Tom L
Reged: 01/07/04
Loc: Sunny Oregon
I noticed that WO is now selling the EasyT Alt-Az mount without the tripod for $379.
-------------------- Tom
Tele Vue 102mm f/8.6 on an EzTouch
Vixen 80mm f/5 A80SSWT on a grab-n-go mount
kfred
Reged: 11/11/03
Loc: Dayton, Ohio
It does look like a very nice Alt-AZ mount - looking foward to hear some user reports.
Fred
-------------------- Trixie
Jim7728
Reged: 04/10/05
W.O.'s said they were going to offer it without the tripod.
EZ Touch
Though it can hold two telescopes, it looks like you need to buy thier combo plate to mount a 2nd telescope. Unless it comes ready as a two telescope mount.
Combo Plate
Nice looking mount.
-------------------- Jim
TV-60/40mm Ha-5mm BF
TV-85 and other tubes...
williamoptics
Vendor (William Optics)
Reged: 05/24/05
You can use any Losmandy-compatible plate, not necessarily WO COMBO plate only...
Tom Trusock
Reged: 02/26/02
Fred
Fred, when you consider it's dual arm capability, in this price class this is probably the best alt/az I've ever used.
It's smooth, it's stable, and the abiltity to mount two scopes at once is particularly cool.
The only "downside" that I see at the moment, is that you apparently can't mount encoders - but for small scopes, I personally don't feel it's needed.
I'm getting rid of my Gibralter and keeping this.
Tom T.
-------------------- Time spent doing something you love is not wasted.
Mark9473
Reged: 07/21/05
Loc: 51°N 4°E
AOK, the manufacturer, is selling a version with encoders.
-------------------- Mark
Leica 8x20; Vixen 8x42; Swift 8.5x44, 10x50 and 20x80; TS 7x50; Orion 15x63
WO Megrez II 80 FD + Baader 90° T2 Amici
skyview
Reged: 02/01/06
All right, it's official. Tom T has endorsed the EZ Touch. I will now go and bust open my piggy bank . I mean it, I'm looking for an alt-az upgrade over my telepod.
Tom, are you still going to mini-review the EZ touch with the WO 105 triplet?
-------------------- SkyView
All glory to the Hypnotoad.
Tom Trusock
Reged: 02/26/02
Yep.
Although - I may bump it up and do it with the UWANS to get it out a little sooner. It makes more sense to do it with the 105, but I've been getting lots of questions via e-mail on this mount, and it's going to be a little while till I get the 105 review out. (I have about 5 reviews on the docket at the moment, and a couple more things I'd like to get to - I've got enough to keep me busy for a while.)
I played with a FS102 on the WO tonight and a 66SD on the other side (being woefully ignored). It works well, but balance is a bit of an issue - like with any alt/az (except the discmounts - which are in a whole nother class).
I'm not sure I'd want to put a whole lot more weight on it than that (especially with a scope as long as the FS102), but it was pretty solid, smooth and useable at 180x or so. The rap test gave a damping time of 4-6 seconds which is about what I'd expect - focusing settled down within a couple of seconds (1-2 when using fine focus). Better than my Gibralter, considering the weight that's on it. It's certainly a lot more versitile in the telescopes you can use with it.
Some small annoyances have popped up - I do wish the tension adjustment screws were captive - however you can tell when they are all the way out before they pop out (and they haven't popped out yet) - they get a little wobbly when all the way out - and the tray's a little small (I also wish they had used a bolt that went all the way through the support, instead of one that screwed into the plastic - that would be less likely to strip out at some point - although that's a minor issue.
Still, given the price, and the fact it's dual armed with Losmandy and Vixen saddle plates (that covers just about everything) - I think it's an excellent deal.
I've got the gibralter sold.
T
Edited by Tom Trusock (03/10/06 11:12 PM)
Tom Trusock
Reged: 02/26/02
I should probably be trying to get some sleep, but I can't. So - I hauled the EZ-Touch out again.
This time I took the 66SD off, and put VSP's (vibration supression pads) under the feet.
At ~200x, with the FS102, the rap test yeilds a settle time of <2 seconds (the combination of a few lbs less and VSP's the difference is astounding). Focusing - the jiggles stop as soon as you remove your hand from the knob.
Overall, I consider this very good for a lightweight alt/az mount.
I came in to get some higher power eyepieces, and I'll check dampning time at 275x and let folks know.
Tom L
Reged: 01/07/04
Loc: Sunny Oregon
No we're talkin'....
