petemumbower
Reged: 07/12/09
Loc: West Michigan
CGE Pro clutch question
      #6208448 - 11/21/13 09:48 PM
I finally got my pier adapter finished so I could unbox my new CGE Pro and get it on the pier. I must say, that sucker is HEAVY! I did manage to get it mounted on the pier with a bit of effort and started to get it ready for the OTA. I installed the extra clutch knobs that are removed for shipping on both the RA and DEC. Then I attached the counterweight bar.
Next comes the strange part, I loosened all four clutch knobs for the RA to swing it around to get a sense of the range of motion it will have in the observatory. But I noticed that with no weights and no OTA, just the counterweight bar. Where ever I stop swinging it, the RA stopped also. I can use my finger to move it, but it stays put when I stop applying pressure. I thought maybe the clutch knobs were not loose enough, so I back them out further and still the same result.
Based off of how it feels unclutched, I cannot imagine being able to "slightly" balance the RA to the east. Is this normal for other users? Or should I be feeling buttery smooth? Is there a set screw or something somewhere I can adjust for the "pre-load" on the clutch?
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
Re: CGE Pro clutch question new [Re: petemumbower]
      #6208459 - 11/21/13 09:56 PM
Brushing the cob webs aside so I can get a look at that area of my memory I seem to recall that my CGE-PRO had butter smooth balancing and no resistance at all. However I never attempted to balance it with nothing on it. All I can say is try it with your OTA and counter weights and see. If it still seems stiff then I would get it checked out. Maybe he bearing keepers are over tightened.
petemumbower
Reged: 07/12/09
Loc: West Michigan
Re: CGE Pro clutch question new [Re: Whichwayisnorth]
      #6208839 - 11/22/13 07:07 AM
The motion does feel smooth: no rough spots, binding or a anything like that. Looking at the RA, I unscrewed the big orange cap at the back revealing a big bearing and a big nut. The way the RA feels, it seems like the nut is too tight, if that makes sense. I should note that DEC with the clutches loosen fells "smooth". I will give Celestron a call today and see what they say too.
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #6208976 - 11/22/13 09:25 AM
They (most likely) will tell you to ship it back to them so their technicians can work on it. At least that is what happened to me when I asked them for a technical mount manual so I can clean up some of the motion. Good luck!!
WesC
Reged: 02/06/13
Loc: La Crescenta, CA
Re: CGE Pro clutch question new [Re: Sunspot]
      #6209590 - 11/22/13 02:31 PM
I would try loading it up first and see if its still doing it.
petemumbower
Reged: 07/12/09
Loc: West Michigan
Re: CGE Pro clutch question new [Re: WesC]
      #6209650 - 11/22/13 02:55 PM
Update: I talked to Celestron this morning for about 30min and something is for sure not right with mine. So they are having me ship it to them (on their dime). Tech was super helpful and knew what he was talking about. 99% sure they are just going to grab a fresh one and ship it me. At least I live in Michigan and it is cloudy for long periods here right now, so I am not missing time. Plus I have my trusty CGEM in case it does clear out.
petemumbower
Reged: 07/12/09
Loc: West Michigan
      #6256873 - 12/16/13 07:26 PM
Well, I received my new mount head today and the RA is buttery smooth now. Took a bit of time, but shipping across the country both ways does take a bit I suppose. Plus Celestron footed the bill, so I cannot complain. Now if I can get some clear skies!
23 registered and 48 anonymous users are browsing this forum.
