Announcements and News >> Discussion of CN Articles, Reviews, and Reports
Olivier Biot
Amused
Reged: 04/25/05
Loc: 51°N (Belgium)
Innovations Foresight On-Axis Guider (ONAG) new
      #4951873 - 12/05/11 05:11 PM
By Frank Colosimo.
g__day
Reged: 06/19/07
Loc: Sydney
Re: Innovations Foresight On-Axis Guider (ONAG) new [Re: Olivier Biot]
      #4965499 - 12/13/11 11:06 PM
Frank,
Thank you for this excellent review. I am really interested in this type of set up, as I use a high quality OAG on a 2.3 M focal lenght SCT (C9.25).
The greatest challenges my set up has / had are:
1. Finding a suitable guide star
2. Focusing the guide camera and
3. Dealing with COMA on the guider
The ONAG from your review makes guide star selection a lot simpler and COMA is no worse then your orignal OTA.
But how simple is it to precision focus the guide camera once the main imaging camera has been precisely focused? Are there mechanical aids to precision (almost micro focus the guide camera) - like a threaded tube moving the guide camera in / out a few microns at a time?
For my set up (OAG) I focused the main imager using a Bhatinov mask on Antares - dead easy with a electronic, PC controlled focuser in the imaging train. The guide camera was far more challenging to focus.
In the end I put Jupiter in the OAG's guide camera's main field of view and used the Bhatinov mask again. Then it took an awfully painful two hours of rotten adjust by hand (loosen one screw on a Lumicon giant OAG, slide guide camera in or out a fraction of a mm) and try again. Only jupiter was bright enough to cast a differaction pattern on the OAG's guide camera.
A threading mechanisms to micro shift the guide camera once you have almost achieved focus was desperately needed (an a $5 oversight had the OAG manufacturer realised the need for it!).
So how did you achieve precise focus on the guide camera and was the ONAG machined with forethought to simply this frustratingly challenging set up task?
Many thanks,
Matthew
Bowmoreman
Clear enough skies
Reged: 09/11/06
Loc: Bolton, MA
Re: Innovations Foresight On-Axis Guider (ONAG) new [Re: g__day]
      #4986523 - 12/27/11 07:02 AM
I wonder without having thought it thru as not had my morning coffee yet... If the Baader or Borg 1.25" Helical focuses could be adapted? That is what I use on my eFinder for my STV. Made finding and keeping perfect focus easy...
Reged: 07/06/07
Re: Innovations Foresight On-Axis Guider (ONAG) new [Re: Bowmoreman]
      #4994131 - 12/31/11 01:39 PM
Great review and a very interesting product. For me, though, the 1K price is a deal breaker. I'll have to wait for the Chinese clone, I reckon.
Frank C
Vendor - star-watcher.org
Reged: 02/02/06
Loc: Pennsylvania
      #5006306 - 01/07/12 09:10 PM
Hi Matthew,
Sorry for the late reply as I did not check in for a while. I did not have any great difficulty achieving focus. I have a CFW and camera on the image side and this caused a certain amount of distance to be needed to get the guider at the same focus point. I made a rough measurement with a small ruler to approximate the focus position of the camera image plane and set the guide camera to the same distance, estimating from the center of the ONAG. I selected one of the T-ring extension tubes that came with the ONAG and then used the slider mechanism to make the final adjustment. I then pointed the scope at a bright star, got a good focus on the main camera, and then adjusted the focus tube to get a good focus on the guider. There is a little trial and error needed, but if you use a short exposure time in continuous exposure mode, and slightly tension the thumbscrews holding the guide focus tube, you can slide it back and forth and tighten it while watching the screen and get a really good focus.
BTW, I gave up on an OAG myself when I was imaging like you with an SCT (an LX200R). I really had problems with a pickoff-shadow on the imager if I slid the pickoff in too far, but out farther there were virtually no stars usable for guiding and the ones I could get were more like arcs than circles.
Frank
g__day
Reged: 06/19/07
Loc: Sydney
Re: Innovations Foresight On-Axis Guider (ONAG) new [Re: Frank C]
      #5017697 - 01/14/12 06:55 PM
Frank
Thanks for the reply - so you had to do precision adjustments using only your hands to try and slide the guide camera in or out a fraction of a mm (much like I had to do with my simple OAG)? Which is possible but very time consuming.
Why can't OAG or ONAG manufacturers provide for micro focusing on one of the attached camera tubes by simply inserting a threaded microfocuser?
An example would be http://www.telescope-service.com/accessories/start/accessoriesstart.html#schneckenfok
g__day
Reged: 06/19/07
Loc: Sydney
      #5023799 - 01/17/12 10:28 PM
Thinking about it further - thread the outside of the guide cameras tube, place a larger, matched thread tube on the outside and also add a locking bolt - you'd have a perfect platform for precision micro focus adjustments of your guide camera for all of $2 cost!
Or maybe I misunderstood what you meant by you moved the slider in and out - are you confirming there is a mechanism for very fine focusing the guide camera? Is that what the slider you mention is?
