Hestemat
Reged: 03/28/14
which mount should i get?
      #6437582 - 03/30/14 11:30 AM
Hey ive ordered an AT65EDQ scope, looking for an EQ mount with guide ability, have my eyes on Advanced VX
but anyone got some cheaper that is just as good or good enough to be considered instead?
note: im shooting with a 550D dslr
terry59
Reged: 07/18/11
Loc: Colorado, USA
Re: which mount should i get? new [Re: Hestemat]
      #6437726 - 03/30/14 12:47 PM
The AVX mount has no DEC axis bearing. Good for visual, not for AP.
RTLR 12
Reged: 12/04/08
Re: which mount should i get? new [Re: terry59]
      #6437742 - 03/30/14 12:57 PM
I, and thousands of others, have been doing AP with the AVX's predecessor CG-5 that also has no DEC bearing for many years. There are many members here on CN that are doing AP with the AVX with great results. The lack of a DEC bearing does not rule the mount out as far as AP is concerned.
Stan
lurkinggrue
Reged: 07/14/13
Re: which mount should i get? new [Re: RTLR 12]
      #6437910 - 03/30/14 02:58 PM
Not arguing about the AVX and AP, just curious. Does the CGEM have a dec bearing? (asking because I am in a great conflict about which to get CGEM vs AVX for AP)
RTLR 12
Reged: 12/04/08
Re: which mount should i get? new [Re: lurkinggrue]
      #6438013 - 03/30/14 04:14 PM
Yes, 3 actually.
Stan
Mkofski
Reged: 07/19/11
Loc: Greenfield, Indiana, USA
      #6438037 - 03/30/14 04:25 PM
Have you considered the iOptron zEQ25? It's not cheaper but isn't as heavy as the AVX and is probably better for unguided work. It has a guide port like the AVX. I don't think you find anything new for less than the AVX that will work for AP.
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #6438345 - 03/30/14 07:51 PM
Stan
Stan I said it wasn't good for it, not that it or any mount without a DEC bearing wasn't usable....people do it all the time. I just won't recommend them for AP. I can't see complicating the learning process intentionally
orlyandico
Reged: 08/10/09
Loc: Singapore
      #6438406 - 03/30/14 08:26 PM
Ironically all of the Vixen GP mounts don't have bearings either. But people have been doing AP with them for decades.
oo_void
Reged: 11/13/09
Loc: San Francisco, CA
      #6438563 - 03/30/14 10:18 PM
Even though I'd normally pick a CGEM over the AVX, The CGEM might be a bit heavy for such a little scope making it hard to balance.
guyroch
Vendor (BackyardEOS)
Reged: 01/22/08
Loc: Under the clouds!
Re: which mount should i get? new [Re: oo_void]
      #6438580 - 03/30/14 10:26 PM
In between the CGEM and the AVX sits the proven Orion Sirius / SkyWatcher HEQ5.
Just a thought.
Guylain
RTLR 12
Reged: 12/04/08
      #6438603 - 03/30/14 10:42 PM Attachment (3 downloads)
I have to use a 7½ lb CW to balance my SV70 on my CGEM and I use 2" diag and some heavy EP. (Ethos)
Hestemat
Reged: 03/28/14
      #6438729 - 03/31/14 12:46 AM
Thanks, seems like i cant care about the bearing as then the price goes way up. Ive seen alot of pics with pinpoint stars shot with an avx, cant do much better than that. May be a little harder but thats ok.
RTLR 12
Reged: 12/04/08
      #6438779 - 03/31/14 01:48 AM
If it was easy, every one could do it!
Stan
Hestemat
Reged: 03/28/14
      #6438825 - 03/31/14 03:40 AM
Exactly, hard makes it fun. Can make decent unguided shots with my nexstar 4se in modified eq stand
Hestemat
Reged: 03/28/14
      #6438876 - 03/31/14 05:10 AM
Also wouldnt a heavier scope be more problem for the lack of a bearing?
With this light scope with a 50mm guidescope wouldnt pressure the dec that much, seen AP being done on this mount with 10" newts without mich of a problem
Eddgie
Reged: 02/01/06
      #6439171 - 03/31/14 10:25 AM
I believe this is incorrect. It may not have a "Ball Bearing" but it does have a sleeve bearing.
Sleve bearings are in fact quite suitable to the task of holding a telescope in a low speed operation.
In fact, a plain bearing has far higher load capacity than a roller bearing because the area.
In these scopes, the worm wheel is meachined into a large aluminum cylinder, and the outside of this cylinder rides on the sleve bearing in the casting.
Nothing wrong with this setup. Plain bearings are used in many important applications and have proven themselves as being very capable.
Just my opinion, but to say a mount is less than acceptable because it does not use a roller bearing in place of a plain bearing seems to me a bit unwarrented. I am confident that used within loading parameters (and that is why people publish load parmaters) the bearing will last a liftetime.
And the motors have far more torque than required to overcome the greater friction of a plain bearing.
But my main intention of resonding to your post was to say that the mount does indeed have a bearing. Just not a roller bearing.
terry59
Reged: 07/18/11
Loc: Colorado, USA
Re: which mount should i get? new [Re: Eddgie]
      #6439199 - 03/31/14 10:36 AM
I stand corrected and should choose my words more carefully. However, I stand by my assessment that this type of mount is not a good choice for AP.
gdd
Reged: 11/23/05
Loc: N Seattle suburb, WA
      #6439222 - 03/31/14 10:49 AM
Is it safe to say you may not need to make any DEC corrections with the AVX because it is a small mount you are more likely to use for wide field AP? But if you try overload the mount it may become an issue?
Gale
andysea
Reged: 09/03/10
Loc: Seattle, WA
      #6439227 - 03/31/14 10:52 AM
Are you going to have to travel to dark sites to image? If so portability and ease of setup/polar alignment may be one of the deciding factors when picking a mount.
I have to travel and I used to image with a mount that weighs 55lbs for the head only. Its payload was way beyond any of my scopes. I am much happier now with a lighter mount that still offers the same accuracy but it's much easier to setup and carry around.
keithlt
Reged: 12/21/13
Loc: Arizona
Re: which mount should i get? new [Re: gdd]
      #6439234 - 03/31/14 10:54 AM
I'm sure Celestron expected them to be used for AP as they come with an auto-Guider port. Eddgie makes a valid point about the sleeve bearings, I would not be surprised if the little DC drive motors in most every mount is of sleeve bearing design.
18 registered and 25 anonymous users are browsing this forum.
