Equipment Discussions >> Classic Telescopes
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | (show all)
svdwal
Vendor (mBrain Software)
Reged: 03/10/13
Loc: Leiden, The Netherlands
Re: Is bigger better? new [Re: Petrus351]
      #6344915 - 01/30/14 11:11 AM
Yes, but what are the margins???
I mean, we´re talking about a 4" refractor in comparison to a C14? or are we talking about a 6" vs 8" scope?
What you say, can be true between small differences in aperture, but not between important ones.
It depends a lot on the scopes. A Ritchey-Chretien with a big central obstruction will have to be bigger than a Newton for it to beat a refractor. And a mass-market SCT with 1/4 lambda spherical abberation will have to be bigger than one with 1/10 lambda.
Apparently the heuristic of subtracting the central obstruction from the objective diameter works quite well.
Jim Curry
Reged: 10/29/07
Loc: STL
Re: Is bigger better? new [Re: Chuck Hards]
      #6345096 - 01/30/14 12:55 PM
I have the answer to that!
Chuck Hards
Reged: 05/03/10
Loc: The Great Basin
Re: Is bigger better? new [Re: Jim Curry]
      #6345123 - 01/30/14 01:11 PM
Lol, you and everyone else!
rcwolpert
Reged: 08/13/12
Loc: San Jose, CA
      #6345165 - 01/30/14 01:25 PM
With 50 years of observing behind me and often pondering this question of "Is Bigger Better", I've come to the following 5 conclusions that seem to work for me:
1. A small aperture telescope out under the stars seems to always out perform a much larger aperture telescope in the garage.
2. Larger aperture provides better resolution of clusters and double stars.
3. Larger aperture provides better views of galaxies and nebulae.
4. On nights of bad seeing, both will perform about the same if the same POWER is used. If the same EYEPIECE is used, the small aperture scope may provide a much better view.
5. On nights of good seeing, both large and small aperture telescopes can have you totally awed all night long when viewing the moon, Jupiter, and Saturn.
- Bob
BigC
Reged: 09/29/10
Loc: SE Indiana
Re: Is bigger better? new [Re: rcwolpert]
      #6345203 - 01/30/14 01:41 PM
+1
TCW
Reged: 11/05/13
Loc: The North 40
Re: Is bigger better? new [Re: actionhac]
      #6345206 - 01/30/14 01:43 PM
That is quite a scope! Can it reach zenith?
starman876
Reged: 04/28/08
Loc: VA
Re: Is bigger better? new [Re: TCW]
      #6345488 - 01/30/14 04:05 PM
For the next post it will be is smaller better
starman876
Reged: 04/28/08
Loc: VA
Re: Is bigger better? new [Re: starman876]
      #6345493 - 01/30/14 04:07 PM
Of course all the data that has been presented are theories that were developed many years ago. I have always wondered if these same theories still hold true with all the advancements in lens making and the exotic glass that is used today.
actionhac
Reged: 08/09/08
Loc: Seattle
      #6345789 - 01/30/14 06:49 PM Attachment (7 downloads)
Yes I make sure the tube will reach zenith. You can see its close! I can roast marshmallows up at the other end of the tube. It settles down quickly once the sun sets. I've got a few more refinements to make to it. Its a ongoing experiment and I enjoy trying new ideas with it.
Reged: 06/16/04
Re: Is bigger better? new [Re: SpooPoker]
      #6346153 - 01/30/14 10:07 PM
A 6" APO could be very well color corrected down to about f/5. A Newtonian on that same focal ratio would get absolutely hammered in terms of contrast, fine resolution, details etc...
Have you ever seen a 6 inch F/5 apo? They might exist but I don't know of any...
SpooPoker
Reged: 06/04/13
Loc: North Bay CA
Re: Is bigger better? [Re: Jon Isaacs]
      #6346191 - 01/30/14 10:27 PM
Here is a 6incher on a short FL:
http://www.teleskop-express.de/shop/product_info.php/info/p5630_TS-PHOTOLINE-...
Reged: 06/16/04
      #6346525 - 01/31/14 05:24 AM
It's actually a 130mm f/7 with a field flattener that can be screwed into the focuser. It's a 5 inch along the lines of the NP-127 but less intergrated and possibly not capable of visual use .
I don't know of any "native" 6 inch F/5 apos. It might be possible but the ones I see are relatively slow and within range of focal lengths where a planetary 6 inch Newtonian is possible.
Petrus351
Reged: 12/17/12
Loc: Spain
Re: Is bigger better? new [Re: Jon Isaacs]
      #6346575 - 01/31/14 07:02 AM
"Only for some objects, although undermagnification is often a problem, even for experienced observers. The penalty for increased magnification is reduced field of view and brightness; faint objects grow fainter as the magnification is increased This is why larger aperture telescopes are so effective on faint objects; they provide enough light to stimulate the eye at high magnifications. For example, a 4-inch telescope will only view a globular cluster effectively at 80X, and it will appear as a blob. A 6-inch will resolve the outer stars at 130X, an 8-inch will resolve further in at 200X. 10 and 12.5-inch telescopes will make them glitter to the core at 300 and 400X".
Copy and paste from the Sky Watcher home web page.
svdwal
Reged: 03/10/13
      #6347128 - 01/31/14 12:23 PM
Those theories still hold, AFAIK. What has changed is that ray tracing is much faster on a computer.
SpooPoker
Reged: 06/04/13
Loc: North Bay CA
      #6347478 - 01/31/14 03:50 PM
You are right, dunno where 130mm = 6" came from. Late night I guess. Yeah, it seems anything in APO world larger than 4" generally comes in f/7 - f/9 forms. I guess the reason would be correcting a 6" f/5 for visual would be prohibitively expensive or nigh on impossible to manufacture. A 6" f/5 on a crown flint form (achromat) would have phenomenal CA and there is only so much a triplet can do. I guess it is far easier to correct via triplet form a f/7 or f/8 than a f/6 or less.
In saying that, your TV 100mm f/5 APO does a good job on color correction - correct?
CHASLX200
Reged: 09/29/07
Loc: Tampa area Florida
Re: Is bigger better? new [Re: DAVIDG]
      #6347962 - 01/31/14 08:02 PM
Bigger is always better until ya have to move it around or set it up.
Chas
starman876
Reged: 04/28/08
Loc: VA
Re: Is bigger better? new [Re: CHASLX200]
      #6348242 - 01/31/14 11:02 PM
I would say bigger is better when you get around 20" and if it is your scope it is the best ever.
Datapanic
Reged: 10/17/09
Loc: Tucson, Arizona
      #6348372 - 02/01/14 01:01 AM
This thread belongs in the Beginners Forum!
Reged: 06/16/04
      #6348514 - 02/01/14 04:43 AM
It is excellent, even out of focus. But it's not really a 4 inch F/5.4, or at least the objective is not. It's a bit of a simplification but it's basically a long focal length apo double with a fancy ED focal reducer/field flattener at the rear of the scope. NP stands for Nagler-Petzval.
You could do a similar thing with a 6 inch apo but then you could do a similar thing with with a Newtonian but neither makes much sense.
SpooPoker
Reged: 06/04/13
Loc: North Bay CA
      #6350147 - 02/01/14 10:11 PM
Cool sounds like an awesome scope.
Is the FOV just like a f/7 or f/8 frac or does the design get around that? I am seriously considering getting one of these for a big FOV, but if it has the same FOV as a regular 4" ED doublet, then I may sit tight on my money
5 registered and 21 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), Brian Risley
