General Astronomy >> Light Pollution
stargazer193857
Reged: 12/01/13
Loc: Southern Idaho
How much would you pay for a perfect LP filter? new
      #6620410 - 07/06/14 08:23 PM
If you could have a filter that blocked 100% of light pollution and let all the good light in, what would be a fair price?
Note:
This filter works best in black and white, or on colored images where the LP is not that bad and you just want to be able to see the black areas better.
If you point it at a street light, you still see the street light at nearly full brightness. The filter does not block the frequencies that light pollution is. It only blocks the background sky glow at a fixed absolute intensity instead of the percentage intensity most filters work at. If you point them at a brighter part of the sky, you have to grab a stronger filter. The filter does no work well near the horizon because the sky glow intensity changes to quickly with angle there. You deal with street lights by putting wings on the sides of your eyepieces.
Imagine stepping outside your house in a Bortle red area, putting wings on the eyepieces of your 7x35 binoculars, filters over the objectives, reclining in your chair, and scanning the zenith, and not seeing any background sky glow. The sky looks rather pristine, maybe losing just some of the finer faint background features, but plenty of stars and DSO none the less.
Imagine taking a digital picture of the zenith, programming a computer to find the darkest 20% of pixels (presumed not to have stars), average the intensity of those pixels, and then subtract that value from every pixel in the picture. This filter would do that chemically, just passing the light above that intensity threshold. They would be sold by the strength, named by the Bortle color. Buy as many different strengths as you want.
I have an idea for how to construct these, but there are a lot of specifics and possible problems when trying to get around the Beer-Lambert law.
Tony Flanders
Reged: 05/18/06
Loc: Cambridge, MA, USA
Re: How much would you pay for a perfect LP filter? new [Re: stargazer193857]
      #6621216 - 07/07/14 11:13 AM
You don't have to imagine that, since it's precisely what many suburban astro-imagers do.
I don't much care for the effect; instead of a low-contrast image on a bright background you get a low-contrast image on a painful, artificially dark background. But the light pollution itself is still evident in the low signal-to-noise ratio.
stargazer193857
Reged: 12/01/13
Loc: Southern Idaho
Re: How much would you pay for a perfect LP filter? new [Re: Tony Flanders]
      #6622700 - 07/08/14 02:21 AM
I think they are subtracting too much. They should take the value they are subtracting and half it, then look again. They are taking the average of a semi dark area, not the darkest 20% of pixels. Finding those 20% is probably not one of the preprogrammed in options in their software.
stargazer193857
Reged: 12/01/13
Loc: Southern Idaho
      #6622703 - 07/08/14 02:23 AM
A lot of photograph show bloated stars. That right there tells me they are doing something wrong. I want to get into astrophotography some day, but from a programmer's angle.
Tony Flanders
Reged: 05/18/06
      #6622816 - 07/08/14 06:07 AM
You can adjust it at will with a slider; it's a trivial job in Photoshop. Just overlay an averaged background as a separate layer, select "Subtract" mode, and move the percentage slider. Trust me, the sweet spot that exists in your mind doesn't exist in reality.
You should understand this if you know any math. Your target is the signal; light pollution is noise. Light pollution reduces the signal-to-noise ratio, and no algorithm in the world -- mathematical or chemical -- can recover it.
Reged: 06/16/04
Re: How much would you pay for a perfect LP filter? [Re: stargazer193857]
      #6622854 - 07/08/14 07:05 AM
Bloated stars do not come from light pollution.. Bloated stars are what the eye sees as well.. Ask yourself why Rigel A should look so much larger in diameter than Rigel B. A camera with it's increased sensitivity also sees larger as brighter. Of course sometimes it's due to the quality of the optics.. achromats..
stargazer193857
Reged: 12/01/13
Loc: Southern Idaho
Re: How much would you pay for a perfect LP filter? new [Re: Jon Isaacs]
      #6624348 - 07/08/14 10:49 PM
Photoshop you say. I want to download some light polluted zenith photos, take them to my school's computers, open Photoshop, and play around with that.
Are you saying that light pollution is not smooth, even in a one degree FOV?
Tony Flanders
Reged: 05/18/06
      #6624648 - 07/09/14 04:51 AM
No, light pollution is extremely smooth. That does not alter the fact that you can't simply "subtract it out."
You need to look up signal-to-noise ratio and bury your brain in a little hard-core mathematics.
hfjacinto
I think he's got it!
Reged: 01/12/09
Loc: Land of clouds and LP
      #6625501 - 07/09/14 04:26 PM Attachment (9 downloads)
There is a gradient with light pollution. Remember most images start at one position and over the night move. Therefore most images taken in light polluted areas get an LP gradient. Which is possible to remove in photoshop.
hfjacinto
Reged: 01/12/09
Re: How much would you pay for a perfect LP filter? new [Re: hfjacinto]
      #6625503 - 07/09/14 04:27 PM Attachment (14 downloads)
The above was taken from my home in suburban NJ, I was able to remove the LP gradient and get a dark background, but its harder to do that on nebula, so a dark site is better.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
      #6646000 - 07/21/14 06:47 PM
Gradients in small-angle FOVs are due almost entirely to instrumental vignetting, at least when largely circularly symmetric.
Simply subtracting intensity from pixels does not selectively reduce light pollution. It alters the contrast, by darkening the dim end relatively more than the bright end.
Star bloat is not necessarily a sign of poor technique. If fainter stars are pinpoint, the brighter ones are enlarged due to scatter and spillover.
An LP filter does nothing if it does not dim the direct view of a light; it would be perfectly clear glass.
The 'perfect' LP filter does not exist. The bad light is present over too much of the visual spectrum, and varies from place to place due to different light sources used in differeing proportion.
The closest we could get to 'perfection' is when all artificial light is emitted only at discrete wavelengths of reasonably small number. Then a filter could be devised which selectively blocks only those wavelengths, with the narrowest of notches in its transmission curve possible. Then might we realize a near-90% transmission of continuum sources (e.g., stars).
3 registered and 3 anonymous users are browsing this forum.
Moderator:  LivingNDixie, richard7
