KP0692
Reged: 01/04/14
Replacement for RA slow-motion cable? new
      #6324652 - 01/20/14 05:33 PM
Hi guys,
I bought an Orion 130ST Space Probe Newtonian reflector about two months ago and it has been great, but one of the things that has been a nuisance is the RA slow-mo cable. If the tube is pointed at a fairly high altitude to the northwest, it will bump in to the cable and prevent any further movement of the tube in that direction when the mount is polar aligned.
I was wondering if anyone of you have had this issue and have found an alternative to this cable that will allow unrestricted motion in all parts of the sky?
Kyle
Tom and Beth
Reged: 01/08/07
Loc: Tucson, AZ
Re: Replacement for RA slow-motion cable? new [Re: KP0692]
      #6324745 - 01/20/14 06:29 PM
This?
Or attach a shortie to the other side of the head
KP0692
Reged: 01/04/14
Re: Replacement for RA slow-motion cable? new [Re: Tom and Beth]
      #6324770 - 01/20/14 06:44 PM
That is the style of cable that came with my telescope. I'm thinking just a knob that threads in to the mount would be just fine. Any suggestions as to where I can find one?
Mike Lynch
Reged: 04/07/06
      #6324851 - 01/20/14 07:43 PM
Does the cable attach to the mount by "threading" into it, as you indicate? Or does it fit over a rotating metal shaft with one flat side?
If that's the case, there would be a set screw on the cable that is tightened against the flat side of the shaft. And you may find a knob at a place like Radio Shack that fits over that shaft and tightens with a set screw in the knob.
That's what I've done for this very purpose!
KP0692
Reged: 01/04/14
Re: Replacement for RA slow-motion cable? new [Re: Mike Lynch]
      #6324979 - 01/20/14 08:34 PM Attachment (9 downloads)
Thanks for the reply, Mike. It goes over a shaft and is fixed by a set screw on the cable.
Here is a picture of the cable attached to my equatorial mount.
rdandrea
Reged: 06/13/10
Loc: Colorado, USA DM59ra
      #6325007 - 01/20/14 08:46 PM
Call Bill Vorce at Telescope Warehouse. See what he has in the way of a cable that isn't on his web site. This is a fairly common part that comes in lots of flavors.
Mike Lynch
Reged: 04/07/06
      #6325116 - 01/20/14 09:49 PM
That picture seems to show that a knob by itself might rub against the setting circle, unless the shaft is long enough to allow you to tighten the knob back enough to avoid coming into contact with the setting circle.
If not, you might, indeed, need to search for a similar--but very short--slow motion cable.
KP0692
Reged: 01/04/14
      #6325281 - 01/20/14 11:34 PM
You are correct that a knob placed directly onto the shaft will bump the RA circle. I'm thinking a shorter cable would fit the ticket.
hottr6
Reged: 06/28/09
      #6325647 - 01/21/14 08:16 AM
focusknobs.com to the rescue!
Mike Lynch
Reged: 04/07/06
Re: Replacement for RA slow-motion cable? new [Re: hottr6]
      #6325667 - 01/21/14 08:37 AM
Heavens above!! There's a knob (and knob dealer!) for all seasons... uh, I mean REASONS!!
SteveG
Reged: 09/27/06
Loc: Seattle, WA
      #6326875 - 01/21/14 07:45 PM
The focusknobs are really nice - I was going to recommend them. Orion used to sell similar knobs - I have a brass version of the short one with no stem.
KP0692
Reged: 01/04/14
Re: Replacement for RA slow-motion cable? new [Re: SteveG]
      #6327168 - 01/21/14 09:48 PM Attachment (8 downloads)
Thank you all for the replies! I ended up going with a $3 knob from Radio Shack. Now my telescope is completely unrestricted with respect to it's range of motion.
Clear skies!
Kyle
Edited by KP0692 (01/21/14 09:51 PM)
Mike Lynch
Reged: 04/07/06
      #6327742 - 01/22/14 07:52 AM
Great, Kyle!
Glad that knob worked out!
csrlice12
Reged: 05/22/12
Loc: Denver, CO
      #6327787 - 01/22/14 08:21 AM
Won't that tend to vibrate a bit more then the older setup when making adjustments? But as long as it settles down quickly.......
KP0692
Reged: 01/04/14
Re: Replacement for RA slow-motion cable? new [Re: csrlice12]
      #6327830 - 01/22/14 08:44 AM
Smaller diameter knob = more rotations for same RA movement as the bigger knob. So yeah, if I really crank on it the telescope vibrates a lot but if I take it slow it isn't really noticeable. The mount that I have isn't very stable anyways and if there is a good amount of wind there is vibration present.
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
Re: Replacement for RA slow-motion cable? [Re: hottr6]
      #6328326 - 01/22/14 12:55 PM
Nice! This goes on my Favorites.
2 registered and 6 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
