csa/montanaModerator
Den Mama
Reged: 05/14/05
Loc: montana
Degree Circles
      #937949 - 05/02/06 01:34 PM Attachment (4474 downloads)
Thru the kindness of a fellow CN'r who made the degree circles for me, I now have the complete setup for $12. I had the degree circles laminated on both sides (Staples-$2)
Bought an inclinometer (Home Depot $10). Had an old wall clock that I removed the hands from for pointers.
The Altitude Degree was affixed with dbl-stick tape. I siliconed the clock hand between 2 thin washers, & installed it first, against the scope, on the "spring" bolt.
Then, with the inclinometer, I adjusted the clock-hand pointer, until they agreed, all thru the scale.
On the base, again I used dbl-stick tape to affix degree circle. I drilled a small hole in the side of the lower base, using a stainless steel screw, mounted the other clock hand (hour). I then bent it to clear edge of other base & forward to point to scale. I think the set-up looks great; I don't need the inclinometer now that the pointer has been coordinated. Of course, now a front has moved in with total overcast, so I cannot try out the new "Go-To" $12 system!
Carol
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: csa/montana]
      #938005 - 05/02/06 01:58 PM Attachment (3044 downloads)
Another
Den Mama
Reged: 05/14/05
Loc: montana
      #938007 - 05/02/06 01:59 PM Attachment (2508 downloads)
Last picture.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #938045 - 05/02/06 02:12 PM
Carol,
Looks great, nice job.
Regarding the inclinometer versus altitude scale. The advantage of the inclinometer is that it reads the true angle of the tube regardless of the angle of the base. A base that is even just sightly off from perfect level can introduce errors into your altitude readings, and at least in my case, my eyepiece's widest field at just 1 degree leaves me little room for level induced errors.
You can certainly keep the scale, but I would take great care in leveling the base, and if it were me, I would leave the inclinometer in place during observing as a way to confirm the scale's readings.
Good Luck with the system, I'm cheering for you.
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: rnabholz]
      #938057 - 05/02/06 02:19 PM
Rod: Thanks for bringing that to my attention! I will definitely use the inclinometer. Soon I am getting the digital one you have, I have the base all ready for it.
Also thanks for all your help & encouragement, so I can have a "Go-To" scope!
Carol
dgs©
Reged: 03/29/04
Loc: West Monroe, Louisiana
      #938066 - 05/02/06 02:25 PM
Looks real snazzy... kind of like the scope should have come with them as original equipment.
The clock hands are a good idea.
Make sure your base is very level whenever you set it up, otherwise your Alt scale could be off a little.
I assume you are using a compass to align your Azimuth scale with true North? If so, keep in mind that magnetic North and True (celestial) North don't always agree. Furthermore, magnetic North wanders around, noticeably over the course of a few years.
Here is a good NOAA site for determining what your magnetic declination is.
SkyArcher
Reged: 04/12/06
Loc: 9545' in Colorado
Re: Degree Circles new [Re: dgs©]
      #938080 - 05/02/06 02:35 PM
Carol, That looks great! You did a nice job!
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: SkyArcher]
      #938088 - 05/02/06 02:37 PM
Thanks to "Honey's" master!
Den Mama
Reged: 05/14/05
Loc: montana
      #938098 - 05/02/06 02:44 PM
Thanks David: It was suggested to me that I point the scope to Polaris, then rotate base to "0". I will try both this, & a compass if & when the "curse" lifts the clouds, to see which is easier for me & most accurate.
Carol
Hillbilly_Gazer
Court Jester
Reged: 11/17/04
      #938114 - 05/02/06 02:51 PM
That was my exact thought. Nice work!
typhus
Reged: 11/06/04
Loc: Tucson, AZ
Re: Degree Circles new [Re: Hillbilly_Gazer]
      #938218 - 05/02/06 04:00 PM
Those are nice Carol. Using the degree circles sounds like it would be more fun observe than DSC. Let us know how they work out for you.
Curt B
Reged: 08/02/05
Loc: Regina, Canada
Re: Degree Circles new [Re: typhus]
      #939034 - 05/03/06 12:46 AM
Good luck Carol. When I did the same thing to my dob, it opened up a whole new world for me! What program are you using to find the objects?? I use Planetarium on my Palm. I also play around with PleiadAtlas. It is an easier interface than Planetarium, but I don't think it is quite as accurate, but still gets you pretty close.
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Curt B]
      #939404 - 05/03/06 09:55 AM
I haven't decided on a program yet; do you have a website for PleiadAtlas? The easier, the better for me! Also, did you use a compass on the base, or put scope on Polaris, & turn the base to "0"?
Carol
rnabholz
Reged: 07/25/04
Loc: Iowa
      #939533 - 05/03/06 11:36 AM
Carol,
When you get tired of hearing from me, just say so.
With regards to aligning the base, I have a cheap $4 compass permanently installed in the base of my scope that helps me get somewhat close to north when I set up the scope.
Then, to "calibrate" I use any known object, many times a star or planet visible well before Polaris is visible. Center that object in the field and adjust the dial to match. My approach was to build it about 20 degrees of adjustability on the dial. That approach allows you to adjust without disturbing the position of the scope, nice if you have spent any time carefully leveling the base.
Remember that each time you move the scope base to adjust your calibration, you will likely move the scope enough to loose the calibration object and will have to reacquire the target and check the reading and repeat. Might be a bit tedious.
An approach I have seen in a set up like yours with a non-adustable scale is to make the pointer movable. One way to do that is a pointer mounted on a magnet that attaches to a steel plate along the edge of the scale. Once centered on an object, You simply move the pointer to match the appropriate reading, again leaving your scope undisturbed, still level and centered on your calibration target.
Hope this helps.
Rod
Edited by rnabholz (05/03/06 11:43 AM)
Den Mama
Reged: 05/14/05
Loc: montana
      #939565 - 05/03/06 11:56 AM
Rod: I won't live long enough to get tired of you trying to help me get set up! Can you explain a little more about the steel plate along the edge of the scale? This idea sounds great, as I know it will be very difficut for me to move the base (full weight of scope!).
Carol
rnabholz
Reged: 07/25/04
Loc: Iowa
      #939587 - 05/03/06 12:19 PM
Carol,
Imagine a piece of thin steel - the steel strapping used on lumber or pallets would work great. You simply attach, say, 6 inches of that to the edge of your groundboard with a couple of screws.
Then attach your pointer to a small magnet, and stick it to the center of the steel strip.
When you need to tweak your calibration you simply slide the pointer along this strip of steel strapping until it matches the computer's azimuth setting and you are good to go.
Let me know if that is clear as mud and I will try again.
Rod
Den Mama
Reged: 05/14/05
Loc: montana
      #939628 - 05/03/06 12:52 PM
Rod: something else that may work is magnetic stripping. I called the local hdwre store, & they have it (used for holding screwdrivers, etc.) It's flexible, so I thought I'd screw it around the edge of the base, then mount my clock-hand pointer on a small magnet. What do you think of this?
Carol
rnabholz
Reged: 07/25/04
Loc: Iowa
      #939645 - 05/03/06 01:06 PM
My only thought on that might be that you could have a situation where the polarities of the strip and small magnet would clash and not let you place the pointer precisely where you would like. Take the small magnet to the store and try it out.
If you live anywhere near a lumberyard or home improvement center, they would likely let you take all the steel strapping you wanted for nothing. Most of the time the yard is littered with the stuff and some poor soul (like me on my summer job as a kid) has to schlep around and pick it up and toss it.
Den Mama
Reged: 05/14/05
Loc: montana
      #939676 - 05/03/06 01:26 PM
After thinking about it, I agree, the strapping would be better (and the price? PRICELESS!) Besides, the cost will still be $12, + 1 small magnet, & a few s.steel screws! How much better can it get? Off to the lumber yard, I go!
Now, all that will be left? Overcast, go away!
Carol
SkyArcher
Reged: 04/12/06
      #939785 - 05/03/06 02:40 PM
Carol, I use Pocket Stars on my PDA (Dell Axim) and Cartes du Ciel on my laptop to give me the coordinates that I need to find stuff. CdC is free but Pocket Stars is $19. CdC shows the comets and lets you update the database. Pocket Stars does not show comets but if I look up the comets on CdC then I can pick it out from the Pocket Stars.
The PDA is definately easier to use out in the field than the laptop.
Fireball
Reged: 03/24/06
      #940000 - 05/03/06 05:21 PM
Carol,
Rod
Sounds interesting and simple.
Is it possible to show a picture of this set-up ?
That would make everything very clear.
Thanks !
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Fireball]
      #940013 - 05/03/06 05:37 PM
Fireball: Go to top of this post, my first picture.
On the outer side edge of the lower circular base, the metal strip will be affixed there, completely around the base; then where the pointer is,(screwed in), I now will have the pointer glued to a small magnet that I can now move anywhere on the degree circle, to get set up.
Carol
Den Mama
Reged: 05/14/05
Loc: montana
      #940019 - 05/03/06 05:43 PM
Ron: Just downloaded trial PC version, & am ordering PC & PDA version. This is a great program, just what I was looking for. Now, I'm going to try to find a good price on the Axim. Again, thanks for all your help, couldn't have done it without your kindness & expertise!
Carol
Curt B
Reged: 08/02/05
Loc: Regina, Canada
      #940116 - 05/03/06 06:52 PM
Here is the link for Pleiadatlas
http://astro.isi.edu/pleiadatlas/
and Planetarium
http://www.aho.ch/pilotplanets/
Edited by Curt B (05/03/06 06:53 PM)
rnabholz
Reged: 07/25/04
Loc: Iowa
      #940389 - 05/03/06 09:59 PM
Carol,
Of course the call is yours to make, but if it were me, I wouldn't bother to make the strip go all the way around.
6-12" of strapping would give you around 30 to 45 degrees of adjustment, plenty for even a casual initial polar alignment.
Just another two cents - making my total to date $3.08.............Sorry.
Den Mama
Reged: 05/14/05
Loc: montana
      #940401 - 05/03/06 10:19 PM
Rod: Again, thanks! Didn't realize this. It will save me a lot of work. Can tell I'm an amateur at this, huh? I've got the "0" degree mark on the left side, so a short strip running each way of this would be good?
Carol (p.s. you have a credit of many thousands of $, so I can pick your brain a lot, at 2cents a question, I'm gonna keep you verrrry busy!)
rnabholz
Reged: 07/25/04
Loc: Iowa
      #940454 - 05/03/06 11:07 PM
Exactly, just a few inches on both sides of zero will do the trick.
Glad to help.
AtLarge
Reged: 08/22/05
Loc: 868 Ft. Above Sea Level
      #943553 - 05/06/06 12:51 AM
Glad to help.
This is very informative but let me make sure I have this straight.
The pointer is on the bottom base.
The pointer is aligned with Polaris and the base leveled.
The steel band with magnet on pointer allow for adjustments so you can tweak that alignment by moving the pointer after you test on some known objects. (without having to keep moving the entire bottom base)
If the markings are on the top board and are stationary with the OTA where do you set the gradients to begin with? The zero / zero goes directly below the center of the OTA at the front of the scope? That way you always begin with the scope pointed at the Polar North.
You then match the Azm:159 and Alt:+38 as per your favorite program (my settings at the moment for Jupiter) and your on target or at least in the neighborhood.
Am I keeping up here or did I miss something?
rnabholz
Reged: 07/25/04
Loc: Iowa
Re: Degree Circles new [Re: AtLarge]
      #943758 - 05/06/06 07:55 AM Attachment (613 downloads)
You have it.
In Carol's pictures you can see that she set zero at 90 degrees from the tube, but it really doesn't matter that the scale match the actual azimuth direction, only that the scale and pointer indicate properly. Her approach makes it convenient to see when at the eyepiece when the scope is pointed north.
Using the approach where the scale is attached to the rocker means that you will have to leave the eyepiece position at times to line up the pointer. The approach I used is to put the scale on the groundboard and build some adjustability into the scale rather than the pointer. That allows the pointer, attached to the rocker, to be visible from the eyepiece at all times, a little handier set up, but a little more complicated build.
Let me know if you have other questions.
Clear Skies
Den Mama
Reged: 05/14/05
Loc: montana
      #943900 - 05/06/06 10:17 AM
See my new post here "my $12 Go-To" test drive
Carol
SkyArcher
Reged: 04/12/06
      #944499 - 05/06/06 07:52 PM Attachment (1312 downloads)
In case any wants it, I've attached the pdf of the file I used to make the degree circle. You can take the pdf to your local "Kinkos" copy center and have them print it out on 24x36 paper. Also while you're there, have them laminate the degree circles.
Relativist
Reged: 10/11/03
Loc: OC, CA, USA
      #944714 - 05/06/06 11:08 PM
Just out of curiosity, how good is that home depot inclinometer? Could we maybe make our own that was a bit better?
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Relativist]
      #944767 - 05/07/06 12:10 AM
It's about 4-3/4" high (circular), with magnetic base. As Rod Nabholtz said, using the inclinometer, it's independent of the base, so no leveling is required.The scale is quite small & a little difficult to read at night, but works. During my viewing session, My Altitude degree scale matched the inclinometer with each change. The ideal one is what Rod has now; MD SmartTool digital level. It runs $100 though. I'm quite happy with my setup & accuracy.
Carol
Relativist
Reged: 10/11/03
Loc: OC, CA, USA
      #947707 - 05/09/06 02:40 AM
Ok, so let me ask this, could you use the inclinometer to "calibrate" the Altitude scale, bypassing the need to level the base? The idea would be to move the arrow as is done with the Azimuth scale.
THESKY
Reged: 02/16/06
Loc: SOCAL
      #947728 - 05/09/06 03:31 AM
Boy this is such a good thread . . . thank you for all . . . especially Carol who initiate this thread. Also to Rob and SkyArcher who make the Alt/Az degree circle work.
I also plan to do the same since it is doable.
My question will be when you have a tracking platform how do you calibrate the level. When you just start tracking you will have the platform swing to the east side and then it will end as it swing all the way to the west for 60 - 80 minutes.
I guess one solution will be searching for the object while the rocker base is level and after the object is in the FOV - turn on the tracking device.
Ridwan
rnabholz
Reged: 07/25/04
Loc: Iowa
      #947818 - 05/09/06 06:47 AM
Curtis,
Using a scale without a level base is problematic because while you can always set the scale to match an inclinometer determined setting, when you turn the rocker on the base, the scale reading will be off immediately and will not be exactly accurate until you return it to the same azimuth you set it at.
Now, depending in the degree of deviation from level, this error could be small, but it could also be very large and make finding things in a one degree or so field of view very difficult.
The inclinometer takes away the possibility of this error, and so makes it the choice for me. The analog inclinometer mentioned in this thread is about $10, a cheap efficient solution.
Of course leveling the scope is another option, and actually, I do both to make things as accurate as possible.
Edited by rnabholz (05/09/06 10:39 AM)
rnabholz
Reged: 07/25/04
Loc: Iowa
Re: Degree Circles new [Re: THESKY]
      #947869 - 05/09/06 08:08 AM
Ridwan,
I have given the tracking platform issue some thought, as I am conisidering building one for my scope.
I think the only approach that will work is stopping and returning the platform to level during the object acquisition process and then turning the motors on.
You would sacrifice 50% of your tracking period, but depending on the platform you would likely have 20 to 30 minutes of travel left. That would generally be enough for my purposes.
THESKY
Reged: 02/16/06
Loc: SOCAL
      #948148 - 05/09/06 11:37 AM
Rod,
That is what I thought . . . having the dob level - align to the object (Alt/Az) - then turn on the tracking. Thank you for that confirmation.
Or another idea would be . . . calculating the difference between a leveled platform and a maximum swing platform. Then we can use this different to a Alt/Az value from the pocket star.
What do you think about that one?
rnabholz
Reged: 07/25/04
Loc: Iowa
      #948202 - 05/09/06 12:12 PM
Well, here is what I have come up with as I have pondered using a platform.
Remember that if you adopt my strongly preferred approach for altitude - an inclinometer, not a scale, the tube reading is always read independent of the base. So even on a platform the altitude reading will be accurate.
It is the azimuth that is vexing. Visualizing the base and the azimuth scale and the different possible orientations of that scale to the tilt of the platform, it seems to me that you would have an infinitely variable factor to consider.
For example, consider the scope pointing precisely perpendicular to the axis of platform rotation or pointing precisely parallel to the axis of rotation. In these cases, your azimuth is likely to be pretty accurate.
Now consider the scope pointing in between those points. It seems to me that depending on the degree of the platform tilt, you would compromise the accuracy of the scale because you have in effect compressed the spacing of the degree marks by tilting the scale.
If my visualizations are correct (and PLEASE, anybody who sees this differently please let me know your thoughts) you would have a very difficult time quantifying the deviation and therefore could probably not easily adjust for it.
Edited by rnabholz (05/09/06 12:28 PM)
SkyArcher
Reged: 04/12/06
      #948402 - 05/09/06 02:33 PM
Rob, I'm just having a little brain fart here, but I'm thinking that if you're using a tracking platform, wouldn't it be better to use the other set of coordinates (RA-DEC) and set up a different set of degree circles. I confess that I don't know what Ra-Dec coordinates are other than they are used on EQ mounts.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #948457 - 05/09/06 03:26 PM
I suppose that you could develop a way to put RA-Dec circles on a platform mounted dob, I have never seen that done, so I can't say that I understand the possible pitfalls.
I guess my way of thinking about this approach is that there may be times when I would use the scope without the platform so the alt/az circles are useful in both settings.
Setting the platform back to level to use the circles can be a quick and simple process on the non-tangent drive platforms, so it seems like a simple solution.
Of course, one could simply get a Equatorial Mount and skin the cat that way if tracking was a requirement.
THESKY
Reged: 02/16/06
Loc: SOCAL
      #948607 - 05/09/06 05:35 PM
I just did some calculation on delta between leveled and full swing platform. It does not work. Because the delta is not a consistant number. The object closer to Polaris for example will have a different delta from an object away from Polaris.
In regard to your inclinometer, I assume when you mount the inclinometer on the tube - it has to be vertical in order to get an accurate reading of the altitude. But . . . when you have a platform swings all the way . . . the inclinometer is not necessarily vertical anymore.
So even using an adjustable mounting, there should be a way to compensate vertical axis.
The RA and Dec method is even more complicated because dobsonian has only two UN-adjustable plane (vertical and horizontal) With RA and Dec, you need to have a 3rd axis in order to make the 2 planes coincide with the true North (Polaris) . . . like the the equatorial mount. . . . Unless I am wrong . . .
Have fun tinkering . . . I am going to sleep on it again . . .
Ridwan
rnabholz
Reged: 07/25/04
Loc: Iowa
      #949041 - 05/09/06 10:44 PM
I am curious, as I suggested in the earlier post, I suspect that as you move toward one of the multiples of 90 degrees - 0 - 90 - 180 -270- 360 you reduce the error. Stated another way, at 0 degrees no error - increasing error to 45 degrees - then decreasing error to 90 where it is minimal, or even eliminated. Continuing the same way every 90 degrees all the way around.
Does this make sense to anyone but me?
Ridwan
Regarding the inclinometer, the analog unit would be susceptible to mechanical error- the indicator would rub on the housing. I am not sure about my electronic unit, I haven't tried it in anything but a normal attitude.
Have to give that a try.
Interesting to think about. Thanks
THESKY
Reged: 02/16/06
Loc: SOCAL
      #950829 - 05/11/06 03:10 AM
Hey Rod,
Just got back from a few hours of observing. The platform and the inclinometer worked very well. I bought the digital one (smarttool - Craftsman) and mount
using a magnetic strip - the program I use Equinox (for Macs) and the platform I use Tom Osypowski's.
I swing the platform all the way - then look for Jupiter - both the program and inclinometer agrees in the altitude with about 0.25 degrees of error.
Then I turned on the tracking and let it track for about 45 minutes or so and again the inclinometer agrees with the program. It is really cool!
I have not installed the azimuth yet since Kinko messed up the enlargement.
Skyarcher make a 19" degrees circle but my DSH base is 25" (I have a 12" DSH) So I have to calculate the percentage of enlargement. Anyway it is almost done.
Thanks again for sharing the idea . . . now I got a goto system fairly affordable. The smart tool $80 was well worth it. Total was still under $100.
Ridwan
rnabholz
Reged: 07/25/04
Loc: Iowa
      #951035 - 05/11/06 09:52 AM
Hi Ridwan,
You got out and tested the SmartTool before I had a chance to. I am pleased to hear that it works properly even if tilted slightly off axis. I had suspected it would, but nothing beats a true field test.
$80 is a great buy on the level. I knew Sears carried them, but at the time I bought mine, their price was higher by $20. My guess is given a year, this tool will be in the $50 range.
The device is quite accurate, my experience matches yours, the error is very small, a quarter of a degree makes this part of the system well within acceptable tolerance. Add that to the resolution possible with a 20" azimuth dial and you have a system that works very well as you and those who have implemented it have discovered.
The whole thing can be done for about $100 to $125. Moving to additional scopes your cost is just that of the azimuth scale and a mount for the level ~$20 or so.
One other advantage this system has over traditional DSC is its ability to work with a scope that is not perfectly orthagonal. Any deviation from perfect orthagonality of the axis on a dob will cause a DSC to not perform up to its capabilities. This system is immune to that issue.
I am very interested to hear of your results with the total system on the platform. Please be sure and post your observations when you have the azimuth dial in place.
Den Mama
Reged: 05/14/05
Loc: montana
      #951132 - 05/11/06 11:16 AM
Thanks for letting us know Sears sells the "SmartTool".
My local hardware store & lumber had only the 24"level w/smart tool for $139! Couldn't order just the module; Sears, it is!
Carol
THESKY
Reged: 02/16/06
Loc: SOCAL
      #951316 - 05/11/06 01:37 PM
Oh yeah . . . forgot to include the price of the program (Equinox). It is $50.
I haven't bought it yet though - still using trial version. I like to try the planetarium with Palm pilot before purchasing. I know that the Palm is much smaller and easier to carry/store. But I like the big screen on my laptop -12". I can set to see the whole sky (180 degrees) or part of it (up to 5 degrees). I can also see both coordinates in RA/DEC and Alt/Az. One other advantage of Equinox over Planetarium is that I am able to use the program for tracking What it is invloved - I don't know yet. Oh yeah . . . one more thing MACs hardly crash . . . he he he . . .
So all in all the price for this HYBRID degrees setting is around $150.
Still way cheaper than a DSC which will cost me around $700 (the unit and the mounting kit)
(I use hybrid since the smartTool is digital for the Alt. But for the Az is analog)
Happy Tinkering people.
Ridwan
kestrel0222
Reged: 05/21/06
Loc: Milford, Michigan
      #1055054 - 07/22/06 06:08 AM
SkyArcher, what program did you use to create the great looking degree circle with? I need one for my scope, but my base is slightly larger than the 19" one you have in your PDF file. My base is 22" outside diameter and the width of the circle needs to be 3/4". Any thoughts on how I can make one of these?
SkyArcher
Reged: 04/12/06
Re: Degree Circles new [Re: kestrel0222]
      #1055130 - 07/22/06 08:29 AM
Hi Tom, I used AutoCad.
An easy way for you to do this is take the file to Kinkos
and have them enlarge the file by 115%. That will give you a 22" circle. Then while you're there, have them laminate it on both sides.
kestrel0222
Reged: 05/21/06
      #1055183 - 07/22/06 09:27 AM
Thanks, I guess since I work on a high end graphics sytem (CATIA V5) that I will just import that PDF file, plot it out at 115% scale (as you suggested) and I'll be all set!! I will have it laminated.
Clif
Reged: 07/19/06
Loc: Perrineville New Jersey
      #1055323 - 07/22/06 11:32 AM Attachment (493 downloads)
Similar approach: I discovered that the plotting accuracy of today's ink jet printers is quite impressive (on a Mac at least, don't know how well it works on a windows system) and the drafting ability of many drawing programs (MacDraw, ClarisDraw, Canvas, probably the CAD packages too) is just as good. Combining these, I have found that one can make setting circles which are very servicable by just drawing them on the computer, printing them out on the ink jet printer and laminating them to plywood circles using liquid epoxy. They are at least as accurate as 0.1 degrees which is about as good as you can read a circle anyway. I have even made verniers for the circles this way. If anyone wants details, I can expand on the technique. Attached is a picture of a 24" RA circle I made this way. The small divisions are one minute of RA in size. The circle is for a big reverse fork mount I am working on.
Astraforce Paul
Reged: 04/05/05
Re: Degree Circles new [Re: Clif]
      #1064589 - 07/28/06 11:20 AM
Clif, yes, please describe more about what you did. Do any of those programs automatically put the circle number in? I presume so. Is there a freebie program or demo program for the Mac that one could test this with? Anyone besides Cliff who knows please chime in, too!
I'm interested in rolling my own template (I like your BIG numbers--easier to read) with my own degree markings (e.g., longer 5 degree line, no outer checkerboard, etc.).
How did you handle the overlapping? I've found that my inkjet does NOT print to the border so that there is a white, unprinted border. It's a bit tricky overlapping the sheets.
Clif
Reged: 07/19/06
Re: Degree Circles new [Re: Astraforce Paul]
      #1129368 - 09/03/06 10:22 AM
No, everything is put in by hand, but it was not very difficult. The tic marks are really lines going all the way across that were put into final position by copying, rotating, grouping, copying, rotating, etc. The numbers had to be rotated also and individually placed. Masking white opaque circles with black borders were plotted on top of the maze of crossed lines to leave the tic marks sprouting from the edge of the circle. I used MacDraw Pro which is just the grown up version of MacDraw that used to be given away free with all Macs. ClarisDraw, Kalaidadraw and Canvas would probably have enough tools to let you do it, PC or Mac.
chmee
Reged: 05/11/05
Loc: Takoma Park, MD
Digital all the way? new [Re: csa/montana]
      #1131690 - 09/04/06 02:33 PM
How about using the smarttool w/ well-designed mount (a la Rod's) for altitude ($80 at sears), and a digital compass for azimuth (see also at sears, for example, $20), total price $100 plus tax.
I don't know how accurate the compass is. It only reads out to the nearest degree. However, Rod points out that by calibrating the smarttool mount onsite, one can get the altitude spot-on every time. This reduces the searching to just azimuth, and a search on only one axis is trivial.
The other problem w/ the compass is the magnetic declination, as pointed out above. However, one can look this up ahead of time (it appears to be 10 degrees 45' west for my location near DC), and compensate onsite.
Does this sound reasonable to anyone? Anyone have experience w/ digital compasses and have an idea how precise they are?
pete
Curt B
Reged: 08/02/05
Loc: Regina, Canada
Re: Digital all the way? new [Re: chmee]
      #1133696 - 09/05/06 07:23 PM
I use Planetarium on my Palm to look for my objects. There is an option for magnetic azimuth on it, so it should solve the problem of knowing what true north is. My only concern is will the metal OTA interfere with the compass?
chmee
Reged: 05/11/05
Re: Digital all the way? new [Re: Curt B]
      #1134694 - 09/06/06 09:52 AM
Good question. I ordered the cheap wayfinder from amazon ($17) and will try it this weekend. I don't have a big tube, but do have four long aluminum poles (2" diameter), so it would probably be similar. However, it's supposed to work inside a car or truck, w/ an indicator when bothered by interference from metal, so we'll see.
pete
Curt B
Reged: 08/02/05
Loc: Regina, Canada
      #1135648 - 09/06/06 07:33 PM
Looking forward to hearing about your results chmee....please keep us posted!
chmee
Reged: 05/11/05
      #1137639 - 09/07/06 08:23 PM
pete
No go, it only registers in increments of 5 degrees, and even that might be overstating its accuracy. My sense is that this is representative of other cheap digital compasses as well.
