What do you all think.....
16 replies to this topic
#1 Da Bear
Da Bear
Posted 03 June 2007 - 10:19 PM
Looking to purchase this reflector..is it a Vixen? Worth $300 for a knock around Newtonian for the front lawn? I always have a lot of trouble in deciding to buy the newer scopes. Weird , huh?
http://sfbay.craigsl.../344020839.html
Da Bear
#2 twhite
twhite
Posted 03 June 2007 - 10:58 PM
Not Vixen. The only 8" Vixen Newt I can think of is the R200SS -- 8" f/4. That appears to be Guan Sheng. Some of those are good scopes. SVD should be worth $300 to somebody...
#3 Jon Isaacs
Posted 03 June 2007 - 11:09 PM
Da Bear
Hi:
Myself, I would pass on that scope simply because it's F/4. And knowing those extruded aluminum legs on the SVD, I am quite sure it would not be very stable...
But mostly it's F/4 with a 1.25 inch focuser so even if you wanted to a Paracorr is not a choice unless you add a 2 inch focuser or happen to have a 1.25 inch Paracorr. IMHO, there is only one reason to get tangled up with an F/4 scope and that is because you need the shorter tube length. Otherwise, F/5 is a much better place to be.
#4 Vesper818
Vesper818
    Astronomess
Posted 04 June 2007 - 12:36 AM
Hey Bear,
This is my neck of the woods! I'm in Novato!
Don't know anything about this scope, tho
#5 clintwhitman
clintwhitman
    Caveman
Posted 04 June 2007 - 01:53 AM
Is it a Cave?
#6 bendab
bendab
Posted 04 June 2007 - 05:21 AM
Hello Bear
Orion droped this line several years ago, and replaced it with the 8" 1000mm f/l.This was a low power scope used for deep space observation if I remember correctly,
Bruce
#7 Jon Isaacs
Posted 04 June 2007 - 07:12 AM
Hello Bear
Bruce
The replaced it with the 1000mm F/5. If I remember correctly they did this when they came out with the SkyView Pro as the SVP is capable of handling a longer, heavier OTA. I believe the SVD is not as sturdy as the old CG-5 with the extrude aluminum legs, I found that marginal with my 8 inch F/5 but the CG-5 ASGT with the 2 inch SS legs does a nice job.
#8 Da Bear
Da Bear
Posted 04 June 2007 - 07:45 AM
Thanks guys..er...everyone....I'll be passing on the Orion.
I found this too... although its at the top of my impulse price range. I've heard the LX75 mounts are pretty good.
http://sfbay.craigsl.../343699793.html
I've got a real desire for something new to play with....The CFO says is because my youngest (daughter) is graduating high school Sunday.. and going off to college this fall (Northwestern ) and this is my first "empty nest" compensation... I'm not that transparent, am I?
Da Bear
#9 Preston Smith
Preston Smith
    The Travel Scope Guy
Posted 04 June 2007 - 09:25 AM
Da Bear
Hey, I'll take approval from the CFO anytime - no matter what the justification! :jump:
Congrats to your daughter!
#10 Bonco
Bonco
Posted 04 June 2007 - 05:13 PM
The picture sure made the mount look marginal. You'd do better getting a new Zhumell 8 inch DOB. I percive Dobs as functional scopes...Dobs offered by Zhumell and others are very cost effective. Great bang for the buck but zero **** appeal. I have a 10 inch Zhumell, its fine and I'll keep it but It's just a tool to me not like my classics which I treasure. Classic Newts like Cave are fantastic but also large and heavy. Guess that's why I favor the classic small refractors.
Bonco
Bonco
#11 Jon Isaacs
Posted 04 June 2007 - 05:47 PM
There is a reason 10 and 12.5 inch Newtonians used to be considered observatory scopes and that now they are sometimes thought of beginners scopes...
#12 Glassthrower
Glassthrower
    Vendor - Galactic Stone & Ironworks
Posted 04 June 2007 - 05:55 PM
The best views I have ever had (by an astronomical margin) of Saturn were through a 12.5" Cave. I needed a drool bib and eventually a cattle-prod to move me away from the eyepiece.
Regards and clear skies,
MikeG
#13 Bonco
Bonco
Posted 04 June 2007 - 06:44 PM
Sure wish I had a picture of my 10 inch f/6 Custom Delux Cave that I bought in about 1973. Chrome pier, polished aluminum rotating rings...A sweethart. Kept it for 25 years and got great use from it. Like a dummy I sold it in 1998. Truth be known it was just too ponderous to transport. My home skies are so treed and polluted I could hardly use it. But I miss it so.
Bonco
#14 clintwhitman
clintwhitman
    Caveman
Posted 05 June 2007 - 02:37 AM
They are not... heavy there my brother dont wim pp out be a caveman!!! 2 arc second Cave :yay: :usa: :refractor: :yay: :yay:
#15 clintwhitman
clintwhitman
    Caveman
Posted 05 June 2007 - 02:38 AM
How else you gonna see god!!!
#16 Awesomelenny
Awesomelenny
Posted 05 June 2007 - 06:36 AM
Wow Clint, that Cave sure looks nifty on the Byers mount!
#17 Bonco
Bonco
Posted 05 June 2007 - 08:40 PM
So beautiful!! Thanks for posting the picture.
Bonco
