General Astronomy >> General Observing and Astronomy
timtrice
Reged: 08/01/13
Loc: Katy, TX
Flaring Object in Puppis
      #6182351 - 11/08/13 07:02 AM
About 20 minutes ago I was on my back porch smoking, enjoying the morning sky. I noticed a very bright star just above one of the rooflines of a two-story home down the road so no more than 10 degrees above the horizon. The object gradually (over dozens of seconds) faded and I thought nothing of it; an airplane.
However the object quickly began to reappear again and became quite bright between 0 and -2 (I'm horrible at these estimations but as Sirius was in the vicinity the object did rival). The object maintained brightness for a few dozen seconds before gradually fading again. It actually pulsated during this time dropping to maybe mag 1 or 2 before brightening slightly and then fading a bit. It became very faint shortly after but then made one more brightening run to around mag 2 before fading again.
I didn't want to go get my camera as I don't have a tripod; my scope mount was in garage so I knew I'd have to pull that out, set it up blah blah blah. But when the object faded the second time I decided to at least try. Of course, when I made it back to the porch, the object was gone and I never saw it return.
So at the risk of "UFO" talk, I'm hoping perhaps someone is aware of a new variable in or at least near the southern edge of Puppis or something? I do plan on being better prepared tomorrow morning just in case but I have no realistic expectations.
A search of bright variables in Puppis returned nothing so far.
BrooksObs
Reged: 12/08/12
Re: Flaring Object in Puppis new [Re: timtrice]
      #6182410 - 11/08/13 08:20 AM
There are absolutely no such things as variable stars, or really any other trans-Earth objects, that can generate brilliant but very short durations flares. In every instance such reports of objects seen simply refer to nothing more than a man-made satellite exhibiting glints off some reflective surface. Consulting one or another of the on-line satellite passage tables for a particular geographic location will usually quickly indicate just which one is involved.
BrooksObs
Edited by tecmage (11/11/13 08:50 PM)
timtrice
Reged: 08/01/13
Loc: Katy, TX
Re: Flaring Object in Puppis new [Re: BrooksObs]
      #6182456 - 11/08/13 08:40 AM
I'm well aware of tumbling satellites and if the object was moving I would've credited nothing more than just that. But it wasn't, it was stationary. Thus my original question of perhaps being some type of variable or other event that I wasn't aware of.
Heavens-above was the site used to see if there were any known objects in the area; nothing. Certainly not stationary and of that brightness.
So if anyone wants to have a reasonable discussion of ideas without griping how many times you've had to clarify something, please go right ahead. Otherwise, I'll just let my imagination go wild with the possibilities.
Edited by tecmage (11/11/13 10:13 PM)
BrooksObs
Reged: 12/08/12
      #6182482 - 11/08/13 08:58 AM
Tim, I'm not being hostile but this same sort of question is asked here on a weekly, if not almost daily basis. Right now just two or three posted questions below yours in this section of Cloudy Nights is another such posting concerning the same sort of sighting. How did you miss it? The fact is that the nature of the sighting alone, if not an aircraft, dictates it had to be a satellite, as there is no other possible source. After half a century of the space program, such sightings are common knowledge among just about all amateur astronomers except perhaps the very newest. So, don't take offense if you just happen to be one of those, but just look around this site for similar occurences before any rush to post.
BrooksObs
Steve OK
Reged: 09/22/07
Loc: OKC, OK
      #6182496 - 11/08/13 09:08 AM
Hey, Tim. One of the details in the good report of your observation makes me think it was a satellite you saw; it appeared about 10° above the horizon. When a satellite is overhead, its motion is very apparent. By the time it is that close to the horizon, it is moving almost directly away from you, and its motion would be hard to detect. If you had had time to get a scope on it, you would likely have seen it moving, though slowly (apparently). Satellite flares can be surprisingly bright. I saw a -8 mag Iridium flare last Friday. Keep looking up!
Steve
steveward53
Reged: 05/14/12
Loc: Newmarket,UK
Re: Flaring Object in Puppis new [Re: Steve OK]
      #6182520 - 11/08/13 09:25 AM Attachment (13 downloads)
Could well have been the HST , being so low down it could be greatly affected by the atmosphere which would make it appear variable (seen this with the ISS at low elevations) and it's very bright when it catches the Sun.
Stellarium screen shot from your approx location this morning.
Steve OK
Reged: 09/22/07
Loc: OKC, OK
Re: Flaring Object in Puppis new [Re: steveward53]
      #6182562 - 11/08/13 09:45 AM
Well, that throws a kink into my explanation! I assumed a N-S polar orbit for my "moving directly away" scenario.
*skyguy*
Reged: 12/31/08
Loc: Western New York
      #6182568 - 11/08/13 09:50 AM
Sorry, I don't agree at all with this advice. I happen to enjoy the posts from members who see something strange in the sky. Yes, it's most likely going to be a satellite ... however, I also very much enjoy doing some sleuthing work to try and identify which satellite it might be!
