Equipment Discussions >> Classic Telescopes
wfj
Reged: 01/10/08
Loc: California, Santa Cruz County
Bausch and Lomb 80mm Spotting Scope f/10
      #6299202 - 01/08/14 12:44 AM Attachment (76 downloads)
Miniature SCT with integral 1.25" visual back. 8" long from front flange to rear threaded visual back. Tube is 3.75" diameter. 44mm CO.
Build quality high. Not a bit of plastic, machined aluminum out of drawn stock with a casting on the end. No mirror flop. Cap on secondary covers hex collimation screws.
wfj
Reged: 01/10/08
Re: Bausch and Lomb 80mm Spotting Scope f/10 new [Re: wfj]
      #6299216 - 01/08/14 12:59 AM Attachment (42 downloads)
Made in Japan. Likely Mizar/Hino. Model #61-8080. Likely around 1994.
After collimation, breakout test of secondary shadow shows almost no SA. Chief issue is > 50% CO! I guess that is because this was primarily for film camera use so low/no vignetting a 35mm film frame.
Links:
http://www.betterviewdesired.com/Bausch-and-Lomb-8080.php
http://www.bytesmiths.com/OM_Tele/index2.html
Jupiter is sharp but contrast suffers. Double stars, the Trapezium, ... resolve just fine. Moon crater wall details excellent. Diffraction patterns dominated by first and second rings, central spot has very little energy.
Also branded with Legacy and Bushnell. Rubber armored version with longer lens shade.
wfj
Reged: 01/10/08
      #6300134 - 01/08/14 02:15 PM
Correction - not Mizar but Towa?
... It is a small 80mm Schmidt-Cassegrain. In the photos below you can see it's of the Towa brand. Don't ask me who they are, I got this as a present as a child. ...
Hmm. Could this be in some way related to the Meade 4" SCT's? See Meade 2045S thread.
wfj
Reged: 01/10/08
      #6306769 - 01/11/14 06:13 PM
Confirmed - not SCT but "mirror lens".
Two lens assemblies - one at the internal end of the baffle tube from the primary, other supported on an optical window.
Somewhat like:
Casting also is similar to Meade 2045, but much smaller.
wfj
Reged: 01/10/08
      #6335256 - 01/25/14 04:51 PM Attachment (26 downloads)
Cannot find makers mark anywhere on body.
Still waiting on promised original EPs(18mm, 30mm), lenscap, and camera extension tube (female 36.4mm, male T thread).
BTW Model #61-8080RA (rubber armor) looks like:
Tourneciel
Reged: 03/24/13
Loc: Vannes - FRANCE
      #6344533 - 01/30/14 04:22 AM
Hello to all!
Actually, it is not a SCT but a Mangin-Cassegrain. I have one on an EQ mount (see picture). I did a research to know who was the original manufacturer and found out that Kenko (Japan) could be it. Towa is just one of the brands it was distributed by. Here in Europe, it was sold in the 80's and 90's under Paralux (MMC 80) and Médas (Perl TCC 80) in France, Bresser in Germany.
Tourneciel
Reged: 03/24/13
Re: Bausch and Lomb 80mm Spotting Scope f/10 new [Re: Tourneciel]
      #6344534 - 01/30/14 04:23 AM Attachment (26 downloads)
Sorry, I forgot the pictures!
Tourneciel
Reged: 03/24/13
      #6344535 - 01/30/14 04:26 AM Attachment (29 downloads)
This one is the Kenko model (D = 800 F = 1000)
Tourneciel
Reged: 03/24/13
      #6344538 - 01/30/14 04:26 AM Attachment (47 downloads)
and, here is the one by Towa
wfj
Reged: 01/10/08
      #6345581 - 01/30/14 04:54 PM
Greetings Alain,
Thank you for sharing your pictures and comments. Its great to hear from you and see your scope of this kind.
So - like a Vixen VMC:
Did you disassemble to see if it was this or possibly a Klevtsov-Cassegrain?
Mine appears to have two lens groups - one at the secondary and the other at the top of the baffle tube from the primary.
Interesting. Kenko does make "mirror lens" telephoto for cameras, as well as Gregory Maksutov Cassegrains. I would very much like to hear more of your research on this.
Did you find any "maker's marks" on your scope?
I assume you wrote this article/post/message:
http://www.webastro.net/forum/showthread.php?t=106861
I've attempted to translate it for others here:
Finally ! I finally got hold of a Maksutov(Mangin)- Cassegrain telescope - I've been looking for this for a while. Thought it might be like the Meade 2045.
