Privacy Policy |
Please read our Terms
of Service | Signup and
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Thru the kindness of a fellow CN'r who made the degree circles for me, I now have the complete setup for $12. I had the degree circles laminated on both sides (Staples-$2) Bought an inclinometer (Home Depot $10). Had an old wall clock that I removed the hands from for pointers. The Altitude Degree was affixed with dbl-stick tape. I siliconed the clock hand between 2 thin washers, & installed it first, against the scope, on the "spring" bolt. Then, with the inclinometer, I adjusted the clock-hand pointer, until they agreed, all thru the scale. On the base, again I used dbl-stick tape to affix degree circle. I drilled a small hole in the side of the lower base, using a stainless steel screw, mounted the other clock hand (hour). I then bent it to clear edge of other base & forward to point to scale. I think the set-up looks great; I don't need the inclinometer now that the pointer has been coordinated. Of course, now a front has moved in with total overcast, so I cannot try out the new "Go-To" $12 system! Carol
-------------------- Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Pentaxes; 5XW, 7XL, 10XW.
14mm Meade 4000 UWA
TV Panoptics; 22, 35
DreamCatcher Dobservatory, #2
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Another
14mm Meade 4000 UWA
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Last picture.
14mm Meade 4000 UWA
rnabholz
Reged: 07/25/04
Loc: Iowa
Carol,
Looks great, nice job.
Regarding the inclinometer versus altitude scale. The advantage of the inclinometer is that it reads the true angle of the tube regardless of the angle of the base. A base that is even just sightly off from perfect level can introduce errors into your altitude readings, and at least in my case, my eyepiece's widest field at just 1 degree leaves me little room for level induced errors.
You can certainly keep the scale, but I would take great care in leveling the base, and if it were me, I would leave the inclinometer in place during observing as a way to confirm the scale's readings.
Good Luck with the system, I'm cheering for you.
-------------------- Rod Nabholz
Home Built Astronomy Projects
Wild Bird Photography
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Rod: Thanks for bringing that to my attention! I will definitely use the inclinometer. Soon I am getting the digital one you have, I have the base all ready for it. Also thanks for all your help & encouragement, so I can have a "Go-To" scope! Carol
14mm Meade 4000 UWA
dgs©
Reged: 03/29/04
Loc: West Monroe, Louisiana
Looks real snazzy... kind of like the scope should have come with them as original equipment.  The clock hands are a good idea.
Make sure your base is very level whenever you set it up, otherwise your Alt scale could be off a little. I assume you are using a compass to align your Azimuth scale with true North? If so, keep in mind that magnetic North and True (celestial) North don't always agree. Furthermore, magnetic North wanders around, noticeably over the course of a few years. Here is a good NOAA site for determining what your magnetic declination is.
-------------------- - david
8"Ø Newtonian on SVP, Moonlite CR2, Telrad
PST Oberwerk Ultra 15x70 Orion Ultraview 10×50
Hand-me-down Sears Refractor (Discoverer) 60mm×900mm
"What we have done for ourselves alone dies with us; what we have done for others and the world, remains and is immortal." --Albert Pike
SkyArcher
Reged: 04/12/06
Loc: 9545' in Colorado
Carol, That looks great! You did a nice job!
-------------------- Sir Skyler Archibald.....
An 8" Deep Space Hunter
4.5 w/ GOTO
4.5 newt w/ home built Dob mount
Omphaloskepsis - I didn't realize that there is a word for what I do while waiting for web pages to download
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Thanks to "Honey's" master!
14mm Meade 4000 UWA
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Thanks David: It was suggested to me that I point the scope to Polaris, then rotate base to "0". I will try both this, & a compass if & when the "curse" lifts the clouds, to see which is easier for me & most accurate. Carol
14mm Meade 4000 UWA
Hillbilly_Gazer
Court Jester
Reged: 11/17/04
That was my exact thought. Nice work!
-------------------- Orion XT-8
Orion Scenix 10x50 WA Binoculars
And not a whole lot else!
typhus
Reged: 11/06/04
Loc: Tucson, AZ
Those are nice Carol. Using the degree circles sounds like it would be more fun observe than DSC. Let us know how they work out for you.
-------------------- Shane
Orion XT10i
10x50 Binoculars
Curt B
Reged: 08/02/05
Loc: Regina, Canada
Good luck Carol. When I did the same thing to my dob, it opened up a whole new world for me! What program are you using to find the objects?? I use Planetarium on my Palm. I also play around with PleiadAtlas. It is an easier interface than Planetarium, but I don't think it is quite as accurate, but still gets you pretty close.