Tom Trusock
Reged: 02/26/02
At 275x (nagler 3-6 zoom on 3mm), loaded with the FS102 (w/ 8x50 finder) ONLY (no scope on the other side as opposed to my earlier post), using VSP's, damping time from the rap test is still right around 1 second. When moving the scope to recenter the target, the scope stops jiggling immediately after removing your hand from the telescope.
To get this level of stability, it's I found it's VERY important you spread the legs as far apart as possible.
I'd recommend Ultrawide angle eyepieces for higher powers, as items just fly across the FOV of the 3-6, but the motions of the mount are smooth - however, unlike the DM4/6, I can't track and observe at the same time - the setup isn't that stable - but to be fair, I've never seen one that is - outside of the DM4/6. This is excellent performance for a lightweight, inexpensive mount.
T
Phil Frederick
Reged: 12/19/05
Loc: Seattle, WA & La Paz MX
Tom--
I've got a Tak Teegul Lapides Mod on a SVP tripod and this setup does allow tracking with the slo mo controls. Very smooth and solid. I've got a 100ED and TV76 in a side-by-side setup and have added slo mo cables to reduce vibration when tracking. See pic.
***Ooops! Sorry about the large pic file****
Phil
Edited by Phil Frederick (03/13/06 05:00 PM)
Tom L
Reged: 01/07/04
Loc: Sunny Oregon
What a great looking setup Phil!
Could you please reduce this to 800x600 pixels...60KB filesize please.
nreid
Reged: 03/06/04
Loc: Highland Village, Texas
What is the weight limit of the eztouch? Please tell me my SV115mm at almost 20lb would work!!
-------------------- Obsession 18" F4/5 with Moonlite Focuser
Stellarvue SV105
WO 66mm SD
WO EZ Touch setup
Tom L
Reged: 01/07/04
Loc: Sunny Oregon
Better call them...that might be pushing it. Maybe a DM6 is in order for that scope...
warf
Reged: 10/25/04
Loc: Wisconsin
Tom, didn't I see on another thread that you purchased a mount from Raul at DesertSky Astro? I have one on order from him too and it is similar in design to the eztouch so I would think that the weight issues might be similar. I went into it with my eyes wide open knowing that my WO ZS80 (baader film) and Coronado PST would be as big as I would be putting on this mount design so I could do side by side Solar observing.
-------------------- Marsh
Celestron NS 11 GPS, Denk Standard Binoviewer, Pair of Denk 21 EP, Denk PowerSwitch Diagonal, Denk PST Corrector, Coronado PST Double Stacked, WO ZS80 Anniversary,Celestron 15x70 Binoculars
Tom L
Reged: 01/07/04
Loc: Sunny Oregon
Marsh, yes I did and returned it after trying it with a 90,, f/11. The scope was difficult to balance and I had a hard time getting the alt adjustment tight enough. Raul had a fix for that but I think the fact that I got a TV102 in the process, I knew it was going to be too much for the DSV-1 to handle it. I went with a Meade LXD75 instead so I could also gain the goto.
I still think the DSV-1 is a good, solid mount for smaller 80mm faster scopes. What you are thinking about mounting on it would probably be fine. He does offer a guarantee on the mount if you ask him.
warf
Reged: 10/25/04
Loc: Wisconsin
My reason for asking Tom was more for one of the other posts that had asked about weight capacity of the EZTouch... since the DS1 is similar in design the key question one will want to ask is what is going to be mounted on these new style Alt/az mounts... again, I feel fairly confident that my two small scopes that I am mounting on this style mount will work fine. And as you stated, Raul has been great to work with as has the folks at WO.
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
I have been using my UA MicroStar deluxe for my 80FD and with a medium bino-mount for the MS I can mount my 66SD and PST side-by-side. Larry from UA is also great to work with and has done some custom work for me as well.
-------------------- Chris
Mallincam Color Hyper Plus
10" DSH with SC DSC, CPC 800 XLT
M110 Doublet ED, AT 102Achro, ZS80FD 10th Anniv, ZS66SD, PST
CG5-AGT, EZ-Touch, Voyager
POD XL3 http://POD.SchroederCity.com
tjswood
Reged: 05/18/05
Loc: Tempe, AZ
Tom -
If you buy just the mount w/o tripod for $379, can you attach your Losmandy DUP / DUPS plates to it right out of the box? Or do you have to buy the $148 adapter plate??
Also, I noticed that it has a 5/8x11 sized mounting thread where it attaches to the tripod - I thought the Gibraltar or Bogen tripods were 1/2" and not 5/8??
Finally, why haven't they posted specs for this yet?? Sort of odd they would sell it without posting the specs - website says "Specs coming soon" That is odd.
Thanks in advance, Tim
