Pages: 1 | 2 | 3 | (show all)
HunterofPhotons
Reged: 04/26/08
Loc: Rhode Island, USA
Re: How many AP Travelers new [Re: Jon Isaacs]
      #6341206 - 01/28/14 02:47 PM
...Do you see any big gaps in the database that indicate maybe each run started at 100, 200, and so on?
Someone correct me if I'm wrong, but aren't the the lens sets given sequential numbers early in the manufacture? When the sets are subject to attrition from anomalies, bad coatings, etc. that number is dropped from the finished list. In practical terms, if you have a run that begins with # 001 and ends with # 100, that doesn't mean there were 100 scopes produced since a number of them will have been lost to attrition.
dan k.
Reged: 06/16/04
Re: How many AP Travelers new [Re: HunterofPhotons]
      #6341407 - 01/28/14 04:30 PM
dan k.
Dan:
I am wondering if a run begins at 200 and if it's 50 scopes, the last scope will be 250... Does the next run start at 251 or 300? That was all..
photiost
Reged: 12/14/06
Loc: Montreal, Canada
      #6341630 - 01/28/14 06:45 PM
I have looked through a couple of travelers and they are excellent scopes for sure.
Anyone know why did AP stop making them?
Tak North
Reged: 11/28/07
      #6341658 - 01/28/14 07:03 PM
My Traveler is from the last production run AP did. Shipped on 4/1/2004 serial number 105EDF688. It's a lifetime keeper for sure.
Well, that has to be really close to the last one out the door for sure! Time to update the database I guess.
No need to go to all this trouble. I'm sure the NSA must already have all of this data collected.
gillmj24
Reged: 12/06/05
Loc: PA
Re: How many AP Travelers new [Re: Tak North]
      #6341850 - 01/28/14 08:42 PM
My guess to why they stopped making them is, Same amount of figuring work for less profit margin relative to the bigger scopes (you'd cry to see what prices they actually sold for new back in the day) and at some point there became a lot more 4" APOs on the market as someone said above.
I started way too late to get any scopes from them new. But I've been fortunate enough to own a traveler or two over the years. Missing them now
Edited by gillmj24 (01/28/14 08:44 PM)
ichdien
Reged: 11/27/08
Re: How many AP Travelers new [Re: gillmj24]
      #6341851 - 01/28/14 08:44 PM
Get out the hankies: $1900 in 1995.
silverking
Reged: 03/11/08
Loc: Canada
Re: How many AP Travelers new [Re: photiost]
      #6341852 - 01/28/14 08:44 PM
Photoist asked "Anyone know why did AP stop making them?"
R.C. started making the 105mm Traveler at a time when apochromatic scopes of such a size were somewhat scarce, if not nonexistent.
The Traveler enjoyed increasing demand as a few competitors in its size range started to appear in the marketplace, although none of them hit all the numbers as well as the Traveler did, often falling just short in one or another of the important categories amateurs demanded, lack of color, overall length, etc.
Over time, and in increasing numbers, 4" apos originating in Asia started appearing in the marketplace at a price point far lower than the Traveler.
As well as the lower priced Asian scopes, competent high-end makers were increasingly putting out similar scopes to the Traveler.
All this caused R.C. to reevaluate the marketplace for scopes under 130mm, and he eventually choose cease production of the Traveler, as he felt the limited marketplace had become saturated with far lower priced scopes that competed directly with the Traveler.
Further, in the minds of many potential purchasers, the Asian scopes operating at 90% to the Travelers 100%, and doing so at 1/5th the price was deemed by increasing numbers of amateur astronomers as "good enough".
As well, one could posit that AP has to operate at an appropriate profit. It would appear that management felt the efforts of the company would be more productively and profitably served and advanced with scopes sized 130mm and above, presumably with more attractive margins for the work involved.
Although the demand for the Traveler was still there in spades, the margins apparently weren't.
The above is my "Coles Notes" version, and has some personal opinions inserted......but has been stated in as much by R.C. in the years since the Traveler was discontinued.
Markab
Reged: 12/15/12
Re: How many AP Travelers new [Re: silverking]
      #6342080 - 01/28/14 11:08 PM
I think you nailed it!
Traveler
Reged: 08/19/07
Loc: The Netherlands
Re: How many AP Travelers new [Re: Markab]
      #6342271 - 01/29/14 02:17 AM
RC not only stops making Travelers but he also stops producing small high quality mounts like the 400QMD/CNC and 400GTO.
Always wonder why A-P is selling a 130mm GT Apo because as the same reason, there are many alternatives out there which are at least on the same level.
My Traveler snr starts with 105EDF and then a number low in the 400's. I bought it in 1999 after a 5 months wait.
M13 Observer
Reged: 12/09/06
Re: How many AP Travelers new [Re: Traveler]
      #6344097 - 01/29/14 08:55 PM
Umm, ever heard of the Mach1GTO? A little more weight, a lot more capability.
Really? There is a take-down 130mm extremely high quality, both mechanically and optically, telescope "out there" other than the AP130GT. WHAT IS IT?!?
Traveler
Reged: 08/19/07
Re: How many AP Travelers new [Re: M13 Observer]
      #6344453 - 01/30/14 01:47 AM
Tec 140, TSA120, Toa130,CFF127, CFF140, Officina Stellare Hiper APO 130, APM-Lzos 123, APM-Lzos 130...
Enough?
Of course i know the Mach1. A little more weight? Yes. But the point is that this Mach1(in the field) is not as small as the AP 400 mounts were. Did you compare the two in the field?
