emadeg
Reged: 10/26/12
Jupiter 08/01/2014 from Rome - PREVIEW R CHANNEL -
      #6303904 - 01/10/14 10:37 AM Attachment (80 downloads)
Hello guys, only one day from my 2014/01/07 last shot on Jupiter here is an other one. I think it's my best R channel....
I have some filters problems so i will post all the single channels , and you can merge your own RGB or LRGB as you like.
Newton 400 "TRAPANER" self build , asi 120mm , barlow 3x , derotation of 5 images from 60 secs @ 60 fps movie.
Here you are:
Edited by emadeg (01/10/14 10:44 AM)
emadeg
Reged: 10/26/12
Re: Jupiter 08/01/2014 from Rome - PREVIEW R CHANNEL - new [Re: emadeg]
      #6304792 - 01/10/14 06:59 PM Attachment (33 downloads)
This is B channel. I have a derotated one , sum of 3 B channel, that is better, but i have to process yet....
22.09 UT.
As you can see, it is not at the level of R channel, so the seeing was good but not too good.
Edited by emadeg (01/10/14 07:01 PM)
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
      #6304926 - 01/10/14 08:08 PM
Really nice images there
CPellier
Reged: 08/07/10
Re: Jupiter 08/01/2014 from Rome - PREVIEW R CHANNEL - new [Re: Rankinstudio]
      #6305569 - 01/11/14 07:36 AM
Excellent R ! The B is still very good. The color image will go fine.
emadeg
Reged: 10/26/12
Re: Jupiter 08/01/2014 from Rome - PREVIEW R CHANNEL - new [Re: CPellier]
      #6305641 - 01/11/14 08:27 AM
You have to see G: it's identical to B. If i don't say you can't understand which is B and which G. I have to mesh some R to G, or take full ir-cut luminance as G. Later i will post G and L....and then we can see what kind of solution is possible....
emadeg
Reged: 10/26/12
      #6306872 - 01/11/14 07:12 PM Attachment (15 downloads)
Here channel G.
emadeg
Reged: 10/26/12
      #6306877 - 01/11/14 07:13 PM
....levels a bit different due to different elaboration....but it is identical to B!!
emadeg
Reged: 10/26/12
      #6306914 - 01/11/14 07:34 PM Attachment (13 downloads)
...and this is a bad attempt for a first (L)RGB ...
emadeg
Reged: 10/26/12
      #6306919 - 01/11/14 07:37 PM Attachment (13 downloads)
or at 100% dimension :
emadeg
Reged: 10/26/12
      #6307564 - 01/12/14 06:06 AM Attachment (11 downloads)
Here is an other try may better balanced:
sfugardi
Reged: 09/30/06
Loc: CT
      #6307691 - 01/12/14 09:02 AM
Emanuele, top shelf quality! Hands down one of the best posted this year. Resolved details are in high definition. Congradulations on this one and thanks for sharing your work
Steve
Mauro Da Lio
Reged: 09/12/04
Re: Jupiter 08/01/2014 from Rome - PREVIEW R CHANNEL - new [Re: sfugardi]
      #6308004 - 01/12/14 12:06 PM
One of the BEST images with one of the CHEAPEST scopes!!!
emadeg
Reged: 10/26/12
      #6308008 - 01/12/14 12:07 PM Attachment (12 downloads)
Last attempt...please be patient
Edited by emadeg (01/12/14 12:13 PM)
15 registered and 13 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
