Any guesses on this scope?
7 replies to this topic
#1 BradC
BradC
Posted 19 May 2007 - 06:14 PM
I've emailed the poster for more info, but any initial guesses on what this scope is? Listed at $25.
#2 twhite
twhite
Posted 19 May 2007 - 10:06 PM
Looks like a Tasco 60/700 Alt/Az (fork mount); early/mid '70's (pre-red tube). The box is puzzling, though...
#3 Jae
Jae
Posted 19 May 2007 - 10:11 PM
How about a Bushnell Sky Chief II ?
#4 BradC
BradC
Posted 19 May 2007 - 11:48 PM
Jae is correct! Email reply said: "BUSHNELL Sky Chief II 6omm - 800 mm"
Anything redeeming about this scope, then? Or is this the classic "department store scope"? Worth $25 for local pickup?
#5 trainsktg
trainsktg
Posted 20 May 2007 - 12:04 AM
Well, the standard 60mm is only 700mm. 800mm is a little better in the CA department. I'm not too fond of alt-az's, but I do have one ( a Scope Orbit) and its a good quick set up for the Moon or Sun. Surprisingly, it has one of the best corrected objectives I own. But (BIG but)...once these kinds of scopes started coming in cardboard boxes I think the quality was already picking up speed downhill fast... If you can pick it up cheap, you might consider it, but if you are looking for a better value in the collectability dept., look for an older one in a wood box, preferably with wood and felt dividers, not styrofoam. I'd say $25 is a fair price, and you might get a very good glass with it.
Good luck.
Keith
#6 Jae
Jae
Posted 20 May 2007 - 10:04 AM
Alll right .... :jump: the winna !!
From memory, one sample, the tube was a composite material and not metal, everything else was nice metal- notch higher in quality. The legs were a nicer than common hardwood, the balance on the mount is tail heavy with a long Alt fine adjustment. Harder to use heavier eyepieces.
The lens seemed pretty sharp. Overall I'd say much better than any dept store scope. Bottom line - easiliy worth $25 for local pickup.
Report in after pickup please :grin:
#7 BHunt
BHunt
Posted 20 May 2007 - 10:36 AM
This looks like my Tasco 9 TE. if it performs like mine you will be happy.
Bill
#8 Jae
Jae
Posted 20 May 2007 - 10:38 AM
I recall the Tasco 9TE-5 as being a tad sharper....
Jae