BTW I mention this thread and the ONAG to one of our folk in the Australian Astronomy (David) from Ice In Space - and it looks like he'll be the first person in our country to buy onefor his 14" ota - lucky guy!
Corsica
Vendor (Innovationsforesight)
Reged: 03/01/10
Loc: PA - USA
      #5024766 - 01/18/12 01:18 PM
Hi Matthew,
You have a valid point about making the guider focus easy.
The ONAG uses a compression ring associated with a drawtube for the guider camera as the primary mechanism for focusing it.
However the T-mount (T-threaded) connection for the guider (at the ONAG’s guider port GP) has been designed with extra threads in order to be able to adjust the guider in a more precise way, if and when needed, the low profile T-ring (provided) will then lock the guider in place. The motion of the T-mount thread is 0.75mm per turn.
From what I read this is consistent with your suggestion, am I right?
So far user feedbacks and my experience have found the guider focusing is pretty simple and fast to do, for instance you can read Ken’s feedback on that matter on our website (http://www.innovationsforesight.com/user_feedback.htm).
Of course I would certainly consider more complex mechanisms for focusing the guider, however there is also a need to keep the back focus minimum. Any suggestions and comments are most welcome to improve the product, nothing is ever perect.
Clear skies!
jeriverafl
newbie
Reged: 08/09/08
Loc: Florida
Re: Innovations Foresight On-Axis Guider (ONAG) new [Re: Corsica]
      #5173033 - 04/15/12 01:26 AM
Hi. First time posting here. I occured to me that it may be possible to turn a binoviewer into a ONAG. Any thoughts?
Jose Rivera
Central Florida Astronomical Society
KDizzle
Reged: 09/12/08
Loc: Woodinville, WA
Re: Innovations Foresight On-Axis Guider (ONAG) new [Re: jeriverafl]
      #5174449 - 04/15/12 10:31 PM
Seems like that would probably work. But keep in mind that a binoviewer delivers just under 50% of the of the incoming light to "each eyepiece". The ONAG purports to cut a different /wavelength/ of light, thereby delivering 90+% of the incoming light to the imager.
jeriverafl
newbie
Reged: 08/09/08
Loc: Florida
Re: Innovations Foresight On-Axis Guider (ONAG) new [Re: KDizzle]
      #5193674 - 04/27/12 04:18 PM
So that would be equivalent to imaging at double the focal ratio of the telescope, correct?. I would have to give it a try someday.
KDizzle
Reged: 09/12/08
      #5194328 - 04/28/12 02:18 AM
No. But let me premise this all with I've never used one before, so this is just my understanding. Someone can probably correct me where I'm wrong... Think of it like a diagonal mirror. Normally the diagonal directs almost 100% of the light at a 90 degree angle and 0% straight through. Now pretend that the diagonal is partly transparent, and about 50% goes up and 50% goes straight through. This would be pretty close in concept but would have the problem of cutting the visible light at your imager/eyepiece in half. Instead the ONAG puts nearly 100% of the visible light through, BUT the deep red/ir it redirects ~100%. This way you end up with good guide stars across the whole field and don't cut your imaging time down.
g__day
Reged: 06/19/07
Loc: Sydney
      #5590683 - 12/27/12 02:28 AM
Will be seriously looking into this mid 2013 - my next new purchase.
I wonder how many folk here have tried one and with what results?
A recent scan on google turned up this interesting post from October 2003 http://www5f.biglobe.ne.jp/~kztanaka/onaxis.html
They stated "the thickness of the Beam Splitter causes astigmatism because of its tilt, so the on-axis has been never developed yet. See the second image, you see the oblate stars near the focus point by single Beam Splitter ...To cancel this astigmatism, another tilt Beam Splitter, so-called astigmatism-correcting plate(maybe as-correcting plate), is needed. I made a prototype on-axis guider and tested taking images. One of them is at bottom de-focusing image in the upper image. It was successful, and I convinced that the on-axis guider was most convenient for tracking stars."
He posted this link on the beam splitter's astigmatism
and the double beam splitter he refers to is depicted
To my question - is this something Foresight or buyers have investigated and have a view on?
Qu 1. How much astigmatism does the beam splitter they use produce (when focused correctly)
Qu 2. To Foresight really - have they tried a dual splitter as designed above and seen a marked improvement in astigmatism management?
Many thanks,
Matthew
MikeCMP
Reged: 07/12/11
Loc: Chardon OH
      #5590811 - 12/27/12 08:09 AM
Matthew,
I was under the impression that the astigmatism was only seen on the guide camera. The imaging camera is just getting the light bounced off of a mirror, so there is no astigmatism introduced. However, since the light is passing through the mirror to the guide camera and the mirror is tilted you see the stars as astigmatic.
At least that is my understanding, from reading a few reviews of this device.
