Orion Expanse 20mm Design: Is There a Name?
4 replies to this topic
#1 chrysalis
chrysalis
Posted 12 March 2007 - 07:51 PM
So I took apart the 20mm Orion Expanse EP. It does not have the optical configuration of any of the EPs I can find, including all of the ones on this webpage. It most closely resembles a variation of the Bertele EP.
From field lens toward eyelens:
1. Cemented element, flat side toward objective; lower element is very thick, upper element thinner at the edge; upper element is convex.
2. Spacer
3. Plano-convex singlet, convex side toward field lens.
4. Spacer
5. Positive lens that is shallow U-shaped in cross-section (not sure what this is called) with concave surface toward observer's eye.
Here is a pictorial representation (the distance between elements is the spacers):
#2 NeoDinian
NeoDinian
    Experienced Postmaster
Posted 12 March 2007 - 09:39 PM
Very similar to a Konig-II design.. But the field lens is quite possibly NOT flat. It would be concave. If even slightly...
#3 chrysalis
chrysalis
Posted 13 March 2007 - 11:44 AM
No, it's very flat. Also, websites on Konig II's tend to speak of short ER, whereas this has generous ER. Maybe it's just a proprietary no-name design.
#4 Deep13
Deep13
Posted 13 March 2007 - 01:28 PM
Looks like a Kelner or RKE with an additional eye lense to correct for the wider AFOV. The Koenig has a doublet in the center with a single lens at the eye and below the cemented doublet. That bottom has to have some curve probably between it and it's cemented mate. Otherwise it has no purpose.
#5 Mark Harry
Mark Harry
  • In Memoriam
Posted 13 March 2007 - 06:09 PM
That may be either a reverse Bertele, or a modified Konig. You'd have a reverse Kellner if you eliminated one of the single elements to the eye end, similar to an RKE. It really doesn't precisely match what I have here on a chart, so it could be proprietary.
The Bertele appears to have the surface nearest the field to be flat. (as in this case.)
Why would a flat surface on the field lens have no purpose? This would affect field curvature,from my way of thinking. There are a couple more designs with flats in this position, too.
Mark
