fetoma
Reged: 09/26/06
Loc: Southern New Jersey
I would like a chip with more real estate? new
      #6225055 - 11/30/13 12:04 PM
Folks,
I'm currently imaging with an SXVF-H9 mono and am thinking about a move to the KAF-8300 chip for the larger FOV. Unfortunately I can't afford the ICX694 based cameras at the moment.
Has anyone made this move that can give me an opinion either way if it's a good or bad move? I'm imaging from a red zone just outside a white zone.
ollypenrice
Reged: 03/10/09
Loc: South east France
Re: I would like a chip with more real estate? new [Re: fetoma]
      #6225463 - 11/30/13 04:06 PM
The chip isn't the camera. Far from it. If you go for the QSI you won't be disappointed. Atik do a good job for much less cost, in Europe at least.
Olly
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
      #6225485 - 11/30/13 04:17 PM
Have you thought about the QHY version? Not a bad deal with the filter wheel included.
David
fetoma
Reged: 09/26/06
Re: I would like a chip with more real estate? new [Re: David Pavlich]
      #6225543 - 11/30/13 04:59 PM
Guys,
I'm asking for an opinion on switching chips as I know all about the cameras available.
alpal
Reged: 06/15/09
Loc: Melbourne Australia.
      #6225573 - 11/30/13 05:15 PM
Guys,
2 people just gave you an opinion.
What more do you want?
fetoma
Reged: 09/26/06
Re: I would like a chip with more real estate? new [Re: alpal]
      #6225587 - 11/30/13 05:21 PM
How about for you to stay out of it with your smart remarks.
JJK
Reged: 04/28/08
      #6225676 - 11/30/13 06:27 PM
Guys,
The OP was about a possible chip real estate upgrade, not about specific camera manufacturers. Just sayin'.
fetoma
Reged: 09/26/06
Re: I would like a chip with more real estate? new [Re: JJK]
      #6225730 - 11/30/13 07:04 PM
Thanks John.
freestar8n
Reged: 10/12/07
      #6225757 - 11/30/13 07:23 PM
I went from sxvf-h9 to atik 8300. I'm not sure exactly what you are asking, but yes it is bigger and it is very different imaging with it - mainly due to the shutter, slower downloads, and larger files. It is also bigger and heavier - but not compared to even larger cameras.
In terms of light pollution I have plenty also, so I do mainly narrow band and photometry. The 8300 is not as sensitive there as Sony but it is sensitive and it is bigger than the h9.
I don't get much chance to image but it has been fine so far. The main adjustment is the shutter and slower downloads.
If you have a well corrected field and you aren't currently making use of it, it is very nice to be able to capture it. But if your main interest happens to be small galaxies then that would not be as important.
Frank
fetoma
Reged: 09/26/06
Re: I would like a chip with more real estate? new [Re: freestar8n]
      #6225812 - 11/30/13 07:45 PM
Thanks Frank. I'm not overly worried about the slower download times, and the shutter shouldn't throw any curve balls either. How will it compare in sensitivity? I currently don't need to take dark frames either. I'm guessing this is the trade off for a larger chip.
PGW Steve
Reged: 10/03/06
Loc: Winnipeg, Canada
      #6225846 - 11/30/13 08:07 PM
I do narrow band with my 14" LX200R and FSQ, both with 8300 chips. I'm never disappointed with the signal I get, but I don't have anything to compare it to.
Mr. freestar8n mentioned about getting used to the shutter, again, I don't have any other frame of reference, but the shutter to me is transparent as Maxim runs the show and I'm generally not around while things are going on.
If the other cameras don't have shutters, does that not make taking darks a manual intervention type of task?
Again, I have no other experience to compare it to other than I'm happy with the 8300's I have.....Until my 16803 shows up in about 3 weeks. :-D
DeanS
Reged: 07/12/05
Loc: Central Kentucky
Re: I would like a chip with more real estate? new [Re: PGW Steve]
      #6225982 - 11/30/13 09:42 PM
It is worth the move to the larger chip size. If you find the seeing is not good enough to handle the smaller 5.4u pixels you can bin it 2x2 and still have a bigger image than the H9. I started with the H9 and ST2k and now have the 8300 and 4022 chips and like them both.
