cruling
Reged: 12/23/12
Loc: Jersey City, NJ
AVX mount RA clutch lever
      #6271587 - 12/25/13 12:57 AM
i just got a AVX mount, the RA axis could not lock very well.
when i tighten the RA clutch lever really hard, i can still turn the RA axis with my bare hands, not very easily, i mean when i grab the CW shaft and push it a little harder, i can still turn it.
i remember my CG5 doesn't behave like this, when i tighten the clutch lever, i cannot turn that axis at all.
is there anything wrong with the mount?
Fan
RTLR 12
Reged: 12/04/08
Re: AVX mount RA clutch lever new [Re: cruling]
      #6271589 - 12/25/13 01:02 AM
Remove the screw and the lever and "re-clock" (rotate) it so that you have more travel in the "Lock" position.
Stan
cruling
Reged: 12/23/12
Re: AVX mount RA clutch lever new [Re: RTLR 12]
      #6271606 - 12/25/13 01:24 AM
Hi Stan, i have done that, it's didn't work.
i mean i have tighten the clutch lever really hard, it won't be any more tighter unless i change to a bigger lever. then if i grab the CW shaft at the middle, i can still turn the axis.
mistyridge
Reged: 10/28/05
Loc: Loomis, CA
      #6271617 - 12/25/13 01:36 AM
Remove ths lever and screw out the clutch bolt. you will find a black derlin plug on the tip. Clean the grease of the plug and reinstll the plug and bolt. The clutch should provide enough friction now.
RTLR 12
Reged: 12/04/08
Re: AVX mount RA clutch lever new [Re: mistyridge]
      #6271661 - 12/25/13 02:51 AM
I had to go to the longer ADM clutch levers on my CGEMs in order to get a good lock on the clutches.
Stan
cruling
Reged: 12/23/12
      #6272085 - 12/25/13 12:09 PM
Hi Mike, i tried clean the grease on the plug, it didn't help, maybe some grease got onto the surface of the barrel inside the housing.
have to think of a way to clean it
cruling
Reged: 12/23/12
      #6272118 - 12/25/13 12:27 PM
Stan
Hi Stan, i try to remove the lever on my CG5, it's a little bigger, but something bad just happened, see here: http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/6272113/page...
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #6272141 - 12/25/13 12:39 PM
is the square block and large threaded piece all one piece? or are they 2 pieces held together by the piece of remaining broken screw? Kasey
37 registered and 47 anonymous users are browsing this forum.
