Equipment Discussions >> Electronically Assisted Astronomy
TL2101
Reged: 09/17/10
Loc: Concord, CA
Lets Talk Equipment new
      #6616863 - 07/04/14 05:10 PM
I am going to get a Mallincam Xtreme camera. I have never seen one in person only on the NSN. So without any hands on knowledge I need help in putting together a list of what I will need. My scope is a C8 mounted on a CGEM and I have a 6.3 F/R. I do not have a guide scope but want to stack using miloslick.
I am leaning towards getting the mono camera because of the shorter integration times and the images I have seen on NSN. Do I get the HAD sensor? The X2?
What guide scope do I get, which F/R to complement my 6.3 F/R and what software do I need? What am I missing? I live in a red zone bordering an orange zone. I am also in the process of building an observatory.
Thanks for your help.
Edited by TL2101 (07/04/14 05:39 PM)
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: Lets Talk Equipment new [Re: TL2101]
      #6616913 - 07/04/14 05:48 PM
Joe,
What kind of observing do you want to do?
- with friends and family?
- kids and/or adults?
- quick viewing or do you take your time?
- do you want to create pretty images to show folks later on?
- favourite objects ... globulars, galaxies, extended nebulae, Nova, planets, moon/sun, etc?
How are you thinking about displaying the video?
- on a laptop?
- larger video monitor? (do you already have the monitor?)
- at the scope or in the house?
What's your budget like for the accessories (after the MCX purchase?) ... not looking for specific $, just a general idea.
What are your night time temperatures like (summer though winter)?
How long have you had your CGEM?
- done any imaging with it?
How technically inclined are you?
- like to tinker and put things together or prefer to have things in a turn key mode?
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #6616919 - 07/04/14 05:55 PM
HAD isn't important. X2 is better cooling. Just get a finder guider setup. Orion's finder guider works well, for a camera I'd get an ASI120MM or a QHY5LII. Finally, look up how much spacing you need from the f/6.3 for the camera and get the right extension tubes.
If you're going to guide, don't worry about how long of exposures you're going to have.
TL2101
Reged: 09/17/10
Loc: Concord, CA
Re: Lets Talk Equipment new [Re: mclewis1]
      #6616935 - 07/04/14 06:07 PM
I will observe from my observatory and on occasion my wife will join me. I want to capture photo's but not interested in post processing. I am primarily interested in galaxies & all the different types of nebula. I want to display at the scope from either my laptop or a monitor or both.
I live in central California so hot summers and mild winters.
I would prefer turn key but can tinker if I have to. I have successfully imaged with my DSLR. I can do a pretty good job polar aligning my scope. My budget is flexible. I am semi-retired and want to get all my gear together before I fully retire.
My ultimate goal is to produce real time images like Chris and Don do on NSN.
Edited by TL2101 (07/04/14 06:21 PM)
mclewis1
Thread Killer
Reged: 02/25/06
      #6617111 - 07/04/14 08:12 PM
Joe,
While there are some wonderful B/W images from B/W cameras, I would suggest a color camera for you. You don't loose much sensitivity and you gain some serious "wow factor" on the brighter objects.
As for the choice between regular (418) sensor or ExView HAD (428) sensor. The regular sensor will give you better color saturation on longer exposures but the HAD sensor will show you more faster, which will be more useful under light polluted skies. This will be especially true if you are going to use LP filters. So I'd probably lean towards the HAD sensor. If you spend a little more and have some patience I'd also suggest getting what Rock calls a class 0 sensor. The patience comes into play because he can't always get them so you might have to wait a little. Talking to Jack Huerkamp (Mallincam US distributor) about what's available will certainly help. The class 0 sensor will give you less hot pixels (usually none) and a bit smoother image.
I think an X2 model would be a good choice given your night time temperatures.
You can save some money by purchasing a 3rd party USB frame grabber (the model from Astro-Video Systems is a good example) ... but I have to say that I really like the Mallincam MCV-1E. The E or enhanced model has a black level adjustment that is quite helpful under moderate light pollution. You can however perform much the same enhancement in the Miloslick software with a little practice. This assumes you are going to use a Windows based PC for control and display of the video image ... if however you're going to us a Mac you'll need some other suggestions about a suitable frame grabber.
