AustinAstronomer
Reged: 03/04/10
Tripod Extension for AVX?
      #6325246 - 01/20/14 11:06 PM
Is there a tripod extension available that will work with the AVX mount?
Thank you.
AustinAstronomer
Reged: 03/04/10
Re: Tripod Extension for AVX? new [Re: AustinAstronomer]
      #6325878 - 01/21/14 10:40 AM
According to Orion's website, their tripod extension fits the CG-5 mount. So, will it fit the AVX mount, too? Anyone here know?
Thank you.
Carl N
Reged: 03/18/12
Loc: San Diego, CA
      #6327141 - 01/21/14 09:40 PM
No it won't.
AustinAstronomer
Reged: 03/04/10
Re: Tripod Extension for AVX? new [Re: Carl N]
      #6328406 - 01/22/14 01:30 PM
It won't...what? The Orion tripod extension won't fit the CG-5? Or it won't fit the AVX? And how do you know? Have you tried the Orion tripod extension on either of these mounts?
Thank you.
Edited by AustinAstronomer (01/22/14 01:32 PM)
RTLR 12
Reged: 12/04/08
      #6328442 - 01/22/14 01:46 PM
It fit's the CG-5, but the alignment peg is in the wrong location for the AVX and there for it is not a direct fit.
Stan
beatlejuice
Reged: 04/05/11
Loc: Hamilton, ON,Canada
      #6328582 - 01/22/14 02:52 PM
Here is the top part of the mount extension:
There are 3 bolt holes to attach the top of the mount extension to the mount extension itself. The holes are orientated such that one is directly opposite the alignment peg and the other two are equally spaced 120 degrees on either side of the end one.
The alignment peg can be removed for fitting the right sized alt-az mount.
The mount sits in the recessed area which is just shy of 2 1/2" in diameter.
The mount is held in place by the screw on the left. This screw is an M10.
Eric
BarrySimon615
Pa Bear
Reged: 03/01/04
Loc: New Orleans, LA
Re: Tripod Extension for AVX? new [Re: beatlejuice]
      #6328761 - 01/22/14 04:06 PM
Is what you have pictured above for the CG5 or the AVX?
Can you post a side view photo and/or a photo of it in use with whatever mount it is designed for.
Cost, and from where?
Barry Simon
beatlejuice
Reged: 04/05/11
Re: Tripod Extension for AVX? new [Re: BarrySimon615]
      #6329011 - 01/22/14 05:58 PM
Barry, it isn't for any particular mount, it is one of a kind and either fits or doesn't. It fits the cg4 and cg5 and my AT Voyager if I wanted to.
Top part attached to the mount:
Top of bottom part:
Bottom of bottom part:
Blown up view:
On my CG4:
Mount extension $75 from Orion.
Eric
AustinAstronomer
Reged: 03/04/10
Re: Tripod Extension for AVX? new [Re: RTLR 12]
      #6329072 - 01/22/14 06:26 PM
Stan
So, there is NO WAY the tripod extension will fit the AVX? Sigh.
The Mighty Mo
Reged: 10/12/13
Loc: South of North, North of South...
      #6330221 - 01/23/14 09:57 AM
I just downloaded the AVX manual and have been comparing the assembly instruction pictures against my CG-5 and SVP extension. If as mentioned above, the only trouble with the extension is that the alignment peg is in the wrong location (being further in to the center than the AVX uses), it appears a good welder/machinist should be able to either fabricate a new peg and bolt on, or weld a small piece to the outside of the existing peg, building it out enough to make it usable with the AVX adjustment bolts. A bit of modification, but it looks doable.
Orion does have a good return policy. So if you decide to get it and then find doesn't bolt up at all to your mount, before you modify anything, they will let you return it.
AustinAstronomer
Reged: 03/04/10
Re: Tripod Extension for AVX? new [Re: The Mighty Mo]
      #6330294 - 01/23/14 10:42 AM
I think your comments are right on the money. Thank you!
IMHO, Celestron/Synta really dropped the ball if it designed the AVX in such a way that Orion's tripod extension, apparently the only one on the market, can't be used. Query: Why can't Celestron sell a tripod extension?
RTLR 12
Reged: 12/04/08
      #6330469 - 01/23/14 11:57 AM
Vixen also makes a 1/2 pillar, but it runs $189.
Stan
http://www.vixenoptics.com/acc/indiv/25167.html
nodalpoint
Reged: 06/03/13
Loc: FEMA camp
      #6330578 - 01/23/14 12:35 PM
It's "really dropping the ball" if something doesn't work on another companies accessory that not that many people likely use?
Seems like one of these could be easily built for quite a bit less than the Orion item. A local machine shop could probably do the work if you supplied the materials.
RTLR 12
Reged: 12/04/08
Re: Tripod Extension for AVX? new [Re: nodalpoint]
      #6330647 - 01/23/14 01:06 PM Attachment (6 downloads)
I made one from schedule 80 PCV pipe for my CG-5's. Three pieces of PCV, three pieces of threaded rod, and some hardware. Cost just under $20.
Stan
BarrySimon615
Pa Bear
Reged: 03/01/04
      #6335286 - 01/25/14 05:11 PM Attachment (2 downloads)
The Orion half pier will fit but modifications do need to be made from what I can gather by fitting my AVX head to my CG4 tripod top plate. In both the CG4 and my Celestron/Vixen Super Polaris mount, both of which do work with either the Orion Half Pier or the Vixen Half Pier, the spacing, center to center of the attachment bolt hole and the azimuth positioning holes which line up with the positioning peg is 1 & 5/8". On the AVX mount the center hole at the top of the tripid and bottom of the mount head and the azimuth positioning holes are 2 & 1/4" separation. The half pier itself is just shy of 4" diameter (3.94"). That means that the azimuth adjustment screws would have to engage a pin mounted to the outside of the pier.
Additionally since the top flange of the AVX tripod and the bottom flange of the AVX equatorial head are wider still, the small half pier would not offer a broad base of support. One of the advantages of the AVX over earlier mounts is this broader base of support. You would lose contact area using the smaller diameter half pier.
Finally, regardless of half pier, I think with few exceptions, they are all too tall. The taller they are the more shake and vibration that is introduced. I cut down the piers to approximately half their height for both my SP mount and my Losmandy GM 8 mounts. Less shake and (my opinion) looks better too. SP mount and baby half pier pictured.
Barry Simon
27 registered and 52 anonymous users are browsing this forum.
