Observing >> Solar System Observing
Telescopic
Reged: 11/29/13
Loc: BC, Canada
120mm ED refractor for planets - wrong choice?
      #6240991 - 12/08/13 03:03 PM
I ordered a Skywatcher Black Diamond 120ED for planetary and lunar viewing. I already have an 8" dob I will then use for DSO.
My main interest right now is the planets, but did I make a mistake getting a 4.7" ED refractor? I also have interest in getting a 16" or building an even larger dob, so would the refractor then be obsolete?
I'm wondering if I should cancel/return the refractor and put it toward a 16" dob instead?
LivingNDixie
TSP Chowhound
Reged: 04/23/03
Loc: Trussville, AL
Re: 120mm ED refractor for planets - wrong choice? new [Re: Telescopic]
      #6241027 - 12/08/13 03:29 PM
The refractor will be great on planets, the 8in will great for Deep Sky observing. Just save your money and get the 16in when you can afford it and use your new refractor and 8in. When you get the 16, you might want to see the 8in. Having a nice refractor and a big dob is a good set up.
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: 120mm ED refractor for planets - wrong choice? new [Re: LivingNDixie]
      #6241268 - 12/08/13 05:57 PM
Depends on how much you want to see on the planets. Personally, I think an 8" f/6 newt is about perfect. All things equal, it'll outperform the 120mm. I have a 120mm f/8.3 refractor piggybacked on my SCT; it's a nice sharp scope, but not in the same league as my 8" newt.
Were it me, I would return the refractor and get the 16". That'd be the bomb on the planets, as well. And since you'll be doubling the aperture instead of cutting it in half, the WOW factor will be there too.
Of course, there's the grab-n-go factor to consider, too...
contrailmaker
Reged: 01/02/09
Re: 120mm ED refractor for planets - wrong choice? new [Re: Rick Woods]
      #6241803 - 12/08/13 11:14 PM
I think that from your location the 120 ED is an excellent choice.
CM
Jon_Doh
Reged: 09/16/11
Loc: On a receiver's back
Re: 120mm ED refractor for planets - wrong choice? new [Re: contrailmaker]
      #6242265 - 12/09/13 09:47 AM
The 120ED will do great on planets, splitting double stars, including tight doubles (try that with the dob) and DSO's. It won't require constant collimation nor will it suffer from cool down issues like the dob.
One last thing to consider. Planets move fast. With the 120ED you can mount it on a goto setup and track the planets while observing. The mount will keep the planet in the center of your eyepiece. With the big clumsy dob you'll constantly be having to nudge the thing every few seconds. Dobs are better for DSO's because of the light grasp and because DSO's move much more slowly through the eyepiece and require fewer adjustments. But you said your primary goal was to view planets, which move quickly out of the FOV so a goto tracking mount is your best option, which means the 120ED scope.
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
Re: 120mm ED refractor for planets - wrong choice? new [Re: Jon_Doh]
      #6242468 - 12/09/13 11:38 AM
Well, it won't suffer as badly from thermal inequilibrium but nevertheless 4-5" refractors tend to take 30-60 minutes to "settle down" if moved to a site with a different temperature.
As for double stars: with research grade mirrors, proper temperature control and accurate collimation, a Dobsonian / Newtonian will do very well indeed. For close doubles with equal or nearly equal components, the modification of the diffraction pattern caused by the approximately 20% central obstruction typical of these scopes is actually beneficial though the effect is noticeable rather than substantial.
But you can stick an equatorial platform under a dob ... and have it track at least as well as a low end equatorial mount, for an hour or two at a time, which is a great boon.
Aperture rules for planetary detail; given equal optical quality, almost nothing else matters. Small/medium fracs are great for low power views of star clusters etc. and unequalled for solar work because there's no secondary mirror to fry, and fracs have much better resistance than other designs to the sort of horrendous seeing that usually prevails when observing the sun.
