Christof
journeyman
Reged: 11/28/13
EQ5 Motor Drive new
      #6222799 - 11/29/13 04:16 AM
Hello there,
I wonder if you could help me, I'm getting very desperate here.
I have a Skywatcher EQ5 motor drive system (looks same as this)
http://www.cloudynights.com/item.php?item_id=550
It works fairly ok, but the slew rate is deadly slow, feel like commiting suicide each time I attempt to use it. LOL.
Is there any way I could boost the speed ALOT, or even get some additional parts to replace/improve this system??
massively appreciate some assistance,
thanks in advance.
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: EQ5 Motor Drive new [Re: Christof]
      #6223349 - 11/29/13 12:42 PM
There is a way to boost the power to the drives to get higher slew speeds and goto functionality.
Picgotogroup@yahoogroups.com
Christof
journeyman
Reged: 11/28/13
Re: EQ5 Motor Drive new [Re: Geo.]
      #6223462 - 11/29/13 01:47 PM
Really! Any details/suggestions would be greatly appreciated. Thanks
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
      #6228908 - 12/02/13 11:32 AM
what drive rate do you have it on? I find 9 fast enough for most slews, 6 to move and 1 or 2 to centre.
Christof
journeyman
Reged: 11/28/13
Re: EQ5 Motor Drive new [Re: John Carruthers]
      #6233249 - 12/04/13 12:43 PM
Hi there JC,
On the controller there is 2x, 4x, 8x slew.
These are megga megga slow speeds. On my old Meade ETX 70-AT, That had a max 800x slew rate I seem to remember. Much better for quickly moving across the sky.
Helios Explorer 200 (8 inch)
EQ4 Mount (compatible EQ4/EQ5 motor drive)
Christof
journeyman
Reged: 11/28/13
      #6235495 - 12/05/13 02:09 PM
I've seen this Skywatcher GOTO kit,
http://rover.ebay.com/rover/0/e11051.m43.l1123/7?euid=28fc4a3cadf54f14bd5285e...
but anybody know if I could use my existing motors, and then buy the handheld bit of this kit??
cheers
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
      #6236608 - 12/06/13 03:56 AM
My bad, I thought you had the eq5 with goto handset.
Christof
journeyman
Reged: 11/28/13
      #6245289 - 12/10/13 05:18 PM
I wish, I'm beginning to discover, lol.
If anybody knows if I can combine these 2 kits, OR, buy a second hand GOTO one, please do advise.
I don't have a big enough bank to afford a brand new £299 GOTO kit.
dandabson
Reged: 10/15/08
Loc: Dover, DE
      #6245378 - 12/10/13 06:02 PM
Unfortunately you do not have goto motors. The ones you have do not have any encoders in them. I don't think you can speed up the current motors without burning them up. It is not financially feasible to upgrade a eq5 to goto now days. There are many used cg5 goto mounts for sale now. Your best bet is to pick up a used one.
Christof
journeyman
Reged: 11/28/13
Re: EQ5 Motor Drive new [Re: dandabson]
      #6247491 - 12/11/13 05:06 PM
Hey thanks for your comments Dan. Very good tips, might just have to start looking for a used mount then. cheers
namregd
journeyman
Reged: 02/23/12
      #6263701 - 12/20/13 12:54 PM
Hi Christof
Are you still looking to upgrade the EQ5? Have you heard of AstroEQ?
Doug
Christof
journeyman
Reged: 11/28/13
Re: EQ5 Motor Drive new [Re: namregd]
      #6322377 - 01/19/14 02:53 PM
Hey there Doug. I've had a good research into that thanks, not heard of that before. All looks pretty darn good!
I am tempted to just bite the bullet and buy the "Sky Watcher SynScan GOTO Upgrade Kit", but still trying to persuade myself to spend £300.
The Mighty Mo
Reged: 10/12/13
Loc: South of North, North of South...
      #6322535 - 01/19/14 04:14 PM
On the non-goto EQ5 drives, if you need to slew to a point further than nearby to your current location, just unlock your RA and Dec axes and manually reposition your scope the vicinity of where you want to go. No need to wait on the motors slewing a long distance
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: EQ5 Motor Drive new [Re: The Mighty Mo]
      #6324459 - 01/20/14 03:55 PM
Actually you don't have to "unlock" your clutches. Just keep enough tension on them to keep'em from slipping and you can move the mount manually without fooling with them. Losmandy mounts are designed to permit manual override of the clutches.
Eddgie
Reged: 02/01/06
      #6324477 - 01/20/14 04:04 PM
I do not know if your hand controller works this way or not, but many controllers do.
If you press the RA button to go east, try holding that button down, then pressing the opposite (West) button and holding it down as well.
On Celestron and some Vixen controllers, this put the scope in a "High Speed" mode that was usually 32X.
Many Celestron Go-To mounts do the exact same thing. Holding the button for the direction you want to go, then holding the opposite buttom puts you in high speed slew. This keeps you from having to change the slew rate if you need to move more than a little bit.
Losmandy mounts and the Ci700 would do this too I think.. know for sure my Ci700 worked this way, and again, 32x siderial.
So, not saying that yours will do this, but a lot of mounts do have this feature.
Free to try..
obin robinson
Reged: 10/25/12
Loc: League City, TX
      #6324509 - 01/20/14 04:21 PM
Hello Christof there is another option available. You can try your hand at making your own goto system for your EQ5. It's not as hard as you may think. You can recoup your money by selling your existing motors and controller to someone else who only has manual cables.
There are several members here including myself which have adapted older mounts with newer motors for goto. You will need an Arduino, some time on eBay, and a little patience. Check out the ATM forum here as there are many people who can help you out on this.
The 'worst' thing that can happen is that you learn a few skills and make a goto system for a fraction of the cost of buying one.
obin
Ian Robinson
Reged: 01/29/09
Loc: 33S , 151E
      #6324687 - 01/20/14 05:55 PM
Hi there JC,
Easier to disengage the clutch and use your manual slew cable to manually slew in RA and Dec if the distance to another object is more than a few degrees. Well that's what I do with my NONGOTO CG5 which has the identical motors as your EQ5 and the same handpaddle/controller.
BTW I've upgraded my handpaddle to make it able to interface with and do ST4 style autoguiding (was really easy to do) so I can now use my Orion autoguider with the old NONGOTO CG5.
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: EQ5 Motor Drive [Re: Eddgie]
      #6326394 - 01/21/14 03:11 PM
Well, I think the Synta drives system started out as a clone of the Vixen DMD1. It has been simplified by the use of a microcontroller. The instructions don't document a "fast" slew. Anyway, I don't think 6v is going to support fast stepping in a motor with 16-18 Ohm coils.
The Losmandy 492 digital drive and the CI-700 both are derived from the DC Ultima mount. The Ultima manual documents the 32X feature. The Celestar and Celestar Dlx also have it as they are Ultima derivatives. For a short period there was a Ultima like drive system for the CG-5, but I've never got my hands on the controller for a look/see.
10 registered and 18 anonymous users are browsing this forum.