Oh well, at least it works quite well for its intended purpose, i.e. in the car.
Curt B
Reged: 08/02/05
Loc: Regina, Canada
      #1139412 - 09/08/06 07:53 PM
Sorry to hear that....was looking forward to hearing about your results...
YankeeJeff
Reged: 08/11/06
Loc: Brooklyn, NY
      #1139541 - 09/08/06 09:17 PM
I picked up the wayfinder v7000 for 50 bucks from overstock.com it's supposed to be accurate to 1 degree and I can set to true or magnetic north. I'll let you folks know how it works out. I don't really need it but I think it may be a cool looking gizmo to add on that also gives me the weather and some other neat tricks.
YankeeJeff
Reged: 08/11/06
Loc: Brooklyn, NY
Re: Digital all the way? new [Re: YankeeJeff]
      #1143802 - 09/11/06 10:57 PM
Update: Received and installed the Wayfinder v7000. IMHO, it does an excellent job (accurate to 1 degree + true or magnetic North settings). With the $9 Home Depot inclinometer and the Wayfinder 7000 digital compass ($50 refurbished from Overstock.com) the total system is about $60. If the digital SmartTool price drops enough maybe I'll get that too. Not a bad overall price for the results. It also works and I find it a bit easier to use. The down side - it costs more and defeats the purpose of doing this on a budget.
In any case, I will keep the setting circles on the scope just in case I'm ever observing in a location w/ strong magnetic interference. I can't thank you folks enough for the threads on this subject - it makes life a whole lot easier AND saves money!
Curt B
Reged: 08/02/05
Loc: Regina, Canada
      #1145445 - 09/12/06 07:46 PM
Thanks for the update....i just might get one too!
chmee
Reged: 05/11/05
      #1145739 - 09/12/06 11:01 PM
Wow, this I really didn't expect. Did you really give the compass a workout? I realize that it reads out in 1 degree increments, but does it repeatedly give the same value for the same orientation (place it against a wall, read, spin it a bit and place it back against the wall, read again)?
What about the backlight, can you keep the display on and backlight off for more than a minute or so?
I've already ordered the smartttool ($90 at amazon w/ an automatic discount) w/ the intent of replicating Rod Nabholz's setup. If this really works, I'd order it in a minute.
YankeeJeff
Reged: 08/11/06
Loc: Brooklyn, NY
      #1145879 - 09/13/06 01:37 AM
When I started using the compass tonight it was a little off. I had to recalibrate (takes about 30 seconds). This entails pressing the menu button once, pressing enter, spinning the base of the scope one full revolution, then repressing menu. I took off the suction cups of the compass and drilled it into the base to make it nice and tight. I also tightened the adjustment screw on swivel/tilt so that it basically can't move out of it's horizontal position. This also allows me to press the buttons without fear of knocking the compass out of it's holder. Your supposed to keep the compass (made for your car) in the same place w/in your car, thus I want to keep it in the same position on my scope.
Which brings me to one of the questions above: Did I
... the answer is no.
Again, I screwed the plastic compass holder into the base (the compass itself can be removed from the holder but I don't move it). On the contrary, I keep it nice and tight on the holder at a horizontal position with the base for most accuracy.
Before viewing I simply calibratrate, make sure magnetic declination is set, and then generally keep the bottom base in place as I slew the scope. I do occassionally move the entire telescope unit around the house from one window to another) and it doesn't seem to affect results. How it works outside I don't know yet. Maybe I'll test it this weekend if the weather permits. For now it seems to be working in my home. I'm finding things very quickly.
Generally the target objects (using starry night & skycharts software) are found within the FOV of my 32mm eyepiece. Once in a while they are slightly off and it takes a nudge on the AZ setting to get it in the FOV. Usually this happens because the AZ coordinate lies almost directly between two 1 degree increments (e.g. 87.467 degrees) - add that to the rounded off declination and you may be off about 1.5 degree total at times. All in all I can live with that. I'm happy with it thus far. I'll keep you posted and report any problems.
FYI - the backlight can stay on up to 3 minutes and when the backlight goes off, the unit stays on a bit longer before the auto shut off kicks in. The compass is plastic. I think this little unit is ideal for my situation because I don't have to fuss w/ Polaris or anything -which is good for me since I can't see it from my window.
Gigatron
Reged: 12/10/05
Loc: Staten Island, N.Y.
      #1146255 - 09/13/06 10:15 AM
Hey Jeff,
Got a couple of questions for ya.
1) do you think the v700 would work well in place of the v7000? The difference seems to be the thermometer and barometer. I don't think I really need those to see a star, as long as the compass is just as accurate.
2) how did you mount it to your scope? any pictures?
3) have a part number on that inclinometer?
Fred
kestrel0222
Reged: 05/21/06
Re: Digital all the way? new [Re: Gigatron]
      #1146311 - 09/13/06 10:46 AM
Jeff,
Are you able to set north to Polaris? How do you calibrate it to correspond with computer generated azimuth coordinates? It all sound good.
YankeeJeff
Reged: 08/11/06
Loc: Brooklyn, NY
Re: Digital all the way? new [Re: kestrel0222]
      #1147030 - 09/13/06 07:52 PM
Fred
1)The v700 gives the read-out in 5 degree increments. IMHO, this is not enough. I believe the v7000 unit has both critical components, namely the ability to correct for magnetic declination, as well as, giving read-outs in one (1) degree increments. There could be other units out there that have those same capabilites without the other bells and whistles for cheaper - I'm not sure.
2)I don't have the ability to post pictures right now.
Basically I screwed the compass into the swivel base board (toward the rear-end of the scope and directly opposite the front of the scope with the handle). If you can imagine placing the degree circle on the base board with zero (0) in the front - the compass would be screwed into EXACTLY where the 180 degree mark would be in the back. The compass should be screwed in tightly to the base. According to the instructions you can tilt the unit up or down within it's swivel bracket a maximum of 20 degrees but I found that not having a tilt at all is most accurate. Whatever angle you select for the tilt, the compass must stay that way (otherwise you'll have to recalibrate), thus I also tightened the side adjustment screw for the angle of the tilt so it doesn't accidently get bumped out of it's bracket.
3)The inclinometer was purchased at Home Depot (you won't find it on their website). It is an "EMPIRE magnetic polycast protractor" that can be purchased for a little less than $9.
I do not need to set North to Polaris - North is set magnetically by the compass and adjusted for magnetic declination. Once I turn on the compass and calibrate it (by pressing a button and spinning it in place one full revolution), I'm set to slew the scope to the coordinates I get from my planetarium software.
Gigatron
Reged: 12/10/05
      #1147654 - 09/14/06 10:05 AM
Thanks for the answers, Jeff. Just one more quick question, is there a particular reason that you mounted the compass where you did, or can it be put anywhere?
I mean, I have no problem mounting it at the rear, I'm just wondering if there's a reason.
Fred
YankeeJeff
Reged: 08/11/06
Loc: Brooklyn, NY
      #1148571 - 09/14/06 08:19 PM
I could be wrong, but I thought it would give me the most accurate reading -esp. when I'm trying to get down to 1 degree. Its placement mimics the finderscope placement - kind of like splitting the primary and seconday. When you step behind to read the display, its like you would in your car, i.e. looking at the compass display which gives the reading of the direction directly in front of you as you drive.
I guess it may be more convenient to place it to the left of the scope so I can just look down and take a quick read before peeking into the eyepiece but intuitively I'm thinking that wouldn't work. I guess you could try that out and test with a sky object. If it were not accurate, you might then readjust the declination to compensate. I'm not sure.
Gigatron
Reged: 12/10/05
      #1149325 - 09/15/06 09:43 AM
Well, here's my thinking on this; as long as the compass is facing forward (i.e. same direction scope is pointing), the readings should be just as accurate. 87* is 87* either under, above or along side the scope.
The only time I can see there being a problem, regardless of where the compass is placed, is when the object is at zenith.
When I get one, I'll mount it temporarily and see what happens if it's mounted along side the scope.
-Fred
chmee
Reged: 05/11/05
      #1150189 - 09/15/06 08:33 PM
Jeff.
I think the only real question is whether the compass will give precise, repeatable directions. I'm definitely looking forward to hearing your experience. Around here (DC), at least, we're going to get the first decent night in weeks tomorrow. Hope you have it as well.
I was thinking about the backlight. This is probably not a problem, as the screen could be covered by a red film.
pete
YankeeJeff
Reged: 08/11/06
Loc: Brooklyn, NY
      #1174324 - 09/30/06 07:48 PM
Update2: Believe it or not, I haven't yet had the opportunity to test the digital compass outside (Floyd Bennett Field is where I would go). The opportunity to step outside has been elusive and to be honest - it's nice and comfy inside and I've been learning a lot from the comfort of my own home. So, thus far I've had about 4 or 5 nights of testing indoors.
When I turn on the compass at the beginning of my viewing session, sometimes it puts an object in the FOV or sometimes it's accurate to about 1 or 2 degrees and requires some nudging to find the object. Thus far it has always been in the ballpark (under 5 degrees).
However, if I do a lot of moving around, which I usually do because of obstructions in the home and the limitation of window angles, it may eventually throw off accuracy by 5 degrees. Unfortunately, I've seen it get as bad as 8 degrees. I end up resetting the compass about 3 times a full night (i.e. 9pm - 5am). I also have a lot of electronic equipment around so I think it may contribute to throwing the thing off. In any case, even when it's off, I know I'm basically looking on the azimuth plane only so nudging is usually over quick.
So... I'm able to live with this non-precise degree of accuracy because it's tough for me sometimes to see Polaris (i.e. girlfriend won't give up the bedroom for the night!), and thus calibrating with other stars takes even longer for me. I would ideally need to test outside. When I'm at my outdoor spot, I'm basically planted in one area and just turn the scope's tube - I'm pretty sure it will work better in that scenario.
Until then, I'm not convinced this is the rock solid digital solution most are looking for. Perhaps there are better digital solutions out there that won't break the bank. It does happen to have a time advantage on the azimuth for me right now. This makes me appreciate that very accurate Home Depot inclinometer that much more. Also, I finally got my Telrad so the combo of finder-scope, Telrad, and this budget 'push-to' system seems to work well enough for me. Again - my humble thanks to the folks who started this thread and have therefore saved me time and money. Oh, and my apologies for folks who ran out and purchased a Wayfinder 7000 and may not be thrilled about it
chmee
Reged: 05/11/05
      #1178379 - 10/02/06 10:14 PM
Too late!
I had the smart tool for altitude, so decided to try the compass for azimuth. I was hoping for 2 or 3 degrees max, figured it was only $40 if not. I did not quite expect 8 degrees.
At any rate, given both devices, I mounted them on my scope last night and took it out to the driveway. I had more confidence w/ the inclinometer (smart tool), as others have used it successfully. W/ the wayfinder I had several concerns: 1) accuracy, 2) backlight, and 3) directionality.
For accuracy, concerns were justified. I calibrated the wayfinder and then used the magnetic declination setting to zero on polaris. I then tried to use the two to find things, with mixed success. My first attempt, M31, was off by 3 degrees of azimuth. M76 was found in the eyepiece (40mm, about 1.5 degrees). M92 two degrees off. Several stars were within a couple degrees azimuth, but two were four degrees off, and one was eight.
Interestingly, when I finally rotated all the way around, polaris was only one degree off. I'm speculating that the "map" of the surroundings the wayfinder makes during calibration is off. Perhaps this was because I didn't do it evenly enough or some such.
Another interesting point that didn't occur to me until afterwards was that I think the error was always in the same direction (of azimuth). If so, this would significantly ease the process. After all, searching in one dimension is much easier than searching in two.
As far as the smart tool, it was always within two or three tenths, at most.
My second concern was the wayfinder's backlight. Turns out this is not bright, is easily disabled, and actually somewhat useful. The wayfinder has to be mounted down on the rocker base, so it's a bit hard to see from up near the eyepiece. Situation might be different when I get to a dark site.
My last concern was directionality, by which I mean that the wayfinder is designed to be mounted on a dashboard, facing forward. Facing the compass in the directy my mount is facing would mean mounting in on the "back", i.e., I'd have to get off the chair and walk around the scope to read it. I put the wayfinder on the side of the scope, meaning that it's 90 degrees off, PLUS the magnetic declination. The wayfinder's magnetic declination can be set up to 99 degrees, which would seem to be enough. However, it didn't seem that way, I seemed to need more like 105. So I left it at 95, meaning that I have to add 10 to each azimuth I look up on the computer. No big deal.
Overall, it's good enough that I'm willing to spend another couple of evenings trying to work out the kinks. If I can't, I'll mount the wayfinder in my car and add a printed azimuth circle to the base (which will be a bit of a pain).
pete
YankeeJeff
Reged: 08/11/06
Loc: Brooklyn, NY
      #1178468 - 10/02/06 10:47 PM
*Gosh, dang dibbity dag nabbit* - sorry Pete. That first night it was only off max 1.5 degrees. It was w/ the longer nights that I saw how bad it could get at times. Now that I think about it, I was limited to a smaller part of the sky. Maybe your right about the direction of error and it’s not the 'moving around' that causes the errors as I thought it might be. I've got to check that out some more myself. Hope you work out the kinks.
chmee
Reged: 05/11/05
      #1179502 - 10/03/06 02:42 PM
Don't worry, I'm just messing w/ you. I'm a gadget freak and had to try it out. Might still work. Unfortunately, weather doesn't look promising here, plus the moon situation, so it might be a couple weeks.
kingjamez
Reged: 10/03/06
Loc: Washington D.C.
      #1216751 - 10/25/06 05:37 PM
First, thanks to all the contributors to this great idea. This is the best thing that has happened to me since I got started in astronomy.
Here's my question. I just got the system setup with skyarchers circle and an inclinometer (I found the Harbor Freight one the best). I'm using Planetarium for Palm. When I set Planetarium to AzM for Azimuth taking into account the earths magnetic offset, and then use a compass to calibrate the scope, it is always off. However if I use a compass to calibrate north and then turn the magnetic offset off, it works fine?
I'm not complaining since the system works, just curious if anybody knows why this is happening.
I live in Washington D.C. and the Magnetic Offset according to every place I've seen is about 11 degrees.
-Jim
Den Mama
Reged: 05/14/05
Loc: montana
Re: Digital all the way? new [Re: kingjamez]
      #1216955 - 10/25/06 07:47 PM
Jim: What I do is center Polaris, then move the "needle" (magnet on metal strip) to zero. From then on, it is extremely accurate. I don't use a compass at all. But if you have yours working, it doesn't matter how, just so it does work for you to benefit from the ease in which to find those elusive targets, especially when there are no bright stars nearby for placement. Have fun!
Carol
kingjamez
Reged: 10/03/06
Re: Digital all the way? new [Re: csa/montana]
      #1217249 - 10/25/06 10:28 PM
Ok, I figured it out. I had the time on my PDA set 1 hour ahead, which for the sun was about the same as the magnetic north offset. When I took it out tonight, I found the error and fixed it.
Wow... I have street lights all around me, I live in a townhouse with neighbors who don't turn off their patio lights. I can't even see polaris. However with the $12.00 "push-to" I was able to find things I've never found from my house before. In less than an hour with NO finderscope (including setup and discovery of the time error) I found:
M31
M32
M34
M27
M13
M92
All of these were either in my field of view or very close to it (using a truly Dobson 7x50 binocular eyepiece from a broken pawnshop pair). I could have hit more very quickly, but LOST was coming on.
I can now really stargaze from my backyard...even though I can't see polaris becuase of the light pollution!
Thank you Carol, Rod, and SkyArcher!!!
Edited by kingjamez (10/25/06 10:52 PM)
Laramie
Reged: 09/03/06
      #1289137 - 12/06/06 11:07 PM
Carol Can you please tell me who did the circles for you. I like the set up and would love to do the same on my dob.
Thanks in advance
Becky
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Laramie]
      #1289252 - 12/07/06 12:10 AM
For anyone interested in the pdf file from SkyArcher for the degree circles; here is the file:
http://www.cloudynights.com/ubbthreads/attachments/944499-Alt-AZ_Setting_Circle.pdf
GordonCopestake
Reged: 03/02/06
Loc: Newcastle-under-Lyme, UK
      #1289358 - 12/07/06 01:25 AM
Someone kindly sent me a 24" one for my 12" lightbridge
http://www.copestake.org/24DialWhite.pdf for those interested in making setting circles for a 12" lightbridge
Stefan Rostyne
Reged: 10/19/04
Loc: Assenede, Belgium
Re: Degree Circles new [Re: GordonCopestake]
      #1289567 - 12/07/06 07:32 AM
thx, Gordon!
Den Mama
Reged: 05/14/05
Loc: montana
      #1289726 - 12/07/06 10:18 AM
Gordon: Thanks so much for posting the pdf for a 12" LightBridge; now if someone would post one for a 10" base, it would help those with that size.
Again, thanks for your kind addition!
Carol
kestrel0222
Reged: 05/21/06
      #1289749 - 12/07/06 10:37 AM
Carol,
As was mentioned earlier in this post, all one would have to do is to figure out what scale factor they would need to make it to the appropriate size that they would need for their particular base size.
However, I had so much trouble trying to get the original PDF file (that SkyArcher made) to the right scale, that I designed my own for my 12” DSO. The problem WAS NOT with SkyArcher's file; the problem was with Kinko’s getting it done for me. They tried numerous times and NEVER got it right. That was when I decided to do it myself. I made the circle to the exact size that I wanted for my scope. That is the PDF file that Gordon posted.
I was reading the post that Gordon had posted in regards to his new 12" Lightbridge, he mentioned that he needed a circle that would fit his base, I thought, well, I have one that I made that worked for me, why not pass it on.
Den Mama
Reged: 05/14/05
Loc: montana
      #1289769 - 12/07/06 10:54 AM
Tom: Thank You!! There are many 12" Dob owners out there that will love you for this great addition to this link!
Again, my friend, many, many thanks for your contributions!
Carol
kestrel0222
Reged: 05/21/06
      #1289781 - 12/07/06 11:03 AM
Thanks Carol,
The circle that I made was designed to be placed on the bottom board (numbers in a clockwise direction). This requires that a small notch (I made mine 2” X 5”) to be made at the edge of the top board to view the circle thru. However, if anyone wants (or needs) one made to be places on the top board (numbers in a counter clockwise direction - 24" diameter), let me know, I will gladly make it for them.
Den Mama
Reged: 05/14/05
Loc: montana
      #1289792 - 12/07/06 11:08 AM
Tom: Again, thanks for your contributions, you rock!
Carol
GordonCopestake
Reged: 03/02/06
      #1289811 - 12/07/06 11:20 AM
i wasn't sure if you wanted to be named Tom, but once again, thanks for the circle! Very much appreciated!
kestrel0222
Reged: 05/21/06
      #1289814 - 12/07/06 11:23 AM
You are very welcome, Gordon. I'm just glad that I could help.
darklighteditor
Theatre King
Reged: 11/07/06
Loc: Land of Sparty
      #1292054 - 12/08/06 01:25 PM
Carol - I finally got around to reading your Degree Circles thread (due to lack of time, not desire) and from my initial read-through, what a great idea for the $12 "Push-To".
It seems like this would be an absolute "must have" for anyone with a Dob.
I have extra some vacation time I've accumulated which I'm taking off between Christmas and New Years, so that will give me time to tinker with it.
Unfortunately, we don't have a Kinkos or such nearby, so I'll be printing the plans separately on a 11- by 17-inch paper printer (which I'll have to figure out how to do it "piece-meal" by overlap). Luckily, I have a large laminator here at work.
I also plan to print out the thread and read it over closely, but I suspect you'll be hearing from me as I move along the process (I'm certainly not an engineer, but I have a knack for figuring things out - albeit sometimes slowly ).
John
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: darklighteditor]
      #1292071 - 12/08/06 01:36 PM
John: Thank you! It is such a wonderful, very inexpensive method. The best part, you can do it yourself. I've had a great time with it.
When you get ready, just fire away, & we will get you thru setting it up.
I've enjoyed so much, reading the posts from others that have employed this idea. That's what it's all about, sharing & helping!
Carol
darklighteditor
Theatre King
Reged: 11/07/06
Loc: Land of Sparty
      #1292104 - 12/08/06 01:50 PM
Thanks Carol!
I'm sure you'll be hearing from me.
And looking at my continously white CSC, I may be getting to that quicker than expected. Ya know, this weather has been something else this fall (and now heading into winter). Since I've received the 8-inch Dob from DBA exactly one month ago today, I've had a total of six nights viewing - that's 24 cloudy nights in a 30-day span. Percentage wise, it can't get any worse, can it??? I think this "Curse" has outlived its usefulness on my end. On the bright side, perhaps I'm simply getting the worse weather out of the way early...
John
Den Mama
Reged: 05/14/05
Loc: montana
      #1292143 - 12/08/06 02:28 PM
John, I agree about the weather; ordinarily, here we have many more clear skies than cloudy, but this Fall, up to now, it's been about 90% cloudy, 10% clear.
Perhaps we should all hide our scopes, & then sneak them out before the evil clouds see us!
Carol
GordonCopestake
Reged: 03/02/06
      #1292147 - 12/08/06 02:29 PM
You should come live in england hehe, it's 10% clear and 90% cloudy ALL the time!
And just to rub it in all our kit costs TWICE as much as yours hehe
Den Mama
Reged: 05/14/05
Loc: montana
      #1292151 - 12/08/06 02:31 PM
Plus you have that Damp cold!!!
Carol
nitroexpress
Reged: 12/16/06
Loc: Hemet, calif
      #1309177 - 12/18/06 12:17 AM
Carol:....
Thank you for your posts on the degree circles. Best thing since the invention of sliced bread......it made my 10" z10 into a push-to great scope.....i am using HNSKY for the computer ( laptop).....works well........thanks again for the best idea on the net....and to skyarcher for the degree wheel..................gary
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: nitroexpress]
      #1309556 - 12/18/06 10:11 AM Attachment (280 downloads)
Gary: A very Warm Welcome to Cloudy Nights! You have joined a great group here.
I'm so glad you are enjoying the setup. It's so simple, I'm sure many feel "No way can it work accurately"; but that's the great thing, simplicity equals accuracy!
If you have any questions, please don't hesitate to ask, we love answering questions, because that is how we learn also.
Again, Welcome aboard, & a very big thank you for taking the time to let me know about your success with the degree circles!
Carol
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1315539 - 12/21/06 10:35 AM Attachment (271 downloads)
The simplest ideas often work the best! I have followed this thread with interest having first come across this idea in Rod's web pages.
Electronic digilevels I looked at but were far too expensive for me. So while trying to find a placky inclinometer I was browsing Lidl's pages at the same time and spotted a digital spirit level. OK. the downside is that it is almost two feet in length, but the good thing is the digital unit screws out of the level itself! (Just as soon as I find my Allen keys!)Beeps every 10 degrees and has soft blue backlight that can be turned off. On the first very rough test I tried (holding the level gingerly along Dob tube!) it seemed pretty accurate. Just got to get the circle for the base printed off now.
All for a grand ... 29.99 euros! Lidl do their offers on a rotation basis each year so no doubt it will pop up again in the near future, for anyone wanting to track the unit down. FYI its got Paget Trading UK on it. Lidl are great for things like that, if you can manage to get there before all the retired people! (No offence intended!)
Anyway great job folks ... I just wanted to say thanks for telling us all about such a great simple idea.
(Today here in Athens, Lidl have Meade ETX70 GOTO, with backpack (which I saw for 55 pounds alone!), for 199 euros ... but I am being very good and keeping my hands in my pockets!)
Terry1229
Reged: 04/16/06
Loc: North, Idaho
Re: Degree Circles new [Re: drzeus]
      #1315719 - 12/21/06 12:15 PM Attachment (303 downloads)
I printed mine from a program i got of of this thread. It printed on to about 6 sheets of paper, then I glued them to some foamboard and cut it out. I am still in the process of finishing. I need to put a clear coat over the top.
Edited by Terry1229 (12/21/06 01:57 PM)
GordonCopestake
Reged: 03/02/06
Re: Degree Circles new [Re: Terry1229]
      #1315776 - 12/21/06 12:41 PM
they sell those digital levels on ebay. Not as cheap as lidl but still pretty good.
Den Mama
Reged: 05/14/05
Loc: montana
      #1315869 - 12/21/06 01:20 PM
Terry, it's looking great!
Let us know when you try it out!
Carol
Mike Moffatt
Reged: 07/13/05
Loc: Broken Arrow, Oklahoma
      #1316411 - 12/21/06 07:15 PM
Make a small red filter cover for it just like we all do for our laptops.
drzeus
Reged: 01/11/05
Loc: Athens, Greece
Re: Degree Circles new [Re: Mike Moffatt]
      #1317104 - 12/22/06 03:44 AM
Will do!
I assume this sort of gadget isn't affected if it gets a magnetic strip stuck on it so I can clip it to my scope tube? I know Rod's is held on magnetically ... I have no idea how these actually work or if anything in it can be affected by magnets. I only know there is so much metal in our building I cannot use a compass to line up so will have to go by visual sighting -hopefully using Polaris- to align everything.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1318608 - 12/22/06 10:12 PM
Will do!
Just by way of clarification, my digital level is held on its mounting bracket by velcro. It was the original analog inclinometer that was magnetically mounted.
Clear skies.....
Edited by rnabholz (12/22/06 10:13 PM)
Roger51
Reged: 09/05/06
Loc: Michigan
      #1322783 - 12/26/06 06:22 AM
Interesting thread. Could someone point me to the PDF file, I don't see it?
RS
Roger51
Reged: 09/05/06
Loc: Michigan
Re: Degree Circles new [Re: Roger51]
      #1322963 - 12/26/06 10:10 AM
Never mind found them...thx
Den Mama
Reged: 05/14/05
Loc: montana
      #1323012 - 12/26/06 10:42 AM
Roger: Welcome, sorry I didn't see you post in time to get you to the pdf file, glad you found it.
Any questions, just ask, we love to help!
Carol
drzeus
Reged: 01/11/05
Loc: Athens, Greece
Heads Up - Lidl UK - Digimeter new [Re: rnabholz]
      #1341481 - 01/05/07 05:56 AM
UK residents looking for cheap digital meter - Lidl has one coming up for sale from 11/1 for 24.99 UK pounds.
Having got Allen keys as a Christmas present (how sad?!) I have now released meter from the level!!
Thanks for the correction Rod. I played with the magnets around the meter and it didnt appear to affect it but I may have to use velcro anyway since I hid my magnets away so toddler wouldn't find them - now can't remember where they are!
Now waiting for some clear skies!
