corpusse
Reged: 04/11/10
Loc: Mississauga, Ontario, Canada
Rings of Saturn through the years
      #6303954 - 01/10/14 10:57 AM
Improved version now that I have a good 2014 image.
I'm not crazy about including 2010 but I will show both versions :
Back in 2010 I could barely polar align well enough to planetary image and was working with a C8 and the original junky celestron neximage. While I got some decent moon and Jupiter images with it, for anything dimmer it wasn't much good of course frame rate and processing with much worse then too. Too bad I don't have those video files anymore, I'm sure more could be squeezed out with modern technology. At the time I was using a netbook with maybe a 20 or 40 gig SSD which basically required EVERYTHING being deleted before beginning a planetary imaging run.
2011 is with the dmk 21 - I had not yet purchased a filter wheel and then I had my hand controller die and it took quite a long time for celestron to send me a replacement so I never got a colour image.
2012 is also with the dmk but with lrgb filters.
2013 and 2014 is with the asi120mm with ir rgb filters.
I can't wait to look at this again in 10 years with 10 more images.
Edited by corpusse (01/10/14 11:17 AM)
steveward53
Reged: 05/14/12
Loc: Newmarket,UK
Re: Rings of Saturn through the years new [Re: corpusse]
      #6304052 - 01/10/14 11:57 AM
Lovely set sir ...
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: Rings of Saturn through the years new [Re: steveward53]
      #6304088 - 01/10/14 12:22 PM
Love those compositions, great work
sfugardi
Reged: 09/30/06
Loc: CT
Re: Rings of Saturn through the years new [Re: Rankinstudio]
      #6304103 - 01/10/14 12:30 PM
Andrew, excellent ring history! I would just desaturate the 2010 and keep it. The hex is already visible on your 2014 shot. Thanks for posting it
Steve
corpusse
Reged: 04/11/10
Re: Rings of Saturn through the years new [Re: sfugardi]
      #6304168 - 01/10/14 01:00 PM
Steve
good idea!
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #6304795 - 01/10/14 07:01 PM
Well I'm not crazy about 2010 either but it is needed just the same. Sometimes even the bad stuff is needed to tell the whole story. Mike
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
Re: Rings of Saturn through the years new [Re: mikey cee]
      #6304882 - 01/10/14 07:47 PM Attachment (6 downloads)
A good graphic example of the changing ring tilt Andrew!
You could always make a mono (b&w) version of the images like this if the first one's colour annoyed you too much..!!!
pedxing
Reged: 11/03/09
Loc: Germany
Re: Rings of Saturn through the years new [Re: Kokatha man]
      #6309580 - 01/13/14 05:41 AM
I like having the 2010 shot in there - the edge-on rings really help show the evolution of the tilt and it also demonstrates how your AP skills have progressed...
brave_ulysses
Reged: 04/19/09
Loc: far outside the wire
Re: Rings of Saturn through the years new [Re: pedxing]
      #6309820 - 01/13/14 09:19 AM
+1 pedxing
6 registered and 7 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
