Scottobservatory
Reged: 12/11/08
Loc: Florida and New Mexico
Nexstar5SE or 6SE?
      #6230277 - 12/02/13 09:17 PM
I have a 10" Skywatcher reflector that is quite large and heavy. I am seriously thinking of buying something smaller I can use for a "daily" scope and am wondering if the 5SE or the 6SE will give me what I am looking for: planetary viewing and discernible deep space viewing, particularly galactic structures, as well as just being outside just "browsing". I'm concerned the 5" won't give me the details of the planets I'm looking for, nor will I get decent views and details of Andromeda and other galactic targets. After I bought the Skywatcher I realized I should have bought the more-friendly 8" Nexstar and am making the best of it. I also find the powertanks haven't been reliable, with two of the larger units not charging at all. Any suggestions re the Nextstars? Thanks.
After posting this I found a similar thread and believe the 6" is preferable to the 5" simply due to the light-gathering power. Now all I need is a good protein drink to help me schlep the 10" Skywatcher around. And I also found some good advice re powertanks, namely the Schumacher at Walmart. Thanks guys.
Edited by Scottobservatory (12/02/13 09:33 PM)
maugi88
Reged: 08/25/13
Loc: SE MN
Re: Nexstar5SE or 6SE? new [Re: Scottobservatory]
      #6230358 - 12/02/13 09:53 PM
6"
Midnight Dan
Reged: 01/23/08
Re: Nexstar5SE or 6SE? new [Re: maugi88]
      #6230423 - 12/02/13 10:17 PM
Hi Scott:
The 6SE should be great on planetary views. It might be a bit weak for "details" of galaxies unless you're under very dark skies.
I guess a lot depends on where you're going with the 10". If you want a scope as a companion to the big gun and you still plan to use the 10" a lot, then the 6SE is an excellent choice.
BUT ... if you think the smaller scope will start weaning you away from the 10" and it's just too much to deal with, then you might want to consider the 8SE. That is, assuming you can afford it - you didn't mention budget. As a replacement to the 10", an 8SE will show less, but not by a substantial amount. On the other hand, the 6 will be a big step down from the 10.
Just something to think about.
-Dan
SouthernSky
Reged: 11/30/06
Re: Nexstar5SE or 6SE? new [Re: Midnight Dan]
      #6244619 - 12/10/13 12:09 PM
Hi Scott,
If I recall correctly, the 5SE and 6SE is not only different in aperature size but also the mount. The 6SE uses the same sturdier mount as the 8SE. But the 5SE mount has built-in equatorial wedges. Sometimes I also wonder why Celestron doesn't use the Nexstar 127SLT's 5" Maksutov-Cassegrain OTA for the 5SE. Maks is supposed to have smaller central obstruction than SCT.
Best Regards.
TK6411
Reged: 07/25/04
Loc: San Antonio, Tx
Re: Nexstar5SE or 6SE? new [Re: SouthernSky]
      #6244899 - 12/10/13 02:19 PM
Of the two choices I would recommend the 6 SE.
faltered
Reged: 04/01/05
Re: Nexstar5SE or 6SE? new [Re: TK6411]
      #6245226 - 12/10/13 04:43 PM
6. All day. And with the sale on these right now, it makes it even more attractive.
OrlandoMatt
Reged: 11/22/13
Loc: Orlando, FL
Re: Nexstar5SE or 6SE? new [Re: faltered]
      #6249211 - 12/12/13 02:26 PM
Do you think the 8SE is a better choice then the 6SE for the money? (fingers on the trigger with all these sales)
Midnight Dan
Reged: 01/23/08
Re: Nexstar5SE or 6SE? new [Re: OrlandoMatt]
      #6249457 - 12/12/13 04:38 PM
Hi Matt:
Absolutely! If you can swing the money, the 8SE will provide nearly twice the light gathering capability of the 6. You'll be able to see quite a bit more when it comes to the faint fuzzies like galaxies and nebulae.
-Dan
hopskipson
Reged: 06/24/10
Loc: Queens, New Yawk, Light pollut...
      #6250367 - 12/13/13 07:06 AM
Matt
If you can swing the money and the added weight go with the 8. I know some will say the mount will be shaky but there are cures for that and once it settles down you will be rewarded with a better view.
dpippel
Reged: 04/05/13
Loc: Desierto de Sonora
Re: Nexstar5SE or 6SE? new [Re: hopskipson]
      #6250804 - 12/13/13 12:04 PM
The 8" is right at the weight limit for stable operation on this mount IMO. It works pretty well, but you will experience "the shakes" to some degree. I think that the 6" is the perfect match for the mount weight/size-wise, although I certainly wouldn't let that dissuade me from going with the 8" if I wanted the extra aperture.
