Moffss
Reged: 09/23/13
Loc: Drexel Hill, PA
6mm Planetary EP new
      #6321217 - 01/18/14 08:39 PM
HI
I figure I have all the EP's I need except a 6mm. I have an 8mm Hyperion and with a barlow it works ok for a planetary view. But I would also like to get a good 6mm planetary EP. I can't afford a neglar. But I am willing to wait until I stumble upon a deal. Anybody have first hand knowledge about this type of EP? Like I said, something to get up close with jupiter and saturn, etc. I wouldn't mind a longer Eye relief. I don't wear glassed by my father and brother do.
By the way I say 6mm because I believe 4 or 5 is to small for my scope and I already have a good 8mm. With a barlow and a 6mm will get me to 308x mag which would be pushing it on all but the best nights. TMB, TV plossl, Ultima? others?
Paul
pstarr
Reged: 09/17/04
Loc: NE Ohio
Re: 6mm Planetary EP new [Re: Moffss]
      #6321237 - 01/18/14 08:53 PM
Pick up a used 6mm Radian for around $140.00 to $150.00. 20mm of eye relief, 60* afov and sharp to the edge.
Paul G
Reged: 05/08/03
Loc: Freedonia
Re: 6mm Planetary EP new [Re: pstarr]
      #6321262 - 01/18/14 09:12 PM
I second the Radian recommendation.
BillP
Reged: 11/26/06
Loc: Vienna, VA
      #6321279 - 01/18/14 09:29 PM
The 8mm Hyperion with the 14mm Fine Tuning Ring (around $15) will make that eyepiece a 6mm Hyperion. I would suggest doing that as a cheap, easy, and FUN way to get to 6mm.
bdcmd
Reged: 03/14/08
Loc: Glen Rose, Texas
      #6321352 - 01/18/14 10:17 PM
What the Pauls said. 6mm Radian is an excellent choice. I use mine a lot on my 4" refractor; the long eye relief and adjustable eyeguard make it easy to find the perfect position for extended study of planets at the eyepiece. Another option if you can't find a Radian readily would be the Vixen NLV. Similar eye relief, slightly narrower fov, 45°, versus 60° for the Radian. Also slightly cheaper, even new. Many people recommend orthos for planetary, but all the short focal length orthos, plossls, etc. are VERY short on eye relief, require real dedication to view through for any length of time.
Pother
Reged: 12/23/13
Loc: Orlando, FL
Re: 6mm Planetary EP new [Re: bdcmd]
      #6321364 - 01/18/14 10:28 PM
I recently picked up 4.5mm and 6.5mm Series 5000 HD-60 eyepieces for planetary viewing, and I have gotten my best views yet of Jupiter through them with my 4 inch refractor. While I haven't used any TV, Pentax, or other best of the best eyepieces, I can say that I have absolutely zero regrets about these Meade eyepieces, and would definitely buy them again. These are replacing my Russell Optics eyepieces as my go-to choices. These run $80 each when purchased new.
http://www.meade.com/product_pages/accessories/hd60.php
Edited by Pother (01/18/14 10:33 PM)
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
      #6321391 - 01/18/14 10:47 PM
For a 6mm, I don't think you can beat a Delos. It has 72 AFOV, 20mm of eye relief, and gives tack sharp, pristine views of the planets.
ibase
Vendor Affiliate
Reged: 03/20/08
Loc: Manila, Philippines 121*E 14*N
Re: 6mm Planetary EP new [Re: BillP]
      #6321405 - 01/18/14 10:55 PM
What a smart suggestion!
L-R: 14mm & 28mm Fine Tuning Rings
Best,
ibase
Vendor Affiliate
Reged: 03/20/08
Re: 6mm Planetary EP new [Re: ibase]
      #6321424 - 01/18/14 11:18 PM
The usual suspects (6mm lineup):
L-R: Delos 6mm, ES/Meade UWA 6.7mm, TMB Planetary 6mm, Baader Genuine Ortho 6mm, Baader Classic Ortho 6mm
The Delos is a widefield (72° AFOV) that's optically excellent both on & off-axis, and has globs of eye relief (20mm) & comfort and a really big eye lens (makes for more immersive feel), but it's big & hefty and expensive too; the 82° ES/Meade 6.7mm is smaller, and has a wider field, but it's less than perfect at the edge and has a tighter ER; the TMB-P 6mm is not the sharpest on-axis but has comfortable ER with good correction at edge, though only 58° AFOV; the BCO 6mm is almost as good as the BGO 6mm which has a sterling reputation in the EP community for its on-axis sharpness, but its AFOV is only 40° (50° on the BCO) and has tight ER, although both are small & light too, very easy to handle.