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
      #6344811 - 01/30/14 10:00 AM
AP lens sets only get serial numbers when all of the elements successfully come out of figuring. If Roland serialized them early, there would be random gaps throughout the serial number sequence, with about 15% to 20% missing, depending on the run. The point where they get serialized is where someone gets a call. Note, with the AP130 EDFGT at 468 after the last run, it's clear there are fairly substantial numbers of AP optics out there.
-Rich
M13 Observer
Reged: 12/09/06
      #6346048 - 01/30/14 09:13 PM
Enough?
Not one of those telescopes you mention is a take-down optical tube - NOT ONE - and you left out the Zeiss APQ. It can't be taken down either by the way.
At to the AP400 and the Mach1GTO, yes, I have. As a matter of fact I have one, of each! To top it off, I have had them both out "in the field", side by side, many times. Have you? And, to bring this back on topic, the Traveler is perfect on the AP400. I really like the shiny anodized black of each.
oldtimer
Reged: 11/13/08
Loc: Lake County Illinois
Re: How many AP Travelers [Re: M13 Observer]
      #6346090 - 01/30/14 09:40 PM
Were not the Travelers made in two differnt focal lenghts. Early ones being F5 and later ones being like 5.8 or so?
Traveler
Reged: 08/19/07
      #6346482 - 01/31/14 02:49 AM
Pardon me, I missed your "take-down" point But besides that i stand by my point that there are several great alternatives for the AP 130GT scope like there are also great alternatives for the traveler.
Yes i did make also a field compare with the two mounts.
That is true: an A-P Traveler on the A-P 400 mount is a perfect match Even after almost 15 years i much enjoy these perfect pieces of equipment.
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
Re: How many AP Travelers new [Re: oldtimer]
      #6346604 - 01/31/14 07:27 AM
You might have the Traveler confused with the 90mm Stowaway. It came in two focal lengths, f/5 and f/7.
My Traveler was one of the first 100 made and it's an f/5.81 (610mm focal length). The Astro-Physics website only mentions one focal length in their Traveler history.
As I mentioned in my earlier post, my Traveler is the best 4 inch scope I have ever owned or looked through. It can easily ride on my Gibraltar as well as the Mach 1 and delivers stunning views every night.
Ron
M13 Observer
Reged: 12/09/06
Re: How many AP Travelers new [Re: RAKing]
      #6346880 - 01/31/14 10:25 AM
Ron
My "new to me" Traveler is also a very early model with an anodized finish and with a serial number less than 10. The one I sold is a late model pebble finish with a serial number in the high 400's. They are both in the f5.8 to f5.9 range. I like the black anodized finish better although it shows fingerprints exceptionally well. There is only one possible contender for a similar telescope in all respects and that is the TEC APO110FL.
Paul G
Reged: 05/08/03
Loc: Freedonia
      #6346964 - 01/31/14 11:03 AM
Ron
Company 7 had either SN 001 or 002 on display at their showroom (not sure if it was stolen in the burglary) and it was ~ f5.8. The early ones were anodized, then a shiny black paint was used, then the pebbly black paint. My first Traveler from the late 1990's had the shiny black paint and was produced just after they changed the designation from EDT to EDF. My SN started with EDF but the engraving on the focuser still said EDT and hadn't yet been changed. I now have a newer pebbly paint version. I wanted to upgrade to the dual speed greaseless focuser and rather than buying a new focuser it was cheaper (net cost nearly zero) to sell my old one and buy a newer one with the dual speed focuser already installed. I like the pebbly paint better than the shiny paint which showed fingerprints like crazy and was very slippery when wet with dew.
The TEC looks like a very nice scope. One difference is the Traveler is aspherized and the TEC is not.
M13 Observer
Reged: 12/09/06
Re: How many AP Travelers new [Re: Paul G]
      #6347044 - 01/31/14 11:43 AM
I'll have to check on the old focuser body when I get an opportunity; I don't know what it says. It was changed out for the greaseless FT model by the previous owner but the original focuser came with the scope when I purchased it. Mine is not serial number 01 or 02 but it does not carry any sort of EDF or EDT designation on the edge of the lens. Now that you mention the painted version, I just had a closer look at it. I can't tell if it is a heavily polished tube which has been deeply anodized or a tube which has been painted gloss black. In fact, there is a strong possibility that the tube has been refinished and powder coated! In any case, it works very well indeed. I sent it away to Astro-Physics to have it re-collimated and some other mechanical work done. I am very glad to have it back. I never thought about the slippery with dew aspect. Dew is something I don't often encounter - and unfortunately so is really excellent seeing. I have some extra lightweight 7" SB. I'll have to look into making a carrying "handle" for it using one of them.
vahe
Reged: 08/27/05
Loc: Houston, Texas
      #6347118 - 01/31/14 12:18 PM
The difference between Traveler and TEC110FL is the ED element, Traveler employs FPL-53, TEC uses fluorite.
In an apo lens design when the speed is increased to near borderline, such as the Traveler the need for aspherization enters the picture, fluorite allows the design to go a bit further before the use of aspheric elements become necessary.
But do not take my word for this, here is what Roland had to say on this subject in a post on tec-ug (#9797):
“To make a fully color corrected triplet with oil space, where the color correction extends all the way to 400nm, the choices are threefold. You can use an FPL-53 aspheric oiled triplet design which makes production a bit slow and dependent on highly skilled opticians. You can use and FPL-53 airspace design with all spherical surfaces, which requires that all 6 surfaces be very smooth and accurate. You can use Calcium Fluorite oiled triplet with all spherical surfaces.”
Vahe
33 registered and 48 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
