focussing problem with oberwerk 12x60
4 replies to this topic
#1 Guest_**DONOTDELETE**_*
Posted 22 July 2004 - 10:35 AM
my oberwerk 12x60's have a very loose focussing mechanism. whenever i use them and put any pressure against the eyepieces the focussing changes! it's very annoying. unfortunately, i'm not mechanically inclined, and can't figure out if there's anything i can do to fix the problem, short of sending them in for repair. can anyone offer any suggestions? thanks. bruce
#2 Guest_**DONOTDELETE**_*
Posted 22 July 2004 - 11:32 AM
I have never encountered this problem before so I can't really help, but there are some CN members that have much experience with binocular assembly and repair. Hopefully, they'll see this soon and give a hand.
That does seem very odd that just pressure on the EPs causes them to de-focus. Are you sure that while you're putting your eyes up to the binos you're not inadvertently doing something else to cause this?
#3 EdZ
EdZ
    Professor EdZ
Posted 22 July 2004 - 11:46 AM
While this is not a serius problem, it is a very annoying one. Instructions could not be given to easily fix this problem. However this is not a problem you can live with. You need to call back to the seller for help in resolving your problem.
edz
#4 Guest_**DONOTDELETE**_*
Posted 22 July 2004 - 03:22 PM
hi, nightwatch, thanks for replying. the focussing wheel turns much too easily, so just pushing a bit on the eyepieces causes it to turn and change the focus. if there was just something that could be tightened to fix that wheel i'd be all set! bruce
#5 EdZ
EdZ
    Professor EdZ
Posted 22 July 2004 - 03:47 PM
There is, but you shouldn't mess with it.
edz
