hottr6
Reged: 06/28/09
Whats missing on my Losmandy polar finder? new
      #6362196 - 02/07/14 03:20 PM Attachment (16 downloads)
I picked up this used Losmandy polar finder, and there seems to be a missing piece that prevents it from threading on to my G8 RA axis. What would you call the missing piece?
I'll call Losmandy and order the part, but I'll sound like an idiot if I say "I need this part, a piece that connects the polar finder to the 'scope... y'know, the thingamy..."
MarioHummer
Reged: 01/08/14
Re: Whats wrong with my Losmandy polar finder? [Re: hottr6]
      #6362265 - 02/07/14 03:53 PM
Hottr6,
You need a ring that sits right between the illuminator (the cylindrical part that sticks out to the side and on top of which an LED can be mounted) and the thread that can be seen on your picture of the polar scope (PS).
If you look at their page, http://www.losmandy.com/access.html, and scroll down to "PS", you'll be able to see it. It is not apparent in their enlarged jpg but the ring has an internal thread that, after you insert the PS into the polar axis bore hole, will fit the external thread at the end of the RA mount tube and secure the PS to it. You'll actually have to not tighten it too much in order to allow it to be turned as you adjust the RA axis towards the pole.
Hopefully you're confused enough by now... ;-)
Good luck!
hottr6
Reged: 06/28/09
Re: Whats wrong with my Losmandy polar finder? new [Re: MarioHummer]
      #6363863 - 02/08/14 11:41 AM
Confused? I'm always confused.
Best description that comes to mind is a coupler ring. I'll shoot Losmandy the photo. Thanks for suggestion.
MarioHummer
Reged: 01/08/14
Re: Whats wrong with my Losmandy polar finder? new [Re: hottr6]
      #6364402 - 02/08/14 04:21 PM
Yup, that'd be a good name alright. Losmandy doesn't seem to offer the piece by itself but if you ask for or email Scott, he'll know.
hottr6
Reged: 06/28/09
      #6369954 - 02/11/14 07:54 AM
Scott says it is an AP-made polar finder, from when Losmandy did not supply AP.
Jeff Crilly
Reged: 07/16/06
      #6392079 - 02/23/14 11:08 AM
Are you sure the "large exposed threaded part" does not unscrew from the polar scope part?
I bought a used ap900 once, came with a polar scope. At one point I upgraded the polar scope, and discovered the new one seemed to not fit. Then the folks at ap explained that there was this ring that needed to be removed from the old polar scope.. It was actually part of the mount.
It was really tight, bit did come loose.
Now if this was is clearly machined on... Then it's a different beast I suppose.
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: Whats wrong with my Losmandy polar finder? new [Re: Jeff Crilly]
      #6392345 - 02/23/14 01:11 PM Attachment (2 downloads)
Guess I'd call it the female threaded PS retaining ring.
19 registered and 43 anonymous users are browsing this forum.