-------------------- WO ZenithStar 80II ED with WO 2" dielectric diagonal, and red dot finder
SkyWatcher 100mm ED Pro, with WO 1 1/4" Dielectric diagonal, 9X50 RAC finder
Baader Hyperion 21mm
GSO 30 & 26mm 2" eyepieces
WO 8-24mm Zoom
Tele Vue 24mm Pan,13mm Ethos,6-3 Nagler Zoom
Celestron Power Tank 17
Astro-Tech Voyager Mount
William Optics TR-188 Tripod
Celestron SLT Mount
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
I haven't decided on a program yet; do you have a website for PleiadAtlas? The easier, the better for me! Also, did you use a compass on the base, or put scope on Polaris, & turn the base to "0"? Thanks! Carol
14mm Meade 4000 UWA
rnabholz
Reged: 07/25/04
Loc: Iowa
Carol,
When you get tired of hearing from me, just say so.
With regards to aligning the base, I have a cheap $4 compass permanently installed in the base of my scope that helps me get somewhat close to north when I set up the scope.
Then, to "calibrate" I use any known object, many times a star or planet visible well before Polaris is visible. Center that object in the field and adjust the dial to match. My approach was to build it about 20 degrees of adjustability on the dial. That approach allows you to adjust without disturbing the position of the scope, nice if you have spent any time carefully leveling the base.
Remember that each time you move the scope base to adjust your calibration, you will likely move the scope enough to loose the calibration object and will have to reacquire the target and check the reading and repeat. Might be a bit tedious.
An approach I have seen in a set up like yours with a non-adustable scale is to make the pointer movable. One way to do that is a pointer mounted on a magnet that attaches to a steel plate along the edge of the scale. Once centered on an object, You simply move the pointer to match the appropriate reading, again leaving your scope undisturbed, still level and centered on your calibration target.
Hope this helps.
Rod
Edited by rnabholz (05/03/06 11:43 AM)
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Rod: I won't live long enough to get tired of you trying to help me get set up! Can you explain a little more about the steel plate along the edge of the scale? This idea sounds great, as I know it will be very difficut for me to move the base (full weight of scope!). Carol
14mm Meade 4000 UWA
rnabholz
Reged: 07/25/04
Loc: Iowa
Carol,
Imagine a piece of thin steel - the steel strapping used on lumber or pallets would work great. You simply attach, say, 6 inches of that to the edge of your groundboard with a couple of screws.
Then attach your pointer to a small magnet, and stick it to the center of the steel strip.
When you need to tweak your calibration you simply slide the pointer along this strip of steel strapping until it matches the computer's azimuth setting and you are good to go.
Let me know if that is clear as mud and I will try again.
Rod
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Rod: something else that may work is magnetic stripping. I called the local hdwre store, & they have it (used for holding screwdrivers, etc.) It's flexible, so I thought I'd screw it around the edge of the base, then mount my clock-hand pointer on a small magnet. What do you think of this?  Carol
14mm Meade 4000 UWA
rnabholz
Reged: 07/25/04
Loc: Iowa
My only thought on that might be that you could have a situation where the polarities of the strip and small magnet would clash and not let you place the pointer precisely where you would like. Take the small magnet to the store and try it out.
If you live anywhere near a lumberyard or home improvement center, they would likely let you take all the steel strapping you wanted for nothing. Most of the time the yard is littered with the stuff and some poor soul (like me on my summer job as a kid) has to schlep around and pick it up and toss it.
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
After thinking about it, I agree, the strapping would be better (and the price? PRICELESS!) Besides, the cost will still be $12, + 1 small magnet, & a few s.steel screws! How much better can it get? Off to the lumber yard, I go! Now, all that will be left? Overcast, go away!  Carol
14mm Meade 4000 UWA
SkyArcher
Reged: 04/12/06
Carol, I use Pocket Stars on my PDA (Dell Axim) and Cartes du Ciel on my laptop to give me the coordinates that I need to find stuff. CdC is free but Pocket Stars is $19. CdC shows the comets and lets you update the database. Pocket Stars does not show comets but if I look up the comets on CdC then I can pick it out from the Pocket Stars.
The PDA is definately easier to use out in the field than the laptop.
4.5 w/ GOTO
3 registered and 9 anonymous users are browsing this forum.
Moderator: spaceydee, csa/montana
