DA53
Reged: 11/23/12
Loc: Shoreview, MN
My Binotron-27 so far new
      #6304352 - 01/10/14 02:19 PM
I received the Binotron I ordered in mid-December, and like everyone else, I am pleased with the careful packaging and quality of the unit itself. I also ordered two 68° ES 20mm eyepieces to use with the binoviewer.
The result is a unit that is rather heavy on a Celestron Nexstar 8SE, but manageable. I have used the whole set up about eight or nine times since. Seeing conditions have been terrible, and the weather has often been worse, so one has to take that into account. I also view from a second story balcony attached to my condo apartment, and the closeness to the surfaces of the building may affect seeing as well.
So far, I have seen no appreciable difference in the image quality the Binotron delivers and what my much cheaper WO binoviewer delivers (I am viewing Jupiter and the moon). If the length of the light path were an issue, I have the 45 degree OCS attachment which, Russ tells me, ensures that I am engaging the full 8 inches of the mirror. This unit added to the weight of the binoviewer to the point, however, that I am afraid to use it again, and I didn't really see any difference with or without it.
In the fall, the WO gave me (with this telescope) the best image of Jupiter I have ever seen through a telescope-better than the Binotron has yet given me.
So there, for what they are worth at this point, are my observations. I will wait for better seeing conditions before I add anything further.
Edited by DA53 (01/10/14 08:18 PM)
crow
Reged: 07/09/12
Loc: BC, Canada
Re: My Binotron-27 so far new [Re: DA53]
      #6304441 - 01/10/14 03:07 PM
Well, I'd say you definitely need more time with them, Many experienced users on here have noted no difference optically with the Baader Mark V. You also mention the seeing, which the Binotrons as good as they are, are not going to drill though, so give yourself some time.
A couple of people own both I believe so your mileage may vary but be confident you've picked a world class binoviewer in the Binotrons.
I've never used the WO's.
DA53
Reged: 11/23/12
Loc: Shoreview, MN
Re: My Binotron-27 so far new [Re: crow]
      #6304467 - 01/10/14 03:22 PM
I should add that one night I did see the craterlets in Plato on the moon better than I have before through the Binotron. On a few evenings the collimation of the telescope was off, so that moons of Jupiter had tails. That was easily fixed, and I moved on.
Eddgie
Reged: 02/01/06
      #6304752 - 01/10/14 06:15 PM
I can't say that I saw a big difference between my inexpensive Binoviewers and top end binoviewers, so I would not be surprised that you did not get an "Oh My Gosh" kind of experience.
The benefit of these systems is really more the ability to get a much wider true field than with the inexpensive BVs.
I suspect that like Crow mentions, seeing is your big factor.
Also, you are likely using more power than you think. Without the OCS, a C8 is working at more like 2400mm to 2500mm (depending on your exact configuration and when used straight through).
Try backing down power a bit and see if things look a bit sharper.
Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
Re: My Binotron-27 so far new [Re: Eddgie]
      #6304794 - 01/10/14 07:01 PM
True. The inexpensive binoviewers seem to have excellent prisms and collimation these days, generally speaking.
Clear skies!
Thomas, Denmark
swampdog
Reged: 10/18/12
Loc: Minnesota
Re: My Binotron-27 so far new [Re: Astrojensen]
      #6305408 - 01/11/14 02:19 AM
I concur with responses, give it more time...the Binotrons are superb, and I totally agree with your seeing evaluation, there hasn't been a decent sky since November, & I hail from the Detroit Lakes area of Minnesota, the weather's been rather brutal! So yeah, the W/O binos are nice, but Denks... much more versatile. Personally I found the OCS, while it worked, was too much power in the sct's (I've had the B-27's since last summer), just keep the light path reasonably short and enjoy, but the OCS will shine with the refractor and dob!
DA53
Reged: 11/23/12
Loc: Shoreview, MN
Re: My Binotron-27 so far new [Re: swampdog]
      #6305760 - 01/11/14 09:39 AM
Russ says that you cannot use the reduction mode when you attach the OCS, but it will give you 1X relative to the eyepieces you are using.
I replaced the ES eyepieces with 25mm Plössls, by the way, and again, apart from a narrower view at less power, did not see any increase in viewing quality.
As for light path, I probably will invest in the new Denkmeier IVB Star Quartz Mirror Dielectric Diagonal if I continue to see no improvement. But at this point, all of this is getting quite expensive.
faackanders2
Reged: 03/28/11
      #6306325 - 01/11/14 02:36 PM
Russ says that you cannot use the reduction mode when you attach the OCS, but it will give you 1X relative to the eyepieces you are using....
What? I use reduction mode all the time with my Denk II and Dobsonian.
nicklane1
Reged: 03/04/08
      #6306521 - 01/11/14 04:21 PM
So many folks with binoviewers never go back to mono viewing. So bottom line, will inexpensive binoviewers provide the "wow factor" compared to mono viewing?
DA53
Reged: 11/23/12
Loc: Shoreview, MN
Re: My Binotron-27 so far new [Re: faackanders2]
      #6306997 - 01/11/14 08:33 PM
In an SCT--not in a Dob.
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
      #6307080 - 01/11/14 09:28 PM
The difference in quality of the B27s is more evident as you increase magnification, which obviously requires good seeing. Give it some time but I agree that the quality of the less expensive binos is surprisingly good.