Happy New Year to all - let's hope we see some great things this year!
Den Mama
Reged: 05/14/05
Loc: montana
Re: Heads Up - Lidl UK - Digimeter new [Re: drzeus]
      #1342705 - 01/05/07 05:52 PM
D:rzeus: Happy New Year to you! Well, Allen keys, hmmm, they did let you release the meter from the level, didn't they?
Let us know how your "push-to" system goes.
Carol
darklighteditor
Theatre King
Reged: 11/07/06
Loc: Land of Sparty
      #1344001 - 01/06/07 11:24 AM Attachment (297 downloads)
Carol - Your $12 "Push-To" is right on the mark - That's exactly what I paid for mine! Although I must say working I for a newspaper did some some advantages.
While I gathered all of the needed materials during my week's vacation between Christmas and New Year, I wasn't able to complete the project until last night (too many "honey-do" projects around the house!).
First, I printed the degree circles at work. We don't have a printer quite large enough to print the entire 19-inch circle, so I ended up doing it "piece meal" in thirds. We have an old light table (from our old "hot wax" days of pasting up the newspaper prior to pagination) so I was able to carefully align the three pieces. Luckily, we also have a double-sided laminator.
I affixed the circle to the base with double-sided duct tape (yes, duct tape - it's a guy thing!)
We also had some strapping steel laying around at work so I used about eight inches of that on the front of the bottom base board attached with three stainless steel screws. I've had no luck in finding clock hands up here, so for the time being I found a package with four thin rectangular-shaped magnets ($1) to point the degrees and align with Polaris.
Now for the inclinometer. I has hoping to find a digital one, but again, living "Up North", no luck. After going to three stores, I finally found a Mayes level and angle finder used to deterine roof slopes and grades ($11). It's magnetic and is attached to the top of the scope (I wonder if the company knows these can be used as a "telescope accessory" ).
I'll use my old Boy Scout compass to determine north and I have a very small level to check the base. Plus the Stellarium program on my laptop gives Alt/Az coordinates.
Now all I need is for these clouds to clear out so I can give the new system a trial run (of course it's cloudy, I'm also waiting on delivery of two nebula filters I've ordered)!!
Thanks again for the great post and I'm looking forward to trying this out (it looks like I may have an opening tonight).
darklighteditor
Theatre King
Reged: 11/07/06
Loc: Land of Sparty
Re: Degree Circles new [Re: csa/montana]
      #1344010 - 01/06/07 11:26 AM Attachment (335 downloads)
Here's another pic of the entire system.
GordonCopestake
Reged: 03/02/06
      #1344020 - 01/06/07 11:31 AM
Being in the UK i plan on purchasing the lidl level for use with my system. I'm currently using a dial inclinometer but hopefully the digital one will be much more acurate
csa/montanaModerator
Den Mama
Reged: 05/14/05
Loc: montana
      #1344081 - 01/06/07 12:07 PM
John: Congratulations! I'm so glad you found the post useful; you will be amazed at the accuracy of this simple addition.
Please let us know how your first night viewing with the $12 Push-to System works.
We better not let the inclinometer manufacturers know it's an Astronomy accessory, or the price will sky rocket!
Thanks for the kind words, also!
Carol
kestrel0222
Reged: 05/21/06
      #1344471 - 01/06/07 03:36 PM
John,
Nice job! You'll find that this system will make a BIG difference in how you find objects in the night sky. Using this system along with a good planning software package, will certainly make viewing the night sky more enjoyable. Good luck and let us know how it works for you.
kestrel0222
Reged: 05/21/06
      #1344537 - 01/06/07 04:08 PM Attachment (369 downloads)
Here is a pic of the dial that I made for my 12" DBA base.
Den Mama
Reged: 05/14/05
Loc: montana
      #1344705 - 01/06/07 05:48 PM
Tom: Beautiful job! How did you cut the indentation out so nicely? I also like the red on the pointer, shows up more.
Carol
darklighteditor
Theatre King
Reged: 11/07/06
Loc: Land of Sparty
      #1344917 - 01/06/07 07:41 PM
Tom - that looks great!
Is that a small head nail painted orange? And I agree with Carol, nice job!
kestrel0222
Reged: 05/21/06
      #1345162 - 01/06/07 10:05 PM
Thanks Carol and John for the kind words!
Woodworking is just one of my favorite past times, as well as astronomy. I have a second base that I got from a freind, so what I did was to cut the notch out of the side of the top board, and covered the cut surface with a piece of the "edging" from one of the spear pieces that I had. I made it look as if it was made that way from the manufacturer of the base.
Yes John, that is a small "finish" nail that I bent and placed between (2) small magnets, one on each side of the nail. They are held together with epoxy glue and finished with black and red enamal paint. It works really well. I am able to see it in the dark to adjust it as need be. I did exactly the same thing on my 8" Dob as well.
spudrick
Reged: 10/22/06
Loc: Hoppers Crossing, Victoria, Au...
      #1353895 - 01/11/07 03:27 AM Attachment (342 downloads)
Well after quite a while and contacting Carol for some information i have finally finished my version of the Push-To. As i had a 12" GSO scope i already decided to replace the ordinary chipboard base by using it as a template and making it from plywood. So i had the circles printed/laminated and constructed the base, i also put full circle laminex (formica) under the top circle and new Teflon bearings, changed the plastic handle to Aluminium and inserted a bubble level into the base. I made adjustable screw feet to help with leveling and added side braces to help with stability. All up a pretty steep learning curve for me as i had no previous experience especially with a router and large circles. The mount is not perfect and there are quite a few mistakes but noted and in future i will have learned and improved (i Hope)
I also tracked down a digital inclinometer and have fitted it to a timber dovetail i made to take the place of the finderscope i can buy a new foot plate and fit it to the tube later so i can replace the finderscope.
There are so many innovations and really professional quality work shown on this project and i just wanted to show my version and say a big thanks to Carol (and others for contributions)
kestrel0222
Reged: 05/21/06
Re: Degree Circles new [Re: spudrick]
      #1353946 - 01/11/07 05:21 AM
Nice Job!!
Glad to see that it works for you!
marxy
Reged: 09/02/06
      #1353963 - 01/11/07 05:46 AM
OK - I just got me one of the lidl meters.
It's works great!
I just want to ask what is the best way to mount it to my scope? It's a skywatcher 8".
I want to make usre that when it's set on it, it is reading correctly, otherwise all my readings will be a degree or 2 off.
Edited by marxy (01/11/07 05:17 PM)
Den Mama
Reged: 05/14/05
Loc: montana
      #1355085 - 01/11/07 06:38 PM
Spudrick: Beautiful job! That's really a nice looking base.
Thanks for letting us know how it turned out for you, it is much appreciated!
You will really enjoy this system. Fitting the digital inclinometer on a dovetail is a great idea, not to mention the bubble level inserted into the base.
Very well done!
Carol
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: marxy]
      #1355091 - 01/11/07 06:42 PM
Doesn't the Lidl meter have a magnetic base? If not, at a craft store they sell packages of magnet sheets, that can be cut easily with sissors. You could glue a strip of this to the bottom, & then it will stay on the tube. It really doesn't matter where you mount it, I have mine about midway on the top of the tube (when horizontal).
Carol
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1356156 - 01/12/07 08:29 AM
My Lidl meter safely released and not so safely attached to tube with double-sided sticky tape (aka ord tape folded back on itself!)- nope doesn't have magnetic strip (and I have not found my magnets or my velcro!).
I just eye-aligned up on the tube. accuracy appears to be .2-.4 degrees of where it should be but this is still only by rough comparison with the altitude data on my Palm software (which may need long/lat tweaking). Doing a full turn on the base will let you know if anything is out of alignment because theoretically if all is levelled correctly you should get the same reading all round a full rotation. Found I don't need to use its blue backlight anyway because our streetlights are so bright (even on 3rd floor) I can pretty well read the digits straight off! (Time to purchase an air-rife to shoot said lamps off!)[Does that trick i read about of shining bright torch on sensor actually work?]
This is a brill thread - thanks to all out there for helping us all get going on this!
Den Mama
Reged: 05/14/05
Loc: montana
      #1356381 - 01/12/07 10:55 AM
Definitely make sure your Palm is setup with the correct information; otherwise you will always be off in locating objects.
If your viewing area is that bright, I would suggest you put up something to block the stray light, otherwise your viewing will suffer greatly. There are many ways to block light. light block screens
Carol
spudrick
Reged: 10/22/06
      #1357928 - 01/12/07 10:41 PM Attachment (334 downloads)
Hello Just to show the Inclinometer fitted to the finderscope dovetail and the bubble level inserted into the base board. I also have a 10" Dob i am seriously thinking about making a new plywood base for it as well it was fun making this one
Terry
Den Mama
Reged: 05/14/05
Loc: montana
      #1358117 - 01/13/07 01:08 AM
Terry: You did a great job mounting the inclinometer! Your base is as professional looking as anything I've seen! It's absolutely beautiful!
Carol
kestrel0222
Reged: 05/21/06
      #1358320 - 01/13/07 06:04 AM
Terry,
Nice job!!!!!!!!
GordonCopestake
Reged: 03/02/06
      #1358322 - 01/13/07 06:05 AM
Great setup Terry, I like the idea of using the inclinometer on the finder dovetail!
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1358730 - 01/13/07 12:28 PM
Carol thanks for the screen link - I have seen various ones about here but not that one. It is rather tricky because I am balcony based and that restricts my viewing angles already, but I do tend to use my rotary airer and a sheet to screen the lamps from up the road! (I won't attach any pics! ) But it is slowly getting worse - thank heavens Christmas is over and all the festive lights have gone at least (and I no longer have to listen to the constant repetitive jingly music they play either!). The sour cherry on the cake came when the local council came to fix one lamp and it now shines seemingly straight at my balcony which it never used to . So now I have no vision towards NNW-NNE. My view to NNE-SSE is totally blocked by our building and McNaught has been currently sat behind a tree in the evenings! Oh the astronmer's woes!
We are planning to move house but I have a tough time convincing hubby to include the criterion for telescope use in the house hunting!
Terry the meter looks excellent placed there and neat idea with the level - I must do something like that.
Keep all the great ideas coming folks - how much better can it get?!
Den Mama
Reged: 05/14/05
Loc: montana
      #1358955 - 01/13/07 02:45 PM
Is there a chance of contacting the utility company & asking them to put a shield on the light, blinding your balcony? About the worse that can happen, is for them to say no. It's definitely worth a try!
Carol
kestrel0222
Reged: 05/21/06
      #1358986 - 01/13/07 03:02 PM
Hey Carol,
I think that very subject came up in another thread a while ago and someone said that they actually did ask the electric company, and they did put up a shield.
Den Mama
Reged: 05/14/05
Loc: montana
      #1359150 - 01/13/07 04:32 PM
Yes Tom, someone did have luck, & a shield was placed on the offending light. As I said, it sure doesn't hurt to ask Nicely!
Carol
kestrel0222
Reged: 05/21/06
      #1360164 - 01/14/07 06:16 AM
I think the final (I know, never say final) upgrade for my scope will be digital inclinometer. I have been putting it off because of the price (nearly $100), but I think it will be a good investment in the long run.
Den Mama
Reged: 05/14/05
Loc: montana
      #1360707 - 01/14/07 12:26 PM
Tom: I know, that's really steep, (I don't have one!); maybe advertise for one?
Carol
GordonCopestake
Reged: 03/02/06
      #1360716 - 01/14/07 12:28 PM
Have a look on ebay, here in the UK they go for £30 ($60) I would have thought there would be something similar for cheaper than $100 available
Den Mama
Reged: 05/14/05
Loc: montana
      #1360838 - 01/14/07 01:11 PM
Thank you! That will give Tom a start; I haven't seen any other digitals than the $100.
carol
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1363137 - 01/15/07 04:02 PM
Carol and Tom I will give them a ring and see. I have to say I don't hold out much hope tho - this is Greece, and while it is my permanent home, these sort of things are a bit laughable. Unless of course I happen across a fellow star fan perhaps. But I will try, nothing ventured, nothing gained!
Also, can I ask a really dumb question?
viz the degree circle printout. Terry I see you took a piecemeal approach to printing - was that using the startrack program on hre? I have hunted about for a printers nearby to printout the pdf, but have had no luck tho a local place offeredto laminate my A4 printouts patched together. I can do the printout myself I reckon. My printer prints very crisply and it should be straightforward to do. But can someone explain how? From Adobe I can't get it to print anything other than odd sections. My printer will do poster print (ie multiple stick together pages) banners, reductions, enlargments etc but I can't figure out how to get this printed out. I have Photoshop and other software.
Also Carol (and others) I see your circles are under the tube support side panels, as opposed to being on the ground board. Was it easy to keep the circle well in place when the panels got screwed back in place? (with my electric screwdriver Santa brought me that should be easier than when I put it together!). Any tips gratefully accepted!
Den Mama
Reged: 05/14/05
Loc: montana
      #1363455 - 01/15/07 06:58 PM
Also Carol (and others) I see your circles are under the tube support side panels, as opposed to being on the ground board. Was it easy to keep the circle well in place when the panels got screwed back in place? (with my electric screwdriver Santa brought me that should be easier than when I put it together!). Any tips gratefully accepted (Quote)
My degree circle slid right under the ground board, I didn't have to loosen it al all. I will get ahold of another member to walk you thru the printing of the pdf file. He should pop on soon. Thanks for being so patient!
Carol
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1364164 - 01/16/07 03:53 AM
OK now I am confused (doesn't take much!)
Carol, you mean that your degree circles weren't actually full printed circles, just the outer inch or so with the scale on? Was that one complete piece itself? Sorry if that sounds dumb, I am just trying to visualise it all - I had the impression it was one whole circle stuck to one whole circular base. I guess it is pretty easy to make sure it is properly aligned all the way round? I am just thinking of ways error can creep in here - but as long as you follow the base perimeter everything should be aligned as well as that itself is.
I can just picture the faces when I go to get something like that laminated! Well, being a foreigner here I can get away with seeming eccentric. My neighbours have at least stopped peering at me suspiciously whenever I am out on the balcony with binocs or scope! I shall look even more daft when I try to see McNaught after midday today
Thanks for the quick response.
Den Mama
Reged: 05/14/05
Loc: montana
      #1364530 - 01/16/07 10:42 AM
Drzeus: My degree circle was printed out on one large sheet of paper; the Altitude scale was in the middle. I had the entire sheet laminated at Staples, front & back for $2.
Then, I simply cut out the Altitude scale, affixed it w/ double-stick tape. Then I cut the Azimuth circle out (just cut the center portion up to the degrees), & again used double-stick tape to hold it in place. If you have the correct size for your base; there is no concern about error, when placing it.
I hope this helps you a little! Just keep asking questions, believe me, I asked so many questions with this project, that it almost was embarrassing!
I admire you for going ahead with this project, you will certainly gain much benefit when complete!
Carol
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1365144 - 01/16/07 04:15 PM
Brill thanks Carol, much as I thought. It will certainly be easier doing it that way than unscrewing everything.
I have a few improvements I want to make to my Skywatcher but I had to wait so so long to own a telescope I am really hesitant to get in there and get dirty in (unlike how I usually approach everything else!) in case something doesn't go right.
This is going to be so good ! Thanks for all the encouragement - it's great when you read about things that can be done and, hey, other people are doing them why not me?!
Now ... if only we had Staples here!
Edited by drzeus (01/16/07 04:18 PM)
Den Mama
Reged: 05/14/05
Loc: montana
      #1365411 - 01/16/07 06:08 PM
I'm like you, I don't want to mess with things, in case I can't get them back the way they should be
What you end up with is a "ring" with the center cut out; much easier!
Carol
spudrick
Reged: 10/22/06
      #1374259 - 01/21/07 07:13 AM Attachment (323 downloads)
Update: trying the circles made me realize that without a light it is not too good to see the scale during the night. So after a bit of playing around with LEDs and how to mount it i decided to use the original plastic handle supplied with the scope. This has a natural 45 degree edge so i drilled a hole from the backside of the handle and threaded a LED through to where the handle bolt connects then drilled a smaller hole parallel to the bolt hole and threaded the wires though to the inside of the base, connected a 12V DC plug and as you can see from the photo lights up and right on target!.
kestrel0222
Reged: 05/21/06
      #1374335 - 01/21/07 08:56 AM
That's a great idea!!! I'm going to look into that for my scopes. Thanks for shearing your idea and photos!
Den Mama
Reged: 05/14/05
Loc: montana
      #1374947 - 01/21/07 02:46 PM
What a fantastic idea! I always have to use my red flashlight; Don't know anything about wiring, but am going to try this!
Thanks so much, great photo!
Carol
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1375000 - 01/21/07 03:13 PM
Oh this thread is great! Spudrick that is so cool. I have seen a couple of people use led's like this - great idea.
I mananged to print my circles out on several A4 sheets ... bit floppy so i tracked down a printers that did it in one piece: even tho it was 52x52 cm he initially printed it out 58cm! (My print was much better quality too tho ). I have since realised a slight problem in that I have got into the habit of moving my base around a fair bit whilst viewing (due to being on a balcony I have to get in close to the railings to go high and go back from the railings to go low), which will mean realigning frequently. So I may have to go the metal strip + indicator way. Plus I definitely need a bubble level for the base. (Goody, a trip to a hardware store !!!!!)
spudrick
Reged: 10/22/06
      #1375111 - 01/21/07 04:12 PM Attachment (288 downloads)
Thanks guys just to show a bit of how i wanted it to look neat the drawing shows how i drilled through the handle and put the LED at the angle then threaded the wires through to the base at the back
kestrel0222
Reged: 05/21/06
      #1375122 - 01/21/07 04:19 PM
That's nicely done!! I'll have to give it a try. Thanks for shearing the drawing with us!!!
Den Mama
Reged: 05/14/05
Loc: montana
      #1375348 - 01/21/07 06:01 PM
Spudrick: You definitely are not a newbie, in my eyes!
Great idea, & exceptional drawing!
Thank you, for adding to this thread.
Carol
darklighteditor
Theatre King
Reged: 11/07/06
Loc: Land of Sparty
      #1376138 - 01/22/07 12:52 AM
Spudrick - What a fantastic idea!
I knew that handle on the front of the Dob base was good for something.
Den Mama
Reged: 05/14/05
Loc: montana
      #1398768 - 02/02/07 10:17 AM
Here is a new link to a digital inclinometer that our member Doug found & used, when he installed his degree circles system. It is much less expensive than the Sears model:
Wixey digital inclinometer
Thanks all for keeping up all the contributions to this thread!
Carol
kestrel0222
Reged: 05/21/06
      #1398829 - 02/02/07 10:55 AM
Carol,
Thanks for the link! I have been considering the Smarttools (Sears) inclinometer, but it is just too expensive for me. This one from Wixey sounds like it will work great for what I need it for. I have seen a few other ones, some are geared toward the auto industry. But this one by Wixey is the least expensive one that I have seen so far. It looks very basic and easy to use!!
jayscheuerle
Reged: 01/16/06
Loc: S. Philadelphia, PA
      #1398874 - 02/02/07 11:16 AM
Also note that it retains its "zero" setting when off, so that once you zero it to horizontal, you're good to go. This isn't mentioned in the specs, but I got the info from Barry Wixey himself.
kestrel0222
Reged: 05/21/06
Re: Degree Circles new [Re: jayscheuerle]
      #1398883 - 02/02/07 11:20 AM
Jay,
Thanks, I was wondering if you had to "zero" it out every time you turned it on.
Den Mama
Reged: 05/14/05
Loc: montana
      #1398906 - 02/02/07 11:26 AM
Jay: It's a win/win tool! I like the more compact size also, not to mention the compact price!
Carol
kestrel0222
Reged: 05/21/06
      #1399223 - 02/02/07 02:12 PM
I just ordered a digital angle gauge from Wixey at 12:35 PM via their website. I got an email confirmation of shipment by priority mail at 2:07 PM!! They said I should have it by Tuesday the latest.
Wow, now that’s customer service!!!
Den Mama
Reged: 05/14/05
Loc: montana
      #1399231 - 02/02/07 02:15 PM
Wow! Good going!
Carol
Terry1229
Reged: 04/16/06
Loc: North, Idaho
      #1399597 - 02/02/07 05:47 PM
Me too!
Den Mama
Reged: 05/14/05
Loc: montana
      #1399664 - 02/02/07 06:26 PM
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1403569 - 02/04/07 04:36 PM
What a neat little unit, with magnets too and at an amazing price. Well found!
Terry1229
Reged: 04/16/06
Loc: North, Idaho
      #1405567 - 02/05/07 03:55 PM
I have degree circles all mounted and ready, but the sky sucks. So I need to ask a question.
I have been trying to calibrate the setting circles, and there is something I have missed. When you set the Alt scale, is 0 sit when the scope is pointing at Polaris?
And is tha AZ 0 set to magnetic north , or off set
kwalker
Reged: 08/22/06
Loc: Oklahoma City, OK
      #1405588 - 02/05/07 04:08 PM
Yes, align your scope to polaris and then move your pointer on the magnet to Zero and your set. Are you using an inclinometer with your setup also?
kestrel0222
Reged: 05/21/06
Re: Degree Circles new [Re: kwalker]
      #1406999 - 02/06/07 05:25 AM
Well,
I ordered my Wixey angle gauge on Friday afternoon and it arrived yesterday (Monday)!! Wow, that was fast!! This is a nice little devise, it is only 2" x 2" x 1". All you have to do is set the "zero" and you are ready to go. Once the "zero" is set, you never have to do it again, just turn it on and go. Oh ya, it has a magnetic base!
It does take a about a second to stabilize, but I don't see that being a problem at all. I really like this gauge, it does exactly what I need it to do, plus the price is right, $40 (with free shipping). I was considering the more expensive Smarttools gauge, but I kept putting it off because of the price. I’m glad I did, because now I have a gauge that is not only smaller, but it is less then half the price. If you have the extra $40 for this gauge, I think it is well worth the money.
Den Mama
Reged: 05/14/05
Loc: montana
      #1407316 - 02/06/07 10:07 AM
Tom: Great deal! No holding you back with the $12 push-to now!
Carol
kestrel0222
Reged: 05/21/06
      #1407324 - 02/06/07 10:12 AM
All I need know are clear skies and the temp to rise a little!!
Mr Magoo
Reged: 11/05/05
Loc: Franklin, Indiana
      #1418093 - 02/11/07 02:45 PM
Where did you find that inclinometer Spudrick?
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Mr Magoo]
      #1418130 - 02/11/07 03:03 PM
Don't know if this is the one you are mentioning: It's much cheaper than the SmartTool, & accomplishes the same thing; it's also much more compact!
Digital inclinometer
Carol
neoweb
Reged: 12/10/06
Loc: UK
      #1418177 - 02/11/07 03:26 PM
Gordon, do you have a link for a UK store that sells these... i've just started out on the idea of degree circles for my Dob and want to be sure i'm getting the right equipment - i'm not too DIY savvy you see!
So the inclinometer will give a reading showing the altitude at which the telescope is pointed?
And all credit to Carol for starting this thread!
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: neoweb]
      #1418234 - 02/11/07 03:50 PM
So the inclinometer will give a reading showing the altitude at which the telescope is pointed? (Quote)
Yes, then when you want to find an object, you look up their location; Azimuth & Altitude, from any astro program, put your base & tube to these readings, & there it is! (Be sure to first center Polaris, then put the Azimuth dial to zero).
And all credit to Carol for starting this thread! (Quote)
Thank you for the kind words! I'm very glad so many have installed this easy & economical system to make their viewing more pleasurable!
Carol
neoweb
Reged: 12/10/06
Loc: UK
      #1418301 - 02/11/07 04:22 PM
Thanks, Carol! For the inclinometer do i just need to put the Dob tube exactly vertical and set the inclinometer to zero or zero it after I've centred Polaris?
If i used software like Stellarium (which i can quickly and easily access on my PC from my viewing location) would it simply be a matter of entering my exact location by way of latitude and longitude and then looking up an object's position? Is Stellarium accurate enough for something like this?
Of course, i still have the Azimuth circle to worry about, but one step at a time... i'm still reading the posts in the thread.
Mr Magoo
Reged: 11/05/05
      #1418880 - 02/11/07 09:11 PM
The azimuth circle is actually quite easy to make if you have AutoCad or some other drawing program. I drew one today in a very short time. I have been thinking about drawing up a whole bunch of different diameter ones for people to use and posting the files here. One thing I'm not sure how to do is how to convert the AutoCad files into PDF files that folks can easily work with. I'm sure it is something very easy to do. I only have Adobe Reader so that may be a problem. Can the copying centers such as Kinkos print from a dwg file?
Mr Magoo
Reged: 11/05/05
      #1418913 - 02/11/07 09:28 PM
I saw the link for that one Carol. That is a great deal and I will be ordering one of those. Spudnik has a different one on his that looks good too. I've also been considering putting on DSC's using David Ek's plans and a Palm Pilot.
neoweb
Reged: 12/10/06
Loc: UK
      #1419463 - 02/12/07 07:39 AM
Very useful. That gives a 19" circle... i don't have the measurements to hand for my Dob base but i suspect it is a little bigger than 19" in diameter. If i just enlarged the image in that PDF file proportionately would that be OK?
Den Mama
Reged: 05/14/05
Loc: montana
      #1420007 - 02/12/07 01:37 PM
There's a post somewhere, in this thread, on how much to enlarge the pdf file for different size bases; can't put my finger on it right now, but it is there.
Carol
neoweb
Reged: 12/10/06
Loc: UK
      #1420264 - 02/12/07 03:40 PM
^ That's OK... got Photoshop to do it.
kingjamez
Reged: 10/03/06
      #1420271 - 02/12/07 03:42 PM
To print the PDF in the correct size in tiles:
All you need to do is (using windows) click on print then select the "current view" option. The preview window will change and display the percentage scale of the document. Change your view percent scale until the print percent scale is the correct percentage of 19" to fit your base.
-Jim
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: kingjamez]
      #1420289 - 02/12/07 03:50 PM
Jim: Thanks for helping the other member out!
It's appreciated.
Carol
jayscheuerle
Reged: 01/16/06
      #1421481 - 02/13/07 07:32 AM Attachment (295 downloads)
Finally got mine done. Along with the Wixey Angle gauge up top, my azimuth circle rotates fully independently of the scope. I can set the scope up, point it at Polaris, and then move the circle with one finger until the arrow (which is on the side of the scope) points to 0.
It's been a month since the scopes been out, but I can't wait to use it (along with all the other mods I've done....)
Great idea! - j
Den Mama
Reged: 05/14/05
Loc: montana
      #1421790 - 02/13/07 10:58 AM
Jay: Great job, looks like a professional job!
Thanks for posting the pic.
Carol
kestrel0222
Reged: 05/21/06
Loc: Milford, Michigan
      #1421805 - 02/13/07 11:04 AM
Nice work Jay, looks great!!!!
Mr Magoo
Reged: 11/05/05
      #1422699 - 02/13/07 07:51 PM
Jay,
That looks fantastic! Looks like it was made to be there when the scope was new. Why in the world don't the manufactures offer this? Seems like it would be a simple no brainer to add during production. A few questions Jay. What is the scale printed on? Do you have a way to lock the scale in once it is aligned?
