djfolchetto
Reged: 03/03/09
Lodestar st4 and neq6
      #6327740 - 01/22/14 07:51 AM
I have trouble with the neq6 and Lodestar to calibrate the guide by MaximDL. I would know if the ST-4 guide port of neq6 mount is compliant with the Lodestar and with the cable provided with the camera. Can you support me, please?
Sergio
guyroch
Vendor (BackyardEOS)
Reged: 01/22/08
Loc: Under the clouds!
Re: Lodestar st4 and neq6 new [Re: djfolchetto]
      #6327783 - 01/22/14 08:20 AM
Sergio
Sure it is, I use it all the time.
The issue is most certainly not the ST4 port, but most likely a setting in PHD.
It's probably your calibration step size set too low but post a picture of your PHD settings so we know more about your settings.
Guylain
guyroch
Reged: 01/22/08
Re: Lodestar st4 and neq6 new [Re: guyroch]
      #6328056 - 01/22/14 10:56 AM
Also, check the connection of the cable on the Lodestar itself; make sure it is properly seated. That little cable is notorious for bad connection.
Guylain
djfolchetto
Reged: 03/03/09
      #6331910 - 01/24/14 04:20 AM
I tied the st4 and the USB cable together. In addition I tested the cable connection and the mount plug with the electrical tester and they seems work. I pointed M35 to try the guide calibration by Maxim DL and sometime I have the L without the right angle or irregular segments. Before starting the calibration, Maxim DL (version 5.14) asks me to cover the camera for bias. I changed the Cal Time and backlash along Y to, because on X the mount behaviour seems right.
Any suggestions to avoid additional night out in the cold?
Thanking you.
Sergio
9 registered and 19 anonymous users are browsing this forum.
Moderator:  tecmage, rflinn68
