Chuck Hards
Reged: 05/03/10
Loc: The Great Basin
M75C Elbow Telescope
      #6173710 - 11/03/13 01:02 PM
I accquired this on Friday. In perfect working order, the filter wheel works, optics are clear and sharp. The prior owner built a power supply/dimming circuit for the illuminated reticle using 4 C cells. He had used it as a finder on a large classic Dob. It was mounted on an aluminum plate that allowed pivot & tilt movement for alignment with the main OTA.
I remember Jaegers selling these for years and years.
Really too heavy for most scopes these days, but I may find a use for it. Just fun to see one again after several decades.
Anybody else ever use one of these as a finder, back in the old days?
richard7Moderator
Not Quite
Reged: 11/02/07
Loc: Sacramento
Re: M75C Elbow Telescope new [Re: Chuck Hards]
      #6173860 - 11/03/13 02:30 PM
Oh Wow. I can't quite read what the plate says but it looks very promising.
I wonder if he ever took it apart and cleaned it?
Chuck Hards
Reged: 05/03/10
Re: M75C Elbow Telescope new [Re: richard7]
      #6173882 - 11/03/13 02:48 PM
The top plate is the filter selector switch. CLEAR, NEUTRAL, AMBER, RED. None of the filters are useful for astronomy, IMO, even the neutral filter is way too dark for even the moon.
It looks amazingly clean on the interior, despite the worn external appearance. A few dust flecks on the reticle.
The focusing action is smooth.
StarStuff1
Reged: 04/01/07
      #6174055 - 11/03/13 04:29 PM Attachment (15 downloads)
About 25 years ago I had one of these. Decent optically but as you say, pretty darn heavy. And bulky. Originally I was going to remove the optics and re-mount in a PVC tube but I wound up selling/trading it at a swap shop. I really hate to destroy original military gear to make it into an astro toy. Altho this WWII surveyor's tripod did clean up pretty well to make a sturdy tripod for a small refractor.
BillB9430
Reged: 12/02/06
Loc: Illinois
      #6174161 - 11/03/13 05:46 PM
Chuck - The M75C is an interesting scope for sure. A M75C I have needed to be disassembled for cleaning - so I had a chance to examine the eyepiece lenses. The M75C ocular is a two achromat arrangement that would likely be called a Plossl today. While the lenses were out, I compared them to an old 28 mm "Kellner" purchased from Edmund 40 years ago. The lenses seemed identical and would even exchange in the barrels. Quoting from page 129 of Edmund Catalog 651 about their 28 mm "Kellner": " . . . Has the same set of lenses used in quality military telescopes. We put them into a new metal cell and extension for 1 1/4" holders . . . ". This Edmund "Kellner" was very popular and showed the "floating image" effect like the RKE 28 mm does now. I recall using one for my first look at Jupiter's bands through a 6" f/8 Newtonian in 1960 - I was hooked! In the original M75C ocular mounting there is a wide metal rim around the eye lens (check your scope), so no "floating" effect is seen when viewing with the elbow scope. - Bill
Chuck Hards
Reged: 05/03/10
Re: M75C Elbow Telescope new [Re: StarStuff1]
      #6174165 - 11/03/13 05:49 PM
Yeah, you could make a much lighter finder, with better coatings, from modern surplus optics. Although the eyepiece has possibilities, I agree with you. It's better kept intact as a military collectible. If it doesn't end up on a permanently mounted observatory scope, it will go on display indoors.
Chuck Hards
Reged: 05/03/10
Re: M75C Elbow Telescope new [Re: BillB9430]
      #6174170 - 11/03/13 05:51 PM
Thanks for the background info, Bill. I'll check it out next time I'm down in the shop and look for the eye lens rim.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
      #6174329 - 11/03/13 07:25 PM
I wonder if this scope uses the same Amici prism I use in my home-made right angle bino? Mine have a clear aperture of 33mm, and are made to very high precision. The way the substrate is shaped for mounting, and the mount itself, are marvels. This pair of prisms is highly prized by me, and will have to be pried from my cold, dead hands.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: M75C Elbow Telescope new [Re: GlennLeDrew]
      #6174891 - 11/04/13 05:35 AM
man I had one of these when I was eight years old... probably an original from World War II left behind by you Americans in my home country.
my dad bought it for me for the equivalent of $6 in the early 1980s.
i was amazed at how clear the stars were through it, compared to naked-eye. this was before i discovered that i needed specs...
mine was still at home, but had completely corroded and froze up. my mom donated it to the local museum.
Chuck Hards
Reged: 05/03/10
Re: M75C Elbow Telescope new [Re: orlyandico]
      #6175024 - 11/04/13 08:59 AM
A very limited web search this morning only got two real hits with pics, one on the M75C and one on it's brother, the M17.
Looks like in both cases, they were originally used on anti-aircraft guns.
http://www.usmilitariaforum.com/forums/index.php?/topic/12950-telescope-elbow...
http://www.usmilitariaforum.com/forums/index.php?/topic/147193-m17-telescope/
8 registered and 15 anonymous users are browsing this forum.