Dean
JJK
Reged: 04/28/08
      #6226027 - 11/30/13 10:09 PM
Frank, I too live in a Red Zone (22 miles from the White House), and have been imaging for just under 2 years with OSC CCD cameras (SBIG ST-2000 & STL-11000) and scopes capable of illuminating much larger chips. Here is my take on the matter of chip real estate, ignoring the obvious increase in cost that scales with size.
Larger chips invite more issues with LP gradients. This can be mitigated to some extent with LP filters (I had decent luck with a Hutech LPS-2), and the use of sophisticated software (e.g., Dynamic Background Extraction in PixInsight). Of course, nothing beats a pristine sky, but these things make imaging near "civilization" a more pleasurable experience.
Personally, I really like having a wider FOV that a larger chip affords. After struggling with equipment malfunctions, software maladies, Windoze updating in the middle of an imaging run, frostbite, insect bites, dropping expensive kit in the dark, etc. it's really cool to look at a wider perspective of the data one took on a computer monitor. While staring at the images for hours, the wider FOV allows you to see more DSOs that might otherwise go unnoticed.
The wider perspective also provides the potential for fun juxtapositions. For example, this past August, I imaged Nova Delphini 2013, and the STL-11K allowed me to include the Blue Flash Nebula in the frame. Having an essentially dead star's colorful remnants across the field from an orange-colored new dying star made the image much more interesting.
I recently sold my OSC cameras and am replacing them with monochrome 8300 (just arrived) & 16803 CCD cameras w/fully-loaded color filter wheels (LRGB + 3 nm Ha/OIII/SII). My current strategy is to image NB to beat down Moonlight and nights when there's bad LP (due to more than average water vapor in the sky) and use LRGB filters when the sky is drier and the Moon's asleep. I assumed that the tight bandpass NB filters (especially OIII) will help.
Hope this helps.
Scott Watson
Reged: 05/26/06
      #6226106 - 11/30/13 10:51 PM
Physically larger chips with larger pixels (at the same read noise figure) are generally a good way to improve light gathering FOV or both.
JJK
Reged: 04/28/08
      #6226167 - 11/30/13 11:36 PM
I forgot to mention that larger chips require more care with taking and applying flats.
gezak22
Reged: 08/15/04
Loc: On far side of moon. Send help...
      #6226339 - 12/01/13 02:55 AM
...I currently don't need to take dark frames either. I'm guessing this is the trade off for a larger chip.
While I never made the jump from a small sensor to a large one, I do own an 8300 based camera. As long as I have 15+ lights (dithered), I can process them without darks and get images that I am satisfied with in terms of noise. And if I am not, I'll take 10 darks, and reuse those for a year.
Edited by gezak22 (12/01/13 02:57 AM)
freestar8n
Reged: 10/12/07
Re: I would like a chip with more real estate? [Re: JJK]
      #6226362 - 12/01/13 03:29 AM
Hi-
Yes that is a good point and I agree and I completely forgot about it. I hate gradients and I hate doing any kind of non-deterministic processing. The only way to get rid of gradients is to deduce what the "true" background is and remove it in image processing. Some people don't mind doing that at all, but I really don't like it.
I am at fairly long focal length and mostly do narrow band. I find color work to be fundamentally frustrating in light pollution and I just don't enjoy it.
So yes - that is a good point. The wider field is great when it lets you see more stuff - but will increase color gradients and possibly be a pain processing.
Frank
fetoma
Reged: 09/26/06
      #6226501 - 12/01/13 08:11 AM
What about filter size? I currently use an SX filter wheel with 1.25" filters. Can I still use them or would I need to move up in size to the 36mm?
freestar8n
Reged: 10/12/07
      #6226510 - 12/01/13 08:22 AM
Filter size was also a factor for me, but I don't intend to use very fast optics. I have the Atik 9 position filter wheel and want to stay with 1.25" filters. At f/10 I see no problem and in the future I intend to use f/6-f/7 and there may be some vignetting in the corners, but I hope not much.
I believe the 8300 is a good intermediate size that still allows use of 1.25" filters. It depends on how fast the optics are, how close the filters are to the ccd, and how sensitive you are to any vignetting.
I believe others here use f/6-f/7 with 8300 and 1.25" filters but I haven't yet.
Frank
fetoma
Reged: 09/26/06
      #6226526 - 12/01/13 08:37 AM
My scopes range from f/3 to f/9. Check my sig.
20 registered and 21 anonymous users are browsing this forum.
Moderator:  Oldfield, droid, bilgebay, WOBentley, dr.who