If by "120mm ED" you mean the common Synta / Orion / Skywatcher 120mm f/7.5 ED doublet, it does have quite a lot of chromatic aberration: you really need an anti-fringing filter for viewing the moon or planets with it.
aa6ww
Reged: 10/23/11
Loc: Sacramento, Calif.
Re: 120mm ED refractor for planets - wrong choice? new [Re: brianb11213]
      #6242902 - 12/09/13 03:26 PM
You did great. You only need one good refractor, then the rest is just aperture. Both your scopes are still very manageable. A larger dob would be nice, but keep the 120. Its portable, and gives very sharp views on planets and great for wide field views and star splitting. Wait till you get some excellent 5/5 seeing conditions. You'll be impressed. Pay more attention to the seeing conditions, jet streams overhead, and pick your nights. Read up on the GRS transit times of Jupiter, and know that on April 14th, 2014, Mars is going to be very close to earth and put on a nice show, so plan for that also. The refractor has light baffles, your dob does not, so you will be able to just do some back yard planetary observing and love it, even with lights nearby.
I would focus more on getting some planetary eyepieces, now. TV Plossls are relatively inexpensive and will out perform the Naglers and Ethos, ES 100 deg eyepieces on sharpness and contras on the planets.
Even if you get a larger dob later, try and hold onto your 8". It's an intermediate size and easy to work with, and wont bog you down if you just need a few hrs of deep space observing.
Stop hanging out in the equipment forums and start visiting the planetary forums and eyepiece forums, and things related to what you already have. The equipment forums will kill you and make you think you keep needing "more" "more" "more."
Its more fun to look through your own gear at space, then to look at it and talk about it, and never use it.
...Ralph
Eric63
Reged: 06/16/12
Loc: Ottawa, Ontario
Re: 120mm ED refractor for planets - wrong choice? new [Re: aa6ww]
      #6243113 - 12/09/13 04:54 PM
+1
It's not often than you will be able to use more than 120mm aperture on planets because of your location. And when that perfect seeing comes along, take out the 8" too. Your 120ed will give you a nicer view 90% of the time.
Eric63
Reged: 06/16/12
Re: 120mm ED refractor for planets - wrong choice? new [Re: Eric63]
      #6244676 - 12/10/13 12:31 PM Attachment (24 downloads)
Just to add to my last post. I did a comparison some months ago when I was also thinking of a 120ED. I used the software Aberrator to compare difference scopes and came up with the following chart. The scopes are a 6" Newt with a 33% CO and an 8" SCT with a 33% Co (Both diffraction limited) and a 120ED. The chart is normalized to a 6" aperture. What I came to realize is that most of the time I would be on the left side of the Chart (average to ok seeing), therefore the 120Ed would provide better contrast and a more pleasing view. When the seeing is excellent, the larger aperture allows for greater detail to be seen, but in my case that would be maybe once or twice a year. Now, it you plan on sitting for hours behind a scope and wait for glimpses of excellent seeing, then a larger aperture is better, but I don't observe that way. So if you are more of a casual observer,use the 120ED most of the time and if the seeing is excellent, take out the 8 Dob.
CelestronDaddy
Reged: 08/22/09
Loc: Central Texas
      #6244850 - 12/10/13 02:01 PM
That should be a nice scope for planets! It should do fine on plenty of other objects too! Congrats...
revans
Reged: 09/26/05
Loc: Fitchburg, MA
      #6245084 - 12/10/13 03:44 PM
Quite right. And I spent my first decade of serious observing with only a 60 mm achromat and you would be amazed at what I could see with it. I couldn't have even imagined getting my hands on a 120 ED in those days (late 1960s). The closest I came to this at the time was when my best friend's dad (an engineer) made a lunar/planetary refractor from a 6 inch aerial camera lens he got at a flea market. And the first time I looked through it (1975 or so) I just couldn't believe the spectacular views of the moon which just blew my 60 mm refractor away. I didn't even notice the chromatic aberration around the edges because the views were so sweeping and so detailed. I don't remember a similar experience until the mid 1990's when I viewed the moon through a 36 inch dob. I suppose that is the ultimate view of the moon I've ever had... but I'll never own a scope like that
Mr. Bill
Reged: 02/09/05
Loc: Northeastern Cal
      #6245175 - 12/10/13 04:25 PM
Eric, thanks for the chart...made me get out my copy of Suiter and reread the chapter on MTF.