For an effective focal reducer ... well I'd start with an Antares .5x 1.25" model (because I'm cheap) and use it paired together with your f6.3 SCT reducer. You'll need to work out the appropriate spacing with some SCT threaded spacers and a SCT 1.25" visual back. If you want simpler, then just get the Mallincam MFR-5 and at least a 5mm spacer.
For just you and one other person I think you'll find that a good laptop screen will be fine for viewing. You can always add a real video monitor later on. With a good video monitor you'll usually be able to see even more faint detail in many objects but if you get good at just using the PC and making the appropriate adjustments (brightness, contrast, saturation, black levels, etc.) you won't miss the video monitor.
So to sum it all up ...
Mallincam Xtreme X2 PC model with a class 0 ExView HAD sensor.
Mallincam MFR-5 focal reducer
Astro-Video USB frame grabber
Good quality 3rd party S-Video cable (I like the moderately prices Pearstone cables from B and H Photo ... but any good quality cable is fine).
Miloslick software (download for $49).
You'll also need a USB-RS232 serial adapter - the Keyspan units are popular.
The MFR focal reducer goes on the camera's 1.25" nosepiece, then you can mount the camera in any 1.25" barrel attachment (a good 1.25" visual back is helpful, you don't want any sag in the attachment point).
The Xtreme control cable (comes with the Xtreme PC model) goes from the camera to the USB-serial adapter and into your PC. You'll need to setup a com port (done by the device driver for the adapter). When you first run the Miloslick s/w you'll need that com port #. This gives you full control over all the camera's functions.
The S-Video cable from the camera to the USB frame grabber and then into the PC. Configure Milosclick to use the S-Video connection. The reason for the S-Video cable is quality of the signal (very slight benefit) and the ability to use the other video connection (composite) on the camera for a future connection to a video monitor. You could if you wish just use the included composite video cable to connect to the USB frame grabber.
You'll now be all set to get the camera to display whatever you want to observe. If you now want to broadcast on NSN you'll need another piece of software, something to split and redirect the video stream - WebCamMax, ManyCam, or SplitCam are popular choices. The folks who regularly broadcast on NSN can help you with this selection and setup. I would however wait for a while and practice with just your own basic setup before jumping into broadcasting. Your broadcasts will be much better if you are well rehearsed using the Miloslick software.
Edited by mclewis1 (07/04/14 08:20 PM)
TL2101
Reged: 09/17/10
Loc: Concord, CA
      #6617235 - 07/04/14 09:43 PM
Mark, thank you for taking the time to explain the details it's starting to become clearer to me what I need. And yes I use a Windows based PC. I can wait for a class 0 sensor. I would rather do it right the first time and not have any regrets later. I am still a month or so away from finishing my home based observatory so I am in no rush but would like to get things started while my wife is still agreeable.
I am a long way off from trying to broadcast on NSN but who knows maybe in the future once I get it all figured out.
Dwight J
Reged: 05/14/09
      #6617334 - 07/04/14 10:55 PM
It will be great to have more NSN broadcasters out west Joe. I certainly couldn't add to what equipment has been suggested and what you already have. I look forward to seeing you on your own broadcast.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Lets Talk Equipment new [Re: Dwight J]
      #6617615 - 07/05/14 06:35 AM
Joe,
I think there is someone on the mallincam yahoo site that is in your city? can't think of his name but he made a great tutorial on video astronomy showing everything needed... I also think he belongs to an astronomy club in your area. hopefully someone can remember more about him.
Kasey
TL2101
Reged: 09/17/10
Loc: Concord, CA
Re: Lets Talk Equipment new [Re: dragonslayer1]
      #6618354 - 07/05/14 04:43 PM
It would be nice to find someone with the same scope and just duplicate what they have done. I am a member of Mount Diablo Astronomical Society but haven't been active for the last year due to a new job and having my home remodeled. I plan to contact them to see if any members have a Mallincam.
pilotlc
Reged: 07/24/13
Loc: Illinois
      #6618843 - 07/05/14 10:42 PM
I don't want to creep in on Joe's thread here but maybe we can get some of the same questions answered in one place. I also have a C8 on CGEM. I do have auto guiding. I was lucky enough to find a never used Xtreme2 online last week. In the package it came with the 0 sensor, cooling fan,MFR-5 focal reducer,10mm and 5mm extension rings, HD converter and 25'of cable. Any suggestions on what else I might need? I do need a light pollution filter for sure. I plan to use it to show to my family and friends. Hopefully take some snapshots with post processing. Right now I plan to view it on my computer but was curious with the HD converter (I know it's not going to be HD) what would the best way to view? Is a small HD tv or monitor a possibility? Any and all suggestions would be appreciated. Again, sorry Joe. I don't mean to try to take over your thread here but since we have the same set-up I hope it will good for both of us.
