mitaccio
Reged: 03/17/09
Loc: Oahu, Hawaii
Semi-Temporary Piers?
      #6257279 - 12/16/13 10:58 PM
I am active duty Army and move around often, but want the stability of a pier. Anyone ever made a pier that is semi-permanent? If so, how did you make it and how well does it work? I have a Nexstar and want a more stable platform, as well as a permanent location to set up.
jbalsam
Reged: 07/06/12
Loc: Darnestown, MD
Re: Semi-Temporary Piers? new [Re: mitaccio]
      #6257315 - 12/16/13 11:32 PM
I use a "portable pier" made by ATS. I have three spray-paint spots on my driveway where the legs go, so I know where to put it each time I set up. If I need to put it somewhere else it's easy to re-level it and polar align. I can take 30 minute guided exposures with it... so I think it's stable enough for anything that anybody would want to do.
dandabson
Reged: 10/15/08
Loc: Dover, DE
Re: Semi-Temporary Piers? new [Re: jbalsam]
      #6257613 - 12/17/13 07:56 AM
I take it you live in housing or do you rent off base. I constructed a wood pier. If I ever sell the house I can cut it off under ground level and fill it in and plant grass. I don't think I will be relocating any time soon. I am retired military. Look forward to retirement. It is worth it.
roscoe
curmudgeon
Reged: 02/04/09
Loc: NW Mass, inches from VT
Re: Semi-Temporary Piers? new [Re: dandabson]
      #6257716 - 12/17/13 09:18 AM
Perhaps you could build a wood box that was somewhat pyramid-shaped, that you could fill with sand or stones, to give it more mass, that bolted to something flush with the ground....and saw the bolts off when you move
frolinmod
Reged: 08/06/10
Loc: Southern California
Re: Semi-Temporary Piers? new [Re: roscoe]
      #6258216 - 12/17/13 01:53 PM
Astro-Physics makes excellent comparatively inexpensive portable piers that can be used as temporary piers. They make them in 6-inch, 8-inch and 10-inch diameters of various heights.
gdd
Reged: 11/23/05
Loc: N Seattle suburb, WA
Re: Semi-Temporary Piers? new [Re: frolinmod]
      #6258286 - 12/17/13 02:49 PM
My Losmandy HD tripod is actually a 6 inch diameter mini-pier elevated with fixed angle tripod legs. I place it on concrete blocks I buried and leveled in my backyard. I marked the blocks so the tripod is always placed in the same position. I placed the blocks so the tripod legs are either fully collapsed or fully extended, so no need to level the tripod.
Gale
3 registered and 10 anonymous users are browsing this forum.
Moderator:  Christopher Erickson, Mitchell Duke
