Privacy Policy |
Please read our Terms
of Service | Signup and
thelittleman
Vendor (Peter's Actions)
Reged: 05/21/05
Loc: Hampshire, UK
I posted this in my most recent report, but I thought it 'deserves' a little post of its own. I was observing Abell 1656 (with little success - the moon was up). I had found the right area really quite easily and was just making sure I was right when I realised I couldn't see this star (see image). Everything else matched. According to the sky chart, it should be of a similar magnitude to the other three in the triangle. Has anyone else seen this, or would like to check it out tonight? Thanks,
-------------------- Clear Skies,
Peter
Photoshop Tutorials and Actions! New actions now added
Preprocessing in Iris Tutorial
http://peter-morris.magix.net/
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
The star atlas you show is incorrect, as there is no bright star at the location of the "missing star" (in the galaxy NGC 4889). The Hubble Guide Star catalog lists a magnitude 9.5 "non-star" at that location", so unless you have that option switched-off in your atlas software, it might show up. Some atlases just bring in a lot of stars from the GSC without regards to whether the GSC itself considers them real or not (non-stars, blends, artifacts, etc.), so that might be a problem with that particular page. Clear skies to you.
-------------------- David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
thelittleman
Reged: 05/21/05
Loc: Hampshire, UK
That would explain why I couldn't see it then! Thanks Dave!
Peter
MikeRatcliff
Reged: 06/12/04
Loc: Redlands, CA
Another thing to watch out for is that variable stars are often printed at their maximum magnitude only. There are a few stars around that have a big range and could cause confusion.
Once when starhopping towards M83, I was expecting three medium bright stars in a line in my binoculars (centered on Gamma Hydra), but only saw two! The missing one was a Mira-type variable.
-------------------- 16" f/4.9 dob
Tele Vue Plossls 32,25,20,15,11
13 Nagler T6
10.5 Pentax XL
Brandon 32, 16
12.5 UO ortho, 9 Circle T ortho
2x TV Barlow
thelittleman
Reged: 05/21/05
Loc: Hampshire, UK
Yes I did think about that - thanks Mike. The next time I go out I will look again.
Peter
4 registered and 2 anonymous users are browsing this forum.
Moderator: matt, Olivier Biot
