General Astronomy >> General Observing and Astronomy
T1R2
Reged: 06/11/13
Loc: NeverWhere
ALERT! bright object moving
      #6181845 - 11/07/13 09:13 PM
I'm observing a bright object moving east to west slowly across the sky, I'm at 35* lat., could it be the ESA's sat.?
Its 8:12 cst.
obin robinson
Reged: 10/25/12
Loc: League City, TX
Re: ALERT! bright object moving new [Re: T1R2]
      #6181862 - 11/07/13 09:22 PM
It's not GOCE. As of 8:22PM EST time it hasn't flown over North America. What is your longitude?
obin
brentwood
Reged: 11/04/05
Loc: BC Canada
Re: ALERT! bright object moving new [Re: obin robinson]
      #6181875 - 11/07/13 09:33 PM
Another example of why we should all have our approximate location showing in our profile.
kfiscus
Reged: 07/09/12
Loc: Albert Lea, MN, USA
Re: ALERT! bright object moving new [Re: brentwood]
      #6181917 - 11/07/13 10:01 PM
+1!
mich_al
Reged: 05/10/09
      #6181958 - 11/07/13 10:30 PM
Yep!
T1R2
Reged: 06/11/13
Loc: NeverWhere
Re: ALERT! bright object moving new [Re: mich_al]
      #6182075 - 11/08/13 12:03 AM
well hit me with a brick why don't cha,..lol, I was trying to leave to the supermarket and was in a hurry, truthfully I have not known my long. since I have GPS, and I don't have a map, I guess I should memorize it for future reference, ..Little Rock, AR 92*
T1R2
Reged: 06/11/13
Loc: NeverWhere
      #6182088 - 11/08/13 12:13 AM
so any ideas? I have not seen anything like that, not even the space station was as bright as this, I tried to estimate it at mag -2.5 or as bright or brighter than Jupiter, and yellow in color, and looked to be dimming and brightening irregularly like it was tumbling.
Retsub
Reged: 12/08/06
Loc: Houston,Tx.
      #6182114 - 11/08/13 12:40 AM
Are you sure it was E to West ? Hmmm. A Cosmos or Tiangong would have been about that time but not very high. Slow ? About how many degrees in how many seconds ? Skies not very clear can make airplanes look like that. Best I can do for now. Thanks. *BW*
T1R2
Reged: 06/11/13
Loc: NeverWhere
Re: ALERT! bright object moving new [Re: Retsub]
      #6182172 - 11/08/13 01:42 AM
yes it was e to w, slightly south of the celestial eq, moving 1* dps, I watched it for about 4-5min., then came in, it wasn't a plane, I've seen plenty of them and it had no flashers which would have given it away, no sound, only very high thin clouds but they were fairly broken and I had a good view of some clusters I was lookin at, it didn't look very high at all, it could of even been a giant space rock, its irregular reflective qualities indicates to me that it was tumbling., I don't think sats. tumble unless their getting ready to fall, and the only one I know of getting ready to fall is the GOCE, and if wasn't the GOCE then.......?
BrooksObs
Reged: 12/08/12
      #6182453 - 11/08/13 08:39 AM
"...it didn't look very high at all, it could of even been a giant space rock, its irregular reflective qualities indicates to me that it was tumbling., I don't think sats. tumble unless their getting ready to fall, and the only one I know of getting ready to fall is the GOCE, and if wasn't the GOCE then.......?" - T1R2
Point number 1: It is utterly impossible to directly estimate the distance of an object at night without a known scale or frame of reference.
Point number 2: Space rocks (asteroids) are not seen passing across the sky as brilliant naked eye objects. The once in a million(s) years exception will have the end result of wiping out a goodly portion of civilization...so you'd know by now if that had happened!
Point number 3: Most satellites tumble when in orbit.
