ngc6475
Fearless Spectator
Reged: 03/02/02
Loc: Northern Sierra Foothills
Re: Best Binoculars for Dark Sky new [Re: Erik D]
      #62505 - 02/28/04 11:32 AM
Paulsky,
I have a pair of Nikon Superior E 12x50 binos and they are a terrific pair of medium-high power glasses. They're not cheap, but they combine respectable power, light weight, and excellent optics. They are also center focus binos, unlike the Fujinons. The exit pupil is going to be on the small side (a touch above 4mm) but, for your purposes, that may not be as important as useful hand-held magnification. Eye-relief is about 12mm, if memory serves, and I believe the field of view is in the vicinity of 5*. The binos lack a threaded socket for mounting, however, but that isn't important to me and it sounds as if that may not matter to you, either. The Nikon Superior E series of binoculars have earned an excellent reputation for optical and mechanical quality and are definitely worth considering.
Walter
"Always do right. This will gratify some people and astonish the rest."
-Mark Twain
Rusty
Reged: 08/06/03
Loc: Brooker, FL
Re: Quick Set tripod Fix new [Re: Erik D]
      #62979 - 02/29/04 03:18 AM
Rusty,
Thanks for the tip. I did stop by a well-stocked local Ace Hardware first. Two of the clerks have no idea what NF thread is. I like your idea about plastic weld better anyway. It will look and work better if I can fix the orginal knob.
Erik D
If the Ace Hardware clerks didn't know what NF is, they're idiots. SAE ("English") bolts/screws come generally in two thread pitches for each diameter - NC - National Coarse, and NF - National Fine. For the 1/4" bolt, NC is 20 threads per inch; NF is 28 Threads/inch. This is not rocket science. The chances are they stock it - go to their bolt/screw section and you can find "socket head heat treated" bolts/screws in both NF and NC flavors.
If you can't find them, PM me, and I'll send you one for about $0.90 most of which would be for postage.
N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8(LRGBHa)/AO-7/DF-2/STV Dlx/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color/DSI II Pro
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
ngc6475
Fearless Spectator
Reged: 03/02/02
Re: Best Binoculars for Dark Sky [Re: Rusty]
      #63264 - 02/29/04 07:08 PM
I visited a website to check my numbers and the eye relief for the Nikon SE 12x50 binos is 17mm, the FOV is 5*, and the weight is about two pounds.
Walter
-Mark Twain
10 registered and 25 anonymous users are browsing this forum.
Moderator:  EdZ
Home
