astro4565
Reged: 11/27/10
Loc: UT
Omicron Persei
      #6172277 - 11/02/13 04:58 PM
Anybody split this double star with a 120mm refractor? My NGC-Max guide says this star is 1.0" arc-seconds. I guess seeing would have to be excellent to split this double. Any reports on Omicron Persei would be appreciated. May have to try this one on a clear cold night.
azure1961p
Reged: 01/17/09
Loc: USA
Re: Omicron Persei new [Re: astro4565]
      #6172384 - 11/02/13 06:26 PM
I'd personally not even mother. That great s difference in magnitude at that distance is too staggering for me to consider with my 8". Maybe a bigger scope can pull it off but it'd not be easy,
Pete
fred1871
Reged: 03/22/09
Loc: Australia
Re: Omicron Persei new [Re: azure1961p]
      #6172583 - 11/02/13 08:45 PM
Omicron Persei will be a tough one - 2.8 mags brightness difference (current WDS numbers, probably from Tycho) and only 1.0" separation. If the stars were equal, 120mm could show a Dawes Limit touching discs view; but with the big brightness difference, it becomes very much harder, and is likely to be marginal with 140-150mm scopes, though the secondary will sit in the first dark interspace of the diffraction image at that aperture.
It could be possible with a good 8-inch (200mm) - the secondary star on the outside edge of the first diffraction ring. For a 7-inch the secondary will sit on the diffraction ring, making it hard to see. Hmmm. Think I'll try it with my C9.25 when it gets into my midnight sky, a month from now. With that aperture the secondary should be nicely outside the first diffraction ring, with Rayleigh being ~0.6" for that aperture.
Doubles like this one need both sufficient aperture, and preferably an aperture that avoids putting the secondary star on the first diffraction ring.
An historical note - SW Burnham discovered Omicron Per (BU 535) as a double in 1878 with the 18.5-inch refractor in Chicago (though it had been measured by another observer the previous year). The separation has been pretty constant since then, but the angle has gradually changed.
azure1961p
Reged: 01/17/09
Loc: USA
Re: Omicron Persei new [Re: fred1871]
      #6172600 - 11/02/13 08:57 PM
I need to cross reference SS more. They have an almost 5 Delta-M!!!!!!
Well your finds top the scale the other way then.
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #6172695 - 11/02/13 10:08 PM
I could not do it at 150mm aperture obstructed, "I also did not resolve Atik (P.A. 23 SEP 1 MAG 3.91-6.7) but it does seem doable."
I agree with Fred, and Pete, at ~ 3 mag difference inside the first ring things get interesting. It might be doable, though difficult.
Edited by Asbytec (11/02/13 10:11 PM)
astro4565
Reged: 11/27/10
Loc: UT
Re: Omicron Persei new [Re: Asbytec]
      #6173504 - 11/03/13 11:03 AM
I guess Omicron Persei is in the same catagory as Zeta Herculis. You need at least an 8 inch scope with superb seeing. I may have better luck with Eta Geminorum.
0 registered and 5 anonymous users are browsing this forum.
Moderator:  PJ Anway, Rich (RLTYS), rflinn68