Edited by pilotlc (07/05/14 11:16 PM)
TL2101
Reged: 09/17/10
Loc: Concord, CA
Re: Lets Talk Equipment new [Re: pilotlc]
      #6618998 - 07/06/14 01:20 AM
Lance welcome you already have what I want to get. I will be very interested on how the Xtreme2 works for you. Let me know how easy or difficult it is to get setup and producing decent images. Which auto guiding system do you use? Thanks
Edited by TL2101 (07/06/14 01:21 AM)
pilotlc
Reged: 07/24/13
Loc: Illinois
      #6619196 - 07/06/14 07:52 AM
Joe,
I have the ST80 and Orion Starshoot for my autoguiding setup. I have also tried a 50mm finderscope too with the Starshoot. Have thought about getting a different guide camera. I have had mixed results with guiding in general but I think it is more of me trying to figure out the settings on PHD for the guiding. My Xtreme2 should get here later in the week so I'm excited to try it out. I will let you know for sure the learning process.
Edited by pilotlc (07/06/14 07:54 AM)
mclewis1
Thread Killer
Reged: 02/25/06
      #6619405 - 07/06/14 10:54 AM
Lance,
Get the manual and camera setup guide from http://www.mallincam.net/manuals--guides.html.
Download Stephan's Control software - http://www.mallincam.net/uploads/2/6/9/1/26913006/mallincam_controlx_v28.msi
It sounds like a fairly complete package (nice score). You'll probably also need a few things ...
- the PC control cable (it's a 25' grey cable with a 8pin DIN connector and a DB9 RS232 serial connector). http://zengineering.us/MallincamControlCablesNew.htm
- USB to RS232 serial adapter
- USB video frame grabber ... see my earlier post.
- video cable ... composite or S-Video (composite can be used in more configurations).
When you first start things up use the MFR-5 without the spacers and point the scope at the moon or something similarly bright and obvious.
You can first test your video connection by either just bringing up the onscreen menu OSD or the color bars using just the buttons on the rear of the camera. Once that works you can fire up the control side of things and try out the camera controls from the PC. Turning on/off the color bars and then try out the pre sets for lunar work. This will set the exposure for something close for working on the moon. Now you can work on focusing and fine tuning the exposure. Notice how many turns from the focus point with an eyepiece the camera/reducer now requires (and what direction), knowing this will save you a lot of time and aggravation. You'll be able to quickly find an object with the eyepiece and then be able to swap the camera in and focus. This is usually only something you'll do as you are getting a feel for the camera ("I can't see anything, am I sure I'm pointed at the object I want?"). Once you are comfortable you'll probably just leave the camera in place to do the initial alignment and jumping around between objects. Less swapping back and forth is much more comfortable.
With the HD updconverter you will also be able to easily use something like a TV with an HDMI input (the HD upconverter will convert composite video to an HDMI signal). Many of the popular and relatively inexpensive 19-25" LCD/LED TVs available today also make nice monitors for viewing with multiple folks.
Have fun and ask lots of questions.
pilotlc
Reged: 07/24/13
Loc: Illinois
Re: Lets Talk Equipment [Re: mclewis1]
      #6623915 - 07/08/14 06:03 PM
Thanks Mark for the info. Would you have any ideas on filters? Thanks.
pilotlc
Reged: 07/24/13
Loc: Illinois
      #6625022 - 07/09/14 11:11 AM
I'm leaning towards the Astronomik UHC filter. I see there is the 1.25" that attaches to the camera or reducer. But also one that is a rear cell one that attaches to the back of the C8. Any advantages either way?
Chris A
Reged: 02/03/07
Loc: Toronto, Canada
      #6625377 - 07/09/14 02:57 PM
Lance that is a great filter for observing with a camera that can go longer in exposure like a Mallincam. Yes there is an advantage of using the 1.25" filter if you decide to use another scope.
Chris A
Astrogate
4 registered and 16 anonymous users are browsing this forum.
Moderator:  droid, David Pavlich, JayinUT