This telescope is a Paralux MMC 80 Paralux, one of many of the brands under which it was distributed (first advertisement appeared in " Ciel & Espace " in 1988 , while others are MEDAS Perl TCC 80 , SBS, Bresser in Germany, Poland ) . The instrument was made in Japan.
Here is a description of the instrument:
It is a Cassegrain with formula Maksutov- Mangin, with a diameter of 80 mm and a focal length of 800 mm which gives us an F / D = 10.
It is equipped with a tiny finder (4 X 20 ), 3 eyepieces ( 2 Kellners of 25 and 12.5 and an OR of 9 mm), a terrestrial erector, a camera adapter, a 1.25" diagonal for use with American or prior Japanese eyepieces, which is a good idea) .
The mount alone is heavy (3 kg). It comes with an integral tabletop tripod, although it can also be mounted on a camera tripod.
The interesting thing with the optical tube is that it only takes a few seconds to remove it from the frame (just unscrew a nut) and it becomes 800 mm telephoto lens with a tripod shoe.
Everything comes in a metal briefcase barely larger than a sheet of A4 paper type ( exact dimensions : 31cm X 25cm X 15cm).
Hardware Pricing ? 50 Euros!
Tourneciel
Reged: 03/24/13
      #6346520 - 01/31/14 04:59 AM Attachment (37 downloads)
Hi William!
No, I haven't disassembled my telescope tube so, the only information I have about its optical formula comes from one of its french formal importers and from Germany.
I had to use Google translator to find pages in japanese to see if I could find its original manufacturer and, from those I contacted, only one gave me a negative reply (no news from the others).
Indeed, the article from Webastro is mine. My model was sold by Paralux (blue tube). Optional motors were available at the time it was sold (I'd like so much to find some for mine!). Sorry if I can't add more info.
Here are a couple more photos about my current instruments.
Tourneciel
Reged: 03/24/13
      #6346521 - 01/31/14 05:01 AM Attachment (29 downloads)
My Vixen Halley 70 + the MMC 80
Tourneciel
Reged: 03/24/13
      #6346522 - 01/31/14 05:07 AM Attachment (39 downloads)
Here is the Bresser version of the 80/800
wfj
Reged: 01/10/08
      #6347349 - 01/31/14 02:41 PM
Formidable!
By the way, you don't have to disassemble the scope to see the lens systems - looking down the front at the top of the baffle tube directly, and then at the reflection off the primary of the secondary can show two separate lens systems.
You can also notice by reflections off the lens systems a concave surface on the rear surface, and a convex off the front.
This confuses me as it doesn't match a Maksutov(Magin).
wfj
Reged: 01/10/08
      #6347358 - 01/31/14 02:46 PM
Looks like the eyepiece is retained by a compression ring rather than a set screw. Casting looks different too!
I've asked my friend in Japan who works with Takahashi about Kenko and "mirror lens" scopes - hope I hear back.
wfj
Reged: 01/10/08
      #6347370 - 01/31/14 02:51 PM
Oh, and here's an example of the makers mark for Kenko - that would nail down the origin:
Tourneciel
Reged: 03/24/13
      #6348420 - 02/01/14 02:06 AM
There was also a difference between models sold in France and those in Germany. Mine has a diagonal for 0.96 (an adapter ring provided for) and 1.25 eyepieces.
I wish you a great weekend! Here, it's cloudy... days!
Alain.
wfj
Reged: 01/10/08
      #6360844 - 02/06/14 10:27 PM
Previous article:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5885254/Main...
Other references:
http://forum.astronomie.de/phpapps/ubbthreads/ubbthreads.php/ubb/showflat/Num...
suggest it may be a Dilworth design:
http://www.atm-workshop.com/dilworth.html
The Bresser model is Pulsar 48-6000, and it has the same screw on adapter thread as the C90 and ETX.
Tourneciel
Reged: 03/24/13
      #6436433 - 03/29/14 04:25 PM
I have just got an information about the actual manufacturer of this cassegrain 80/800 telescope from a reliable source. It's confirmed: TOWA!
wfj
Reged: 01/10/08
      #6436444 - 03/29/14 04:36 PM
Alain,
That's great news, to finally pin it down. I have heard that as a rumour when in Japan and Australia, but no one could say outright.
Best I could get out of a German contact was a cautious "could be"
6 registered and 13 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), Brian Risley
