Tightening focuser on AT80ED
Started by
Olivier Biot
, Mar 10 2007 10:59 AM
3 replies to this topic
#1
Posted 10 March 2007 - 10:59 AM
Hi folks,
It looks like the 40mm Paragon and a 2" diagonal are a bit too much for the default friction provided by the Crayford focuser in my AT80ED. I'd like to tighten up the focuser in order to remove the occasional slipping. The 2-page description sheet of the AT80ED on Astro-Tech's website doesn't specify this manipulation.
When I put the OTA upside down, I see a number of recessed bolts, some anodized, some not (see attached photo).
What's the procedure to follow?
#2
Posted 10 March 2007 - 11:52 AM
I tweaked a SW Equniox before and the focuser is exactly the same as your scope's
You need to first try the one in the middle (the biggest hole). There's a screw (you need allen key) to control the tension
#3
Posted 10 March 2007 - 12:13 PM
Hi Pollux,
Many thanks for your reply! I slightly tightened the nut in the central recessed hole in the elliptical flat base. Now there's no more slack!
Olivier
Olivier
#4
Posted 10 March 2007 - 01:05 PM
Yeah!!