I also found an article where a gent converted an old vixen 2" diagonal to something very similar to this, with a mirror he bought from edmund scientific. It only worked ok due to the construction techniques used, but it was far less expensive.
g__day
Reged: 06/19/07
Loc: Sydney
Re: Innovations Foresight On-Axis Guider (ONAG) new [Re: MikeCMP]
      #5591523 - 12/27/12 05:36 PM
Mike,
That is my understanding too, the astigmatism is seen on the guiders light path, unless a double beam splitter is used as the diagram above depicts.
So Qu 1. still stands - how much astigmatism is introduced (and is it an even spread that will allow a centroid calculation used by a guide program to be run effectively).
So this lends one to ask does matter significantly or is it barely discernible? If the centroid of the star can still be reliably measured (something I believe PHD can do with soft or bloated stars, not sure about how it handles a range of ovals depending on how the X and Y axis (i.e. where the hump is) shifts?) - its not too worrying. I just like attainable precision - were its possible. Ponder though if for PHD or MaximDL if its needed? I would like to hear the manufacturers views, as the imaging results look very good - I suppose everything is quite okay. I would like to see some information on this (shots of the guide camera on a bright star around and at the focal point). So the user understand exactly what to expect when they buy the product!
Matthew
Corsica
Reged: 03/01/10
Loc: PA - USA
      #5815508 - 04/22/13 03:09 PM
We used to sale a corrector plates as accesories for the ONAG guider port (GP) to remove the guide star astigmatism. There are 3 M2 holes on the guider drawtube for this adapter.
However we never sold any because ours customers did not need this to achieve a good tracking. Auto guiding algorithms are based to centroids and are not much sensitive to guide star deformation, unless it is so big then the SNR drops dramatically (like extreme coma coming from off-axis imaging on SCT or a like).
You can find more information on that matter on our FAQ page, question/answer #3:
http://innovationsforesight.com/faqs.htm
Although the FWHM is larger for the guide start the ½ FD is very close and the SNR is preserved leading to good tracking with the ONAG without any corrector on its GP. There is also the same feedback from Dennis’s article on its test review of the ONAG (Sky and telescope, December 2012).
The fact that at best focus the guide star looks like a tight small cross is in fact a feature that you can use to make guide star focus easier and handy.
The new larger ONAG XT comes in standard with build-in corrector in the GP. This has been a request for applications involving NIR imaging from the GP, while guiding in the visible from the ONAG imager port (IP).
Finally I would like to make one more comment about guiding in NIR, see more at:
http://innovationsforesight.com/NIRGuiding.htm.
Seeing is reduced at longer wavelengths and this provides a unique opportunity to improve guided tracking, as see in the M83 example on a 32” f/6 scope shown in the link above.
I hope this helps.
Clear skies!
Ron (Lubbock)
Reged: 08/17/12
Loc: West TX
      #5816254 - 04/22/13 08:03 PM
I bought an ONAG last fall for use with my 17 yr. old C8. I use an inexpensive Orion SSAG with it, and finding a guide star takes 3 to 5 minutes at worst. I think there is no need to go to a more expensive autoguider with 8" aperture. I regularly acquire 15 minute subs. with good results using a CGEM mount. Here's a recent image of M101 taken with 15 minute subs (linked below). The stars are as tight as I can get with my optics and mount, which are not the best or most expensive. Overall, I love the ONAG and it has made me forget about any guiding troubles in my past. Disclaimer: no affiliation with the seller.
Link to AstroBin M101
Dave Hudson
journeyman
Reged: 09/10/13
      #6458357 - 04/10/14 11:27 AM
I know this is an old thread, but has anyone bought from them recently? I just ordered their ONAG XT and its a black hole - no response from them...
Not a happy camper to submit my CCARD number to a company and after 3 days, numerous emails and phone calls, I can't get a response from the company....
Corsica
Reged: 03/01/10
Loc: PA - USA
Re: Innovations Foresight On-Axis Guider (ONAG) [Re: Dave Hudson]
      #6479831 - 04/21/14 07:49 PM
Hello Dave,
I am not sure what was wrong. We replied to your emaif of April 9th the next day, but maybe it has been lost or identified as SPAM, here is a copy below:
Dave,
We are shipping today.
Best Regards,
Tom Cockley
Innovations Foresight LLC
225 Cadwalader Ave
Elkins Park, PA 19027-2020 USA
215-884-1101
-------- Original message --------
Date:04/09/2014 5:05 PM (GMT-05:00)
To: customerservice@innovationsforesight.com
Subject: Customer Contact from Innovations Foresight web site.
MessageType: Purchase
Comments: Hello,
I placed and order for the ONAG XT yesterday and recieved a confirmation email, but did not receive any information on expected ship dates. Can you provide that to me?
Order Number
..........81
Order Date and Time
04/08/2014 03:39:32 PM
Dave Hudson
You should have got your product by now, please conact me directly otherwise.
Besrt Regards, Dr. Gaston Baudat
Vagus
Reged: 04/02/11
Loc: Ontario, Canada
      #6563704 - 06/04/14 07:08 PM
So Dave, did you receive the ONAG and if so what do you think of it?
0 registered and 4 anonymous users are browsing this forum.
Moderator:  droid
