stargazer193857
Reged: 12/01/13
Loc: Southern Idaho
20x80 or 6" f5 for the Pleiades? new
      #6600641 - 06/25/14 03:15 AM
Which do you think would give you the better view? I think a 25x100 would do better than the 20x80, but at a much higher price.
Brian Carter
Reged: 11/24/04
Loc: Atlanta, GA
Re: 20x80 or 6" f5 for the Pleiades? new [Re: stargazer193857]
      #6600760 - 06/25/14 07:24 AM
For the Pleiades: good binoculars will show it best, nice wide fields. It's the smaller clusters that need a telescope.
Reged: 06/16/04
Re: 20x80 or 6" f5 for the Pleiades? new [Re: Brian Carter]
      #6600775 - 06/25/14 07:48 AM
I own a pair Japanese 20x80s that are pretty decent. My favorite views of the Pleiades are in telescopes. For the entire cluster, a 4 inch refractor with quality widefield eyepieces are my favorites. An excellent pair of 80mm or 100mm binoculars with angled eyepieces might be better but most binoculars are too optically compromised. For the reflection nebulae, something much larger shows them best.
Tony Flanders
Reged: 05/18/06
Loc: Cambridge, MA, USA
      #6600777 - 06/25/14 07:51 AM
Both 20x80 binoculars and a 6-inch f/5 scope will give fine views of the Pleiades -- as long as the scope has a 2-inch focuser. With 1.25-inch eyepieces, the field of view is too cramped to appreciate the Pleiades properly.
A slightly smaller scope might be best of all; the Pleiades are wonderful in my 4.5-inch f/4 StarBlast and in my 70-mm f/6.9 refractor. I agree that 25X is just about optimal, but 20X is fine, too.
Illinois
Reged: 12/18/06
Loc: near Dixon, Illinois USA
Re: 20x80 or 6" f5 for the Pleiades? [Re: Tony Flanders]
      #6600791 - 06/25/14 08:08 AM
6" f5 for me because I can use low up to high power! Around 25 to 30 power is great view Pleiades!
Midnight Dan
Reged: 01/23/08
Re: 20x80 or 6" f5 for the Pleiades? new [Re: Illinois]
      #6600847 - 06/25/14 09:06 AM
My 2 cents: the 6" f/5.
-Dan
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: 20x80 or 6" f5 for the Pleiades? new [Re: Midnight Dan]
      #6600871 - 06/25/14 09:33 AM
Uh, both....because you won't always be looking at one object in the sky.......
BigC
Reged: 09/29/10
Loc: SE Indiana
      #6601119 - 06/25/14 11:50 AM
15x70 binoculars are easier to hold ;a fast f4 or f5 scope lets you use higher power.Really hard to select a do-it-all set of optics.
izar187
Reged: 09/02/06
Loc: 43N
Re: 20x80 or 6" f5 for the Pleiades? new [Re: csrlice12]
      #6601128 - 06/25/14 11:55 AM
There you go.
Both work best mounted, and this 6 is only about ten pounds, so not hard to mount.
But it will reach out to places places the 20x80's can not go.
gene 4181
Reged: 11/12/13
Loc: n.e. ohio
Re: 20x80 or 6" f5 for the Pleiades? new [Re: BigC]
      #6601190 - 06/25/14 12:31 PM
its only my opinion, but the 6in f5 with a 2in focuser is a do-it all optic. some might say not as wide a field as a st 80 or short 102 , but gathering 6in of light and resolution has made it a keeper in my use.
Love Cowboy
Reged: 05/05/14
Loc: Houston, TX USA
Re: 20x80 or 6" f5 for the Pleiades? new [Re: gene 4181]
      #6601233 - 06/25/14 12:57 PM
I've looked at the Pleiades a good bit in my day, and my favorite view of them ever came in a pair of 15x70s
gene 4181
Reged: 11/12/13
Loc: n.e. ohio
Re: 20x80 or 6" f5 for the Pleiades? new [Re: Love Cowboy]
      #6601284 - 06/25/14 01:31 PM
i guess my response is jaded by the fact of utility and ease of use . hand holding a more than 10 power bino isn't my cup of tea.
Tony Flanders
Reged: 05/18/06
      #6601389 - 06/25/14 02:34 PM
It's only my opinion, but the 6in f5 with a 2in focuser is a do-it all optic.
"Do it all" is a bit of an exaggeration; for instance, it's not a good choice for viewing the Coma Star Cluster, nor for resolving stars in the fainter half of the Messier globular clusters. But it is mighty versatile.
If I had to keep just one of my current scopes, it would almost certainly be my 7-inch f/5.4 Dob.
gene 4181
Reged: 11/12/13
Loc: n.e. ohio
Re: 20x80 or 6" f5 for the Pleiades? new [Re: Tony Flanders]
      #6601562 - 06/25/14 04:40 PM
well then, within reason its a mostly do it all scope. thank you tony
Reged: 06/16/04
      #6602202 - 06/26/14 12:15 AM
My "do it all scope" is a 4 inch refractor and a Dobsonian with some reasonable (or not so reasonable) aperture.
16 registered and 27 anonymous users are browsing this forum.
Moderator:  WOBentley, kkokkolis
