tonyb
Reged: 07/27/05
Loc: WA, USA
This is Jupiter 5.4.06. TouCam Pro II 840 K3CCDTools: x25; gain25; gam60; br50; sat50; met130 Registax: ST410_WSL1_`2_WV10_10_50_100_500_10 The colors don't seem quite right to me and I wanted to ask folk if there are any particular Photoshop steps I could take to enhance? Thanks!
-------------------- Celestron C9.25" SCT Carbon.
William Optics FLT 110 Triplet APO Refractor.
Atlas EQ-G with GoTo hand controller.
SBIG ST-2000XCM color CCD.
QHY8 / Q453-HR color CCD.
Lumenera LU075C color webcam.
Meade DSI II for autoguiding using PHDGuiding and WO66mm refractor.
Meade DSI III color w/Envisage sw.
Toucam Pro II 840k EPROM flashed to SP900NC.
K3CCDtools/Registax/CCDSoft v5/Nebulosity//PS CS3.
Dell Latitude D830 notebook w/Vista Ultimate 32.
Canon EOS 5D MkII DSLR.
imjeffp
Senior Space Cadet
Reged: 09/30/03
Loc: Cedar Park, Texas
My Photoshop steps: Adjustments->Auto Levels* Adjustments->Hue/Saturation->Saturation +60 Filters->Smart Sharpen->Amount 100%, Radius 1
*Open the Levels dialog (cmd-L), click on "Options
." Select the "Enhance Per Channel Contrast" radio button. Click the white square next to "Highlights." Adjust the highlight color to H: 0°, S: 0%, B: 90%. (This is a light grey color that keeps the highlights from blowing out.) Click "OK." Click "OK." Click "OK" again. I don't save the new target colors.
-------------------- Blog
ST80 AT80EDT/LXD650
ETX-90/DS-2000 10" LX200 Classic ("The Quarter-Meter Telescope at the Heritage Park Observatory")
SPC900NC DMK21AF04 Digital Rebel XT
tonyb
Reged: 07/27/05
Loc: WA, USA
Hi:
Wow! Thank you! This looks much better. If you notice the "ring" around the circumference of the planet's disk - is that a result of me not getting the Registax wavelets quite right, in your opinion?
Thanks so much again!
Tony.
imjeffp
Senior Space Cadet
Reged: 09/30/03
Yup, those are from the wavelets, and I'm not sure how to avoid them.
ST80 AT80EDT/LXD650
tonyb
Reged: 07/27/05
Loc: WA, USA
Hi:
I took another whack and stepped the wavelets down a few notches - I lose a bit of detail, but I also lessen those rings too.
ST304_WSL1_`2_WV10_10_50_100_150_100
Tony.
gazerjim
Reged: 02/12/04
Loc: About where I thought I was......
Tony: I might suggest turning the saturation up, and running gamma no higher than about 20% max at capture.
Jupiter is mostly forgiving in terms of color if there's plenty of it at capture.
"Ringing" is a headache well known to planetary imagers. At least 2 contributors to this dreaded nuisance are underexposed Avi's and less than excellent seeing.
PixInsight has a de-ringing feature in their Wavelets (excellent tool) that helps; but only up to a point and seems to reduce sharpnness slightly.
Thanks for posting, and keep 'em coming.
-------------------- Jim Fisher
If you're not part of the solution, you're part of the precipitate.
Henry J. Tillman
9 registered and 12 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