So ... in the future ... if you you find some post offensive because of its repetitive nature ... the solution is not to reply to the post. Let some other member ... who enjoys the discussion of strange sky sightings ... respond to the OP.
timtrice
Reged: 08/01/13
Loc: Katy, TX
      #6182581 - 11/08/13 09:55 AM
I've seen plenty of tumblers though never of this variation. It was my initial thought but as it sat right above the roofline, I drew an imaginary line up from the corner of the house and though this object was close to that line it never crossed or strayed. I suppose it's possible under a fantastic setup; it just seemed very odd. And again, this was nearly five minutes (long enough for a cigarette). As it wasn't moving I just thought it was a very bright star that I was not aware of and perhaps high clouds far away were causing the fading. But there are no stars of that brightness in Puppis. I even though it may have been Canopus but no way I would've been able to see it over that house.
I have seen commercial jetliners give a similar appearance and that was another thought. But I have never seen them coming in from that direction. However, that's honestly my best guess.
Steve, thanks for posting that pic but it wasn't HST. This happened around 5:30CDT. HST was gone by then. No other known satellites around that time period (5:40CDT) reached that brightness that I'm aware of.
PeterR280
Reged: 05/27/13
Re: Flaring Object in Puppis new [Re: *skyguy*]
      #6182587 - 11/08/13 09:57 AM
What if it was a supernova and people were shy about reporting it?
StarStuff1
Reged: 04/01/07
Re: Flaring Object in Puppis new [Re: PeterR280]
      #6182619 - 11/08/13 10:11 AM
Weather balloon?
This type of naked eye observation is another reason to get a grab 'n' go scope such as a 70 or 80mm refractor on a lightweight mount. Or at least some binoculars in the 8-10X range.
kt4hx
Reged: 01/21/09
Loc: Fredericksburg, Va
      #6182775 - 11/08/13 11:37 AM
Very well put skyguy. No reason to get persnickety just because someone asks a question that has been asked before. If you don't like the show, change the channel. If you don't like the question, don't respond.
Usquebae
Reged: 06/11/13
Loc: 43 N, 73 W
      #6182809 - 11/08/13 11:53 AM
It was probably a TARDIS.
esd726
Reged: 09/30/04
Loc: Rochester, IN
      #6182821 - 11/08/13 11:59 AM
BrooksObs
timtrice
Reged: 08/01/13
Loc: Katy, TX
Re: Flaring Object in Puppis new [Re: esd726]
      #6182834 - 11/08/13 12:04 PM
For whatever reason the TARDIS reply made me remember something years ago. In early 2003, I woke up and went on the front porch to have a cigarette (maybe cigarette's make me see things???).
Anyway, I noticed off to what would've been my northern sky two bright objects floating across the sky. I thought nothing of it at the time; airplanes. I hadn't turned on the news. I lived on the west side of Houston at that time.
It wasn't until that night I was watching the evening news when I saw the tragedy of Columbia. And to this day I know I saw debris from that tragic event.
You never know what you're going to see when you're looking up.
BrooksObs
Reged: 12/08/12
Re: Flaring Object in Puppis *DELETED* new [Re: kt4hx]
      #6182852 - 11/08/13 12:19 PM
Post deleted by tecmage
Edited by BrooksObs (11/08/13 12:20 PM)
timtrice
Reged: 08/01/13
Loc: Katy, TX
Re: Flaring Object in Puppis *DELETED* new [Re: BrooksObs]
      #6182870 - 11/08/13 12:28 PM
woodscavenger
Reged: 08/20/13
Loc: Boise, ID
Re: Flaring Object in Puppis [Re: timtrice]
      #6183061 - 11/08/13 02:17 PM
We were out observing late one night and had some UBLs (unexplained bright lights) on the eastern horizon that were there for about 10-15 minutes. Some variation in brightness with very slow downward movement. We eventually go our scopes and binos on them and saw hazy smoke around them. we finally realized we were viewing over the local air force base and when a few more appeared we think we were seeing high altitude flares being used for a night war game scenario. It was pretty cool except it wreaked havoc on our night vision if you looked through your scope at it.
brentwood
Reged: 11/04/05
Loc: BC Canada
Re: Flaring Object in Puppis [Re: woodscavenger]
      #6183185 - 11/08/13 03:30 PM
My thought when I first read the post was that the object was a plane or planes approaching with their landing lights on. I have been fooled so many times with these objects. It is often only when you put some optical aid on them that you can see the navigation lights, but not always. This site can be helpful in determining if it is a plane or not once you allow for the 5 minute? delay and the fact that it does not show military aircraft IMO.
kt4hx
Reged: 01/21/09
Re: Flaring Object in Puppis *DELETED* [Re: BrooksObs]
      #6183884 - 11/08/13 11:52 PM
14 registered and 15 anonymous users are browsing this forum.
Moderator:  cildarith, panhard, tecmage
