPU so it would be better to bin.
anat
Reged: 06/03/04
      #6149275 - 10/21/13 04:29 AM
If you convert your original image file to a compressed format (JPG) first, it may help. Plate-solving doesn't need a big raw file
Edited by anat (10/21/13 04:41 AM)
Phillip Easton
Reged: 12/24/10
Loc: DFW
      #6149423 - 10/21/13 08:42 AM
hi Anat,
Have you tried adjusting sigma? I set mine to around 7 and get around 20-40 stars to search. Much quicker than if you are searching on several hundred.
Cheers!
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AstroTortilla vs UniMap for plate solving new [Re: Phillip Easton]
      #6149509 - 10/21/13 09:38 AM
i just checked and i was at sigma 30!
scale minimum 0, maximum 200 (arc-minutes). well i'll try again with tighter limits.
Phillip Easton
Reged: 12/24/10
Loc: DFW
      #6149579 - 10/21/13 10:22 AM
That should help. Just a FYI I am imaging at 0.887 arcsec-pix. I set my limits too 0.75 - 1.0 arcsecperpix. Field is set to 45 and sigma 6 or 7. My exposure is 10sec. It solves in about 10 sec.
Cheers!
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6149630 - 10/21/13 10:52 AM
i've been using arcminwidth - but you can also use arcsecperpix?
Coastal
Reged: 04/23/09
Loc: Vancouver island, Canada
      #6149655 - 10/21/13 11:05 AM
If I understand correctly, you're using arcminwidth with a range of 0-200. Certainly doesn't sound ideal. Use Pinpoint to calculate your actual image scale and try 0.1 lower and 0.1 higher (ie I use 1.6 and 1.8 for my 1.8"/px scale) using arcsecperpix.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AstroTortilla vs UniMap for plate solving new [Re: Coastal]
      #6149665 - 10/21/13 11:17 AM
Well Astrometry itself tells me my correct pixel scale. which (was) 2.68"/pixel as opposed to... 2.68"/pixel according to the Starizona calculator (http://starizona.com/acb/ccd/calc_pixel.aspx)
I don't have PinPoint, and I have no interest in Elbrus (you need to set the camera angle correctly every time?!?!?!?!?!) but I will try being very exact.
BTW nice idea with the USB power box.. I went with a similar method (R78B05 DC-DC converter to provide 5V for my USB hub form a battery). Thankfully I don't need 7.5V, but the camera cooler sucks power like there's no tomorrow...
Moromete
Reged: 02/15/12
Loc: Romania
      #6149677 - 10/21/13 11:26 AM
Why don't you try Unimap if you are using hints already?
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AstroTortilla vs UniMap for plate solving new [Re: Moromete]
      #6149745 - 10/21/13 12:03 PM
astrometry works for me (if a bit slow), I like their development model (and the fact there's a lot of published research that uses their engine), etc. etc.
the reality is I only do 1-2 slews per session, so that's 1-2 solves per session. 20-second solves barely annoy me. I would like things to go faster, but the current scheme isn't killing me.
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
      #6159901 - 10/26/13 10:19 PM
I have an MI250 controlled by SiTech. Since it's an ASCOM driven program, I'll assume that it'll work with this setup. Is there anything that in the SiTech system that may cause a problem with the mount interfacing with AT?
David
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: AstroTortilla vs UniMap for plate solving new [Re: David Pavlich]
      #6160064 - 10/27/13 12:54 AM
Dave, not that I know of. AT only knows how to talk to ASCOM (and nothing else) on the mount side, so anything with a working ASCOM driver that supports resyncs will work.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #6160340 - 10/27/13 08:43 AM
Dave, it works good
Transmographied
Reged: 05/18/05
Re: AstroTortilla vs UniMap for plate solving new [Re: Raginar]
      #6160524 - 10/27/13 11:00 AM
Dave, it works good
That's all I needed to read! Thanks, Chris.
David
Transmographied
Reged: 05/18/05
      #6160528 - 10/27/13 11:01 AM
Well, I'll have to download it and give it a try. Thanks for the quick reply!
David
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: AstroTortilla vs UniMap for plate solving [Re: David Pavlich]
      #6162164 - 10/28/13 10:12 AM
One thing to consider, what are you imaging with? You might try out Sequence Generator Pro. It can use the localized astrometry.net server you install with AT. Free plate solving included with acquisition automation kis really me. And, they're adding dome/roof support this version.
Gvs
Reged: 05/19/11
Loc: Texas
      #6176843 - 11/05/13 06:43 AM
It is possible to refactor Astrotortilla to point to http://nova.astrometry.net/ which is up an running.
live dot astronomy dot net has issues.
12 registered and 24 anonymous users are browsing this forum.
