DNA array
journeyman
Reged: 05/08/14
1.25 visual back upgrade new
      #6515527 - 05/09/14 10:23 AM
Hi All,
Upgrading my stock 8SE diagonal with a 1.25 Baader prism. I want to get rid of the stock visual back connector as I don't like the set screw arrangement. Found this suggestion from older posts here, Baader clicklock.
http://agenaastro.com/baader-1-25-click-lock-eyepiece-adapter-visual-back-t-2...
How does this physically attach to the back of the scope? With the original collar or another adapter? Any other solutions would be greatly appreciated.
Thanks in advance.
-Dave
DNA array
journeyman
Reged: 05/08/14
Re: 1.25 visual back upgrade new [Re: DNA array]
      #6515640 - 05/09/14 11:38 AM
Here:
core
Reged: 02/23/08
Loc: Mostly in Norman, OK
      #6516257 - 05/09/14 05:00 PM
If you're look for a 1.25" ClickLock, that's the one. However the mating end is T-2 threads. You'll need a SCT to T-thread adapter; there are several available depending on how much of an extension you want. iirc the stock 8SE 1.25" visual back already has T-threads on the back of it. The other alternative is to get the 2" Baader ClickLock that threads directly to the 8SE, then get a 2"->1.25" adapter - in this case I like the Antares twist-lock variety.
DNA array
journeyman
Reged: 05/08/14
Re: 1.25 visual back upgrade [Re: core]
      #6516275 - 05/09/14 05:15 PM
Thanks for the input, Peter. It was also suggetsed over in equipment that a T2-21 adapter would work for me. Have some options now.
-David
6 registered and 20 anonymous users are browsing this forum.