Onslowe
Reged: 01/28/07
Loc: North East England
      #1423556 - 02/14/07 09:57 AM
Neoweb, i have just got the Wixey gauge in the UK for £33.90 inc delivery from a company that advertises on ebay "The Wi-Fi Antenna shop", it arrived 2 days after ordering. It needs setting to zero before you use it, I used a bubble level and managed to get it dead level (turn the Wixey gauge the opposite way to check for same reading to ensure correct 0.0 reading, thanks to Stargazers Lounge forum for that tip). I levelled my scope horizontally by eye and checked it, got 0.1 on the gauge not bad ! As far as I know you do not need to check with Polaris, I tried it between the clouds on Castor, Rigel etc and using Stellarium I was within 0.3 of a Degree and the stars were quite central in my 25mm eyepiece Not bad, so thanks to everybody on this thread for their advice. I have fitted the degree circle to the base but have not had chance to try it yet but so far so good.
Onslowe
jayscheuerle
Reged: 01/16/06
Re: Degree Circles new [Re: Onslowe]
      #1423607 - 02/14/07 10:31 AM
Ken, the scale was just printed at Staples on their large format printer. After roughing a sheet of clear acrylic with sandpaper, I spray-mounted the scale on (after I had trimmed it out into a circular ring). I put several coats of polyurethane on it, routed the shape out, hand-sanded the edges smooth, and then painted the exposed acrylic with satin-black enamel on the top and outer edge.
There's no need to lock the scale. It has no contact with the scope itself as it sits outside the diameter of the roller bearings by a couple inches. It's a ring and I have a triangular arrangement of 3mm cylindrical stops that the inner edge of the scale rides against. My routing must have been off a little as it doesn't rotate perfectly smooth (like butter), but "catches" in areas and there's a little more friction. I suppose I could make the stops abrasive and they'd wear down the high spots over time...
kestrel0222
Reged: 05/21/06
      #1423608 - 02/14/07 10:31 AM
I'm glad to hear the the Wixey gauge works for you. I too am using one of their gauges and it is great!!! The size is just perfect!!! Once you set the "zero", you never have to set it agian!!!
Terry1229
Reged: 04/16/06
Loc: North, Idaho
Re: Degree Circles new [Re: kestrel0222]
      #1423817 - 02/14/07 12:22 PM
Do you set it on a level surface to calibrate, or point the scope to polaris then zero it?
Onslowe
Reged: 01/28/07
      #1423920 - 02/14/07 01:10 PM
Set it on a level surface as far as I am aware, though I have just got the gauge and due to cloudy skies I have not had chance to try it out properly.
Onslowe
kestrel0222
Reged: 05/21/06
      #1423929 - 02/14/07 01:15 PM
Just place the gauge on a level surface, turn it on, and select the "zero" button and you are all set!! Once you do this, you never have to set the "zero" again. Next time you use the gauge, just place it on your scope and turn it on, that's it!! It remembers that you have already set the "zero". Good luck!!!
Onslowe
Reged: 01/28/07
      #1424387 - 02/14/07 05:09 PM
Well the clouds broke and I gave it a try (no Azimuth circles working yet). In my Mag 4.5 skies using the 9x50 finder and Wixey angle gauge I easily found M78, m35,m36,m37,m38 and M1 !! The angle gauge was spot on every time, no messing about leveling the base of the Dob, justset the Alt and moved the Azimuth slowly around until the object came into view in my 25mm eyepiece (not the best eyepiece as it came with the scope). About 10 years ago I spent £400 on didgital setting circles for an Eq Vixen GP mount, loads more hassle with not much better performance compared to the £33 Wixey gauge. You know it makes sense to get one.
Onslowe
neoweb
Reged: 12/10/06
Loc: UK
      #1425382 - 02/15/07 07:59 AM
Neoweb, i have just got the Wixey gauge in the UK for £33.90 inc delivery from a company that advertises on ebay "The Wi-Fi Antenna shop"...
Many thanks, just ordered one! ... now back to the degree circles.
spudrick
Reged: 10/22/06
      #1430807 - 02/18/07 12:52 AM
Hello Sorry for not answering have been away. I found the inclinometer from searching the internet for chinese manufacturer http://www.gemred.com/en/product.asp
i see they have updated the product list with what looks suspiciously like the Wixley model.
as i am always over there on business i got a friend to get a "Sample" for me cost US$40. Here in Australia the only one i could find was built into a laser level and was pretty expensive.
neoweb
Reged: 12/10/06
Loc: UK
Re: Degree Circles new [Re: SkyArcher]
      #1431492 - 02/18/07 12:07 PM
Hi all... well, I'm getting there slowly but surely. I've attached an azimuth scale to the Dob's ground board. Now I need to cut out a small section from the top board through which I can sight the scale. Some questions if i may:-
1. Should this cut-out be made at the very front of the top board directly below the centre of the OTA?
2. To align for azimuth, do I centre Polaris through the eyepiece and, whilst keeping the OTA where it is, turn the ground board independently until the zero/zero point appears at the front?
3. I've ordered this digital inclinometer which should be arriving shortly
4. I plan to use Stellarium to get the alt/az readings as I can access it on a PC close by the scope.
Thanks in advance for any help.
kestrel0222
Reged: 05/21/06
      #1431535 - 02/18/07 12:40 PM
I cut the notch in my top board on the same side as the eyepiece, that way it is easier to see and make any adjustments.
The digital angle gauge that you ordered is the same one that I have, and it sure works great!! All you have to do is to set it on a level surface, turn it on, and press the "zero" button to set it to 0°. That is it, you never have to set the "zero" again, just turn it on and go!
neoweb
Reged: 12/10/06
Loc: UK
      #1431559 - 02/18/07 12:53 PM
^ Thanks, Tom. So cut the notch on the same side as the eyepiece, then for alignment centre Polaris in the eyepiece and, whilst keeping the OTA where it is, turn the ground board independently until the zero/zero point appears at the notch?
Beri
Reged: 06/29/05
Loc: Croatia
      #1431653 - 02/18/07 01:34 PM Attachment (238 downloads)
Here is how I resolved the initial az setup problem..
The ring with the azimuth protractor turns independently from ground board and az bearing....
So, the procedure is
1. Level scope
2. Aim Polaris (or any other object)
3 Adjust az protractor until desired number is under the ponter
This is much more convenient that trying to keep the tube aimed at an object while adjusting the base..
kestrel0222
Reged: 05/21/06
Re: Degree Circles new [Re: Beri]
      #1431830 - 02/18/07 02:58 PM Attachment (256 downloads)
Cut the notch and take a piece of metal strapping about 2-3" long and attach it to the inside surface of the surface that you just cut. This way, you can use a magnetic pointer for the fine-tuned adjustment to 0° for polaris.
In the picture below, I am able to adjust the pointer from about 74° to about 87°. This is only an example of the amount of adjustment I have built into my scope.
Beri
Reged: 06/29/05
Loc: Croatia
      #1433006 - 02/19/07 02:08 AM
I like that magnetic pointer idea, seen that somewhere before
Here is another variation :
More about this scope
And, the "grandpa" of my "push to" scopes , my old white 8" dob:
Azimuth circle with magnetic pointer
Altitude protractor, it doesn't get any cheaper
The computer, a vintage HP DOS palmtop PC.
Main advantage : LCD screeen with no backlight, so it doesn't mess up your dark adaptation, clearly readable with dimm red light.It runs on 2 AA batteries for months.
Software :
Its free, and can be downloaded here
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1433311 - 02/19/07 09:38 AM Attachment (215 downloads)
2. To align for azimuth, do I centre Polaris through the eyepiece and, whilst keeping the OTA where it is, turn the ground board independently until the zero/zero point appears at the front.......
I placed the notch in the base on the eyepiece side, just a lot more convenient to not have to move from the observing position to line up the pointer.
As Tom and Beri have mentioned, having some way to adjust the scale or the pointer is important. It is impractical to have to move the base to calibrate the azimuth reading.
On my scope, I built about 20 degrees or so of adjustability in the azimuth scale. The entire scale can be turned to match the appropriate reading.
Good Luck with your system.
lerock
Reged: 03/23/06
Loc: Arizona Coast
Re: Degree Circles new [Re: rnabholz]
      #1433727 - 02/19/07 01:29 PM
I wished the digital compass had worked better, it would solve many problems. I may try a hand held digital compass that sells for about $60 & claims 1 degree accuricy.
lerock
Reged: 03/23/06
Loc: Arizona Coast
Re: Degree Circles new [Re: lerock]
      #1433819 - 02/19/07 02:19 PM
Well, the more I read the specs, it's accually only +/- 2* accuracy. By the way, the compass tried earlier in this thread has a +/- 5* accuracy....
kestrel0222
Reged: 05/21/06
      #1433860 - 02/19/07 02:36 PM
The digital compass (in my opinion) is not accurate enough to be used for astronomical targeting. I still rely on my manual setting circles with my Wixey digital angle finder. This seems to be a pretty good match.
Den Mama
Reged: 05/14/05
Loc: montana
      #1433909 - 02/19/07 02:54 PM
Mike: Why is the magnetic compass important to you? Once you center Polaris, adjust your Azimuth scale needle to zero, you are ready to go! If using the digital inclinometer, I don't even have to level the scope. Rarely, is an object completely out of the view, & when it is, it's because I got sloppy on setting the degree needle.
It sounds difficult, & yet it sounds so simple that one thinks, no way can this work; but it does, indeed work beautifully.
I appreciate everyone's input to this thread, it's been a great help to all!
Carol
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1433940 - 02/19/07 03:06 PM Attachment (255 downloads)
I have to agree with Tom, it is pretty hard to beat the accuracy of a 20" dial that you can buy for about $10 - no batteries, no magnetic interference from metal scope parts, no worries about magnetic declination.
Tom's Wixey inclinometer at $40 is a great value too, less than half the cost of the SmartTool that I used.
A $50 system with electronic altitude accurate to .1 and azimuth accurate to (conservatively) a half degree is a very cheap and precise set up- less than half the cost of encoders alone for a DSC system!
Rod
lerock
Reged: 03/23/06
Loc: Arizona Coast
      #1433969 - 02/19/07 03:15 PM
I too have the Wixey & setting circles. but with a compass you would not have to worry about finding north, you could just drop it & go, much like you do with the Wixey. I'm very lazy, I'm always looking for the easest way to do something. But, at least for cheap money, the compasses arn't their yet. I'll break down & buy the Tech 2000 drive system, it motorizes the dob & the motors have built in encoders for about $700, but that is not what this thread is all about. Thank you Carol, this is a very good thread...
Beri
Reged: 06/29/05
Loc: Croatia
      #1434048 - 02/19/07 03:55 PM
Well, this is not completely true. Depending on the relations of the aim of the scope (or to be precise, the inclinometer), and the inclination of the base, errors are larger as you get near zenith..
For example, the scope is pointed due North, and the base is tilted, low on the east, high on west.
When the tube is horizontal, the error is 0. But as you rise the tube, since the axis of the altitude bearings is tilted, the scope will point a few degrees to the NE, allthough both the azimuth and altitude scale tell you that the scope is pointed at Polaris...
Same situation, the scope pointed due east or due west, you will not get any error when using a inclinometer, because the altitude axis is parallel with the ground
When I carefully level the scope, I always get the desired object inside a 1º field, using both az and alt scales printed on paper...
Den Mama
Reged: 05/14/05
Loc: montana
      #1434113 - 02/19/07 04:28 PM
Using a scale without a level base is problematic because while you can always set the scale to match an inclinometer determined setting, when you turn the rocker on the base, the scale reading will be off immediately and will not be exactly accurate until you return it to the same azimuth you set it at.
Now, depending in the degree of deviation from level, this error could be small, but it could also be very large and make finding things in a one degree or so field of view very difficult.
The inclinometer takes away the possibility of this error, and so makes it the choice for me. The analog inclinometer mentioned in this thread is about $10, a cheap efficient solution.
Of course leveling the scope is another option, and actually, I do both to make things as accurate as possible.
Rod Nabholz (Quote)
I've been told that the inclinometer reads true angle of the tube, regardless of the base angle. It certainly doesn't hurt to level the base, but I never have, & have very good results.
Carol
Beri
Reged: 06/29/05
Loc: Croatia
      #1434128 - 02/19/07 04:39 PM
Carol
Yes, your altitude is always correct (or to be precise, its just a small fraction of a degree off, presuming a perfect inclinometer) when the base is tilted
But azimuth is not, the error is more prominent as the tube points higher, easily 3º or even 5º depending how uneven the ground is..
To get rid of it, you need to level the base.
Edited by Beri (02/19/07 04:41 PM)
Den Mama
Reged: 05/14/05
Loc: montana
      #1434156 - 02/19/07 04:52 PM
Ahh, I see what you mean! Thanks for clarifying it!
Carol
Beri
Reged: 06/29/05
Loc: Croatia
      #1434157 - 02/19/07 04:52 PM Attachment (286 downloads)
Maybe this will help you understand the problem
In red, there is obvious drift in azimuth, when the base is tilted, althoug both the azimuth scale and the inclinometer show correct values. As you can see, the error in altitude is small, negligble, but azimuth is serious
Beri
Reged: 06/29/05
Loc: Croatia
      #1434160 - 02/19/07 04:53 PM
Carol
Well I guess I was too slow drafting this up
marxy
Reged: 09/02/06
      #1440789 - 02/22/07 02:53 PM
Hey all.
I will be picking up my 8" dob on tuesday next week, and have already prepared all I need (hopefully).
I want to know how people have attached te diital inclinometer?
I have removed mine from it's holer, but how can I attatch it to the OTA?
Thanks alot - this thread has been a great help
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1440900 - 02/22/07 03:54 PM
Which Inclinometer did you buy and what kind of scope, (Truss vs Tube, tube material, etc.)?
marxy
Reged: 09/02/06
      #1440928 - 02/22/07 04:12 PM
It is the lidl one from england - I can't find a webpage for it.
it isaccurate to +/- 0.3 degrees and has a metal finish to it.
It is to mounted on a skywatcher 8" - solid tube (I think it is metal)
Den Mama
Reged: 05/14/05
Loc: montana
      #1441498 - 02/22/07 09:04 PM
Marxy: Does it have a magnetic strip on the base? If not, I would glue a magnetic strip on the base, & then it will just "stick" wherever you want it on the tube.
Carol
marxy
Reged: 09/02/06
      #1441974 - 02/23/07 03:57 AM
csa/montana - It doesn't have anything magnetic on it (nothing a quick trip to the hardware store won't fix though), so I'll stick on a magnetic strip.
Thething is, are all OTAs magnetic?
I tried it once by puttg a fridge magnet onto my antares refractor and it didn't hold at all!
kestrel0222
Reged: 05/21/06
      #1441999 - 02/23/07 05:17 AM
My refractor is aluminum, not steel.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1442317 - 02/23/07 10:09 AM Attachment (190 downloads)
Velcro is another option for non magnetic surfaces. The industrial strength stuff will hold it just fine.
Is there any chance magnets will interfere with the mechanism in the unit? I admit that I don't know how they work. Anybody know for sure, or anybody using magnets and getting along OK?
Den Mama
Reged: 05/14/05
Loc: montana
      #1443746 - 02/23/07 10:48 PM
If a fridge magnet won't adhere, then as Rod suggests, velcro would work fine.
You will enjoy this system so much!
Carol
marxy
Reged: 09/02/06
      #1444843 - 02/24/07 02:14 PM
Won't the velcro mean that the measurer isn't aligned completely with the tube (since it sticks up slightly) and will give a sligtly 'false' reading?
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1446328 - 02/25/07 10:06 AM
If you mounted the velcro on the bottom of the level, there is some possibility you could introduce some small error. In practice, I believe it would likely be very small and could probably be avoided with careful attachment of the level to the velcro.
Another approach would be to bolt a short piece of angle aluminum directly to the tube and then place the velcro on the upright of the aluminum and the back of the level. You place the level on the base of the aluminum and slide it back into the velcro. Doing it that way you can assure that the level will match the angle of the tube.
If you want the next level of accuracy, you could take the approach that I used (as pictured above) and build a mount that allows you to adjust the level to match the readings of the computer.
You could always start the simple way - velcro to the tube- and see if you see a problem with errors. If you do, it would be easy to take it off and go to the next step.
marxy
Reged: 09/02/06
      #1446387 - 02/25/07 10:43 AM
Thanks a lot for all te advice - at least I've got plenty of cloudy nights to fiddle with this
Mr Magoo
Reged: 11/05/05
      #1449811 - 02/26/07 10:50 PM
Sears has their digital levels on sale right now or at least they do in my area. If you are a member of the Craftsman club, there is an additional discount. They have a 10" model and a 24" model. The 10" was $35.00 ($15.00 off regular price)and the 24" was $45.00 ($25.00 off regular price).
Den Mama
Reged: 05/14/05
Loc: montana
      #1449872 - 02/26/07 11:25 PM
Steve R. (Conus) was very kind to give this link for degree circles. This would be of help for those having trouble getting the circles enlarged & laminated.
degree circles/manufactured.
My thanks to Steve R. (Conus)!
Carol
drzeus
Reged: 01/11/05
Loc: Athens, Greece
      #1463847 - 03/05/07 04:53 PM
I always wondered what that part of your gear was for! Now I know. Neat idea.
danner
Reged: 02/27/07
Loc: Bay Area, Cali
      #1490818 - 03/18/07 11:52 PM
What is a good, relatively inexpensive Palm to use with this degree circle system?
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: danner]
      #1491330 - 03/19/07 10:45 AM
Danner, go down the forums to Computers, & at the top of that forum I believe they list quite a few programs for the Palm. I myself, have a Dell Axim, using Pocket Stars.
Thanks for looking at this thread!
Carol
hansolo
Reged: 12/10/05
Loc: lebanon,pa
      #1515670 - 03/30/07 05:55 PM
can someone tell me if instead of using degree circles if you could use the angle meter mounted on scope and a gps mounted on scope set to digital compass if this would work just as well
thanks
rnabholz
Reged: 07/25/04
Loc: Iowa
Re: Degree Circles new [Re: hansolo]
      #1516098 - 03/30/07 10:16 PM
My understanding is that most GPS units must be in motion to provide an accurate bearing. Mounted to a relatively stationary scope would cause the unit to provide what I would think would be relatively unreliable data, at least data that would likely fall outside a usable range for this purpose.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1516323 - 03/31/07 12:25 AM
In addition, there has already been some discussion here about how most digital compasses is really not terribly accurate.
hansolo
Reged: 12/10/05
Loc: lebanon,pa
Re: Degree Circles new [Re: BradC]
      #1516546 - 03/31/07 07:46 AM
ok now that that is answered i have look through the threadbut can not find a link unless i missed it where to print the circles so can someone send me a link or file to print out the circles themselves this just seems like i have to do this project on monday or tues when im off
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1516721 - 03/31/07 10:11 AM
For anyone interested in the pdf file from SkyArcher for the degree circles; here is the file:
http://www.cloudynights.com/ubbthreads/attachments/944499-Alt-AZ_Setting_Circle.pdf
Here is the link
hansolo
Reged: 12/10/05
Loc: lebanon,pa
      #1517244 - 03/31/07 04:53 PM
thanks
Tom Andrews
Reged: 01/25/07
Loc: Albuquerque, NM
      #1545788 - 04/15/07 01:15 PM
I used my Craftsman Inclinometer last night and at 34 degrees the LCD display started to fade. I put it in my coat pocket in between uses and kept it warm enough to work properly. I'll have to get some of those lithium batteries that Rod was talking about.
I spotted objects last night with my 10x60 binos (due to extreme light pollution), used the level to take the alt reading, then transferred the level to both my scopes, set the alt reading and had the objects in my field of view using a 32mm eyepiece. The level worked great!
I got my az dial printed/laminated yesterday at Staples (same price as Kinko's) but didn't have time to install it on the scope; maybe today.
My "Push-To" system will have cost ~ $40.00 (the Sears inclinometer costing $30.00) and seems as though it will work as well as the "GoTo" systems albeit, manually. I can handle $40.00 vs. $500. for the DSC's!
Thanks to everyone that contributed to Carol's thread on "Push-To" systems and thanks Carol for getting it started.
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Tom Andrews]
      #1545862 - 04/15/07 01:57 PM
Tom: You are most welcome! The credit goes to all the other members that have also contributed to make this a great, informative thread, such as you!
Carol
martini man
Reged: 12/07/06
      #1547526 - 04/16/07 12:05 PM
I have revied this thread and was wondering if anyone has a template for the groundbox of a 10" DSO scope. I noted that some have said that you can adjust the scale (of the 8" or 12" I assume) to make the right size. How do I do that?
Thanks and clear skies -
MM
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: martini man]
      #1547587 - 04/16/07 12:33 PM
MM: If you take the measurement of your base & the PDF file to Kinkos, Staples, etc. they should be able to adjust the size for your base.
I went thru the whole thread, I thought someone had posted it for the 10", but alas, I didn't find anything.
Carol
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1547705 - 04/16/07 01:33 PM
Carol mentioned her "first light" thread, but I didn't see a link. I've posted the link so it doesn't get buried too deep, and because it has some nice additional pictures and good discussion:
My $12 Go-To test drive
Edited by BradC (04/16/07 02:23 PM)
Den Mama
Reged: 05/14/05
Loc: montana
      #1547741 - 04/16/07 01:46 PM
Brad: Thanks for your kindness in posting the link!
Carol
sleepwalker
Reged: 04/16/07
Loc: Australia
      #1549171 - 04/17/07 06:57 AM
I feel its appropriate that I should use my first post to add my voice of appreciation for those responsible for the 'How to', photos and PDF file in this thread.
Truly one of the most useful I've ever come across. And thanks to it, my Father and myself down here in Oz now have nice push to systems on our 10 & 12" scopes (we went with the Wixey gauges).
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: sleepwalker]
      #1549392 - 04/17/07 09:55 AM
Sleepwalker: a very Warm Welcome to Cloudy Nights! We are most happy to share the forums with you & your father!
Please don't be hesitant to post your experience with this, you can start a thread, describing your first time out with the "push-to", or add it right here.
That's the beauty of Cloudy Nights, everyone is eager to share their ideas, & help with the members. We all, at one time or another, started out as a total beginer, & I know from my own experience, I have the knowledge today, because of other members that reached out a hand to help & encourage me along the way.
So again, Welcome to the greatest Astronomy website, CN!
Carol
Tom Andrews
Reged: 01/25/07
      #1554103 - 04/19/07 02:25 PM Attachment (331 downloads)
Here's my version of the azimuth setting circle. It's not as professional looking as the other versions posted here but a much more simple setup and just as functional. It allows easy adjustment of the dial once aligned on an object. I had Staples print out/laminate the dial then attached it to foamboard (the hobby store had foamboard with its own adhesive which made the process very easy). Staples cost $6.00 and the foamboard was $6.00.
I borrowed this version from the man I bought my 8" dob from back in 1992. He had installed the same design on that scope.
I'm posting several pictures to show how it goes together. For the altitude reading I'm using the Craftsman digital level (inclinometer - $30.00).
Thanks again to all on this forum for their help with special gratitude to Rod (rnabholz) and Carol (csa/montana) for their extended help.
Tom Andrews
Reged: 01/25/07
      #1554107 - 04/19/07 02:28 PM Attachment (615 downloads)
Picture 2
Den Mama
Reged: 05/14/05
Loc: montana
      #1554109 - 04/19/07 02:29 PM
And a special thanks to you also, Tom. It's all the great input from all the members that posted here, that has made this thread a nice addition, to help others utilize this system.
Carol
Tom Andrews
Reged: 01/25/07
      #1554112 - 04/19/07 02:30 PM Attachment (264 downloads)
Picture 3
Tom Andrews
Reged: 01/25/07
      #1554119 - 04/19/07 02:32 PM Attachment (239 downloads)
Picture 4
Tom Andrews
Reged: 01/25/07
      #1554123 - 04/19/07 02:34 PM Attachment (237 downloads)
Picture 5
Tom Andrews
Reged: 01/25/07
      #1554137 - 04/19/07 02:40 PM Attachment (242 downloads)
Picture 6
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1554211 - 04/19/07 03:25 PM
Tom,
You are welcome - glad to help.
Nice install on your scope, looks like an easy job, and one that is easily reversible without damage to the original finish. Well done.
Clear Skies,
Sader762
Reged: 06/29/06
Loc: East Texas
      #1555254 - 04/20/07 01:48 AM
Carol
10" Dob w/ a 22" base - 19" pdf file scaled to 115% gives you a 22" printout. It's somewhere around pages 5 or 6.
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Sader762]
      #1555649 - 04/20/07 09:36 AM
Thanks for your help!
Carol
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1555855 - 04/20/07 11:13 AM
Tom-
Looks good, and easy!
So I take it the dial stays fixed in the center, and the base rotates around it? Is it easy to read from the eyepiece, or do you have to contort around to see where you are at?
martini man
Reged: 12/07/06
      #1555913 - 04/20/07 11:41 AM
19" pdf scaled to 115% - What is the method for this? Printer settings, set to free scale, and up the percentage?
I love being computer literate!
Clear Skies -
MM
Tom Andrews
Reged: 01/25/07
      #1556393 - 04/20/07 03:25 PM
Brad,
The dial stays fixed to the ground board bolt and the box spins around it (as you said).
It is not readable from the eyepiece - that is a definite drawback to this design. Looking at the picture, the focuser is on the left side so I set my "0" alignment at the left back corner. So it's just a step or two back and forth. I'm still playing with options, I may try using the front left corner. Carol and Rod's setup is definitely more user-friendly. I'm real okay with mine because at this time I'm using a laptop computer which is set up a few steps away from the scope. I have to walk to it to get coordinates so as I walk back to the scope I stop at the back to set the azimuth first then the altitude. I'm in the market for a PDA and will Velcro it to the scope next to the inclinometer. At that point I may wish I had a different set up but I'll deal with that if/when it happens.
Tom Andrews
Reged: 01/25/07
      #1556423 - 04/20/07 03:37 PM
MM,
In my case, I just took the pdf file to Staples on a flash drive. They had a chart to figure out exactly the percentage based on the size you want. I needed 17.25" and it came out exactly that. The equation that Sader used is the same used at Staples only they have it printed out on a chart. That was my experience.
Sader762
Reged: 06/29/06
Loc: East Texas
      #1557113 - 04/20/07 10:00 PM
Clear Skies -
MM
I just did mine at Kinko's tonight - $14. You take the size you need and divide it by the 19" drawing/pdf file that is listed in this thread, that gives you your factor scale.
Example:
22" base (10" dob) needed
19" pdf file drawing
22/19 = 1.158 or 115.8% scaled up
17-1/4" base
19" pdf drawing
17.25/19 = 0.908 or a scaled down facor of 90.8%
You can go into setup in the printer screen and usually tell it to scale up or down a drawing. I wanted the clean look and had mine plotted out at Kinko's, I then cut it out there and had them laminate it. Hopefully I'll have it together in a few weeks.
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
      #1571471 - 04/27/07 10:40 PM Attachment (240 downloads)
Another satisfied Wixey Angle Gauge customer , seen here on my Z10.
