Observing >> Deep Sky Observing
Carol L
Reged: 07/05/04
Loc: Tomahawk, WI 45N//89W
Re: About to make an assault on the Horsehead new [Re: Rick Woods]
      #6341147 - 01/28/14 02:23 PM
And bigger than I expected.
That's what I thought, too - widefield images make it look like a tiny little notch. Glad you finally bagged it!
Sarkikos
Reged: 12/18/07
Loc: Scotophobe Maryland, USA
      #6341151 - 01/28/14 02:24 PM
Our plan was to use the 48mm Brandon, but the background sky was so black (a popular feature of Brandons) that we couldn't make it out. Pop in the 40mm, with its lighter background sky, and for some reason that made the difference.
Let's see, now I wonder what could be the reason? I'll just say that I began leaving my Brandons home whenever I went to the dark site.
We compared the view to the U2000 chart, made sketches of what we saw, and they matched. So we're calling it a success.
But boy, is it faint! And bigger than I expected.
Congratulations! I've been observing for over 40 years and I never saw the Horsehead until last Winter. To get a good idea of the scale of the Horsehead, I like to switch over to the Burning Bush Nebula se of Alnitak (Zeta Orionis). The central dark area is about the size of the Horsehead ... but a lot easier to see.
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: About to make an assault on the Horsehead new [Re: Sarkikos]
      #6344537 - 01/30/14 04:26 AM
Mike, I know you're baiting me for some reason, but I really don't understand what you mean. What are you saying? Or implying? If you don't plan on planetary viewing, you probably won't miss the Brandons.
But, the 31 Nagler didn't show the Horsehead, either. Maybe you'd want to leave that one home, too?
Sarkikos
Reged: 12/18/07
      #6344657 - 01/30/14 08:15 AM
Rick,
No, I didn't intend to bait ... maybe tease a little.
IME, the Brandons do not have the best light transmission. Your observation about the 48mm seems to confirm that. A black background is not necessarily an indication of high light transmission. Often it shows just the opposite. I've seen that the XW's, Delos, Sterling Plossls have higher light transmission than the Brandons. This shouldn't be surprising given the Brandon's simpler coatings.
Brandons for planet, lunar and double stars? Yes! For deep deep sky? No.
But at this point I've sold all my Brandons. I have other eyepieces for planet/lunar. I had too many eyepieces. I had to reduce the troops. Now I'm down to a small elite force of only 40 eyepieces.
Rick Woods
Reged: 01/27/05
      #6346345 - 01/30/14 11:55 PM
The thing is, when I've compared before, the 48mm B showed fainter stars and better contrast than the 40mm WF. Plus, we had an h-Beta filter on, which sort of renders any light-transmission comparisons irrelevant. So I can't explain it, except to say that the 40mm is the one for the Horsehead.
Sarkikos
Reged: 12/18/07
      #6346593 - 01/31/14 07:16 AM
I don't think the h-Beta would make light-transmission comparisons irrelevant. Those eyepieces with better light transmission should still show objects brighter. If anything, the filter will make transmission differences more obvious. That was the effect I noticed. I think that was also what you experienced.
Sarkikos
Reged: 12/18/07
      #6346645 - 01/31/14 08:02 AM
The WF's go back to 1982. I'm not sure if they have superior light transmission, either. Do they have that "coffee" tone?
Rick Woods
Reged: 01/27/05
      #6349835 - 02/01/14 07:17 PM
Not that I've ever noticed.
DG Aucoin
Reged: 03/20/13
Re: About to make an assault on the Horsehead new [Re: deepskydarrell]
      #6400169 - 02/27/14 01:02 PM
I observed IC434/B33 back in 1987 with a Coulter I 13" Telescope, a 9mm Nagler and an H-beta filter. I could just detect the nebulous curtain being bisected by the dark nebula.
I observed it again last weekend in my C11, with an 8.8mm ep and an H-beta filter. Could just barely see the curtain and used averted vision to just barely detect B33.
Re: About to make an assault on the Horsehead new [Re: David Knisely]
      #6401853 - 02/28/14 12:39 PM
I'll be giving it a whirl from the Sonoran desert at the end of March in a C9.25. You've encouraged me greatly.
- Jim
Sarkikos
Reged: 12/18/07
Re: About to make an assault on the Horsehead new [Re: jrbarnett]
      #6401875 - 02/28/14 12:49 PM
The end of March will be a little late in the season for Horsehead hunting.
      #6404665 - 03/01/14 09:38 PM
We'll see.
It's on my supplemental MM menu. I'll hunt for it during the M42, M42, M78 and M79 part of the Marathon search sequence.
I'll be below 34N.
- Jim
Sarkikos
Reged: 12/18/07
Re: About to make an assault on the Horsehead [Re: jrbarnett]
      #6405658 - 03/02/14 01:20 PM
I made my first attempt at the Messier Marathon last year here at 39N. It was easy sneezy with Sky Safari Pro on my Android tablet, using the program as an on-the-fly star hopping guide and memory jogger (no fancy electronics connection to a mount). IIRC, I completed about 88 with no gaps before I called it a night due to cold and fatigue. I'm certain I would have bagged them all if I'd stayed at the dark site all night.
Vondragonnoggin
Reged: 02/21/10
Loc: Southern CA, USA
      #6444705 - 04/03/14 03:06 AM
I just caught first sight with real recognition of it earlier tonight and a prominent flame nebula in my 6" mak with .5x reducer and IIE with 7nm H-Alpha.
Able to just fit flame and HH in same view. Backyard in LP
Worked better to see the detail by sort of rocking view slowly a little side to side like bagging galaxies, then once found the notch, could just make out head curve with nose, but still kind of hard to get any real detail. That region has a nice misty neb though and flame was easy to make out lighter bands separated by dark streaks.
Probably darker skies than backyard or faster focal ratio or bigger scope could have got some further detail.
Was pretty awesome to see it finally. First time solid view though and it was great. On the other hand, moving the scope down a bit to take in M42 was photograph like details. Crazy.
Astronomy rocks!
0 registered and 4 anonymous users are browsing this forum.
Moderator:  Dave Mitsky, Phillip Creed, okieav8r