Point number 4: ALL very slow moving brilliant objects seen traversing the night sky which cannot be simply identified as aircraft of some sort are attributable to Earth-orbiting satellites. Their specific identification is best left to the viewer to determine. Without the observer's known location it is not very likely a firm ID can be made as there will be dozens, if not hundreds, of potential choices.
BrooksObs
Edited by BrooksObs (11/08/13 08:42 AM)
T1R2
Reged: 06/11/13
Loc: NeverWhere
Re: ALERT! bright object moving new [Re: BrooksObs]
      #6183432 - 11/08/13 06:25 PM
point 3, I don't think that's correct, spin maybe, but not tumble end over end. thanks for your input, if you care to explain please feel free, as far as "it didn't look very high" let me explain, all sats I've seen through my scope look like little dim stars moving at a pretty good rate of speed, and since brightness is relative to size and distance(at least in our neck of the woods)it was not as far up as other sats, but its speed was slow almost like an airplane at 30-40K in alt no plane has lights that equal a -2.5 or greater mag. planet at that alt. and since it was at 8:22pm at night, the sun was well down, and it wouldn't have illuminated anything that was inside or atmosphere, only an space bound object.
Point 2, please explain
Point 4, I'm well aware of that, just having a little fun, I was going on the assumption that all sats were accounted for, what else is out there, besides rocks and junk?
Edit: could they have been moving HST?
Edited by T1R2 (11/08/13 06:26 PM)
Thomas Karpf
Reged: 02/09/09
Loc: Newington, CT
      #6183614 - 11/08/13 08:33 PM
At that speed it would have had to have been HUGE. Unlikely in the extreme that it was a very close near miss or there would have been huge numbers of reports.
T1R2
Reged: 06/11/13
Loc: NeverWhere
Re: ALERT! bright object moving new [Re: Thomas Karpf]
      #6183679 - 11/08/13 09:11 PM
it was big, just cause no one reported it doesn't mean it was not seen by others, some without an astronomy background could of easily not though anything of it. I'm aware that there are things flying out there that remain undetected, lots of people don't know who to report it to nor would even bother with it
as for me I'm fine with the satellite theory, but I also know that there large NEO's orbiting our earth/moon system with orbits as far out or as close as 500K miles to 1 million out, not saying this was one of those, but its always possible one got away.
every time I'm out observing I witness multiple objects that are close, some far away, either sats, astroids, space junk, sometimes even in the same FOV only min. apart going in different directions, I've even seen meteor's streak by in the ep, moved the scope to a different part of the sky, only to have it happen again, that's a 1/1000000 chance, I'm sure others have witnessed similar things.
but since no one wants to play, I guess I'm done.
no need to worry about large rocks in space that may have came near our planet, or sats falling out of the sky, lord knows that could never happen, specially twice in a day.
Retsub
Reged: 12/08/06
Loc: Houston,Tx.
      #6183688 - 11/08/13 09:17 PM
Sorry but I can't find anything that was near you, especially that late. Nothing earlier or later than the time you wrote. Didn't find anything on your local news either. Not much else I can say about it. From 29-95 thanks. *BW*
T1R2
Reged: 06/11/13
Loc: NeverWhere
      #6183708 - 11/08/13 09:38 PM
Thanks, earlier I got to look at the GOCE orbit and it was not that, I was satisfied with the sat theory, but now I've changed my mind to a large asteroid flyby seeing as to no sats were in the area, it was not a plane and it was large, bright and slow and its irregular brightening and dimming suggests tumbling, and since nothing else has a deteriorating orbit that's supposed to be coming down, I don't see how it could be anything else.
BrooksObs
Reged: 12/08/12
      #6184232 - 11/09/13 08:58 AM
1. Today, with the sky being intensely monitored 24-7 by both dozens and dozens of advanced amateurs with sophisticated instrumentation, as well as by some professional installations, be assured that the average hobbyist frequenting these forums has absolutely a zero chance of spotting something very bright anywhere in the sky that is as yet undiscovered.
