jassan
Reged: 03/02/12
ASI120MM Issue new
      #6345916 - 01/30/14 08:02 PM
Have an ASI120MM, but have not been able to get it to record stable video. The video capture seems buffered, as in fitful, jumpy and generally erratic. FireCapture says drop the slider for USB traffic, but even on the minimum value the situation improves marginally. I've tried it two comps, so I dunno if its a hardware issue or what. Any advice?
yock1960
Reged: 06/22/08
Loc: (Mostly Cloudy) Ohio, USA
Re: ASI120MM Issue new [Re: jassan]
      #6345926 - 01/30/14 08:09 PM
Well, I would suggest that you join the Yahoo! group and post there. Torsten will work with you. I need to get over there myself, since anything over 2.3 beta 13 breaks things for me.
Steve
StrangeDejavu
Reged: 03/20/13
Loc: Florida
      #6346007 - 01/30/14 08:53 PM
How old is the laptop you're capturing with?
jassan
Reged: 03/02/12
Re: ASI120MM Issue new [Re: StrangeDejavu]
      #6346072 - 01/30/14 09:26 PM
Two years and three years respectively.
Angela G
Reged: 12/07/07
Loc: North Central Florida
      #6346114 - 01/30/14 09:49 PM
Are you using a long USB cable or a USB Hub? I have the ASI120MC and its behavior becomes very irratic if I try to use a long cable. Also these cameras do not work well when plugged into a hub.
jassan
Reged: 03/02/12
Re: ASI120MM Issue [Re: Angela G]
      #6346136 - 01/30/14 10:00 PM
I'm using the camera provided cable straight into my USB port.
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
      #6346246 - 01/30/14 10:54 PM
Two things, make sure you are plugged into the USB 2.0 port. And if this applies, the ASI camera will not work on HP machines with AMD chips. I had to ditch a $500, one year old HP laptop when I bought my ASI. Maybe not on any machine with an AMD?
jassan
Reged: 03/02/12
Re: ASI120MM Issue new [Re: CharlesW]
      #6346263 - 01/30/14 11:04 PM
AMD, huh? Well problem identified then. Is there a recommended windows processor as I've been wanting a new machine?
StrangeDejavu
Reged: 03/20/13
Loc: Florida
      #6346305 - 01/30/14 11:28 PM
Interesting, my NexImage 5 didn't work with AMD processors either. If you can afford it, try to get one with an i7-4700MQ processor and your choice of RAM. Depending on your budget, something like this would last a long time.
jassan
Reged: 03/02/12
      #6346896 - 01/31/14 10:31 AM
Is Win8 a problem?
4 registered and 11 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