Eric63
Reged: 06/16/12
Re: 120mm ED refractor for planets - wrong choice? new [Re: Mr. Bill]
      #6245613 - 12/10/13 07:47 PM
That's a great book, a must read for anyone interested in star testing. Aberrator is also a great software (freeware) that allows you to simulate your scope and figure out how well it performs. You can even simulate planetary views with different scope designs.
It's always nice to keep learning.
Eric
Edited by Eric63 (12/10/13 07:51 PM)
Happy Birthday Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
      #6246214 - 12/11/13 01:31 AM
Actually, the refractor would be an excellent planetary telescope. So are 8-inch and bigger Dobs with quality optics. Where an APO beats Dobsonians is sheer high image contrast and color fidelity, planets look like pen and ink drawings through an APO. Where a big Dob excels on planets is very high power viewing to show details on them and even their moons that is simply impossible to see through a small telescope. Even on deep sky objects from a dark site the APO you bought will show a surprisingly good view on the brighter galaxies and nebulae.
Taras
Eddgie
Reged: 02/01/06
      #6248635 - 12/12/13 09:47 AM
Lovely chart.
I think your approach is in theory an excellent one. This is the approach I have been advocating for making comparisons, and I thought it was reallly great for you to include references to different detail sizes on Jupiter as a way to match MTF performacne to real world performance.
There is a flaw however. For the 120ED scope, you assumed it would be "Perfect" and at f/7.5, even with FPL-53 glass, the Polychromatic Sthrel is liklely about .92 or .93.
When people compare refractors to reflectors, they always handicap the reflector for central obstruction, but give the refractor a pass and ignore polychomatic Sthrel.
Not saying that you made a mistake buy ordering the 120mm, but if your reflector is very good optically, don't expect to see more in the 120ED, though my bet is that you wont' see any less.
Also, after using an 8" scope, going to a 120mm, there is a big dropoff in brightness. At 200x the 8" is going to have a much brighter image, which is an aid in combating floaters and for resolving the lowest contrast detail on the target.
I expect though that the 120mm will indeed be as good, but if you were looking for a big improvement, then yes, you may have made a mistake.
But if you want a great all around refractor that can do everyting competently, the 120mm looks like a fantastic choice.
Don't forget Polystrehl though. To plot MTF against an reflector and include the CO, and ignore polysthrel is a kind of bias for refractors that while unintentional, badly distorts these kinds of comparisons.
Suiter discusses Polystrehl in his chapter on charmatic aberration. Even triplets loose some contrast to Polysthrel. An excellent triplet with aspherized elements (gee, who does that?) can get close to perfect.
But a fast doublet with no asperizing is probably .92 at best when you look at the full spectrum.
Again, I have to tell you that I absolutelyl love the chart. I admire the effort you put into this. It is clear that you have studied MTF and have a great grasp of the inportance it can play in comparing different apertures.
Edited by Eddgie (12/12/13 09:51 AM)
Eddgie
Reged: 02/01/06
Re: 120mm ED refractor for planets - wrong choice? new [Re: Eddgie]
      #6248670 - 12/12/13 10:02 AM
Also, just noticed that while your current 8" is a dob which probably has a total obstruction (adding 2% for the secondary spider) you plotted a 33% obstruction, which wold indicate that you were comparing to an 8" SCT.
Unless your dob is very fast and has a very large CO, then this chart is comparing different scopes.
And this. Hate to say it, but if your dob is not already using a high quality mirror, you may have found a more meaninful improvement in performance by sending the mirror to someone for re-figuring. You could also slightly under-size the secondary (if total obstruction is not below 25% already) to further improve contrast transfer.
