novbabies
Reged: 06/05/05
Loc: Northern Georgia!
Stratus 21mm - First Light/Impressions new
      #784214 - 01/19/06 07:10 AM
(Please read below if you have the time/desire; but if not, there's a synopsis all the way at the bottom!)
I came home from work, and there it was - a box from Orion! It would be my Stratus 21 mm!
Out of the package and looking perfect, no flaws. How long til dark? AND.....will it clear up??
A tropical storm system had blown through with 70 mph winds earlier (AND rain...LOTS of rain!), so the skies ought to be scoured clean; unfortunately, the wind was still up around 10-15 mph...
Hey, it's clearing up! Lucky I got the telescope out at 4:15...
After reading the mixed (but more good than bad) reviews on the Stratus 21mm in fast scopes, I can tell you I was anxious about looking through it for the first time while setting up and calibrating the COL with the 13 mm Stratus. What would I see? Would this be a disappointment as was the Expanse 20mm (what with more-than-soft edges and soft focus?)
I wanted bright stars for the first test, so moved to the Pleiades. While the entire cluster certainly did not fit within the AFOV, the stars seemed nicely defined and focused throughout the field. I was pleased with the edge performance, and let out a sight of relief (yes, really!)
Over to the Double Cluster: nearly fit in the field, the stars were very sharp and remained so out to the edges. There might be a TINY bit of edge - aberration? softness? - but only worth mentioning in a clinical sense; certainly not any distratction at all aesthetically!
NGC 457, NGC 7789, M39 - all good views. The wide field and sharper views than in the 20mm Expanse were nice, and there was no comparison whatever with the OLD 25 mm Plossl... M33 yielded one of the best views EVER, and M31-32-110 were very nice also.
Slewed over and easily located M77, but no NGC 1055...even when changing to the 13mm Stratus. Back to the 21mm and off to find NGC 1407 (which had eluded me up to this point...) I know it was me because, while I didn't see it in the 21mm, I easily saw it in the 13mm....and THEN in the 21mm! I think I've become a little spoiled by the contrast and power of 13!
Couldn't stand it any more, moved over to M42. WOW! If it was nice in the 20mm Expanse, it was breath-taking in the 21 mm Stratus. And no, I'm not being over-dramatic. I stayed here awhile, playing with my UHC and OIII filters.
When it became more fully dark, I found that the field of view in the Stratus 21mm was brighter than I had been accustomed to through continual use of the Stratus 13mm (duh!) If there is anything negative about my experience last night, this is it - and only this!
While I was fooling around with the UHC/OIII filters, popped over to Cas and picked up NGC 7635, the Bubble Nebula, for the first time. Quick over to NGC 2264, and yes, there was nebulosity! Then NGC 281, which was quite spectacular, and NGCs 40 and 1501.
So, anyway, I'm not sure EXACTLY how this happened, but I found myself in Cyg(NA Nebula) - WAY too big, but you know, I saw its edges quite well (first time)!; and wouldn't you know, the Veil Nebula was still "up" (this means it was *just* above the next door neighbor's rooftop), and even though it was fairly low in the sky, I could trace along its wispy lines! Wow, first time with the OII, and it's just as everyone had said!
All of this took place in about an hour and fifteen minutes; and then whoops! here come the clouds, triumphantly returning. But my mission had been accomplished - to check out the performance of the Stratus 21mm on my scope.
Joan - you must LOVE this EP!
SYNOPSIS: The eyepiece performed admirably in my fast scope. From other posts, I saw that even the VERY expensive EPs are not *PERFECT* to the edge. To be 100% accurate, the edges in the S21 were not *PERFECT*, but they were darn close! My eye was not distracted by any edge "weirdnesses" at all, unlike the experience with the 20mm Expanse, where edge problems are **painfully** obvious. For the money, I give this EP an "A"....it performed impressively on many objects both stellar and nebular. I would recommend it to any of you with fast scopes like mine who are looking to purchase an EP in this FL range that has a nice AFOV of 68°.
Good Seeing!
Mark
Orion 12" XTi f/4.9
VERY old Edmund 6" f/8 reflector
Assorted binoculars
ForgottenMObject
Reged: 09/11/04
Loc: Maryland, US
Re: Stratus 21mm - First Light/Impressions new [Re: novbabies]
      #784279 - 01/19/06 08:25 AM
Glad you enjoyed the Stratus and it is nice to see such a modestly-priced option out there on the market.
Matthew
IDA member
XT8i, 10x50 binoculars, lots of eyepieces
Chopin
Canis Insanus
Reged: 02/03/05
Loc: In the doghouse.
Re: Stratus 21mm - First Light/Impressions [Re: novbabies]
      #784304 - 01/19/06 08:54 AM
Great review Novbabies.
JasonŽ
birdsbyjason.com
BobNY
Reged: 11/30/04
Loc: Long Island, NY
Re: Stratus 21mm - First Light/Impressions new [Re: Chopin]
      #784354 - 01/19/06 09:48 AM
Nice report Mark.
Sounds like you had a great time with the 21mm.