I originally ordered from Wixey, but they sent out an email saying it was out of stock until early May . I couldn't wait that long, so I ordered it from Woodcraft (had to pay shipping ) and got it today.
I ran a couple tests this evening before the clouds rolled in. Used some easy to find targets to check - Moon, Venus, Saturn and the beehive cluster. Every one of them was right where Stellarium and the Wixey said they would be. Now for the next challenge - the dreaded azimuth scale!
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: HockeyRulesX4]
      #1571523 - 04/27/07 11:16 PM
Looks great! Nice scope, you will really enjoy the system!
Carol
Tom in FLA
Reged: 04/08/07
Loc: SpaceCoast, FL.
      #1572100 - 04/28/07 10:43 AM
Hey Dave what did you use to mount your gauge to the Z10? Let us know when you do your azimuth scale, it looks a little tricky with the Z10 base.
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
Re: Degree Circles new [Re: Tom in FLA]
      #1572877 - 04/28/07 07:20 PM
That's the beauty of the Wixey gauge - it's got 3 magnets on the bottom of it so it just sticks to the Z10 tube. My only wish for this gauge would be some form of backlight.
I've been pondering the azimuth scale too. I keep going back and forth between the way Carol did it (top side of the bottom base board) or the way some others have done with attaching it to the ground board and notching the bottom base board.
Does anyone think either approach is better than the other?
Den Mama
Reged: 05/14/05
Loc: montana
      #1572952 - 04/28/07 08:13 PM
Dave: I think it looks better to notch the top board; I had no way of doing that, so I took the easy way.
Either way gets the same result; Satisfaction! I like the link that the poster added a tiny red light to view at the notch.
Thanks for posting! Let us know how it goes.
Carol
Tom in FLA
Reged: 04/08/07
      #1572989 - 04/28/07 08:36 PM
I realize the Wixey has magnets but for some reason I thought Dave's picture looked like he had a bracket on his, I guess not. I'm leaning towards notching the top base board myself.
BobW
Reged: 12/29/06
Loc: Mebane,North Carolina
      #1573080 - 04/28/07 09:23 PM
I got my Wixey angle gauge on Monday. Maybe I got the last one:)
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1576318 - 04/30/07 01:05 PM
For convenience, I think that notching the top board and placing the scale bewteen the top and ground board has one significant advantage.
By doing it that way, you can place the pointer in a position that rotates with the focuser - the natural position for the observer to be in while at the scope. You can always see the pointer without moving around the scope.
By placing the pointer on the ground board, there will be times when you have to walk around the scope to see the pointer and then return to the eyepiece. Not quite as convenient.
Having said that, both systems will work, and nobody should let this issue prevent them from putting this system in use on their scope. Just do it in whatever manner fits your idea of convenience, your skills or your whatever other preference you might have.
Good Luck
Den Mama
Reged: 05/14/05
Loc: montana
      #1576501 - 04/30/07 02:35 PM
By doing it that way, you can place the pointer in a position that rotates with the focuser - the natural position for the observer to be in while at the scope. You can always see the pointer without moving around the scope. (QUOTE)
Absolutely! I wish I could have notched my board. I have to get up each time to see where the pointer is on the scale. Good exercise, but frustrating!
Carol
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
      #1577047 - 04/30/07 06:32 PM
Thanks! I wanted a couple opinions before I got out the trusty jig saw. Stopped by Kinko's today and got the 22" azimuth scale. $9.82 printed and laminated.
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
      #1579185 - 05/01/07 02:34 PM Attachment (270 downloads)
I think I'm all set
Thanks to Carol and everyone else for leading the way!
Edited by HockeyRulesX4 (05/01/07 02:35 PM)
Den Mama
Reged: 05/14/05
Loc: montana
      #1579232 - 05/01/07 02:49 PM
Dave: Beautiful job! Looks very professional. Now all you have to do, is get out under the night skies & enjoy it!
Thanks for posting your picture!
Carol
Tom Andrews
Reged: 01/25/07
      #1585379 - 05/04/07 01:34 PM Attachment (274 downloads)
Here's a picture of my current az setting setup. I used an aluminum tent stake that I cut off to fit. The clip-on light my wife found at CompUSA at the check out stand. It has two LED's, uses a small lithium battery (replacable), is totally flexible and extremely lightweight. I used a red permenant marker to color the lens. It works so well I bought another to clip on my astronomy equipment toolbox.
This setup works very well though I don't like the less-than-professional look. I'll be experimenting with various other ideas in time.
csa/montanaModerator
Den Mama
Reged: 05/14/05
Loc: montana
      #1585479 - 05/04/07 02:28 PM
Tom: Quite an ingenious way to light the "pointer"! I like it!
Thanks for sharing the photo with us.
Carol
Philip Levine
Reged: 03/22/07
Loc: near Boston, MA
      #1587711 - 05/05/07 08:21 PM
SkyArcher,
Thanks very much for the pdf file of degree circles.
Phil
Roger51
Reged: 09/05/06
Loc: Michigan
Re: Degree Circles new [Re: Philip Levine]
      #1596965 - 05/10/07 05:16 PM
I just purchased a 16 Lightbridge. Does anyone know what the degree circle size is for this scope? I would like to have everything ready so when I assemble for the first time I can add the degree circle as I put it together.
Roger
Rob Willett
Vendor (Degree Circles)
Reged: 02/07/05
Loc: London, UK.
Re: Degree Circles new [Re: Roger51]
      #1597021 - 05/10/07 05:35 PM
Just in case it helps, this thread has a link on how to generate setting circles of any size. The size is only limited by your printer.
Cloudy Nights Setting Circles
Roger51
Reged: 09/05/06
Loc: Michigan
Re: Degree Circles new [Re: Rob Willett]
      #1597205 - 05/10/07 07:20 PM
Thanks Rob I was going to use the formula provided above (size of base/ 19) However, I don't know off-hand the size of the 16" Lightbridge base? I was hoping someone who has the scope would be able to give me the dimension.
Roger
Rob Willett
Reged: 02/07/05
Loc: London, UK.
      #1597789 - 05/11/07 01:08 AM
I've got no idea about the size of the base I'm afraid. The setting circles program will work to any size, if you have access to a large plotter, it could handle A0.
Shout if you need a hand to get it working once you find the size of the base.
Den Mama
Reged: 05/14/05
Loc: montana
      #1598141 - 05/11/07 09:16 AM
Roger: There are a couple that have the 16LB that have posted reviews. Just PM on of them, or ask this question in a new post in the forum, & I know one of them will be more than happy to measure the base & give you the diminsions.
Carol
Philip Levine
Reged: 03/22/07
Re: Degree Circles new [Re: csa/montana]
      #1598274 - 05/11/07 10:48 AM
Hi Carol,
I've been reading about your success with the "go-to" system, using degree circles.
I have a couple of questions. I am still a little unclear about lining up the zero on the degree scale with the "sliding" pointer. I read you center Polaris in your scope, then set the degree circle "sliding" pointer to the zero mark on the degree circle scale.
So, do you first roughly set the degree scale to zero when you first setup to view Polaris, then center Polaris in your scope and fine adjust the "sliding" pointer to zero?
Have you tried using a compass to align the degree circle to zero? Just wondering which method is easier or more accurate.
I just received the Wixey digital angle gauge (neat), and have the pdf file for the degree circle. What did you use to mount the degree circle to the base, glue?
thanks so much for the wonderful info,
Phil
Den Mama
Reged: 05/14/05
Loc: montana
      #1598400 - 05/11/07 12:08 PM
Phil: Thank you! When I line up my scope in the beginning, I do adjust the base so that "0" is "north" facing. Then I line up Polaris in my eyepiece, & then it's just a matter of fine-tuning the "pointer" to "0". I have not used a compass, there you get into declination, etc., which to me, just complicates the process. The system I use is very accurate.
I just used double-stick scotch tape to attach the degree circles. I just applied some in about 1" strips in about 6 places around the circle.
You will be amazed at how accurate this simple system is! Good luck, & please post your results!
Thanks, Phil!
Carol
Sader762
Reged: 06/29/06
Loc: East Texas
      #1623932 - 05/24/07 07:04 PM
I had some difficulty getting my push-to system working right at first. It ended up being the settings in the program I was using. Here is a second "first light" report:
Well I got to get out and play for an hour last night. I went out and I guess I caught the sxy between the thunderstorms and it was pretty good skies. I dragged out the Orion 10 XT and quickly set it up. Jupiter was as high as it was going to get so I quickly set up to observe it. Not too bad considering the seeing conditions. Very steady seeing, the 4 moons on one side looked really cool, I was able to catch moderate banding but no spot. Overall a fairly good session with Jupiter.
I quickly grabbed the palm and found out the coordinates for Jupiter and I set up off that. I did not level the scope, instead I had it on my back yard wood deck. I then had a good direct view of Sagittarius. In 45 minutes I was able to catch 10 or so M objects by using the new push to system. Almost always the object was in the eyepiece or really close (I used a GSO 2' 26mm eyepiece - it's good for finding objects). I was very pleased with the system and saw more last night in 45 minutes than I have seen in hours of other observing sessions.....
Here are the mods I did to it:
1. Push-to system with new ground board
2. About 9 magic sliders between the ground board and the Az. board
3. Added a Telrad
4. Complete flocking of the OTA
5. Added a permanent compass to the Az. board
6. Added a light to the push-to pointer
7. Complete cleaning of the optics, darkening the back of the optics, and a good collimation
8. Added a keychain ring to the declination springs to make motion smoother
This scope is a very smooth moving scope that holds well when you stop the direction motion. I am very pleased with how everything turned out. Thanks to everyone for all the help and leading the way......
Den Mama
Reged: 05/14/05
Loc: montana
      #1623979 - 05/24/07 07:27 PM
Sader762: Congratulations on a great job modding your scope. I'm so glad you find the degree circle system working so well for you. The simplicity of this fools people into thinking that it couldn't possibly be accurate; thanks for pointing out the opposite!
Again, Congratulations, & also thanks for your post & photos.
Carol
Sader762
Reged: 06/29/06
Loc: East Texas
      #1624498 - 05/25/07 12:59 AM
Thank you Carol for leading the way on this great mod for us "Dob-Heads".......
Den Mama
Reged: 05/14/05
Loc: montana
      #1624831 - 05/25/07 09:22 AM
You are most Welcome! I'm very excited so many have applied this system to their Dobs and are enjoying it.
shmish
Reged: 04/22/07
Loc: Vancouver BC
      #1625813 - 05/25/07 07:28 PM
Here is another source of digital inclinometers. This one has magnets on the sides and not the base. I think the easiest way to use it is to level it on its side then press zero. Now when it is upright it will read 90°. So when you stick it to your tube and the tube is pointing straight up you'll get 90°. It's called the Tilt Box from Lee Valley.
Philip Levine
Reged: 03/22/07
Degree Circles, Wixey, Red LED light new [Re: csa/montana]
      #1626067 - 05/25/07 10:55 PM Attachment (301 downloads)
Hi All,
Finally finished modifying my Zhumell dob, with degree circles, Wixey, AND Cyclopes red LED lights (purchased for about $12 ea. at Cabelas.com). The small red LED (has 3) is battery operated, I attached one to illuminate the Wixey, and one to illuminate the degree circles.
Thanks to all for the great ideas and help (especially csa/montana, skyarcher, rnabholz).
See photos.
Now all I need are clear skys!
Phil
Edited by Philip Levine (05/26/07 09:28 PM)
Tom Andrews
Reged: 01/25/07
Re: Degree Circles, Wixey, Red LED light new [Re: Philip Levine]
      #1626719 - 05/26/07 11:50 AM
Philip,
Congrats on your setup! You're not going to believe how many objects you'll see with this system. I've been observing off and on since 1995 and in the last month since I finished my "Push-To" system, I've logged more objects than all previous years combined.
By the way, your hyperlink isn't working. I keep getting an error message. I would like to see your pictures. To attach here, type your post, check the box at the bottom which says,
"I want to preview my post and/or attach a file."
Hit the "Continue" button which will give you a preview of your post and a box at the bottom to attach files. It gives you a "Browse" button so you can easily locate your picture files.
Enjoy the sights!
Philip Levine
Reged: 03/22/07
      #1627523 - 05/26/07 09:30 PM Attachment (264 downloads)
Another photo with Cyclopes red LED
Den Mama
Reged: 05/14/05
Loc: montana
      #1627594 - 05/26/07 10:39 PM
Phillip: Fantastic job. I really like the lights!
I'd like to thank all of you also, that have installed this, contributed to the thread, because each one of you adds a little more to the system, which makes it better for all!
Carol
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: shmish]
      #1627596 - 05/26/07 10:40 PM
Smish: Thanks for the link!
Carol
veebs2
special label
Reged: 03/13/07
Loc: DeKalb, IL
Re: Degree Circles, Wixey, Red LED light new [Re: csa/montana]
      #1630326 - 05/28/07 03:43 PM
I got my push-to system completed yesterday afternoon and thankfully last night was perfectly clear. With the push-to system and Stellarium, I was able to locate M13 (which had eluded me), M5, M81, M82, Saturn, Venus, Jupiter and the Moon. Even though the moon washed everything out, it was very exciting knowing I will now be able to locate items in the sky. Thank you to everyone who has contributed to this thread!!
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles, Wixey, Red LED light new [Re: veebs2]
      #1630387 - 05/28/07 04:20 PM
Paul: Congratulations & thank you for your "first light" with the great, simple system.
Glad to hear it's working so well for you!
Carol
Tom Andrews
Reged: 01/25/07
      #1630394 - 05/28/07 04:24 PM
Paul,
Congratulations! You're going to have hours of great observing with this system. I finished mine a month ago and the only other problem besides weather is there aren't enough hours in a night to see everything! If you can stay out late enough for Sagittarius to come up, it's full of clusters and nebulae; one of the best constellations! It doesn't come up until midnight here in Albuquerque, at least not high enough for me to see it with all the obstructions.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Degree Circles, Wixey, Red LED light new [Re: Tom Andrews]
      #1631203 - 05/29/07 01:10 AM Attachment (257 downloads)
This thread has definitely intrigued me! After studying it for a few weeks now, I decided to make a "push-to" system for my LightBridge. It certainly won't cost $12, but its going to be cool! After many nights of calculations, I came up with a circle diameter that will work for me.
I went down to Staples and had them print the circle and then laminate it. I'll post my progress here, as it's going to take atleast a week to finish it.
Many thanks to all who have posted on this thread, and the many pictures to go along with.
Tom Andrews
Reged: 01/25/07
Re: Degree Circles, Wixey, Red LED light new [Re: Sky Captain]
      #1631226 - 05/29/07 01:46 AM
Kerry,
Be sure to post your pictures after completion and then your experience using it.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1631476 - 05/29/07 08:49 AM
...and the many pictures to go along with.
Will do Tom.
I have an up coming star party to test it out on.
jack45
Reged: 07/07/03
Loc: Lacey WA
      #1632889 - 05/29/07 10:00 PM
Carol
Many thanks!
I'm doing two scopes now with your plans and will save a lot of money! Again, great job!!!
Clear Skies!
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles, Wixey, Red LED light new [Re: jack45]
      #1632938 - 05/29/07 10:30 PM
Jack45: You are most welcome! I'm so glad so many of my fellow observers are using this great "system"!
Be sure to post pictures & your first lights with both your scopes!
Carol
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1633073 - 05/30/07 12:16 AM Attachment (257 downloads)
Well, its going a little faster that I thought. I'm putting a big twist on my setting circle design. Here is the second step. The photo shows the 3-axis router table cutting the disc that the setting circle will be laminated to. The O.D. is 23.5 inches and the I.D. is 12-5\8ths". The I.D. will go over the center roller bearing of the LightBridge.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1633075 - 05/30/07 12:17 AM Attachment (237 downloads)
Here is the unfinished\cut disc laying on the base for final fitting.
This design will allow me to rotate the setting circle 360 degrees, this is a change from some of the other designs I saw which are limited to a smaller area of adjustment. Certainly nothing wrong with that method, but the LightBridge bearing system lets me get away with this design, and its less work.
Edited by Sky Captain (05/30/07 12:52 AM)
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1633080 - 05/30/07 12:24 AM Attachment (262 downloads)
After bending the tab over and threading it for a locking screw, I laminated the circle to the disc. I cut and trimmed it to fit. The LightBridge bearing is 0.155" thick, and the aluminum disc with circle laminated to it is 0.107 thick. This is enough clearance for the top to rotate and the disc will remain stationary.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1633086 - 05/30/07 12:31 AM
Niiiiiice.
Taking it to the next level! Looks great, Kerry!
jack45
Reged: 07/07/03
Loc: Lacey WA
      #1633089 - 05/30/07 12:32 AM
Sky
Great job!
Clear Skies!
Den Mama
Reged: 05/14/05
Loc: montana
      #1633780 - 05/30/07 12:45 PM
Kerry:
Beautiful job! And great photos; thanks so much for adding yet another great improvement to our thread!
Carol
BWBlackett
newbie
Reged: 01/11/07
      #1634315 - 05/30/07 05:30 PM
Does anyone know somewhere in the UK where I can get a circle printed and laminated?
I have a 10" Dob whose base is 20.5" diameter so I think I need to resize the 19" pdf by 1.08.
Brian.
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles, Wixey, Red LED light new [Re: BWBlackett]
      #1634357 - 05/30/07 05:56 PM
Brian: Welcome to Cloudy Nights! Thank you for joining our forums!
We have many UK members, so I'm sure they will step forward to help you find a place.
Again, welcome!
Carol
Downward Bound
Adrenaline Junkie
Reged: 03/29/06
Loc: Seattle
      #1635898 - 05/31/07 01:48 PM
Nice work Kerry!
with everything you've done, that scope won't even remember my name or that it once shared many a great view with me
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Degree Circles, Wixey, Red LED light new [Re: Downward Bound]
      #1637048 - 06/01/07 01:05 AM
Nice work Kerry!
Bill
Would it help if I name it little Bill?
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1637052 - 06/01/07 01:11 AM Attachment (340 downloads)
Well, here's where I left off the other day. The method I came up with to view the setting circle was a 3" plastic cord feed for office desk tops. I got it at Staples while waiting for the circles to be printed and laminated.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1637054 - 06/01/07 01:15 AM Attachment (305 downloads)
I installed a switch, a red LED, an aluminum indicator arm, and a #2023 button cell (3 volt) holder. I cut in the switch but had to fab and JB Weld the other components to the inside base.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1637055 - 06/01/07 01:18 AM Attachment (313 downloads)
Here is a shot of it installed in the base.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1637059 - 06/01/07 01:22 AM Attachment (299 downloads)
This shot shows the base to level the scope and I installed a dual axis bubble level that is counter sunk into the top board.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1637062 - 06/01/07 01:27 AM Attachment (277 downloads)
Here is a closer shot of the counter sunk bubble level with the scope on the base. This way I can level the scope with the full load on it in the up right position.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1637071 - 06/01/07 01:38 AM Attachment (305 downloads)
Here it is, all ready for action! First light to test it will be in a few days, I'll post here my results.
Again, many-many thanks for everyones input to this thread, of which I wouldn't have been able to do this job as well as I did. I hope my ideas and photos will in turn help others to build something great too.
Sader762
Reged: 06/29/06
Loc: East Texas
      #1637077 - 06/01/07 01:45 AM
Show-Off...................
J/K....man that looks nice. I dare say that Meade could not have done a better job........
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1637500 - 06/01/07 09:58 AM
Congratulations on a super installation. The level of ingenuity and skill evident is really first rate.
I really like your LED install. Very clean and professional.
Well done!!
Den Mama
Reged: 05/14/05
Loc: montana
      #1637571 - 06/01/07 10:54 AM
Kerry: Outstanding job! Wow, that is absolutely perfection!
This thread just keeps getting better & better; going from primative, to elite!
Thanks for your contribution & photos, to help others!
Carol
Roger51
Reged: 09/05/06
Loc: Michigan
      #1637724 - 06/01/07 12:21 PM
Kerry,
Nice job! Is there a part number for the insert you purchased at Staples. I just received my 16 inch Lightbridge and would like to use your method.
Thx
Roger
Roger51
Reged: 09/05/06
Loc: Michigan
Re: Degree Circles, Wixey, Red LED light new [Re: Roger51]
      #1637726 - 06/01/07 12:23 PM
All,
Anyone interested in knowing the base diameter for the 16" Lightbridge it's 31.5 inches.
Roger
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1638591 - 06/01/07 09:06 PM
Thanks everyone for the kind words! This was a very fun project, though a bit much on the money side, but still well worth it.
If anyone needs additional pictures\angles, just let me know and I will post them here.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1638597 - 06/01/07 09:11 PM
Kerry,
Thx
Roger
There probably was Roger, but I threw it out several days ago. It was in the office\desk area of Staples and it was the 3 inch version. I looked around at other places but could only find 2 inch versions. A 4 inch version would be nice on the 16 in. LB you have. The 3 inch just fits the 12 inch base.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1639517 - 06/02/07 11:40 AM
Quality workmanship, Kerry. Great design, and looks real professional.
One question: Is the hole going to be wide enought to be usable? Based on the scale of the circles, there are a lot of positions that all you will see through the hole is a bunch of lines with no numbers to tell where you really are. Maybe numbers every 5 degrees instead of every 10 would help this.
Let me know if this is a problem when you test it out.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Degree Circles, Wixey, Red LED light new [Re: BradC]
      #1639637 - 06/02/07 12:49 PM
I was wondering that too, but I'm glad I kept looking for the 3 in. version as opposed to the 2 incher's I had been seeing. Numbers every 5 would be better, but in practice it was very easy to use. The program I downloaded from the beggining of this thread only had the markings as shown and it does spread out a bit when enlarged.
Last night I got a chance to use it, as I was invited to an outreach program at an elementry school for 4th graders. Tom (square-peg) hosted it along with the Maple Valley Astro (MVAS) club. After setting up and leveling the scope (9:00pm) it was still very light out and the only thing visible was Venus. So I decided to start with that one. I looked up the Alt\Az numbers on Starrynight and set the ring\az to the correct number. Saturn was not visible because of it being still bright and the thin marine layer of clouds in the sky. I looked up the position for Saturn on the lap top and moved the scope to those readings...there it was, in the EP (I was using the 12mm Speers WALER at 127x !!! I would have liked to use it more but there was one HUGE problem, (not really )...over 175 people showed up for the out reach! The line at my scope was 30 people deep, all night, just to see Saturn and Venus.
I will try to view again with my wife tonight in a more controlled enviroment and report my findings. Overall I couldn't be happier with the way it turned out and how easy it is to use.
Roger51
Reged: 09/05/06
Loc: Michigan
      #1639861 - 06/02/07 03:12 PM Attachment (300 downloads)
Finally received my 16" Lightbridge. I had everything ready as I assembled it for the first time (setting circle). Here is a picture. Just your basic cut out with a magnet and finish nail as a pointer. I did paint the nail green. I have to put wheels on this beast to move it. I had to assemble it in the garage because the base is too large to fit through the doors. No first light yet, hopefully tomorrow night.
Roger
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1639891 - 06/02/07 03:36 PM
Way to go Roger! Very cool. What were you going to use for the altitude measurement? My magnetic dial stuck to the tube worked well, but I was thinking of getting a digital one too.
I don't mean to laugh, but I was going to get one too and later changed to the 12 in. instead. I know I would have had trouble in our 3rd story condo.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1639935 - 06/02/07 04:12 PM Attachment (238 downloads)
Thanks for posing this inquiry Brad. This got me thinking (with the wifes help!) and she brought me our label maker.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1639937 - 06/02/07 04:14 PM Attachment (244 downloads)
It has clear tape with black numbers\letters, and they are smaller than the ones on the circle. I put on a few to try.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1639946 - 06/02/07 04:16 PM Attachment (261 downloads)
This is much better and as you can see from the picture of it installed, numbers are visible all the time.
square_peg
Reged: 03/26/04
Loc: Maple Valley, WA
Re: Degree Circles, Wixey, Red LED light new [Re: Sader762]
      #1640069 - 06/02/07 05:43 PM Attachment (233 downloads)
No disrepect toward Meade intended, but they couldn't hold a candle to Kerry. His system is just slick as can be.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1640158 - 06/02/07 06:28 PM
Nice mod of your mod I'm glad you found a solution short of re-printing the circle or hand-writing them in. I even like that the intermediate numbers are smaller and offset from the primaries.
Glad to hear that it worked well in the field, too! Make sure you let us know how well it works when you get the chance to try it on more (and more obscure) targets!
Roger51
Reged: 09/05/06
Loc: Michigan
      #1640244 - 06/02/07 07:41 PM
Kerry,
I have the digital altitude indicator (Wilney). On another note, I seemed to recall someone saying the inside of the tubes were white on the Lightbridge? When I received my 16 both the lower and upper units are painted flat black. Was your 12 white?
Roger
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1640502 - 06/02/07 10:49 PM
Roger
The inside tubes are black, just the end rings were white and the truss poles are silver...just like yours. I powder coated the end rings and poles flat black on mine.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1640517 - 06/02/07 10:55 PM
Thanks Brad, it really couldn't have worked out better. If I re-do another setting circle, i'll apply the intermediate numbers first and then have them (Staples) laminate it.
So your saying Saturn and Venus are to easy.
We are going to do some more tonight, it will be just me and the wife...and the telescope.
Gigatron
Reged: 12/10/05
Loc: Staten Island, N.Y.
      #1642088 - 06/03/07 08:57 PM
Hey gang,
Can anyone confirm the size of the base for a Zhumell 10"?
I've read through all 17 pages and I don't recall seeing any direct PDF links. I measured the base at 22 3/8", which would be an increase of 117.6% from the original 19" PDF.
I copied the original PDF to an SD card. Will Kinko's/Staples just be able to upscale it 117.6% and print it out, or would they need something else?
Fred
nasag
Reged: 05/22/07
Re: Degree Circles, Wixey, Red LED light new [Re: Gigatron]
      #1642099 - 06/03/07 09:04 PM
Have those that have used the $10 inclinometer had any major problems using it? I really don't want to go the digital route if I can get by with the cheeper one.
Gary
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Degree Circles, Wixey, Red LED light new [Re: nasag]
      #1642139 - 06/03/07 09:31 PM Attachment (167 downloads)
Gary
The only thing I found Gary, was that the marks between were very small and tough to get just right. It was doable and sometimes the red light from my flashlight would cause some glare off the clear plastic housing protecting the needle. The needle tends to bounce a bit after you move the scope, and thus you have to wait for it to stop moving. In reality if you have a wide angle EP, just "search" a little to find the object.
It still works though.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1642164 - 06/03/07 09:47 PM
Fred
I know for mine, they needed to go to 137% to get it right but mine was just a little bigger than yours.
I copied mine to a CD, but the operator wasn't able to enlarge it in the computer. She made an initial copy (19") and then ran the copy through the large format copier and enlarged it that way.
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
      #1642236 - 06/03/07 10:43 PM
22 3/8" sounds about right for the Z10. Like Sky Captain, I took mine to Kinko's on a CD. I originally took the PDF attached to this thread to Kinko's on an SD card, but they didn't have an SD card reader
I told the girl behind the counter the size I needed and she took care of enlarging and printing on the large format printer, so you don't need to worry about enlarging it yourself.
