skadder
Reged: 03/22/04
How do you select the AVI frames you want? new
      #86030 - 04/06/04 02:55 PM
Can somebody tell me, as my knowledge of image processing is effectively zero, how, from an AVI, you can SELECT the frames you want stacked and discard the ones that will degrade the final stacked image.
I took an AVI of the moon yesterday, without a tripod (telescope arrives in one week!)just to practise some stacking with. In some frames there is some detail in others it is just washed out. I wanted to only select the image laden frames and discard the washed out frames but I cant seem to find an option for this in registax.
Any ideas?
Adam
ST80 on EQ1
Canon 300d
Pentax 10x25 Binos
Berkut 10X50 mono
Thinking about a 8" Dob...
TeamGS
Reged: 01/20/04
Loc: Elk Grove, CA
Re: How do you select the AVI frames you want? new [Re: skadder]
      #86092 - 04/06/04 04:09 PM
Hey Adam, check your PM!
Gary
Celestron 80ED
Losmandy G11
NexStar 80
Starlight Xpress SXV-H9
SXV guidehead, ToUcam 840
http://www.teamgs.org/astrophotography.htm
skadder
Reged: 03/22/04
Re: How do you select the AVI frames you want? [Re: TeamGS]
      #86128 - 04/06/04 05:09 PM
Thanks Gary,
i have checked my PM and the tutorial seems to explain it. I only posted here because when I PM'd you earlier you were on line but didn't respond . I guess now that it was because of you hadn't used this method before! Sorry.
Thanks for your response though- spot on!
Adam
ST80 on EQ1
Canon 300d
Pentax 10x25 Binos
Berkut 10X50 mono
5 registered and 6 anonymous users are browsing this forum.
Home
