Telescope Specific Forums >> Meade Computerized Telescopes
Paulmurphy
Reged: 05/19/08
Corrosion on my lx200 fork arms new
      #6377361 - 02/15/14 08:50 AM
All
I have some corrosion appearing on my lx200 fork arms which i would like to deal with. Has anyone experienced similar and what is the general consensus on how best to treat this.
Several years ago i stupidly left batteries in the fork arms which leaked and has created "pitting and bubbling" on the surface. This is different to the corrosion i have elsewhere and would be grateful for thoughts on treating this too?
Many thanks from a wet and windswept Brit
Paul
SteveRosenow
Reged: 07/10/12
Loc: Shelton, Washington
Re: Corrosion on my lx200 fork arms [Re: Paulmurphy]
      #6377877 - 02/15/14 02:24 PM
Take a Dremel with a wire brush head to the affected areas, wipe clean with solvent, and then repaint it in textured black paint.
jaymcgil19
Vendor-LX200 CLASSIC ELECTRONICS EXCHANGE
Reged: 04/01/13
Loc: S/E Michigan
Re: Corrosion on my lx200 fork arms new [Re: Paulmurphy]
      #6381991 - 02/17/14 11:30 PM
If it looks anything like these two pictures your fighting a losing battle as it's a bad prep job from the factory and will continue to spread
[image]http://rs1121.pbsrc.com/albums/l502/67camaroinHS/Mobile%20Uploads/IMG_0094Small.jpg~320x480?t=1392697250[/image]
[image]http://rs1121.pbsrc.com/albums/l502/67camaroinHS/Mobile%20Uploads/IMG_0093Small.jpg~320x480?t=1392697249[/image]
SteveRosenow
Reged: 07/10/12
Re: Corrosion on my lx200 fork arms new [Re: jaymcgil19]
      #6382143 - 02/18/14 03:06 AM
Even that can be salvaged and re-finished. All you need is to remove the existing paint via sanding or grinding brush, then treat with the following:
http://www.por15.com/
Once you've done that, it can be painted normally.
0 registered and 9 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