Tom Andrews
Reged: 01/25/07
      #1642308 - 06/03/07 11:27 PM
I took the pdf file on a flash drive to Staples and they were able to download it and adjust the size needed.
Gigatron
Reged: 12/10/05
      #1642701 - 06/04/07 09:07 AM
Thanks for all the responses, guys.
There might be a Staples near me at work. Maybe I'll take a hike over there during lunch (assuming it's not pouring buckets )
-Fred
justabob
Reged: 05/05/07
      #1642836 - 06/04/07 10:45 AM
Hey gang,
Fred
22 1/8 fits the z10. Kinkos was able to up size the 19" file.
Gigatron
Reged: 12/10/05
Re: Degree Circles, Wixey, Red LED light new [Re: justabob]
      #1644051 - 06/04/07 10:14 PM
Well, Staples has no freakin' idea what they're doing.
I took them the PDF and told them to enlarge it 117% so that it would be 22 1/8" across. They tell me to come back in an hour and a half. I show up and I notice it looks a little small. I ask for a ruler and the thing is 18 1/2" across. How did it get smaller by increasing it 117%?
Can anyone explain to me what possibly went wrong, because I'd love to know.
Tomorrow, I'm going to try kinkos, even though I'm already out $8.
-Fred
Den Mama
Reged: 05/14/05
Loc: montana
      #1644091 - 06/04/07 10:42 PM
Fred: They obviously made a mistake, you shouldn't have had to pay for it.
Carol
Tom Andrews
Reged: 01/25/07
      #1644118 - 06/04/07 11:01 PM
I agree, you should not have been charged. If they didn't do what you asked, you should not have had to pay.
The guy at my Staples ran it once and got it exactly the right size (using a preprinted sizing chart) but the ink was a little light. I asked him to run it again a little darker which he did and didn't charge me for the second copy. He gave me both, laminated the good one and charged me only $6.00 total. By the way, he did all this while I waited.
I don't know if it will help but you can use my experience to complain to your Staples. They obviously have an inexperienced person working there.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1644234 - 06/05/07 12:12 AM
I had a similar experience to yours, (the operator didn't know how to enlarge) but she knew how to make it bigger on the large format copier which turned out very well. She just took the 19" version and enlarged it 137% for my size.
Gigatron
Reged: 12/10/05
Re: Degree Circles, Wixey, Red LED light *DELETED* new [Re: Sky Captain]
      #1644634 - 06/05/07 09:01 AM
Post deleted by erik
justabob
Reged: 05/05/07
      #1644682 - 06/05/07 09:32 AM
This is evidently not an everyday request. At the Kinko's I was at they had to get the boss over as I explained it is critical that the outer diameter be 22 1/8". It took him a couple of tries before he got it.
Gigatron
Reged: 12/10/05
      #1644694 - 06/05/07 09:40 AM
I guess I just can't comprehend how hard it can be to understand that I want a file enlarged so that it has a particualr outside diameter.
Even if I didn't know the original size, the smart thing to do would have been to print the original file and see what size it prints out at. From there, take the final size, divide it by the size of the original print out and that gives you your enlargement percentage.
It's nothing harder than 5th grade math and a little time and effort.
-Fred
Den Mama
Reged: 05/14/05
Loc: montana
      #1644746 - 06/05/07 10:06 AM
Fred: Please refrain from these edgy posts; this has been a very pleasant, helpful thread, & we wish to keep it that way. It's unfortunate you had this problem, but it's not something to destroy this thread over.
You could have asked for a manager to come over & solve the problem, but it's over. Now, lets get back on track here.
Carol
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1646117 - 06/06/07 01:08 AM
Carol
Yes, very good idea.
I did a little experiment today regarding the finding of "day time" stars or Venus and maybe Mercury. I have heard of being able to see a handfull of stars during the day with a telescope. I was going to try it with my LX200 GPS, but never got around to it.
With this idea, I looked on my astronomy program (Starrynight) and discovered that it lists the Sun with coordinates of alt\az. I could set up my scope during the day and put on my custom 60mm finder scope with Baader solar film, cover the 12" LB main UTA with a cover, then scan toward the SUN and then set the Azimuth setting while checking the alt. reading. Once aligned you could find Venus and recheck the settings and adjust as needed.
Then your off to find those daytime stars!
Of course after uncovering the scope, you would want to be VERY carefull about scanning near the Sun while looking for those stars, or even Mercury!
justabob
Reged: 05/05/07
      #1646190 - 06/06/07 02:56 AM
Finally first light with the push to on my z10. I thought if it was going to rain another day I would plant rice here.
One word wow. My interest in a goto scope has diminished considerably. First off there are so many trees in my yard I decided to use a spot were I could not see Polaris in order to view Jupiter as a first target. I leveled the base and used my trusty Silva Ranger for polar alignment. Spun the ole z10 to the alt azm numbers on stellarium and bingo Jupiter right in fov in the 32mm 2". I then moved to were I could see Polaris and got m 51 and m 81 and a fading view of Saturn.
Total cost about 30$ and a couple of hours labor.
Thanks to all for this great system.
Bob
Cliff Dweller
Reged: 05/11/07
      #1646529 - 06/06/07 10:09 AM
Hi Kerry,
Amazing way to do this mod!!!
As always I have a few questions, I hope you don’t mind.
I see that you wrote that the Lightbridge bearing is 0.155" thick, and the aluminium disc with circle laminated to it is 0.107” thick. But how thick is the aluminum setting circle disk itself?
What grade of aluminum did you use for the setting circle?
What size of thumb screw did you find worked well with the metal tab (bent over the edge of the bottom base melamine) thickness, to stop striping of the threads?
Do you find that there is any side to side wobble of the top and bottom melamine bases to be a problem with binding?
Any problems with the aluminum setting circle damaging or grooving the base melamine, or binding on the Lightbridge bearing?
You must be a NASA engineer or something; your mods are truly professional and inspiring. Thanks for taking the time to share them with all of us.
Dark Sky’s: Cliff Dweller
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Degree Circles, Wixey, Red LED light new [Re: Cliff Dweller]
      #1646584 - 06/06/07 10:52 AM Attachment (216 downloads)
The aluminum disc is 0.090" as bought but actualy measures out at 0.094".
I believe the grade was 5053. Its a little softer and easier to work with, only because of the tab I had to bend. A higher grade would only be more money and a little tougher to work with.
The thumb screw I used is 1\4"x20tpi. Because of the thickness (or lack of), I JB Weld-ed a stainless steel jam-nut (they are 1\2 as thick as a normal nut) to the outside of the tab. You can see this in the picture. I still have to finish sanding it and shoot a little aluminum color paint on it.
I did take the wobble into account when designing it. By putting on the weight system and being able to perfectly balance any load, this has helped to minimize this greatly. Sunday night I put in my 4mm TMB\Burg. EP and tracked the core of M13 at 381x with ease.
No binding at all with these measurements. I originaly wanted 0.080" but that wasn't in stock. As a side note, I could have had the router table engrave the tick marks and the numbers on the plate with a 1\16th bit, but sadly didn't think of it till I was done.
Absolutly no binding on the LB's bearing. Once set, there is no movement of the setting circle for rubbing. There may be some on the bottom half of the base where the disk sets, but I de-burred it and sanded it with 600 grit wet\dry. This gave it enough stiction not to move, I really don't even need to set the 1\4x20 thumb screw. It will be a long, long time before there is any damage to worry about, and besides, a new base is probably in the works anyway.
Well, an engineer for sure, just not for NASA. Besides could you imagine what would happen if I got a hold of the Space Shuttle? You think it costs alot now...
(Here is the close up photo of the knob...which could be a little shorter now that I'm looking at it)
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1646597 - 06/06/07 10:58 AM Attachment (233 downloads)
I took a better angled shot of the under belly of the pointer. It shows the indicator arm is angled with the LED under it. This prevented any shadows being transmitted to the number system since the opening is a little smaller than most of the others.
Mynok
Reged: 02/14/07
Loc: NC
      #1646758 - 06/06/07 12:18 PM
Wow. Very nicely done. I have a Z10 and this is definitely a future mod for me. A couple questions for you:
1. I love the insert viewport with the LED and switch. I intend to do this as well. Can you provide a part list?
2. Did you use your router table to make that big hole for the insert or a special drill bit?
3. Did you buy that leveler base or make it? If you made it, would you be willing to make another for profit?
kestrel0222
Reged: 05/21/06
Loc: Milford, Michigan
Re: Degree Circles, Wixey, Red LED light new [Re: Mynok]
      #1646767 - 06/06/07 12:21 PM
Kerry,
AWESOME Job!!!!!!!!!!!!
Den Mama
Reged: 05/14/05
Loc: montana
      #1647002 - 06/06/07 02:20 PM
Bob: Welcome to the growing list of happy owners of this great little system! So glad it's working well for you, & thanks for sharing your success!
Carol
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles, Wixey, Red LED light new [Re: kestrel0222]
      #1647007 - 06/06/07 02:24 PM
Kerry,
I definitely Second that!!! Absolutely Top Notch!
Carol
Cliff Dweller
Reged: 05/11/07
      #1647052 - 06/06/07 02:42 PM
Hi Kerry,
Thanks so much for the info. Engraving!@#... That sounds interesting!.....
I can hardly wait to see your new base. I really appreciate all your help to me the newbie!
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1647718 - 06/06/07 08:07 PM
No problem, very glad to help!
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1647726 - 06/06/07 08:11 PM
Kerry,
Thanks Tom!
Carol
Thanks again Carol!
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1647789 - 06/06/07 08:44 PM
Thanks Mynok,
#1: That might be tough, as I have many boxes of electrical parts to work with...20+ years of collecting. I can tell you that I used a rocker switch, a 3 volt red L.E.D., some JB Weld, the "viewing port" was from Staples (saw MANY others but only theirs was the best), a couple of inches of 18 guage wire, a #2032 button cell battery, a #2032 button cell holder, and an aluminum strip that formed the pointer and circle that holds the L.E.D.
The aluminum is 0.027" thick by 5\8 th's" wide by 6" long.
#2: I used a hole saw, it was a 3 1\4". You could also use a Forstner bit too.
#3: The base leveler was my design but I had my buddy at the machine shop drill the lightening holes in the arms, and I finished the rest. To be honest, that leveler base even without a profit would be very expensive to recreate. If you are really interested, PM me and I'll let you know. Parts alone at cost would be close to $175...labor is the real killer.
Den Mama
Reged: 05/14/05
Loc: montana
      #1648543 - 06/07/07 09:19 AM
PDF File for degree circles: (8" Dob base)
SkyArcher's PDF file
Since this thread has gotten so many wonderful posts, the Pdf file for the degree circles has gotten buried; so here it is again.
Thanks to all who have added to this thread!
Carol
justabob
Reged: 05/05/07
      #1648796 - 06/07/07 11:29 AM
Carol
Thank you Carol
I will be in a dark sky location this weekend to give it a proper run.
Tom Andrews
Reged: 01/25/07
      #1651097 - 06/08/07 01:27 PM
After two months of being back in Albuquerque, last night was one of less than a handful that was clear and calm. We've had winds as high as 50mph, clouds constantly and rain on and off (not typical Albuquerque weather for this time of year).
I was able to get to a slightly darker observing spot than the RV park we're staying in (in the park I can only see to mag. 8.5; last night I was seeing to 11.00) I spent five hours pushing my "Push-To" system to the max. I wanted to post the results here just in case someone is reading this thread and interested but not sure if it's worth the work. I can't tell you enough that for someone who is really interested in amateur astronomy, this system is well worth whatever work you have to put into it, not to mention that it's as inexpensive as $12.00 or as expensive as you want to take it (you know who you are...Sky Captain )
Here's a list of my viewed objects:
Venus, Jupiter, Saturn, Pluto, Neptune
Messier objects:
3, 5, 6, 7, 8, 13, 15, 16, 17, 18, 20, 21, 23, 25, 27, 40, 44, 49, 51, 54, 55, 56, 58, 59, 60, 61, 63, 65, 66, 67, 68, 71, 72, 73, 75, 80, 83, 84, 86, 87, 88, 90, 91, 92, 94, 95, 96, 98, 99, 100, 101, 102, 104, 105, 106, 108.
Caldwell objects:
1, 6, 15, 21, 26, 29, 32, 36, 37, 38, 40, 47, 48, 52, 53, 55, 59, 61, 66, 77, 78, 80, 82, 83.
85 objects!
I hope everyone else using this system is enjoying it as much as I am.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1651148 - 06/08/07 02:02 PM
Thats fantastic Tom! I'm looking forward to being able to do the same. We have a star party on Saturday, but it looks like the clouds might win this one. I have been impressed with my LX200GPS and its ability to find alot of stuff in a short time, but I have been equally impressed with the ability to do the same with a manualy tracked dob!
What was the time period of your observing?
Den Mama
Reged: 05/14/05
Loc: montana
      #1651386 - 06/08/07 04:22 PM
Tom: If anyone doubted this system, your success should have them rethinking!
What an impressive list of targets you observed!
Thanks for your post.
Carol
nasag
Reged: 05/22/07
      #1651512 - 06/08/07 05:38 PM
I have been excited just reading all the posts about this. I have been getting my materials and getting it ready. I go to put it together today and like most projects, I hit a snag. I have a 6" orion dob. There are three teflon? or plastic gliders that the base sits on to turn for azimuth directions. They sit only about 1/2- 3/4 of an inch from the edge. I cut a slot in the base to be able to see the degree circle. It all works fine until that slot goes over one of the gliders and then it drops off and since the weight is now only on TWO gliders it does not turn any more until I kind of lift it up and back on to the glider again. I think if I add one more glider it will be OK. So, finally my question. What are those gliders? Are they telflon? Just some sort of plastic? Can I get some to add another or something that will do? Has anyone else had this problem?
Thanks for all of the great help and ideas. I really appreciate it.
Gary
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
      #1651562 - 06/08/07 06:14 PM
Hi Gary,
If you can gently pry those pads off and move them inward so they are inside the radius of the dial and of the cutout notch, that will fix the problem.
I had to do the same thing to mine since they were too close to the edge.
Those pads are what the top part of the base rides on, so they are very necessary.
You could also replace them with magic sliders (found at Lowes, Home Depot, etc.). That is the brand name, so just ask someone in the store and they should be able to direct you to them.
I've read that having them too far toward the outer edge might cause some problems with motion anyway, so you might just end up improving the azimuth motion of your mount in the process.
Edited by HockeyRulesX4 (06/08/07 06:16 PM)
nasag
Reged: 05/22/07
Re: Degree Circles, Wixey, Red LED light new [Re: HockeyRulesX4]
      #1651605 - 06/08/07 06:41 PM
Perfect. I will do it right now. I want to try it out tonight. The sky is clear, we are right under a high pressure system, the winds are calm. It should be a prefect night.
Thanks Dave for the help. Thanks also to Carol and everyone else that has made this "Thread" such a great one.
It is getting to the point that it could become its own topic.
Thanks again.
Gary
Den Mama
Reged: 05/14/05
Loc: montana
      #1651624 - 06/08/07 06:55 PM
Gary, you are most welcome; but everyone that has posted to this great thread also deserves credit. Everyone's questions & contributions have added so much to it.
Carol
Tom Andrews
Reged: 01/25/07
      #1651773 - 06/08/07 08:02 PM
5 hours: 9pm - 2am
justabob
Reged: 05/05/07
      #1654674 - 06/10/07 03:32 PM
Got up to my summer place in northern WI this weekend for two nights of absolutely clear mag 6.8 skies. My results were not quite as good as Tom, but I think they could have been given the fact I had my 14 year old son with me who shared the eye piece. Did not keep a log but I do remember M 4,81,82, 51, 67,104,3. Venus, Saturn, Jupiter, and Pluto. Without the push-to system I am sure this thing would end up in the closet.
Some structure in the whirlpool galaxy as well as striking red color on M 4. Of course I wish I would have gotten the 12" dob instead of the z10!, and now I lust after some better eyepieces, and so it goes.
If you have a dob this system is a must have.
Thanks again to all.
Bob
Den Mama
Reged: 05/14/05
Loc: montana
      #1654679 - 06/10/07 03:35 PM
Bob: Fantastic night! I'm so glad you installed & enjoy the "system". I would hate to think of what you would be missing in that great location with the scope in the closet!
Thanks again, for proving our little "push to" works!
Carol
Tom Andrews
Reged: 01/25/07
      #1654709 - 06/10/07 03:55 PM
Bob,
It's great to hear good reports from others on how well the system is working. Keep 'em coming. And I agree that this system is a must-have if you don't have the motorized version. One advantage to this system is the speed of finding things. I've used the motorized system on a friend's scope and it takes a little more time slewing than I do. But on the other hand, what's the hurry? It's all going to be there long after I've moved on.
jack45
Reged: 07/07/03
Loc: Lacey WA
      #1655052 - 06/10/07 06:41 PM
Seeing how the objects move. What program do I use to know the AZT/AZI at the time that I'm viewing?
I use a program on my computer to get information on where objects are at a certain time. Do I need to keep going in the house as time goes by to get new AZT/AZI reading to keepup?
I can print out a sky map for DSO, for 10pm tonight! A laptop would be nice but I'm not buying one at this time! Is there something I can have outside with me to keepup with these objects, as they move over time? Am I missing something here?
Clear Skies!
Edited by jack45 (06/10/07 06:42 PM)
Tom Andrews
Reged: 01/25/07
      #1655068 - 06/10/07 06:49 PM
You will have to have a computer program that makes the constant changes as the earth spins. The alt/az coordinates are changing constantly. If you don't have a computer to bring outside then you have to go in and get the current coordinates off your inside computer. It won't do any good to print out a map for 10:00 because it will only be good at that moment.
I'm sorry that it seems that you didn't realize that this was part of the "Push-To" system. Let us know how else we can help.
Den Mama
Reged: 05/14/05
Loc: montana
      #1655099 - 06/10/07 07:10 PM
If you happen to have a PDA or a PALM, there are several programs you can use on them for this purpose. Until I got one, I had to run into the house to get the coordinates off my computer.
Carol
jack45
Reged: 07/07/03
Loc: Lacey WA
      #1655320 - 06/10/07 09:19 PM
Thanks Tom/Carol!
I was just hoping there was an easy way of doing this! I can still use it for those hard to find DSO's until I get a laptop. I did just get a red light and the 0 to 90 deg protractor. The protractor is magnetic but my two scopes aren't metal. I'll use velcro to attach it to my scope. I also have the setting circle PDF that Carol made available on a thumb drive as we call it in the military. I'll take it to Staples tomorrow and see what they can do! I'm getting two setting circles made, one for each of my scopes! I don't need one for the 12XInTelliscope.
Again, Carol has saved us a lot of money and the many post on this has been a great help!
Clear Skies!
Edited by jack45 (06/10/07 09:21 PM)
coopman
Reged: 04/23/06
Loc: South Louisiana
      #1655498 - 06/10/07 10:51 PM
I just downloaded the trial PC version of PocketStars and I can see how neat this thing is. However, I have a problem because the base and rocker box bottom of my homemade Dob are square instead of circular. I would have to make them circular to fit the azimuth ring, I guess, but this is not that difficult to do. Then I would have to get a PDA and the PDA version of PocketStars, so this would end up being much more expensive than $12 for me to do. I still might do it anyways....
Gigatron
Reged: 12/10/05
Re: Degree Circles, Wixey, Red LED light new [Re: coopman]
      #1655512 - 06/10/07 11:00 PM
Well, I'm a few hours of work away from having my system set up and ready to go.
I finally got my circles from kinko's, I have my wixey inclinometer and I fashioned a pointer from sheet aluminium and a rare earth magnet. All I need to do is notch the base board and replace the teflon pads with magic sliders and I'm set.
Now if I could get mother nature to cooperate ...
-Fred
Tom Andrews
Reged: 01/25/07
Loc: Albuquerque, NM
      #1655570 - 06/10/07 11:41 PM
Check out my version for a square box:
http://www.cloudynights.com/ubbthreads/download.php?Number=1554107
There are more pictures of how it goes together on previous pages of this same thread. There are also pictures of others' versions with square boxes within this thread.
Do you have a laptop you can take out with you to the scope? If not, Carol's suggestion to me was to check ebay for pda's. They almost always have used pda's for sale going from $50.00-$100.00.
For a few days I used a laptop in the house and went back and forth to get coordinates. Then I brought the laptop out and set it up near the scope to use. In the meantime I put out the word to my friends that use pda's that I needed an old, used one for astronomy use. Within a few weeks, a friend gave me an old one which still worked.
Keep working all the angles, the system is well worth it.
Tom Andrews
Reged: 01/25/07
      #1655574 - 06/10/07 11:45 PM
Right on, Fred. Please let us know how it works whenever you get to use it.
Den Mama
Reged: 05/14/05
Loc: montana
      #1656118 - 06/11/07 10:18 AM
The original $12 system works great. I used it for months before I purchased a used Dell Axim. It was inconvenient to run into the house often to get the coordinates from the computer, but it's definitely workable.
It's like everything else, one adds options for convenience. A $300 scope ends up at least double, by the time all the bells & whistles are tacked on
Carol
kestrel0222
Reged: 05/21/06
      #1656135 - 06/11/07 10:26 AM
I also use the Axim with pocket stars. When I first installed the degree circles on my (2) Dob's, I would make a spread sheet with all the objects that I would want to observe that night. I would write in the coordinates for every 15 minutes for each object. That became a real chour after awhile, so I "bit the bullet" and got the Axim. It's was the best move I ever made!!! Having a Palm or pocket PC is a great investment, it has so many other uses.
coopman
Reged: 04/23/06
Re: Degree Circles new [Re: SkyArcher]
      #1656819 - 06/11/07 03:41 PM
Are there any programs that offer azimuth & altitude positions for celestial objects (like PocketStars does) but use the Palm OS? Those Dell Axims are expensive!
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: coopman]
      #1656836 - 06/11/07 03:53 PM
I picked my Axim up used on AMart for $100, with a bunch of access. It looked brand new.
Down in the "Astro Software & Computer" forum, click on Software links for programs for Palm
Carol
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1656852 - 06/11/07 04:03 PM Attachment (150 downloads)
Astromist has a version for the Palm - about $30 I think.
If you are interested in a cheaper Pocket PC, The HP Jornada 548 is a very nice unit that I use at the scope. It has a great metal flip cover that makes it perfect for slipping safely into your pocket after consulting it. They regularly sell on EBAY for around $50 or so.
Good Luck
Gigatron
Reged: 12/10/05
      #1657485 - 06/11/07 09:51 PM
I use AstroMist on a Palm TX. AstroMist has everything you could want and more from an astronomy program. There are some functions you may never ever use.
The Tx is a little more expensive than your run of the mill ebay Palm III, but it's so darn versatile that it make it worthwhile. Not only do I run AM on it, but I also copy movies to the SD card and watch DVD quality movies on my commute to work.
-Fred
sleepwalker
Reged: 04/16/07
Loc: Australia
      #1658031 - 06/12/07 07:18 AM
I second the call on the Jornadas, they seem to go pretty cheap on Ebay.
Just off the top of my head, there is PalmDSC (free) ,Planetarium and Pleiadatlas - and I'm sure others, for the Palm OS
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Degree Circles new [Re: sleepwalker]
      #1658319 - 06/12/07 10:38 AM
Question, are these used or new?
Is there a particular vendor on ebay thats good to buy these from?
sleepwalker
Reged: 04/16/07
Loc: Australia
Re: Degree Circles new [Re: Sky Captain]
      #1658388 - 06/12/07 11:14 AM
The Jornadas are older models so they'd all be secondhand I would think. No particular vendor that I know of, I just know they were generally cheaper than other PDAs running Windows Mobile from Australian ebay sellers (where I am) at least, and I was looking to get one until a particularly cheap Ipaq turned up.
Good chance that the secondhand PDAs running rechargeable batteries will require new ones but they are cheap and easily found on ebay too
Terry1229
Reged: 04/16/06
Loc: North, Idaho
      #1661531 - 06/13/07 09:25 PM
I see a lot of Axims on Ebay for sale. Pdas also.
Which model would be the best, I see 5 and 3, are their others?
For a rookie like me, what should I be looking for. I don't want to buy one, and have Murphy deliver me something that has the wrong system or wierd software.
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Terry1229]
      #1661785 - 06/13/07 11:34 PM
Terry: the one I picked up is the Axim 5. I'm very happy with it.
Carol
kestrel0222
Reged: 05/21/06
      #1662219 - 06/14/07 09:43 AM
Axim 5 would be the better of the two.
coopman
Reged: 04/23/06
      #1670142 - 06/18/07 09:43 PM
I must level my scope for it to work properly with this altitude & azimuth system, correct?
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
      #1670209 - 06/18/07 10:14 PM
The closer to level you have your base, the more accurate your push-to will be. See page 11 of this thread about 1/2 way down the page. One poster named Beri gives a good drawing of the problem if you don't level the base.
That being said, perfectly level is not necessary, but you might have to do a little scanning to find the object you're looking for.
Edited by HockeyRulesX4 (06/18/07 10:16 PM)
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #1672755 - 06/20/07 09:38 AM
OK, I guess I'm the last one to this party !
I have the setting circle printing work underway at Kinkos and I ordered the Wixey.
Can someone walk me through how the Wixey is used in practice -- kind of step wise, after it is mounted? How exactly do I calibrate and use it? Is calibration needed at each use, etc. Thanks a ton!
Here is a new link to a digital inclinometer that our member Doug found & used, when he installed his degree circles system. It is much less expensive than the Sears model:
Wixey digital inclinometer
Thanks all for keeping up all the contributions to this thread!
Carol
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
Re: Degree Circles new [Re: Jaxdialation]
      #1672885 - 06/20/07 10:49 AM
The Wixey is a calibrate once device. When you get it, put it on a level surface and turn it on. Then press the "Zero" button. If I remember right, the instructions for zeroing are printed on the package, but it really is that simple.
When you go to use it, put it on your tube, turn it on and read the display.
That's as easy as it gets.
justabob
Reged: 05/05/07
      #1673152 - 06/20/07 12:49 PM
Carol
I carry a small level that I set next to the wixey on the ota. I re-zero it every time I setup. If your base is not spot on level the wixey will be off, especially at zenith. The better you set up the better the system works. I have mine to the point that I can use my 6.7mm meade ultra wide and things are generally in fov.
justabob
Reged: 05/05/07
Re: Degree Circles new [Re: justabob]
      #1673189 - 06/20/07 01:05 PM
A quick word on the wixey. This past weekend I was in a very high dew situation. There was fog visable. The ota and telrad were constantly getting fogged. After a couple hours the wixey freaked out and the display went crazy. I wiped it off with a towel and took the battery out, then put it back in a few min later and it was fine. The primary on the z10 never fogged though, the fan works well.
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
      #1673229 - 06/20/07 01:22 PM
Hello justabob!
