Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | (show all)
Relativist
Reged: 10/11/03
Loc: OC, CA, USA
Re: Post a picture of your Assisted Visual Setup. new [Re: Hemmi]
      #6165228 - 10/29/13 07:45 PM
Little reflector finder! My favorite!
budman1961
Reged: 02/25/11
Loc: Springfield, MO
      #6165579 - 10/30/13 12:24 AM
Great setups everyone....lets keep them coming!
JimT
Reged: 08/13/05
Loc: Milky Way Galaxy
Re: Post a picture of your Assisted Visual Setup. new [Re: budman1961]
      #6165781 - 10/30/13 06:47 AM
Really cool set up Hemmi. The finder looks like it was your older main scope from the past. Good use of it now with that dob. Well done sir.
DonBoy
Reged: 09/06/07
Re: Post a picture of your Assisted Visual Setup. new [Re: JimT]
      #6187521 - 11/10/13 08:57 PM Attachment (64 downloads)
I just added 8" to the pier and will need to update this image.
Edited by DonBoy (11/10/13 09:04 PM)
pufahl
newbie
Reged: 11/09/06
Loc: Los Gatos, Ca.
      #6189128 - 11/11/13 05:49 PM Attachment (88 downloads)
First light a couple nights ago. 10" LX-200GPS F6.3 in alt/az, no guiding, no computer. I got up and running with my Mallincam Jr Pro in no time by looking at all the setups folks have posted here (thanks! i never would have thought to use the diagonal). I thought I would see what the Jr Pro would do without any filters or focal reducers.
I started with a few bright clusters like M15 and the views were pretty good though a little washed out in the core (i was not well enough versed in the finer settings). I was using sense up = 128x and with the wireless controller capturing exposures of 5 to 12 seconds. Cabling was using the supplied BNC cable and the RCA adapter to my monitor. About as simple as it gets which is what I wanted.
I moved on to see how deep it would go. I found M57 quite easily and it looks pretty good too. Just a tad bit of color but the skies were so light polluted i could not complain.
So on to something fainter for this test run: NGC 7465 (perhaps 60 degrees from the moon). When it slewed into view i was surprised to see 3 big bright galaxies and was thinking my GOTO was off. But after checking the charts, i found not only NCG 7465 (mag 12.8) but also 7464 (mag 13.3) and 7463 (mag 13.2). Sweet!
In the attached photo, you can actually see the 3 galaxies on the monitor, they were that bright!
Inspired and feeling that I had not given the Jr a real challenge, I decided to try deeper: 7467 (mag 15.6). It too showed up clearly in the monitor (Marshall 7" LCD). I could not believe it, this was EXACTLY what I was hoping to achieve in my back yard. Actually this was WAAAY better than what I expected could be done.
This is in light polluted silicon valley, mag 3 or 4 skies, with first quarter moon just setting behind some trees.
Pictured is the optic train: F6.3 OTA, William Optics Focuser, AP Maxbright diagonal, 1.25 reducer and the Mallincam Jr. Pro.
For my next outing I hope to add the F6.3 SCT reducer between the OTA and focuser. Hopefully I can get the diagonal out of the equation too. I hope to push the exposure times up too but I may be limited by the alt/az mount - we shall see.
pufahl
newbie
Reged: 11/09/06
Loc: Los Gatos, Ca.
Re: Post a picture of your Assisted Visual Setup. new [Re: pufahl]
      #6189254 - 11/11/13 07:16 PM Attachment (75 downloads)
Mostly a test to see if a JPEG will display a little bigger than a PNG (and still under 200k).
And maybe someone wanted to see the setup and monitor a little better… though the shot was taken 15ft away, with flash, using a *BLEEP* point and shoot camera. The image on the monitor was really nice.
I forgot to mention in the prior post, this Jr Pro has the EXView upgrade chip (I have never seen a Jr Pro with the standard chip so i cannot compare or comment on that front).
(yikes! all the dust on the forks show how long its been since its been worth setting up in the backyard).
I want to extend a big thank you to everybody for advancing video assisted astronomy. It has brought REAL astronomy to my backyard.
Back to lurking...
JimT
Reged: 08/13/05
Re: Post a picture of your Assisted Visual Setup. [Re: pufahl]
      #6189288 - 11/11/13 07:34 PM
pufahl
Nice set up enjoy it. Video astronomy is a great way to observer.
Edited by JimT (11/11/13 07:35 PM)
Andy1845
newbie
Reged: 03/31/14
      #6439828 - 03/31/14 05:01 PM
Hi pufahl,
nice setup! The 7" Marshall monitor is a 16:9 panel?!
The video out of the Mallincam is 4:3, so do you
use full screen?
Regards
Andy
1 registered and 5 anonymous users are browsing this forum.
Moderator:  csa/montana, JayinUT