Nice plug for the 0III filter as well. Sounds like I may need to pick one of those up someday soon
CPC 925
Vixen ED80SF
Atlas EQ-G
Hardin DSH-10
Nexstar 130GT
rosecityred
Reged: 02/13/04
Loc: Pacific Northwetest
      #784631 - 01/19/06 01:23 PM
Thanks for the review! I got one of these with my Christmas gift certificate but haven't had a chance to take it out yet. Now I'm looking forward to it even more!
Julia
novbabies
Reged: 06/05/05
Re: Stratus 21mm - First Light/Impressions new [Re: rosecityred]
      #784670 - 01/19/06 02:03 PM
What scope do you have?
Good Seeing!
Mark
Orion 12" XTi f/4.9
Assorted binoculars
erik
telescope surgeon
Reged: 01/30/04
Loc: Off Grid in Paradise (Big Isla...
      #785055 - 01/19/06 06:59 PM
congrats on getting the stratus, mark!
-Erik Wilcox
Homebuilt 16" Truss Dob
SV 80mm ED Nighthawk NG on M1 ALT/AZ
Nikon Prostaff 65mm spotter on Trekpod
Konusvue 20x80 binos/Peterson pipemount
Orion 10x50 binos
Homebuilt 80mm f/5 refractor
Mirador 60mm f/12 1960's refractor
kfred
Reged: 11/11/03
Loc: Dayton, Ohio
Re: Stratus 21mm - First Light/Impressions new [Re: erik]
      #785121 - 01/19/06 07:52 PM
Mark,
Do you plan on getting another Stratus?
The reason I ask, is that if you like them, they are sale now from Orion - however, I dont know how long the sale will last.
Fred
Trixie
rosecityred
Reged: 02/13/04
      #785412 - 01/19/06 11:04 PM
I should put my scope list back in my sig.
I have a 10 inch F5 GSO dob, a WO ZS80, and a 5 1/2 F8 newtonian of unmentionable heritage. None of these beauties has seen starlight for two months because of the weather and there's no end in sight!
Julia
Chopin
Canis Insanus
Reged: 02/03/05
Re: Stratus 21mm - First Light/Impressions new [Re: kfred]
      #785520 - 01/20/06 12:41 AM
Mark,
Fred
I talked to a rep at Orion a few days ago, and they said the sale should go until March (I think 31st). I hope so, because the Stratus EPs are all hitting back oredered one by one...yet again.
JasonŽ
birdsbyjason.com
square_pegAdministrator
Reged: 03/26/04
Loc: Maple Valley, WA
      #785566 - 01/20/06 01:30 AM
Julia
I fell your pain, Julia.
Say, is the WO ZS80 new? Since OSP?
Tom (Pegster)
DSH-8 (GSO Dob)
15x70 Oberwerks
SVP 100 f/6 achro
WO 66 Petzval
Sears Discoverer EQ 60/900
8x42 Regals
History is Philosophy teaching by examples.
Thucydides
novbabies
Reged: 06/05/05
      #785676 - 01/20/06 05:07 AM
Thanks Fred, but no; at this point, having Stratus 5mm, 13mm, and 21mm, I am all EPed out!
But in April, I may be lookng for my first 2" widefield
Any suggestions out there for a 12" f/4.9 owner wanting 2" widefield EP? (gee, I feel like I just fell into a personal ads section!)
Good Seeing!
Mark
Orion 12" XTi f/4.9
Assorted binoculars
novbabies
Reged: 06/05/05
      #785677 - 01/20/06 05:08 AM
I'd guess your Christmas gift will perform nicely on your scope!
Good Seeing!
Mark
Orion 12" XTi f/4.9
Assorted binoculars
Chopin
Canis Insanus
Reged: 02/03/05
      #785726 - 01/20/06 07:43 AM
Have you heard about the 35mm Panoptic?
Although, on a budget, I hear the 40mm Optiluxe is pretty awesome, dispite the 8+mm exit pupil.
JasonŽ
birdsbyjason.com
Tom L
Reged: 01/07/04
Loc: Sunny Oregon
      #786990 - 01/20/06 10:03 PM
Julia
Could happen this weekend, Julia...fingers are crossed.
Tele Vue 102mm f/8.6 on an EzTouch
Vixen 80mm f/5 A80SSWT on a grab-n-go mount
bgi
Reged: 12/01/05
Loc: Ga
      #788275 - 01/21/06 06:07 PM
35 pan give you a 6.2mm exit pupil with a paracorr. That's great. Without a paracorr you get a 7.1mm exit pupil - that's kinda big unless you're really young, but very usable. I use mine a good bit on my f/4.15 scope with paracorr yielding a 7.3mm exit pupil. It works very well for those "as wide as you can go" views. It's hard to beat a 35 pan unless you go for the 31mm terminagler.
Meade 127ED/LXD650 with motorized moonlite
Starmaster 18 Zambuto Stabilite f/4.16 with goto/track
12 registered and 14 anonymous users are browsing this forum.
Moderator:  Greg K., Jason B, csa/montana