Zero-ing the Wixey for every use seems a bit unnecessary. Leveling the base however, as I said a couple posts up, will affect the accuracy. It's not the Wixey that is "off", it's the base.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1673275 - 06/20/07 01:47 PM
Justabob,
Dave is right, a tilted base using a digital inclinometer will not cause the altitude reading to be off - level is level, 90 degrees is 90 degrees, etc.
You will suffer in azimuth accuracy from a tilted base- and an error in one axis makes things frustrating.
Having said all of that, a few minutes extra for a careful set up and levelling is time you will recover many fold over the course of the evening's observations.
Clear Skies
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
Re: Degree Circles new [Re: rnabholz]
      #1673468 - 06/20/07 03:29 PM
Thanks guys, I'm headlong into this project - go the setting circle from Kinkos today. How do we make the base-leveling process as pain free as possible? I have a Zuhmell was thinking of getting a small "+" shaped double level and mounting it permanently to the base. Even then I'm usually on concrete driveway at my house so what is an easy way to level the whole thing ?
coopman
Reged: 04/23/06
      #1673857 - 06/20/07 06:42 PM
How about using some small leveling wedges under the feet of the scope?
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #1673899 - 06/20/07 06:52 PM
Thanks, great idea, but my azmuth movement is not the smoothest in the world. Maybe rubber wedges/doorstops would work though ??
coopman
Reged: 04/23/06
      #1674011 - 06/20/07 07:39 PM
I found both steel and wooden leveling wedges on the internet when I did a search earlier today. Unless you use leveling screws of some sort, how else do you propose to get your scope level?
Edited by coopman (06/20/07 07:40 PM)
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #1674073 - 06/20/07 08:34 PM
LOL, I don't have a proposal. I was hoping I was once again missing an obviously superior solution. Happens all the time to me.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1674421 - 06/21/07 12:08 AM
THIS is the superior solution:
New Lightbridge Mods (see the first 5 or 6 posts to see Sky Captain's custom hand-machined leveling platform.)
Try not to drool too much.
Tom Andrews
Reged: 01/25/07
      #1674449 - 06/21/07 12:23 AM
I've been using rubber door stops and they work great. I also bought a rubber floor mat (for vehicles) that I put down on the ground first then my base. It keeps dirt and moisture away plus helps keep the base from shifting. Rubber door stops under the wood feet of my base don't slip and the rubber stops sitting on the rubber floor mat don't slip.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Degree Circles new [Re: Tom Andrews]
      #1674507 - 06/21/07 12:53 AM
Can anyone recommend a good place in the USA to pick up a Wixey digital. My local wood working shop is out till the end of July.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1674540 - 06/21/07 01:36 AM
You could order it directly from the manufacturer. $40 and free shipping.
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #1674694 - 06/21/07 07:10 AM
Thanks Tom. Sounds like my plan "A" where did you get the mat ?
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Degree Circles new [Re: BradC]
      #1674875 - 06/21/07 10:03 AM
Thanks Brad!
justabob
Reged: 05/05/07
      #1675057 - 06/21/07 11:42 AM
Justabob,
Of course level is level, my point is the wixey is not that accurate. I have zeroed it on my work bench with a very large expensive level then checked it the next day to find it off .2 deg.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1675149 - 06/21/07 12:48 PM
Justabob,
Perhaps I misunderstood what you wrote which was:
"If your base is not spot on level the wixey will be off,"
The digital level's accuracy is not affected by the tilt of an unlevel base - it is that azimuth accuracy that will be affected. The Wixey will still show the correct altitude in spite of a leveling error in the base. That was the basis for my comment regarding level being level etc.
Rod
Tom Andrews
Reged: 01/25/07
      #1675420 - 06/21/07 03:11 PM
Walmart.
coopman
Reged: 04/23/06
      #1684913 - 06/26/07 06:25 PM
I ordered my Wixey digital inclinometer today and bought a PDA last week, so I'm working my way towards getting my Dob ready to try this degree circle thing out. I have a concern though: How do I cut decent looking, accurate circles out of plywood sheet when I go to redo my Dob mounting? No matter what I do, I always seem to botch up the circles that I try to cut with my electric handheld jig saw. Is there a more accurate way to do this, short of having some fancy table saw gadget that I can't afford? Thanks for any advice.
Edited by coopman (06/26/07 06:26 PM)
kwalker
Reged: 08/22/06
Loc: Oklahoma City, OK
      #1685054 - 06/26/07 07:51 PM
if you know of someone with a band saw there are alot of those people that have a template that they lay on the saw and will cut perfect circles.
Tom Andrews
Reged: 01/25/07
      #1685619 - 06/27/07 12:11 AM
Do you have to use plywood? I used foam board with self-adhesive...easy to cut.
Gigatron
Reged: 12/10/05
      #1685989 - 06/27/07 09:06 AM
Depends on the size of the circle. If you're talking small size holes (up to about 4"), you can get a hole saw attachment for your drill at any decent hardware store.
For larger (like alt bearing cutouts), use a jig saw to cut close to the line, but not exact. This way if it's all jagged, it won't matter. Then, use a drum sander attachment for the drill to smooth out the cut up to the line. It's a little more work, but you'll get a better finish.
-Fred
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1686020 - 06/27/07 09:33 AM
Not knowing much about your scope design, I can't say that this will work for sure in your plan, but I'll throw it out.
On my scope the scale is sandwiched between the groundboard and the rocker box. I had the scale printed on a translucent mylar using a xerographic process which makes it waterproof. I then mounted that to a circle that I cut out of countertop laminate.
I was able to cut the laminate with a tin snip, so getting a accurate cut was easy using scissor skills that I learned in Kindergarten - which is good because they haven't progressed much since that point
Good Luck with the Project.
Bill Kocken
Reged: 08/07/04
Loc: Coon Rapids, MN
      #1687261 - 06/27/07 10:00 PM Attachment (174 downloads)
The best way to cut circles in plywood is with a router mounted on a trammel. (I think that's what yuou call it.) Here's a photo of me cutting semi-circles into my old Meade's base. The router pivots around a screw which goes through the plastic square, I used a big 1/2" straight router bit because the MDF cuts easily The two bars are adjustable so I can easily adjust the circle size. Router cost $90, bit cost $25, parts to make trammel $10. If you're cutting that stuff, wear a dust mask!
Next to my table saw and drill press, the router is my most used ATM tool.
Edited by Bill Kocken (06/27/07 10:06 PM)
BobW
Reged: 12/29/06
Loc: Mebane,North Carolina
      #1692744 - 06/30/07 10:46 PM
Well I built my push-to today. Had the degree circle laminated. cut a notch in the top board and attached a piece of metal banding so the magnet with a pointer would have adjustment. Put it all back together and guess what? I cut the top base board on the wrong side. I can't believe I could be so stupid:( I will have to recut on the other side and redo the whole thing.
So I will have 2 view windows. You guys can't know how bad I feel. But tomorrows another day and all will be well
csa/montanaModerator
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: BobW]
      #1692783 - 06/30/07 11:17 PM
BobW: Sorry
But you know, as "crafty" as we Astronomers are, I'll bet you will come up with a use for the other notch!
Carol
rboe
Reged: 03/16/02
Loc: Phx, AZ
Re: Degree Circles new [Re: csa/montana]
      #1692829 - 06/30/07 11:46 PM
If I had a nickel for all the mis-cuts I did I could start my own lumberyard.
Or firewood lot.
Just tell everyone your scope was built to be used in the Northern AND Southern hemispheres if they ask about the second notch. Experience does not really let us make fewer mistakes, just better excuses.
Tom Andrews
Reged: 01/25/07
Re: Degree Circles new [Re: rboe]
      #1692847 - 06/30/07 11:50 PM
Good one!
BobW
Reged: 12/29/06
      #1693189 - 07/01/07 07:34 AM
Thanks Guys. One good thing is the bottom base is just a round board. It can be replaced with no problem. One of the great things about owning a Dob.
Gigatron
Reged: 12/10/05
      #1693310 - 07/01/07 09:53 AM
Find a way to turn it into a cup holder. Nothing makes observing more enjoyable than your favorite beverage within arms reach.
-Fred
BobW
Reged: 12/29/06
Re: Degree Circles new [Re: Gigatron]
      #1693382 - 07/01/07 10:37 AM
-Fred
Lol..well the ep holder can be used..tiny little cups
coopman
Reged: 04/23/06
      #1697104 - 07/03/07 09:05 AM
Can someone give me a list of parts and/or a schematic that shows what I need to do to add battery powered LED lights to my alt. & az. gauges? I'm a buffoon when it comes to wiring & electronics related stuff. Thanks.
Tom Andrews
Reged: 01/25/07
      #1697398 - 07/03/07 11:56 AM Attachment (171 downloads)
Clay,
Here's what I found at CompUSA. I'm sure they can be found almost anywhere, my wife just happened to spot them near the check out.
These are light as a feather, have 2 LED's, can flex in any direction and use 2 button batteries which are replacable. I used a red permanent marker to color the lens. They have a plastic clip-on base which spreads fairly wide for attaching almost anywhere.
Just another resource to consider...
Philip Levine
Reged: 03/22/07
Loc: near Boston, MA
      #1698367 - 07/03/07 08:50 PM
Hi Clay,
See my photo on page 15 of this thread, I attached a Cyclopes battery operated light (3 red LEDs) via double stick foam tape. I purchased the Cyclopes for about $12 at Cabelas.com
Phil
BobW
Reged: 12/29/06
      #1703705 - 07/07/07 01:52 AM
Update on my push-to. First I'd like to say thank you to everyone in this tread for all the wonderful ideas. Tonight I got to try it out. I leveled the scope, when the north star came out I lined up with it( sited it between tree branches).
Got my little table and set up the laptop on it with hnsky and went to town. I saw more objects in 2 hours then since I had my scope. Clusters and more clusters..lol I spent over 2 hours alone in and around the teapot. I couldn't believe how easy it was. The seeing was good but the skys were hazy and I'm not in the darkest area, so alot of the m ojects were just fuzzy patches but I saw them all.
I got a good shot east-south-and south west, but trees block the north. So tomorrow night I will set up on the north side on the trees and go at it again.
I did find one problem with my scope. I shakes for a long time when touching or moving. I think its the 2 " magic sliders I got on the base. I might go to smaller ones or back to teflon. I packed it up when the lapto battery started to get low. Almost 3 hours of viewing. I cant wait for fall and winter or aleast a non-hazy summer night.
Again thank you all:)
Bob
Den Mama
Reged: 05/14/05
Loc: montana
      #1703938 - 07/07/07 09:32 AM
Bob: Thanks for posting your success story with the Degree Circles! I hope this will encourage yet more, to take a few minutes to put this "system" on their dobs.
Carol
HockeyRulesX4
Reged: 01/16/06
Loc: Batavia, IL
      #1704121 - 07/07/07 11:57 AM
Glad to hear it worked so well for you, Bob.
Keep in mind that you don't have to align on Polaris. You can align the scope on any known object. Lately, I've been aligning on Venus since it is so easy to find. If Stellarium or whatever program says Venus is at AZ 270, I turn my base until it reads 270 and make sure Venus is as close to the center of the FOV as possible.
If you're base is wobbling, it sounds like something is uneven with the sliders or the center bolt isn't tight enough.
BobW
Reged: 12/29/06
Re: Degree Circles new [Re: HockeyRulesX4]
      #1704198 - 07/07/07 01:23 PM
Dave
Could be the center bolt needs to be a little tighter, but I have noticed that the 2" sliders are like little pillows.
Bob
Tom Andrews
Reged: 01/25/07
      #1704247 - 07/07/07 01:56 PM
Bob,
Congratulations on your success. It's so amazing how easy it is to find objects. I've been keeping a log so I can know when I find all the Messier and Caldwell objects.
The center bolt on my 8" had reamed out the ground plate wood somewhat over the years (it's a vintage 1988 model). I used that expanding foam insulation stuff around the bolt and it's rock solid.
I used the same Magic Sliders as you and it's working great. However, I used 4 because 3 was wobbling. I've never had such smooth movement with that scope since I bought it used in 1995.
I also replaced the teflon alt bearings with the tiny Magic Sliders and the movement there is better than ever also.
justabob
Reged: 05/05/07
      #1708663 - 07/10/07 01:08 AM
Got a new etx90 pe, had both the z10 with the home brew push-to and the meade with autostar side by side. The push to was overall by far more accurate.
Den Mama
Reged: 05/14/05
Loc: montana
      #1709239 - 07/10/07 11:19 AM
Wow! That's a great endorsement! Thanks.
Carol
justabob
Reged: 05/05/07
      #1709349 - 07/10/07 12:28 PM
You are most welcome Carol. I think the auto star is quite a capable goto system. However it requires a much more involved initial set up. With the push-to, I just level the base, find polaris and turn on the wixey and spin her around!
Den Mama
Reged: 05/14/05
Loc: montana
      #1709378 - 07/10/07 12:53 PM
Simplicity rules!
Carol
astrasouth
Reged: 07/11/07
Loc: NC
      #1711025 - 07/11/07 10:39 AM
I'm new to this forum and to this project, but not to astronomy.
I would like to clarify a few things as I work on this project:
First I'm not intending to put the circle between the base and rocker box-- either on top or along the side of the base with a strip...
1) Digital compasses are not accurate and a manual circle is the way to go. Am I correct?
2) A manual circle. If the circle moves with the scope and the pointer is stationary, am I correct to say that the numbers should be counter-clockwise?
3) If the circle is stationary and the pointer moves then am I correct to say that the circle numbers should be clock-wise?
I'm clarifying with points #2 and #3 because I have 2 scopes where I'm modifying two different ways. My first scope has a huge rocker box (15" mirror) so the circle will be a strip along the base. It will remain stationary as the pointer moves across (assume numbers should be clockwise).
My other scope is an Orion XT and I'm putting a circle on the top of the base so it will move along with the motion of the scope and the pointer will remain stationary (the pointer will be movable for calibration only for fine-tuning).
Any help will be great. I'm getting mine made with Oregon Rule Co. They have a very helpful engineer to help design the circle there.
http://www.oregonruleco.com/dials.htm
Mark
Edited by astrasouth (07/11/07 11:05 AM)
astrasouth
Reged: 07/11/07
Loc: NC
      #1711280 - 07/11/07 12:38 PM
In a grassy area that is not cut recently (but too high) have you noticed with the rubber door stoppers the rocker box becoming wobbly... or is that dependent how "tough" the rubber mat is. How would you feel about a strong piece of plywood? thanks.
Mark
Tom Andrews
Reged: 01/25/07
Re: Degree Circles new [Re: astrasouth]
      #1711482 - 07/11/07 02:41 PM Attachment (151 downloads)
Mark
Mark,
I haven't had the opportunity to observe in a grassy area. I would imagine that you are right, this would create a wobbly base. In that situation, I think the plywood would be the better choice. (My wife and I live in a motorhome and there's not really any room for a 19" x 19" piece of plywood [the footprint of my base]). A piece of plywood would give you a more stable base then the door stops would do just fine.
I was given some plastic shims that are used on construction sites for prefab concrete wall sections. These are working great because they are bigger in diameter than the door stops, they're flat, come in three thicknesses and have ridges so nothing slides. Attached are 2 pictures.
Tom Andrews
Reged: 01/25/07
      #1711488 - 07/11/07 02:44 PM Attachment (148 downloads)
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
      #1711581 - 07/11/07 03:27 PM
Carol, I finally had a chance to use my SC set up two nights ago. I used Astromist on an Axim along with it.
This is the best thing since sliced bread! Thanks for showing the way!
Carol
Den Mama
Reged: 05/14/05
Loc: montana
      #1712111 - 07/11/07 07:43 PM
I'm so glad it's a success for you as well! That's what Astronomy is all about, sharing ideas with their fellow Astronomers!
Thanks for taking the time to post your gracious message.
Carol
astrasouth
Reged: 07/11/07
Loc: NC
      #1712763 - 07/12/07 01:19 AM
Tom, this is a good idea. I may give that a try as well if my other plan proves to be a failure.
For now, I found some leveling feet at Lowes and have attached them to the bottom of the base. I'm sure this should hold up to the weight just find since the forces are equally distributed in three directions.
I also am going to go clockwise on my stationary dial and counter-clockwise on my non-stationary dial.
thanks!
Mark
Edited by astrasouth (07/12/07 01:20 AM)
Tom Andrews
Reged: 01/25/07
      #1713408 - 07/12/07 12:34 PM Attachment (115 downloads)
Mark,
Sorry I couldn't answer the question of clockwise/counterclockwise. I have two dobs (8" & 12"), both with boxes on a ground plate. Both of my circles go clockwise. I don't know anything about your other scope...
Edited by Tom Andrews (07/12/07 11:23 PM)
Ghazzer
journeyman
Reged: 04/27/07
Loc: Sykesville, Maryland
      #1719550 - 07/16/07 12:21 AM
Carol: Please tell me where you found the "plans" for your Degree Circles, this is exactly what I have been looking for.
I purchased a "previously owned" Antares 10" Dob in March and have not devoted enuff time to master the art of starhopping. Modifying a Dob to add a "go-to" capability seems like a waste of time and resources, so "push-to" seems a very acceptable alternative.
The Antares will need to have the slider in the base replaced with bearings, and I have some teflon tape that should smooth up the altitude action.
Maybe tomorrow nite I can read more of this 23 page thread, so my apologies in advance if the source has already been identified.
Thanks -
<< Steve >>
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: Ghazzer]
      #1720063 - 07/16/07 10:15 AM
Steve: Welcome to Cloudy Nights! Glad to have you join us on the forums!
There were no "plans" for this system. If you go to the very beginning of this very lengthy thread, it is self-explanatory. All you need are the appropriately sized degree circles, a couple of home-made "pointers", and an inclinometer.
Through-out the thread there have been different, excellent variations applied to my original system.
I will try to go back & get the PDF files for the 10" & 12" degree circles, when I have the time.
They are in the thread
Carol
Den Mama
Reged: 05/14/05
Loc: montana
      #1720144 - 07/16/07 10:56 AM
Here are the PDF files:
8" Dob:
8" Dob degree circles
12" LightBridge:
12" LB
Manufactured circles:
Manufactured Degree Circles
As soon as I can find the PDF file for 10", I will add it. (22" enlarge 8" degree PDF 115%)
16" LightBridge base is 31.5"
Carol
Edited by csa/montana (07/16/07 05:57 PM)
Gigatron
Reged: 12/10/05
      #1720439 - 07/16/07 01:37 PM
While this degree circle isn't for the 10" specifically, it's the original PDF file. You'll need to have kinkos bump it up to 115% so that it prints out at 22" across.
http://www.cloudynights.com/ubbthreads/attachments/944499-Alt-AZ_Setting_Circle.pdf
just take a tape measure with you and measure it after they print it. Some of these places aren't all that great at getting the size right the first few times. I had to get mine printed out 4 times before they got everything correct. After the size is right, have them laminate it. Depending on the kinko's, it can cost anywhere between $10 and $25 (there doesn't seem to be any corporate set prices for these things).
-Fred
Reged: 11/04/06
      #1720451 - 07/16/07 01:43 PM
Thanks for the Oregonruleco link Carol. My XT10 is telling to get a set now.
Den Mama
Reged: 05/14/05
Loc: montana
      #1720886 - 07/16/07 05:47 PM
Hi Fred: Your link is the same as the one in my post under 8" Dob (that was what it originally was made for).
Carol
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: ................]
      #1720893 - 07/16/07 05:49 PM
Steve, you are most welcome! You better answer your XT10 calling, or it may hang up on you!
Carol
Reged: 11/04/06
      #1720969 - 07/16/07 06:20 PM
Actually I might be in trouble; I left both my cell phone and Amex card home unattended today.
Last week the Cats Eye 3-piece set, this week...
Den Mama
Reged: 05/14/05
Loc: montana
      #1721344 - 07/16/07 09:55 PM
Ohhh, don't check the last # dialed when you get home!
Carol
astrasouth
Reged: 07/11/07
Loc: NC
      #1721955 - 07/17/07 08:38 AM
Mark
Mark,
Another good idea for the flat shimmys. Leveling feet seem to take too long to level.
astrasouth
Reged: 07/11/07
Loc: NC
      #1721987 - 07/17/07 08:58 AM
Hi Ridwan,
You got out and tested the SmartTool before I had a chance to. I am pleased to hear that it works properly even if tilted slightly off axis. I had suspected it would, but nothing beats a true field test.
$80 is a great buy on the level. I knew Sears carried them, but at the time I bought mine, their price was higher by $20. My guess is given a year, this tool will be in the $50 range.
The device is quite accurate, my experience matches yours, the error is very small, a quarter of a degree makes this part of the system well within acceptable tolerance. Add that to the resolution possible with a 20" azimuth dial and you have a system that works very well as you and those who have implemented it have discovered.
The whole thing can be done for about $100 to $125. Moving to additional scopes your cost is just that of the azimuth scale and a mount for the level ~$20 or so.
One other advantage this system has over traditional DSC is its ability to work with a scope that is not perfectly orthagonal. Any deviation from perfect orthagonality of the axis on a dob will cause a DSC to not perform up to its capabilities. This system is immune to that issue.
I am very interested to hear of your results with the total system on the platform. Please be sure and post your observations when you have the azimuth dial in place.
Rod and Carol:
I tried out the Smart-tool for altitude last night without my telrad, finderscope or an azimuth circle (I'm going to add the circle this week). I used a compass or eyeballing for the azimuth.
Before I went out, I made sure that my palm program Planetarium (a ***** program I tell ya) had the most accurate positioning in latitude/longitude and that the time was set as close to possible with atomic time.
When I used the smart tool, the error was +/- 0.1 degrees and nudging the scope on the azimuth would show the object in my 0.8-degree FOV eyepiece. Amazing. In mostly cloudy conditions under heavily light-polluted skies, I was able to find M27, M5, M3, M11 (wild-duck), and M2. That's crazy! I'm so used to star-hopping everything for the discipline of learning the sky, but this push-to system is a nice alternative when conditions are really bad.
Hence I can make the obvious conclusion that the more accurate the time and site-location (long/lat) in the preferences of the computer program, the more accurate it will match the smart-tool.
Anyway, I find the Smart-tool an amazing addition to my astro gear. Thanks Rod for this idea!!!
Can't wait to see what will happen with the azimuth circle!
Mark
Den Mama
Reged: 05/14/05
Loc: montana
      #1722574 - 07/17/07 02:40 PM
Mark: with the degree circles, you will be right on the money. This system is such a simple addition to a Dob, that a lot of people cannot believe it can be so accurate & simple to use!
Carol
Philip Levine
Reged: 03/22/07
      #1723353 - 07/17/07 09:56 PM
I have a dob modified with and azimuth circle and Wixey digital inclinometer. I travel to different viewing areas in New England, and I need a program to give accurate latitude and longtitude.
Any suggestions?
thanks, Phil
kwalker
Reged: 08/22/06
Re: Degree Circles new [Re: Philip Levine]
      #1723357 - 07/17/07 09:57 PM
Dell Axim and pocket stars
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles new [Re: kwalker]
      #1723412 - 07/17/07 10:30 PM
I second Pocket Stars, great program!
pocket stars
Carol
alanon
Nobody tells me anything
Reged: 06/29/07
Loc: Las Vegas
      #1723573 - 07/18/07 12:00 AM
Hi philip,
Have you tried Google Earth?
kwalker
Reged: 08/22/06
Re: Degree Circles new [Re: alanon]
      #1723617 - 07/18/07 12:23 AM
I added so more viewing locations in my pocket stars program from Google Earth. It seems to be very accurate. I placed it on my house and it came up with the exact same lat & long. Best of all its free. I not for sure about this though, but do you have to have an active internet connection for google to work right?
astrasouth
Reged: 07/11/07
Loc: NC
      #1724189 - 07/18/07 11:38 AM
Any suggestions?
thanks, Phil
Hi I suggest using Google Earth. I find my location and at the bottom of the screen-- giving the coordinates of lat/long.
For the most accuracy, consider that these readings are in degrees-minutes-seconds format. Therefore, I convert these readings to a decimal format. For example if the reading is 78-degree 36' I'll divide 36/60 to get 0.6. So I'll type in the computer 78.6 degrees. I usually leave seconds alone because it's close enough from my experience to convert minutes only.
Again, I've noticed that the more precise the "spherical geometry" (time/location on the earth) the more precise the altitude readings will match the angles on the digital inclimator.
thanks
Mark
Edited by astrasouth (07/18/07 11:43 AM)
astrasouth
Reged: 07/11/07
Loc: NC
      #1724222 - 07/18/07 11:59 AM
Carol
Yes, this is quite amazing and fun as well.
Mark
Disclaimer: the following is a ramble re: star-hopping vs. circles:
I still fear that I'll get "lazy" with this system and not continue to learn the sky as I've been doing. I can't get credit for the AL Messier clubs with this, but I sometimes would rather spend more time observing/sketching than hunting.
With that said, I won't make this a crutch, but an extra help when some objects are just too hard to find. I also like Rod's approach. Find the target with circles, look at where the object is in the sky with the Telrad, move the scope, and see if you can locate the object with nothing but the Telrad alone. that's a great way to not get "lazy."
Den Mama
Reged: 05/14/05
Loc: montana
      #1724238 - 07/18/07 12:14 PM
I agree with not getting "lazy" using this great little system. I use mine only when I can't seem to find an object; that way, I'm not totally dependent on it, I have to use skycharts, which in turn, familiarizes me with the sky. But, it's great to have it when you need it!
It's also nice for beginners, so they can find objects, without getting discouraged!
Carol
astrasouth
Reged: 07/11/07
Loc: NC
      #1724252 - 07/18/07 12:22 PM
Carol
Carol,
I absolutely agree. It's nice to have both systems and methods. I will always want to keep my star-hopping skills and the joy of the "hunt", but sometimes it's nice to "push to" the object and spend more time observing!
Kind regards
Mark
Den Mama
Reged: 05/14/05
Loc: montana
      #1725504 - 07/18/07 10:50 PM
Mark, thanks, & congratulations on your beautiful scopes!
Carol
Ghazzer
journeyman
Reged: 04/27/07
      #1727573 - 07/19/07 09:41 PM
Carol: For anyone stil interested in the Sears 10" digital level, Sears is having a "member sale" 7/22 - 7/28. The 10" Multi-Function Digital Level (#48292) shows a member price of $29.99 and a regular price of $49.99.
You can join their club on line at Craftsman Club
Here is the blurb: New digital technology clearly reads the angle of the tool to the 1/10 of a degree. Reads right side up or down. Audible tone identifies angle in 45-degree increments from 0 to 90 degrees. Recalls last 9 measurements, calculates degrees between two angles, projects bright red laser dot accurately to 1/4 in. at 100 feet. Use tripod threads or hang magnetically. Wt. 1.2 lbs.
I don't have one yet but I'll be there Monday with my $30!
<< Steve >>
Tom Andrews
Reged: 01/25/07
      #1727796 - 07/19/07 11:35 PM
Steve,
Welcome to CN and thanks for the heads-up. I got mine 3 months ago when they were on sale for the same $30. There have been a few people working on their circles since then who may want the digital level. It works great for me!
Den Mama
Reged: 05/14/05
Loc: montana
      #1729136 - 07/20/07 05:16 PM
Steve: Thanks for posting this info! I'm sure quite a few will jump on that great price!