Best,
george tatsis
Reged: 11/20/08
Loc: Long Island, NY - Europe
      #6321579 - 01/19/14 02:24 AM
One more vote for the Radian ! It's a win- win situation
George
ausastronomerModerator
Reged: 06/30/03
Loc: Kiama NSW (Australia)
Re: 6mm Planetary EP [Re: george tatsis]
      #6321591 - 01/19/14 02:51 AM
Hi Paul
If you do go with a new eyepiece over the fine tuning ring I would also recommend a 2nd hand 6mm Radian. They are excellent value 2nd hand at around $150.
I have a 6mm Radian, a 6mm Delos and a 6mm UO HD orthoscopic. Any performance differences between these 3 eyepieces, in terms of on axis optical performance, is very subtle.
To differentiate between them you will require:-
1) a very good telescope
2) very good conditions
3) an experienced, skilled observer
While the Delos gets the nod slightly over the other two in terms of performance, it's only by a very small amount.
Cheers
hottr6
Reged: 06/28/09
      #6321819 - 01/19/14 09:16 AM
I wrote a review some years back comparing a TMB PII 6mm, Radian 6mm and a volcano top 6mm ortho by Vixen. 'Scopes used were a f/4.5 Newt and a f/11 achro. In both 'scopes and all targets (planets, doubles, DSO) I found the Radian more comfortable (better eye relief, slightly wider FOV) than the TMB, but otherwise they were indistinguishable. My conclusions were that I was unable to justify the expense of the Radian, and so sold the Radian. I still have the TMB PII. If you are made of money, the Radian may help you sleep at night. The volcano top did not fare as well, but I kept it because I prefer it's cooler tone to the TMB and Radian.
precaud
Reged: 12/05/12
Loc: north central New Mexico
Re: 6mm Planetary EP new [Re: hottr6]
      #6321841 - 01/19/14 09:37 AM
A 6mm BCO gave the sharpest views of Jupiter last night with excellent contrast, compared against other 4-element and barlowed combos.
Interesting. There must be considerable variation between each FL in that lineup, the 5mm is ok but not great.
Moffss
Reged: 09/23/13
Re: 6mm Planetary EP new [Re: precaud]
      #6321874 - 01/19/14 10:01 AM
hi
Thanks and I looked for a long while for Radian. I'll keep looking. It doesn't even seem they make the 6mm new any more. maybe in the mean time I will get the fine tuning ring that Bill suggests. How does that work exactly? If anyone has a lead on a Radian 6mm let me know. I'll also keep an eye out for a cheap used BC or BG ortho out of curiosity.
I like the idea of the Ring because I like the Hyperion a lot. I never see people talk about them but to me they seem like really good EP's.
Paul
BillP
Reged: 11/26/06
Loc: Vienna, VA
      #6322200 - 01/19/14 01:25 PM
I used to have the full set of Hyperions, and the two fine tuning rings. That was such a fun set being to adjust focal lengths all the time. I would usually decide before going out what focal lengths I wanted then just put the rings on my Hyperions as appropriate.
It is real easy to do. The Hyperion is made so the barrel and bottom plate it is connected to unscrews. When you do this, simply screw the retaining ring onto the body of the Hyperion, then screw the barrel and place assembly back onto the fine tuning ring and you are done. The eyepiece is now physically longer so that the integrated Barlow/Smyth lens in the barrel provides greater magnification to the upper lens assembly.
Here's a video - Fine Tuning Ring Video (FF to 2 minute mark).
pstarr
Reged: 09/17/04
Loc: NE Ohio
      #6322613 - 01/19/14 04:55 PM
hi
Paul
There is a 6mm radian for sale on AM right now. look here
izar187
Reged: 09/02/06
Loc: 43N
      #6322629 - 01/19/14 05:00 PM
In addition to the very good options already suggested, another consideration is one of these:
http://www.siebertoptics.com/SiebertOptics-Ortho%20page).html
My experience is with a couple of the SSS3.
They are a good match with short fast newts.
CeleNoptic
Reged: 12/20/07
Loc: Cloudy East Coast
Re: 6mm Planetary EP new [Re: izar187]
      #6323032 - 01/19/14 09:14 PM
Hi Paul,
If you decide on Radian, you may want to read post #6264029 by George Gatsis in this thread. He provided evidences that the newer Radians with the smooth lower housing part have better light transmission. BTW, if I'm not mistaken, the AM classified referred to by Paul (pstarr) above listed the older, knurled version.
Deven Matlick
Vendor - Criterion Machine Co. LLC
Reged: 12/31/05
Loc: Moatsville, WV
      #6323123 - 01/19/14 10:16 PM
3-6mm Nagler zoom, expensive but worth it.
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: 6mm Planetary EP new [Re: Deven Matlick]
      #6323407 - 01/20/14 01:15 AM
I'm with Bill.
The 14mm Fine Tuning Ring is just what the doctor ordered.
Get the 28mm as well and convert your 8 to a 5mm and 4.3mm as well as a 6mm.
The eye relief gets a little tighter, but otherwise, it's neat to be able to get 4 magnifications out of one eyepiece without using a Barlow.
14 registered and 23 anonymous users are browsing this forum.
