Ratchet
Reged: 08/07/11
Loc: Tallahassee, FL
Starblast 6 Dob Mount new
      #5978910 - 07/18/13 11:02 PM
I'm trying to cure one of the pitfalls of a 6" F5 scope, which is you either need a GEM, or you sit on the ground with the OEM base, or you bring a table + scope.
I had some 1970s old mass produced desk wood lying around in 1" and 3/4" thickness oak veneer plywood. It is a very odd ply with thick, unidentified lightweight wood plys. The 1" ply weighs about the same as 1/2 B/C ply from the big box stores.
My base circle is 17.5", eyepiece height is a couple inches shorter than the XT10. The bottom isn't finalized, nor are the bearings or wood finish. The bearings will be teflon riding on some surplus material I found labeled as "ABS plastic sheet" at Skycraft in Orlando. The only parts glued so far is the rectangular section. I hope to finish it this weekend and attain a final weight around 15 lbs. I made templates for the side panels which are cut on the router table and front/rear panels are joined with stub tenon and groove (stop dado?). The dowel is 1.25" and inset into the side panels. It adds some stiffness, provides a handle, and acts as a bump stop for the OTA. I'll probably condition the wood with a water/glue mixture and use india ink for dye and treat with a topcoat of something or another for sealing the plywood against moisture. I have some epoxy, but might try some water based poly. Ignore all the pencil and marker marks for now.
I know a 6" F5 dob is a compromise. Since the base needs to be so tall most people will say "just get an 8" F6". But this will still be nice because there will be room in the bottom to line with foam and add a lid for built in finder and eyepiece storage. One less thing to carry, right? I was hoping the OTA could turn 90 degrees, lower and sit/lock between the side panels, but it's not possible with my current rings. Still, it doesn't take up much space.
I'm building this for a member of our club who is having trouble with their vintage 6" F5 Meade mounted to a GEM. She wants to just be able to set the scope on the ground and start star hopping without all the fuss of polar aligning and dealing with old style GEM gears/clutches/brakes and rickety legs.
Ratchet
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
Re: Starblast 6 Dob Mount new [Re: Ratchet]
      #5978948 - 07/18/13 11:30 PM
Looks great if you ask me! Nicely proportioned and a practical solution to the height problem. I'm gonna steal your design for my 6" mirror.
JimC
Ed D
Reged: 04/30/10
Loc: Sunny South Florida
Re: Starblast 6 Dob Mount new [Re: Mirzam]
      #5979196 - 07/19/13 05:49 AM
I have often thought about building a small Dob just like yours. It's awesome, and I'm sure it will perform as good as it looks. Don't forget to post pics of your finished masterpiece.
Ed D
Tom McDonald
Reged: 12/19/06
Loc: No where man!
      #5979234 - 07/19/13 07:00 AM
Nice design and your woodworking skills are commendable!
I should build something along those lines for my 6" Starblast. I got rid of the original mount before I moved.
Congrats! And keep us posted on how it works.
BigC
Reged: 09/29/10
Loc: SE Indiana
      #5979480 - 07/19/13 09:52 AM
Excellent work there!
Putting the focuser at a more comfortable height for the user ought to be a design goal of manufacturers.
In order to invert the scope for storage you'd have to remove the crossbar that adds much to the mounts rigidity.Or make it easily to remove and install.
Ratchet
Reged: 08/07/11
Re: Starblast 6 Dob Mount new [Re: BigC]
      #6290874 - 01/04/14 12:26 AM
I finally got back in the garage to work on the dob conversion some more. Been busy lately with a newborn boy peeing and pooping all over me.
The dob conversion is still far from finished, but I'm making good progress. I decided to try using some cutting board material for a combination thrust bearing and brake. All I have so far is a pic of me cutting the disk and I probably won't have the completed altitude bearing for another couple of weeks.
The scope pictured in the first post above is my Starblast 6 which I was using for mock-up of the base dimensions. This first conversion I'm doing is for a Meade 6600 so I had to make a cradle for the scope since Meade doesn't use a flat spot on one of the rings. I drew up something in CAD and made some layout lines on a 9" plywood square and just cut to my layout lines and trimmed out the corners.
The two rings are joined by 4 tenoned struts. Once I get all the burn marks sanded off, I'll glue it up and cut right down the middle of two opposite sides to make it a clamshell.
Edited by Ratchet (01/04/14 12:40 AM)
cheapersleeper
Reged: 01/22/10
Loc: Sachse TX
Re: Starblast 6 Dob Mount [Re: Ratchet]
      #6290948 - 01/04/14 01:31 AM
I love 6" f5. I love them so much that I will be working on one this weekend.
B
StarStuff1
Reged: 04/01/07
Re: Starblast 6 Dob Mount new [Re: cheapersleeper]
      #6292259 - 01/04/14 04:29 PM
Looking really good! I especially like your clamshell/rings.
A coupla minor recommendations. A hole could made in the front board to reduce weight a little further. And a wooden eypiece holder could be easily added to the base. Just sayin.
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: Starblast 6 Dob Mount new [Re: StarStuff1]
      #6296137 - 01/06/14 02:35 PM Attachment (4 downloads)
Found this stuff at Lowe's. It's HDPE plumber's tape that I needed for rerouting the dryer vent. $7 for 50'. It's pretty slippery and may work well for bearing material.
cpr1
Reged: 03/24/12
Loc: Louisiana
Re: Starblast 6 Dob Mount new [Re: Geo.]
      #6297087 - 01/06/14 10:23 PM
Nice design!! and skills. I never really liked the tabletop mounts for these small scopes. What you have done should make your scope much more user friendly.
8 registered and 18 anonymous users are browsing this forum.