Again, I don't think the 120ED is going to be any worse than what you have, but my concern for you is that unless your current mirror is poor, the 120ED won't be any better.
If you want to make a meaninguf step up, here would be my prescriptoin.
Asess your current mirror. If the SA and smoothness are pretty good (less than 1/20th roughness and less than 1/6th SA), then leave the mirror alone.
If not, spend $600 to have the mirror refinished and recoated to a high Strehl.
The, buy a pair of binoviewers..
You can do this for less than you will spend on a 120ED scope.
Just an alternative, but qood quality apeture (the more the better) and a pair of binoviewers to me are the planetary observers best tools.
And don't let the "Seeing" people lead you to beleive that the bigger apture is somehow wasted. Side by side, 6" APO to C14, it was very rare for me to have a night where both scopes were side by side that I could not get at least a little more detail out of the C14.
That just takes commitment and patience (which the binoviewers make much easier).
Edited by Eddgie (12/12/13 10:04 AM)
Eddgie
Reged: 02/01/06
      #6248698 - 12/12/13 10:16 AM
With respect to "Seeing", you may want to read this recent post comparing my observations using a small apeture and a much larger aperture on the same night of not so great seeing...
Second to last post.. Direct comparison on night of less than great seeing...
stanislas-jean
Reged: 10/22/08
      #6248729 - 12/12/13 10:39 AM
Edgie, regarding your 2 posts I agree with your comments.
I donot think that the 8" with low CO ratio (say 20% and less) and high PTV will be out performed by a 120ED.
I had the 2 kinds in hands and this is a fact.
We should assess also the fact that for very low contrasted fine feature the 120ed is not excellent, also in the blue channel where venus clouds on mine were almost absent.
The consequence was the non use of the 120ed. For the 1" arc resolution I prefer the use of the MN127 highly more acurate for such exercise, it shows easily venus clouds in blue channel and other colors and allow access of very low contrasted features of little sizes on planets.
If it is a good scope, not an excellent scope, in white light its potential is actually restrained in comparison with better designs and of less prices (1000 for the MN and 1250 for the 120ed).
Now it can make observations by the rear of the tube which is an avantage.
The curves introduced on this forum must be pushed away, in blue channel, by the actual optical acuracies of each, by the seeing involvement which is almost 2 danjon scale steps in favor of the 120mm (3/5 in the 8" can be 4-5/5 in the 120 with about 67% contrast kept only in the 8" in comparison).
At final this is always a 120mm, not more, the 8" will show always more in holes of seeing even at 3/5 mostly.
Stanislas-Jean
Eric63
Reged: 06/16/12
      #6249003 - 12/12/13 12:53 PM
Thank you very much for your kind words Eddgie. In fact I have you to thank for this; its all your posts and charts on MTF that led me to research this topic. You are right though that the 120Ed in the chart is a perfect scope and so it may be a bit too optimistic. When I first made this graph earlier in the year I was thinking of either upgrading the mirror in my 6F5 Newtonian, getting a C8 or accepting my horrible seeing conditions and getting an ED120 for more aesthetic view under average seeing conditions. I made other comparison charts with varying optic quality but in the end I put off the decision. Now however, after reading your post on seeing, Im leaning towards getting an 8 SCT in the future since it will also fit my size/aperture requirement (limited storage space) and will work well with a binoviewer (which I will eventually get). As for the OP, I think the 120ED will serve him well as you noted.
Thank you again Eddgie
Eric
Jon_Doh
Reged: 09/16/11
      #6250535 - 12/13/13 09:38 AM
Eric,
If you want to add an SCT I might suggest a 10 or 11 inch. I have an 8 inch and the 120ED and the SCT shows me nothing the 120 doesn't. In fact on many targets like the Andromeda and Dumbbell, the 120 shows me more. It may be because I'm viewing from skies with fairly high humidity and light pollution and where you are may be different. But you may want to look through an 8" SCT before buying one.
3 registered and 9 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), star drop, Mitchell Duke