Edited by johnnyha (01/11/14 09:28 PM)
Ava
Reged: 11/30/11
Loc: Sweden
      #6307466 - 01/12/14 02:22 AM
If you want to shorten the light path a prism diagonal would generally be more suitable, for instance the badder T2 prisms (ordinary or Zeiss). Not sure about how one would go about connecting one to the binotron though, adapters might eat more than you gain I guess.
axle01
Reged: 01/26/13
Loc: Townsville Nth Qld Australia
Re: My Binotron-27 so far new [Re: Ava]
      #6307538 - 01/12/14 05:15 AM
Ava this thread will show how to connect a bino 27 to a Baader prism.
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5984517/page...
Edited by axle01 (01/12/14 05:16 AM)
Adam S
Reged: 12/21/05
Loc: Gunnison, Colorado
Re: My Binotron-27 so far new [Re: nicklane1]
      #6307721 - 01/12/14 09:33 AM
Nick, the first time I used a binoviewer a decision was made to never go back to monoviewing. I couldn't believe the improved experience on planets, the Sun and the Moon in my refractors. Within a month or so I began to go back and forth between mono and bino on DSOs and with many of them the light loss was very notable in four and five inch refractors (Tak FS 102 and AP 130). Most significant losses are on GCs.
If I had 12" or more in aperture I'd likely binoviewer full time. I love refractors for many reasons and find myself using a Denk II for the solar system and going mono outside of it.
The wow factor is real, light loss is as well. Aperture trumps a lot of the light loss. If I ever get an 18" dob the Denk will live in the focuser.
nicklane1
Reged: 03/04/08
Re: My Binotron-27 so far new [Re: Adam S]
      #6307864 - 01/12/14 10:47 AM
Thanks Adam. Your response was very helpful. It answered many questions that I had.
I've been thinking about getting a Binotron-27, but since many folks don't believe there is a big difference between top end and inexpensive binoviewers, is it really worth it?
From my perspective and from the standpoint of "total package" I believe a top end eyepiece is worth it.
Adam S
Reged: 12/21/05
      #6308042 - 01/12/14 12:22 PM
If you can afford it do it. My experience is that seeing has more to do with the payoff than any other factor. From my current home seeing is atrocious, I rarely get above a 4 on the Pickering scale. Can't imagine there'd be any difference between the Binotron and an entry level unit. When we lived 30 miles north of our current home it was a much better site. I started out with a standard Denk and Russ convinced me that I'd love the Denk II. I did it and was able to see less scatter around bright objects on virtually any given night. It may have been in my head, but the clarity of planetary detail was better as well. Worth the extra money in a good area, plus you never have to second guess whether or not you should have gone big (this is assuming you can afford to go big without breaking the bank).
Edited by Adam S (01/12/14 12:28 PM)
DA53
Reged: 11/23/12
Loc: Shoreview, MN
Re: My Binotron-27 so far [Re: Adam S]
      #6308091 - 01/12/14 12:49 PM
There is no going back for me from binoviewing to monoviewing, at least for the moon, planets and brighter DSOs. And for many where viewing is better than it is here, the Binotron is a superior unit to the WO one. But I still have to see the difference for myself.
I placed 25mm Plössls into the Binotron last night, and did get a clearer view and sharper, albeit smaller, view of Jupiter. I believe I actually saw the GRS, in fact, which wasn't visible with the ES eyepieces. Then I started messing with the collimation, and that made things worse. After two hours in the cold, I gave it up for another time.
Eddgie
Reged: 02/01/06
      #6310185 - 01/13/14 12:26 PM
Yes, the desire to binoview full time was a key component in my move from the C14 to a 12" dob (major reason was the logistics of the C14 was getting to much, but the BV component was a factor as well).
Once I started to binoview, I just could no longer enjoy mono viewing.
In the end, of the key reasons I went with a 12" rather than 14" was the focal length and true field. The 12", even with the 1.7x GPC, gives me almost as wide a true field as I could get in the C14 using mono-vision and that was my "treashold". Despite the narrow field of the C14, there were actually very few objects that would not fit into the field with the 41mm Pan.
I tried the Binotron briefly, but it was more than I could spend at the time (I already owned a pair of Mark Vs).
I really loved the power-switchs in the Binotron though, and still hope to get a Denk II or Binotron one day, though budget being what it is, I have been looking for a pair of used Denk IIs.
contrailmaker
Reged: 01/02/09
      #6310360 - 01/13/14 02:02 PM
Dave
How is the Nexstar mount handling the extra weight? Mine stated showing signs of strain when I used the heavier Pentax EPs with the Denks. The motors had a hard time tracking under certain conditions. I ultimately sold the the Nexstar since I had bought a 6" APO refractor with a very sturdy mount but I sure miss my C8.
CM
DA53
Reged: 11/23/12
Loc: Shoreview, MN
Re: My Binotron-27 so far new [Re: contrailmaker]
      #6311220 - 01/13/14 09:54 PM
I have the scope pushed all the up on the mount as far as the rail will go. It seems to do all right for now, but I notice sometimes that the slightest touch will cause the back of the scope to move down and the front up. So I use my ES 34mm eyepiece to help me find what I am looking for, and then insert the binoviewer into the diagonal. I hope that reduces wear on tracking and slewing mechanism.
1 registered and 7 anonymous users are browsing this forum.
Moderator:  TG, Geo557