OrlandoMatt
Reged: 11/22/13
Loc: Orlando, FL
Re: Nexstar5SE or 6SE? new [Re: dpippel]
      #6250906 - 12/13/13 01:14 PM
Weight wouldn't be an issue for me, and thanks for the replies. I've been seeing the same things regarding the mount.
BigC
Reged: 09/29/10
Loc: SE Indiana
      #6251909 - 12/13/13 11:10 PM
The cure for the shakes is a motorized focuser to keep my big clumsy fingers off the scope!!It made a huge improvement in satisfaction and ease of achieving best focus on my 80GT.
My SN-10 has had a motor for years.The faster the scope and ,or, the shakier the mount ,the more benefit I have found from motorizing the focuser.Same principles apply to slo-motion control vs. RA motor with remote.Initial cost is high(er) but operation becomes more pleasant.
Seriously, it is the observer who mostly provides the unwanted force the tripod and mount must then absorb or transmit to the ground.
I am in the process of adding powered focusers to several scopes as time and money allow.
Edited by BigC (12/13/13 11:11 PM)
Gary Z
Reged: 01/26/12
Loc: New Mexico
Re: Nexstar5SE or 6SE? new [Re: BigC]
      #6251965 - 12/13/13 11:45 PM
Having an 8 SE for over a year now, I love the views the 8 inch provides. Yes, when the smallest wind comes up, it will shake the scope a bit. One way to help mitigate this is by lowering the tripod at it's lowest level while maintaining leveling for the mount. Best wishes for your purchases and most of all, Clear Skies....
BTW, where do you observe in NM. I live in eastern NM (Clovis).
Warmest regards,
Scottobservatory
Reged: 12/11/08
      #6257061 - 12/16/13 09:03 PM
Thanks for the definitive response. I've been away and just now returned home. Sorry for the delayed thanks. 73
Scottobservatory
Reged: 12/11/08
      #6257077 - 12/16/13 09:10 PM
Dan, thank you for the detailed response. Budget is vital--I'm married. My wife sees the 10" in our living room every day and just shakes her head and says something in Japanese (I won't ask her what she said). So the 8" is not an option. Either the 5 or 6 will work, though the greater power of the 6" is probably going to be the deciding factor. It's also MUCH more portable than the 10" will ever be, though I will now occasionally take the 10" to acreage we have in rural Florida near our primary residence. The 5/6" scope can be used there too, as well as when we travel. I should also note my handle Scottobservatory refers to the C.S. Scott Observatory at Park University, which I attended in the mid-1960's. I worked at the observatory for 4 years and it has since burned to the ground mysteriously. It had a beautiful 8" refractor with a 108" focal length and a great brass clock drive tracking mechanism. So...in remembrance of those days, I use the handle Scottobservatory.
Scottobservatory
Reged: 12/11/08
      #6257083 - 12/16/13 09:13 PM
Many thanks. I think having the sturdier mount trumps the wedges (I believe I can add them as an accessory).
Scottobservatory
Reged: 12/11/08
      #6257085 - 12/16/13 09:15 PM
Thank you Jim. I'm going to be in Dallas for the holidays and plan to personally buy the scope from a retailer in the region while I'm out there. No one near me in Florida. Besides, I can test it out to ensure its working properly before heading east again.
Scottobservatory
Reged: 12/11/08
      #6257090 - 12/16/13 09:17 PM
And the sale is what got me to make a purchase.
Scottobservatory
Reged: 12/11/08
      #6257095 - 12/16/13 09:19 PM
Matt, the 8" would be the ideal, but as I mentioned in an earlier response in this thread, I'm married. 35 years. My wife knows I like to spend $$ and she goes the opposite way. Washes straws so she can re-use them. The 6" would be the absolute limit.
sonny.barile
Reged: 10/19/10
Loc: In the middle of the glow.
      #6257131 - 12/16/13 09:34 PM
Why not go all the way and get the 8se? It is only a little heavier than the 6 as they are on the same mount.
6 registered and 15 anonymous users are browsing this forum.
Moderator:  Brian Risley, panhard, Mitchell Duke, mayidunk