Carol
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1732537 - 07/22/07 05:05 PM
mark,
Sorry for the delayed response - I was on a vacation-TOTAL- no cellphones or computers at all.
Glad to hear it works as well for you as it does for me. It is really fun to use .
I have found that those with troubles with the system typically have a software set up issue. You are right on the point, take the time to set up the software with the most accurate information available and you will be rewarded with increased accuracy all night long.
Regarding Software - I just bought Astromist - it has some great features that TheSky Pocket addition does not have. Haven't had it out with the scope yet, but will report my findings.
astrasouth
Reged: 07/11/07
Loc: NC
      #1732659 - 07/22/07 06:21 PM
mark,
Regarding Software - I just bought Astronomist - it has some great features that TheSky Pocket addition does not have. Haven't had it out with the scope yet, but will report my findings.
Astronomist looks amazing. One my observing buds has theSKY and doesn't like it that much mainly because it's difficult to zoom in on objects for quick star-hopping and the "look" of the sky on it is ho-hum.
I use "Planetarium" and it LOVE this program. (has a 5-star rating on palm sites). I've mostly used it for star-hopping and have found some pretty remote stuff with it. It's also good for adding comet orbital data as well.
If my Palm memory could fit Astronomist, I would buy that program in a second.
Again, thanks for the amazing idea of the "smart tool."
Kind Regards,
Mark
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1733221 - 07/22/07 11:34 PM Attachment (267 downloads)
I took Gordon's 24" original (for 12" scopes), and scaled it to 22" for 10" scopes. While I was at it, I went ahead and added intermediate numbers, every 5 degrees.
Please note this one is clockwise-only, so wouldn't work attached to the TOP of the base--it should be attached to the BOTTOM part.
I printed it today, and it looks perfect for the Zhumell 10" scope. The PDF file itself is actually 23" x 23" (because of a slim margin around the circle). When they print, just make sure they print it at 100% size, and don't do a "shrink to page size" (took two printings for my local OfficeMAX to get it right).
I'll post pics when I get it installed. Thanks for the fabulous ideas, everyone!
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1733232 - 07/22/07 11:43 PM Attachment (206 downloads)
Here's a sample of what the revised 10" circle looks like: (re-uploaded to get rid of the jaggies)
Edited by BradC (07/22/07 11:47 PM)
Den Mama
Reged: 05/14/05
Loc: montana
      #1733251 - 07/22/07 11:55 PM
8" Dob:
10" Dob
http://www.cloudynights.com/ubbthreads/attachments/1733221-22%20inch%20clockwise.pdf
Counterclockwise 10"
http://www.cloudynights.com/ubbthreads/attachments/3285539-New%20Az%20Scale%20Model%2022%20inch.pdf
12" LightBridge:
http://www.cloudynights.com/ubbthreads/attachments/3285532-New%20Az%20Scale%20Model%2025%20inch.pdf
16" LightBridge 1/2 Degree Circles: (not PDF).
link
Carol
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1733769 - 07/23/07 10:35 AM
That looks alot better Brad.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1733876 - 07/23/07 11:47 AM
Thanks, Kerry.
It is based on your labeler-mod. I liked the smaller-sized offset numbers.
kwalker
Reged: 08/22/06
      #1733964 - 07/23/07 12:28 PM
I recieved my Wixey in the mail today. I needed to change. The old eyes struggle to read the inclinometer anymore.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1734055 - 07/23/07 01:07 PM
Thanks, Kerry.
I thought it looked familiar.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1778218 - 08/15/07 01:04 AM Attachment (151 downloads)
Sometimes you just get lucky....
Found a cool protractor at the dollar store to use as my altitude indicator. Just cut out a tiny bit at the "center" so it sits right on the spring bolt:
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1778224 - 08/15/07 01:10 AM Attachment (167 downloads)
But WAIT, don't touch that phone!
You also get...
YES, a pushbutton illuminated dial, in night-safe red!!
Here's an ebay link to show you what the product looks like in the package. For $1 at the dollar store!!
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1778231 - 08/15/07 01:13 AM Attachment (202 downloads)
Still a work in progress, here is my dial on the base. I used the new 22" dial I posted above, which worked great.
Cutting this out was really a pain in the rear. I still need to clean up the edges a bit, and am looking for black edging to cover the entire cutout, so it looks as "factory" as possible. What did y'all use to cover the exposed edge of the cutout?
Den Mama
Reged: 05/14/05
Loc: montana
      #1778744 - 08/15/07 11:04 AM
Brad: My highest compliments! Wow, you took this project & really added class to it! The lighted protractor is the cat's meow! Really cool, & extremely professional job you have done. The cutaway is great. If you could find a flexible strip of black plastic, you could use that to cover the raw wood, or just touch it up with black paint.
I am really impressed with your job! Thank you for sharing with us! You are the first to find this lighted protractor, & I'm definitely going to get one for mine.
Carol
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1779581 - 08/15/07 05:21 PM
You also get...
Way-To-Go Brad!! Thats a great find. Thanks for the link.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1779840 - 08/15/07 07:39 PM
Thanks, Carol.
I got it at a "Deal's" discount store, if anyone has one locally. Watch out, though, they have them in red and also in bright orange light. I suspect even the red may be a bit bright for night-adapted eyes.
I guess if there is enough interest here, I can go back by and see if they have any more on the shelf. PM me if you are interested...
astrasouth
Reged: 07/11/07
Loc: NC
      #1779965 - 08/15/07 08:39 PM
Mark,
Hi, i wanted to see how you constructed the dial inside your rocker box. thanks!
Mark
BobW
Reged: 12/29/06
      #1780101 - 08/15/07 09:54 PM
Brad, I used a strip of metal banding. It formed around the curves and is near black in color. Picked it up at work. They just throw them away. Now I just need to make a better looking pointer. I just hot glued a L shaped finish nail painted dayglow orange to a magnet.
BradC
Reged: 01/31/07
Loc: St. Louis, MO
      #1780300 - 08/15/07 11:35 PM
For my pointer, I used a very small allen wrench, trimmed the long handle down, and painted one arm bright red. I super-glued it to a strong button magnet. The magnet is very strong--as a matter of fact in the picture above, I have a steel strip BEHIND the rubber patch (which I took off the wedge I cut). I am probably going to paint the magnet part black to conceal the glue gunk, and maybe give the red a second coat.
Lowe's hardware didn't have any trim (that or nobody knew where it would was in the store). I have a Rocker hardware (specialty woodworker store) in town, they might have something useful. On this page they have an adhesive trim and a plastic T-edging that both might work.
Tom Andrews
Reged: 01/25/07
      #1780978 - 08/16/07 11:27 AM
Mark
Here's a link to a picture of my az circle. There are other pictures of how it goes together a page or two back in this thread.
astrasouth
Reged: 07/11/07
Loc: NC
      #1781009 - 08/16/07 11:49 AM
excellent thanks! a dial strip on the bottom of scope did not work at all, so I'm going to design my circle inside the rocker box like yours.
With my 6-inch Orion dob, i've had good results with a donut circle like most folks here.
mark
south
Ghazzer
journeyman
Reged: 04/27/07
      #1782099 - 08/16/07 10:12 PM
Most of the base plates appear to be constructed of particle board. Any time you cut into this stuff you are creating an open invitation for moisture. Moisture causes particle board to swell, and pretty soon you have an unsightly headache.
One solution is to always use a good sealer when you cut into the particle board, before you re-assemble the base.
You could also dress up the cut with a good wood putty, then file or sand it smooth before a coat of sealer and some matching, outdoor paint.
<< Steve >>
Tom Andrews
Reged: 01/25/07
      #1782176 - 08/16/07 11:01 PM Attachment (159 downloads)
Mark,
Didn't know if you found the rest of my pictures so here's a repeat.
Tom Andrews
Reged: 01/25/07
      #1782182 - 08/16/07 11:03 PM Attachment (106 downloads)
Picture.
Tom Andrews
Reged: 01/25/07
      #1782186 - 08/16/07 11:05 PM Attachment (138 downloads)
Picture..
astrasouth
Reged: 07/11/07
Loc: NC
      #1783795 - 08/17/07 06:31 PM
excellent thanks!!!!
looks like you have a discovery scope like mine, so this is very helpful.
mark
Tom Andrews
Reged: 01/25/07
      #1784242 - 08/17/07 11:37 PM
Mark,
Yes, it's a 12.5" PDHQ split-tube.
I forgot to tell you that I had to replace the center bolt because the original was too short. I used stock 1/2"x13 all-thread from Home Depot and cut it to fit.
rnabholz
Reged: 07/25/04
Loc: Iowa
Re: Degree Circles - Dob Driver II Compatible new [Re: Tom Andrews]
      #1786932 - 08/19/07 02:58 PM Attachment (173 downloads)
I recently added tracking to my Dob with a Dob Driver II. It is a great addition to my set up, but it did create an issue with my Manual Setting Circles.
I had originally had my azimuth scale placed between the ground board and rocker floor. The DDII azimuth motor uses a knurled wheel that turns against the top of the groundboard. Had to find a new place for my azimuth scale.
Because of wiring and other components in on the rocker floor, and a small amount of available clearance when the mirror box swings through I couldn't use a scale like Tom's in the rocker.
I decided to add the scale outside surrounding the groundboard. Because my round groundboard is the same diameter as the rocker width, I could not simply slip the scale down over the rocker. It would have to be split.
First step was a ring with an inside diameter just 1/4" larger than the groundboard diameter. I used tempered hardboard and cut the ring with my router and home made circle jig
rnabholz
Reged: 07/25/04
Loc: Iowa
Re: Degree Circles - Dob Driver II Compatible new [Re: rnabholz]
      #1786945 - 08/19/07 03:03 PM Attachment (133 downloads)
My idea was to support this ring with 3 removable pins that would fit in the side of the groundboard. The pins were 3/8ths bolts. I had considered threaded inserts as the attachment method, but had a second Idea.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1786947 - 08/19/07 03:05 PM Attachment (186 downloads)
One of these magnets epoxied in the bottom of each hole would provide all the holding power necessary for this job.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1786952 - 08/19/07 03:07 PM Attachment (155 downloads)
They would also be much quicker to place vs threading the bolt in to an insert. Here is a magnet epoxied into place.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1786957 - 08/19/07 03:13 PM Attachment (148 downloads)
As I mentioned earlier, because of the size of the rocker, I could not just slip the scale over the rocker. It needed to be split and installed under the rocker.
Since I had extra magnets, I thought they would be a handy way to join the split circle.
I made small blocks out of maple, one to be attached to each end of the circle sectors. On one side would be 2 magnets, countersunk and epoxied in place. The mating block would have 2 wood screws with their heads left proud of the surface. Bring the two blocks together and the magnets attract the screw heads and pull them in to the magnet countersink hole. You can adjust the fit by adjusting the depth the screw is driven.
I cut the ring in half using the finest and thinnest saw I have, a mitre box back saw. I then attached the blocks to both sectors using epoxy.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1786962 - 08/19/07 03:17 PM Attachment (142 downloads)
For the scale I used Brad C's file (thanks Brad) and had it printed by a local engineering drafting service on translucent mylar using a xerographic process. The charge was a reasonable $8. The Mylar and process makes it waterproof. After painting the ring white, I centered the scale on the ring and glued it in place with a very thin coat of Silicone, pressed during curing with appropriate astro weights
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1786966 - 08/19/07 03:18 PM Attachment (134 downloads)
When dry, I trimmed the excess with a hobby knife.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1786979 - 08/19/07 03:22 PM Attachment (148 downloads)
When trimmed out, I have my two sections.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1786991 - 08/19/07 03:27 PM Attachment (170 downloads)
To install them on the scope, I insert the 3 pins, the set the sectors on the pins and bring the ends together and magnets grab and close the ring.
The Ring is held in place by the heads of the pins (bolts). on one side and the side of the groundboard on the other.
To calibrate, the entire ring can rotate on the pins giving me about 60 degrees of adjustability. Once I have a known object centered I just rotate the dial to match. I am still thinking out what I want for a pointer, but I have a temporary for the time being.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1787000 - 08/19/07 03:31 PM Attachment (175 downloads)
I am pleased at the outcome - looks pretty decent and is low hassle and easy to install.
So I now have a tracking scope with the Manual Setting Circle system - getting close to perfect..... ;^)
Den Mama
Reged: 05/14/05
Loc: montana
      #1787356 - 08/19/07 06:51 PM
Rod: Very Nice!! Sure looks great! Thanks for posting the steps/photos, to help out anyone else, wanting to do this setup like yours.
Again, Thanks!
Carol
Tom Andrews
Reged: 01/25/07
Re: Degree Circles - Dob Driver II Compatible new [Re: csa/montana]
      #1788003 - 08/20/07 12:19 AM
Rod,
You remain the construction guru...
Cool stuff!
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1789626 - 08/20/07 06:58 PM
Thanks Carol & Tom.
derekm
Reged: 08/22/07
Loc: Scarborough UK
      #1793453 - 08/22/07 01:36 PM
Hi guys,
New to the forum and just spent half a lifetime reading the whole of this thread! Sounds like a brilliant mod and I'll have to get myself into gear on my 8".
A couple of small offerings to add. First, for UK or European members, a source of Wixeys for GBP25 delivered (with EU VAT included).
http://stores.ebay.co.uk/GetItRightUK
For those of us without Palms or laptops, a free program for the desktop that will print lists of alt/az coordinates at x minute intervals for 1000s of objects.
http://casazza.net/astrohelper/
Hope someone finds them useful.
Clear skies
Derekm
Edited by derekm (08/23/07 03:17 AM)
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles - Dob Driver II Compatible new [Re: derekm]
      #1793975 - 08/22/07 06:09 PM
Derekm: Thanks for the great links, they are a good addition to this thread, very, very lenthy thread
Carol
derekm
Reged: 08/22/07
Loc: Scarborough UK
      #1808936 - 08/30/07 04:30 AM
Just received a "GETITRIGHT" clinometer from the link in my post above. Advertised as same as Wixey. Seems a good unit. Fast readout, quick to settle and the magnetic base sticks very well to my 8" Skywatcher tube.
One point though; the window over the LCD readout is simply a flexible film, rather than say perspex. Has anyone got the Wixey version and can say if this is the same or not? Makes no difference to the operation, but seems a bit of a cheap finish to an otherwise solid bit of gear.
derekm
Reged: 08/22/07
Loc: Scarborough UK
      #1812873 - 09/01/07 05:14 AM
"First light" for the push-to system last night. Absolutely brilliant! Even using the coordinates of our club site in Astro Helper and observing from home, 15 miles away, everything was at least just inside the field of my 32mm EP. Dropped straight onto the Wild Duck Cluster (yes, I know it's hardly a difficult target) with a 3/4 moon, skyglow from the local town and a hazy sky..
After being told by the "experts", that setting circles are a waste of time (with reference to small scales on equally small EQ mounts anyway)this has been a revelation.
Total cost (in UK) $50 for clinometer and $30(!)for printing and laminating the groundboard scale - we get ripped off in Britain; it's our National pastime!
Many thanks for this brilliant thread, which for me at least, has transformed observing with a Dob. I want that 16" Lightbridge eveb more now!!!
Den Mama
Reged: 05/14/05
Loc: montana
      #1813085 - 09/01/07 09:32 AM
Isn't it wonderful when the "experts" are wrong? I'm so glad you are having such great success with this system. I think, because it is so simple, many believe it simply can't work!
Thanks for your sharing of your successful venture with the degree circles!
Carol
lerock
Reged: 03/23/06
Loc: Arizona Coast
      #1818116 - 09/03/07 08:11 PM
Carol,
You have your scope yet? Do you have pics yet. (Sorry if you allready posted, but I missed it if you did).
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles - Dob Driver II Compatible new [Re: lerock]
      #1818313 - 09/03/07 09:41 PM
No, we decided against them bringing it in, until I have my Observatory completed, end of this month sometime. I really had no place to store it, & couldn't use it until the Observatory is complete.
Carol
lerock
Reged: 03/23/06
Loc: Arizona Coast
      #1823694 - 09/06/07 10:06 AM
You have way more patience than I could ever muster....
greenglass
Reged: 01/22/06
Loc: Ontario, Canada
      #1850553 - 09/18/07 10:18 PM
Does the azimuth scale have errors if its not perfectly round and centered on the pivot and the pivot hole has some play in it?
Den Mama
Reged: 05/14/05
Loc: montana
Re: Degree Circles - Dob Driver II Compatible new [Re: greenglass]
      #1850789 - 09/19/07 12:14 AM
I just cut the scale out, & adhered it around the edge of the base.
Carol
DaveDog
Reged: 06/15/07
Loc: near Blue Ridge Mts, VA
      #1853927 - 09/20/07 12:25 PM Attachment (195 downloads)
Finally got my AZ circle printed and installed on the Z10. Now to try it. I got a 22" circle printed at a local shop for $7, cut it out like a large flat donut, and installed it on the base with 4 plastic spacers so I could rotate the AZ marks to any place I want. Cut out a slice from the top base. I was thinking about using a red LED and a piece of wire to cast a shadow on the AZ markings, but I notice I can just use the edge of the cutout. I will try that for now. It seems to work just fine, I use my finger to rotate the AZ where I want it. It stays there because this scope has the lazy susan type az, and there it plenty of space. Now for the trials.
Dave
Z10 some mods.
Tom Andrews
Reged: 01/25/07
Re: Degree Circles new [Re: DaveDog]
      #1854222 - 09/20/07 02:34 PM
Right on Dave, let us know how it works for you. You should be amazed at the objects you'll beable to log.
Den Mama
Reged: 05/14/05
Loc: montana
      #1854762 - 09/20/07 06:48 PM
Dave, nice job! Be sure to let us know how it works for you.
Carol
DaveDog
Reged: 06/15/07
      #1855031 - 09/20/07 09:06 PM
Yeah, it may be a while, the clouds have moved in again since I got it done. Typical!!
Dave
Z10
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1855605 - 09/21/07 02:37 AM
Finally got my Wixey digital inclinometer a few weeks ago. Much better than the dial\CW version I was using...it bounced to much and was thus slow to use.
First light was a hole in the clouds a few days ago. I aligned on Altair and then went for the Ring (M57) and there it was! The Ring is tough, given the high light pollution in our condo. complex not to mention the rediculous growing LP in the Seattle area.
Using the Lightbridge on my deck is not the best place for it since the deck is only 5 ft. wide...can't see much at all but between 90 and 70 degrees, because the scope will hit the railing.
But overall the setting circles and the Wixey are a GREAT combo and highly recommended. I have been using the laptop so far for the readings to find DSO's, but it looks like I will pick up some kind of Palm-ect for a more portable and quicker way to get the coordinates.
I do have a question though ...
I have just started on my all aluminum tracking platform and was wondering if the scope has to start at "level" position every time I find a DSO or other object. Or will it be OK if I find my first alignment object and it will be OK all night, despite the movement and resetting of the platform through out the night.
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1856032 - 09/21/07 10:26 AM
My experience using a EQ platform and this system is that the scope must be returned to level to accurately acquire the next object.
With the platform tilted, the error is smallest when the object sought is on or close to the North/South line or the East/West line, and increases as you move to the center points between these lines and decreases as you move away from the center point towards these lines.
That issue was a contributing factor in my move away from a platform to a Dob Driver system.
Good Luck,
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1857603 - 09/21/07 11:09 PM
Good Luck,
Rod Nabholz
Hmmm, where would I find one of those or a link?
rnabholz
Reged: 07/25/04
Loc: Iowa
      #1858109 - 09/22/07 08:32 AM
Here you go:
http://homepages.accnorwalk.com/tddi/tech2000/page3.html
http://webpages.charter.net/jparticle/rasddr2.htm
http://telescopereviews.com/documents/dobdriver.pdf
Michael Miles
Reged: 02/11/05
      #1867824 - 09/26/07 05:26 PM
Hi folks:
I just stumbled onto this thread, and I love it! I've done my own setup of an azimuth circle for my Orion Teletrack mount here:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Board/lxd55/Number/1763566/page/4/view/collapsed/sb/5/o/all/fpart/2
I also use Astromist (love it 2!).
Glad I'm not the only one,
Michael
Cantankerously
Reged: 09/17/07
Loc: Midwest
      #1872085 - 09/28/07 12:57 PM
Thanks soo much! I was looking for the circle with both sets of #'s
DaveDog
Reged: 06/15/07
Re: Degree Circles new [Re: Cantankerously]
      #1890428 - 10/06/07 12:06 PM Attachment (164 downloads)
I have a laminated 22 3/4" circle that someone can have for the price of the shipping and the shipping tube.
Dave
Z10
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1890566 - 10/06/07 01:04 PM
Dave
Z10
Dave, you might want to post this in the swap&shop section instead.
DaveDog
Reged: 06/15/07
      #1890668 - 10/06/07 01:44 PM
OK, will do.
Dave
Astraforce Paul
Reged: 04/05/05
Astroscan and Degree Circles... new [Re: DaveDog]
      #1906041 - 10/12/07 06:05 PM
Is this doable?
Perhaps even just the inclinometer?
The 'Scan is a little red ball that rotates every which way-- think 4" Portaball!
So the inclinometer might end up at an angle to the vertical.
Also unsure how one would do the degree circles, but I figure if anyone can figure out how to do either or both, the crowd here could!
Here's a picture and review of the Astroscan.
http://www.dansdata.com/astroscan.htm
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Astroscan and Degree Circles... new [Re: Astraforce Paul]
      #1906112 - 10/12/07 06:54 PM
Is this doable?
That sure would be a tough one Paul. Both inclinometers I have need a steel base because they have magnets to make them "stick". I know the Astroscan has a plastic body. Since the Astroscan only uses ONE axis, it probably won't be possible. The setting circles need 2 seperate axis to work, the alt & az.
DarrylS
Reged: 09/02/07
Loc: Ottawa, Canada
Re: Astroscan and Degree Circles... new [Re: Sky Captain]
      #1915532 - 10/16/07 11:07 PM
Hi folks,
For the Canucks in the crowd, Canadian Tire has a digital torpedo level on sale that looks like it would work quite well -- regular $60, on sale for $36. It is accurate to 0.1 or 0.2 degrees, and has a magnetic base. Search for digital torpedo level, or look at page 18 of the on-line flyer.
Darryl
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Astroscan and Degree Circles... new [Re: DarrylS]
      #1917638 - 10/17/07 07:50 PM
Here is a little viewing update concerning the new setting circles I installed a while back.
A few nights back it was pretty clear and I'm getting all my "goto's" right on the money. I new it was going to be rain free that night and was to tired to bring it in. This worked out very well as when I went to bring it in, I got the idea that I would try for some day time star viewing. Since the scope was left as is over night and still aligned, I tried for an easy one-Venus. No problem at all, put it in the FOV of the 24mm Hyperion. I then tried for Regulus, but it was just not bright enough.
I then consulted the star program and found that Arcturus might be a good one. It sure was, right in the FOV.
That brings my daytime viewing list to 6 objects...Sun, Moon, Comet, Venus, Mercury, and Arcturus.
When the Sun makes an apperance again, I'll use the setting circles on the dob to try for more daytime stars.
Oh yeah, I forgot to mention that the trusses were open, I didn't have the shroud on! Might have had a better time at finding other "fainter" day time stars with it on.
Den Mama
Reged: 05/14/05
Loc: montana
      #1917743 - 10/17/07 08:34 PM
Kerry: Great idea! So glad the Degree Circles are working in daytime, as well as night!
Thanks for letting us know!
Carol
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
Re: Astroscan and Degree Circles... new [Re: csa/montana]
      #1918236 - 10/17/07 11:59 PM
Carol
Thanks Carol, I was pretty excited that it worked so well. I have been wanting to find some day time stars for quite a while, just never got around to it...till now. Using the setting circles was just as easy as the the night time use, well maybe a little easier.
Bill Kocken
Reged: 08/07/04
Re: Astroscan and Degree Circles... *DELETED* *DELETED* new [Re: Sky Captain]
      #1918837 - 10/18/07 10:00 AM
Post deleted by Bill Kocken
Den Mama
Reged: 05/14/05
Loc: montana
      #1919209 - 10/18/07 12:32 PM
Kerry, I've got to try it! Never dawned on me to look for Stars during daylight!
Carol
Den Mama
Reged: 05/14/05
Loc: montana
Re: Astroscan and Degree Circles... new [Re: Bill Kocken]
      #1919216 - 10/18/07 12:34 PM
Hi Bill, you can PM Kerry with info such as this, that way the subject of the thread remains intact.
Carol
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: WA.
      #1920551 - 10/18/07 09:27 PM
Carol
Carol, I've heard there are several dozen that are bright enough to be seen. Arcturus at -0.07 mag. was pretty easy to see as well as Venus at -4.44 mag. (duh).
It might be fun to see who could spot the faintest star during the day.
Den Mama
Reged: 05/14/05
Loc: montana
      #1920625 - 10/18/07 10:09 PM
Soon as my skies clear up, I'm going to give it a try! This is a fantastic idea Kerry, thanks!
Carol
derekm
Reged: 08/22/07
Loc: Scarborough UK
      #1938473 - 10/26/07 10:13 AM
Referring back to my post of 22 August, suggesting the program "Astro Helper".
If you set the time on the program to Universal Time and ignore the "DST" box on the location editor, all is well.
If however, you tick the "DST" box, the daylight saving time appears to go the wrong way!! Here in UK we are on the zero meridian. DST is UT + 1hr, but astro helper says it's minus 1 hr!! Took me a long time to get my head around it, comparing it to Redshift 5 and our local time. Some of you may have been caught out and "binned" the program as no good. Simply set it to UT, without the DST option and all should be well. The Alt/Az values it gives vary slightly from Redshift, but still put objects in a 1 or 1 1/2deg field. Which is correct, AH or RS5, I don't know.
Den Mama
Reged: 05/14/05
Loc: montana
      #1938875 - 10/26/07 01:19 PM
Thanks for the helpful tip!
Carol
DaveDog
Reged: 06/15/07
      #2067562 - 12/22/07 09:28 AM Attachment (152 downloads)
Follow up to my post of 9/20/07 about the adjustable degree circle on the Z10.
It works just fine. I am able to find everything I point it at using the az/el numbers from Cartes Du Ceil. I usually use the 24mm first and move up to the 13 and then 8 if the seeing is any good.
The only thing I would change is to make the 5 degree marks between the 10deg numbers bigger or thicker. It is hard to just quickly go to say 177 degrees. If the 5 degree marks were more obvious, it would be easier to count up from 5 to 7 rather than from 10 down to 7. 6 is even harder. I am still thinking about a pointer or light projected on the circle. Right now I am using the right side of the cut out for the registration mark. Make sure when you cut out the top base so you can see the circle, you cut out enough so you can see more than 10 degrees. That makes it easier to see where you are. If you can only see one 10 degree mark, it is not always obvious which way you need to turn without first turning it.
All in all, it has improved the scopes usefulness enormously for me. About as good as adding a real good EP, except it only costs about $50-$60 including the Wixey.
Dave
Z10
Den Mama
Reged: 05/14/05
Loc: montana
      #2067690 - 12/22/07 10:35 AM Attachment (137 downloads)