2. There are absolutely no "large NEO's orbiting our Earth/moon system". Seaches for same, those employing deep imaging for decades, have demonstated that no significant-sized such bodies currently exist that can very closely approach Earth. Those few objects in "locked" revolution with Earth are all tiny and require huge instruments just to be detected.
3. Any asteroidal body appearing as bright as implied in the initial post(s) would have had to be physically enormous and have been discovered and under observation for weeks (if not years!), not spotted last night simply by chance.
BrooksObs
Edited by BrooksObs (11/09/13 10:23 AM)
T1R2
Reged: 06/11/13
Loc: NeverWhere
      #6184971 - 11/09/13 04:05 PM
Well I see your pretty good at telling people what it "IS NOT", just like on another thread! how about being useful and help narrow down what it was, seeing that was intent of the post, What about the Russian meteor! didn't that just come outa nowhere! even with all these detection systems and solar AP'ers out there! I'll never be gullible enough to believe that we know everything that's out there on any givin sunday!
maugi88
Reged: 08/25/13
Loc: SE MN
      #6185107 - 11/09/13 05:17 PM
BrooksObs
I will never understand how anyone could tell anyone else what they saw or didn't see. If someone is giving the best description they possibly can and it doesn't mesh with what you know, that is no reason to call someone a liar.
Just my opinion.
Qwickdraw
Reged: 03/03/12
Loc: Ann Arbor, MI
      #6186083 - 11/10/13 08:29 AM
This is because there is not already enough personal info about me on the internet?
Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
Re: ALERT! bright object moving new [Re: Qwickdraw]
      #6186206 - 11/10/13 10:04 AM
You said,
"...every time I'm out observing I witness multiple objects that are close, some far away...."
Unfortunately, one cannot tell how far away a point of light is as it travels across the sky. There is no frame of reference. Is it a small object close by or a bright object further away? You have no way of knowing this. Your space rock theory suffers from this problem as we don't know whether it might have been a large object far away or a small object nearby, relatively.
Based upon the brightness you report, the E-W path, the speed (1 deg/sec) and the brightness variations (but no blinking lights) the most likely scenario is a man-made orbiting satellite.
The asteroid/space rock theory is much less likely. As pointed out before there are no asteroids orbiting the Earth-Moon system that are large enough to be seen naked eye. Earth does have some Trojan companions but, again, they are very far away (much further than the moon) and very tiny. Objects like these have magnitudes down in the 15th -20th magnitude range....
As for a Chelyabinsk-sized object, your reported speed of 1 deg/sec is far too slow if it were near enough to be seen that brightly - the Chelyabinsk rock crossed about 150 degrees of sky in about 5 seconds! If a Chelyabinsk-sized object were far enough away to be moving at only a degree a second it couldn't be as bright as you say.
Consider a school bus sized space rock passing us at a distance of about 35000 miles, the same distance as the geosynchronous satellites which is a reasonable distance for an asteroid moving at about 1 deg / sec in the sky. The geo-synch satellites, made of very shiny, reflective metal are all no brighter than magnitude 5 and most are mag 8 or fainter. A space rock is unlikely to have an albedo anywhere nearly as 'shiny' and will, therefore, have no chance of being any brighter than the brightest geo-synch satellite even if it is quite a bit larger. If the school bus space rock were, in fact, as bright as you say it would be huge - kilometres in size and be a well known near-Earth asteroid.
T1, it is difficult to narrow down what an object might be without ruling out certain things. Things that are highly unlikely need to be pointed out. Folks here are trying to help you, based upon their knowledge and experience. Unfortunately, pointing out unlikely scenarios comes across as excess negativity. An unintended consequence.
All of us would love to see something unique and fantastic in the sky - a nova, a previously unknown object etc. I certainly would! In this hobby we are out a lot, looking up, and we frequently see stuff that, at first blush, has a chance to be something special. Unfortunately mundane explanations win out virtually 100% of the time.
Dave
4 registered and 8 anonymous users are browsing this forum.
Moderator:  cildarith, panhard, tecmage
