Pete-LH
Reged: 03/25/09
Loc: Wilmington, DE
Lambda Orionis new
      #6285180 - 01/01/14 10:21 AM Attachment (18 downloads)
This is a Sketch from last Friday night of Lambda Orionis and the asterism (Lambda Orionis Cluster or Collinder 69) where it is located (Orion's Head). I recently acquired a used Borg 60ED which I am trying out as both a finder for the C8 and a wide field view. Here I used an 11mm Nagler with the 60Ed giving a 32X/2.4deg field of view. With a 3.5mm Nagler at 100X/0.8 deg Lambda Orionis was resolved with the major star a very nice disc with one concentric ring which overlapped at the edge of the companion. I should have tried sketching that as well. I need to work on my magnitudes-in the 2.4 deg view Lambda, Phi 1 and Phi 2;1 should stand out a bit more from the rest as well as the three stars in a slight arc between Lambda and Phi 1.
Not a difficult split except it was fairly cool and the atmosphere was not so stable at first (or my C8 had not stabilized). But eventually had a fairly good view.
There is a pretty good description of Lamda Orionis in Wiki-pedia.
kenrenard
Reged: 12/13/12
Loc: Dunmore, PA
Re: Lambda Orionis new [Re: Pete-LH]
      #6285503 - 01/01/14 12:53 PM
Nice wide field sketch. You have to love those little refractors.
Ken
PeterDob
Reged: 07/29/05
Loc: CarĂ¹, Italy
Re: Lambda Orionis new [Re: kenrenard]
      #6285782 - 01/01/14 03:21 PM
Very nicely done, Pete! The comparison is very interesting.
Peter
Chopin
Canis Insanus
Reged: 02/03/05
Loc: In the doghouse.
Re: Lambda Orionis new [Re: PeterDob]
      #6286181 - 01/01/14 06:34 PM
Still a great observation, Pete! Even if you feel the split wasn't very challenging. I love the related sketches at varying magnifications.
Pete-LH
Reged: 03/25/09
Loc: Wilmington, DE
Re: Lambda Orionis new [Re: Chopin]
      #6286655 - 01/01/14 11:16 PM
Jason, That's what I've been aiming at for a visual setup-A finder that can also be a good wide field visual tool as well when sketching. I really like this set-up of the C8 with a 60-70mm light telescope.
Reged: 10/05/09
Re: Lambda Orionis [Re: Pete-LH]
      #6288543 - 01/02/14 09:30 PM
Pete,
Nice sketch of Lambda Orionis .
0 registered and 8 anonymous users are browsing this forum.
Moderator:  cildarith, JayinUT, WOBentley
